Breakthrough Biocatalytic Process
Some of the known approaches for CO2 to fuel recycling include (1) direct photolysis which uses intense light energy to break off the oxygen atoms in CO2, and (2) chemically reacting carbon dioxide gas (CO2) with hydrogen gas (H2) to create methane or methanol. Both of these conventional engineering approaches require immense energy due to high pressure and high temperature chemical processes. For certain applications such as military and space, the high cost of these technologies may be justifiable. However, we do not believe these approaches will be economically viable in creating transportation fuels for global consumption.
By innovating at the intersection of chemical engineering and bio-engineering, we have discovered a low energy and highly scalable process to recycle large quantities of CO2 into gaseous and liquid fuels using organic biocatalysts. The key to our CO2-to-Fuel approach lies in a proprietary multi-step biocatalytic process. Instead of using expensive inorganic catalysts, such as zinc, gold or zeolite, with traditional high energy catalytic chemical processes, our process uses inexpensive, renewable biomolecules to catalyze certain chemical reactions required to transform CO2 and water (H2O) into fuel molecules. Of greatest significance, our process occurs at low temperature and low pressure, thereby requiring far less energy than other approaches.
The energy efficient biocatalytic processes we are exploiting in our technology actually occur in certain micro-organisms where carbon atoms, extracted from CO2, and hydrogen atoms, extracted from H2O, are combined to create hydrocarbon molecules. Our breakthrough technology allows these processes to operate on a very large industrial scale through advance nano-engineering of the biocatalysts and highly efficient process design.
Dont voici la traduction "google améliorée par bibi":
Avancée majeur dans la biocatalyse
Certaines des approches connues pour le cracker et recycler le CO2 sont (1) la photolyse directe qui utilise l'énergie lumineuse intense pour extraire les atomes d'oxygène dans le CO2, et (2) faire réagir chimiquement le dioxyde de carbone (CO2) et de l'hydrogène (H2) pour créer le méthane ou le méthanol. Ces deux approches techniques classiques nécessitent une grande énergie due à haute pression et haute température de processus chimiques. Pour certaines applications telles que les militaires et l'espace, le coût élevé de ces technologies est justifiable. Cependant, nous ne pensons pas que ces approches seront économiquement viables pour créer des carburants "grand public".
En innovant à l'intersection de génie chimique et bio-ingénierie, nous avons découvert une méthode à faible consommation d'énergie pour recycler de grandes quantités de CO2 en utilisant des biocatalyseurs. La clé de notre méthode se trouve dans un processus biocatalytique. Au lieu d'utiliser de coûteux catalyseurs inorganiques, tels que le zinc, l'or ou zéolithe, avec les processus traditionnels de haute énergie chimique catalytique, notre procédé peu coûteux utilise des biomolécules "renouvelables". Elles permettent certaines réactions chimiques nécessaires pour transformer le CO2 et l'eau (H2O) en molécules de carburant. La plus grande partie de notre processus se produit à basse température et basse pression, ce qui nécessite beaucoup moins d'énergie que les autres approches.
Le procédé biocatalytique (énergétiquement efficace) que nous exploitons se produit dans certains micro-organismes où les atomes de carbone, extraits du CO2, et des atomes d'hydrogène, extrait de l'eau, sont combinés pour créer des molécules d'hydrocarbures. Notre technologie révolutionnaire permet à ces processus afin de fonctionner à une échelle industrielle très grande avance grâce à nano-ingénierie des biocatalyseurs et très efficace
Maintenant reste à voir où ils en sont réellement car les images de synthèse c'est bien beau mais si cela reste à 100% au stade de la théorie ben alors moi aussi je peux dire que je roule à l'eau photocatalysée !!
