New 4 stroke engine (en anglais)
Topics about this forum and the econology in english speaking language for people who are not not understanding french language.
Cuicui
x 6
par Cuicui » 15/08/06, 15:41
Génial pour remplacer la fusée de la 206 à eau...
inventor
x 82
par inventor » 09/09/06, 23:33
If don't like a" short valve", put at valve "squarer" valve piston:
Square Valve Piston
Most advantages this conception :easy water coled piston (especial exhaust) , eliminates piston rocking ,roller bearings slide piston , etc.
View:Pivotal Piston
Colling water piston made very low NOx,;Please, use from catalysts platinum for electrolyze :D
Sorry , I live 30 years in "piston valve reality" :D :D
Andrew Feliks
inventor
x 82
par inventor » 27/09/06, 11:02
Possible mutation:
Pivot piston little modification. Using in four-stroke “piston “ square valve.
One big advantage have “piston Pivotâ€￾. Pistons not have force: Nm !!!
This reaction is only in bearing piston !!
[pic]http://www.new4stroke.com/images/tlok%20silyp.gif[/pic]
Another, piston no need lubrication, lubrication only need “Ringsâ€￾ (sliding seals)
Next my modification: sliding seals put no in piston. This seals put in cylinder!!
Advantages: cylinder are LIFETIME , maby building only aluminum cast.
Because on cylinder no sliding piston and seals, made aluminum, excellent conduct heat !!
But piston must make steel cast. (Or steel surface)
Then piston and seals only need change at refit engine, without any mechanical enginery.
Theoretical, only need to change part to repair engine!
In this version lubrications are need only seals, sure much little in conventional piston.
Ecology are happy,when seals made Teflon and engine no need oil :idea: :D
Are you like square pistons now ?? :rolleyes: :D:D
Andrew Feliks
inventor
x 82
par inventor » 09/10/06, 16:52
A like square piston , and don't like many rod and long crankshaft::D:D
Simple engine:
Two stroke mutation:
Without oil when teflon seals.
Base animation:
[url]
http://www.pivotalengine.com/solutions.html#animation [/url]
:D:D:D
Andrew Feliks
inventor
x 82
par inventor » 28/10/06, 15:42
Some other details:
Example seals: no oil, Teflon or VITON®
Regards Andrew :idea: :D
Andrew Feliks
zac
Chercheur moteur pantone
par zac » 28/10/06, 19:29
salut
si tu me fait une étanchéitée qui dure plus de 3 minute avec ça,je rentre dans les ordres :lol:
lug
Localisation : quelque part au milieu des vaches...en normandie
pour bien comprendre le fonctionnement de ce moteur
par lug » 29/10/06, 16:29
je vais traduire les explications de inventor et les poster en français sur le forum, faut un peu de temps c tout , ça servira à tous
j 'ai visité son site et y aura des choses à adapter c sur mais oas impossible
lug
pour nos enfants, laissons leur un air pur et une terre sans déchets
Philippe Schutt
x 33
par Philippe Schutt » 29/10/06, 20:09
à choisir, je préférais le moteur à 3 pistons. si on en est aux pistons de formes bizares, autant passer à la quasiturbine, non ?
inventor
x 82
par inventor » 13/11/06, 20:18
Dans grand échelle graduée êtes mieux voyons avantages ou inconvénient
:cheesy: :cheesy:
Andrew Feliks
zac
par zac » 13/11/06, 21:19
salut
A quoi sert le petit vilbrequin au bout? à faire plus joli ou à rassurer les boites d'usinages? :mrgreen: :mrgreen: :mrgreen:
Revenir vers « Econology forum in english »
