New steam engine (only one) using in Big Boy locomotive,ships, tractor, or enegy plant.
Possible fuel: biomass ,wood,peat, russet coal,coal,ethanol,biooils,oil,hydrogen,biogas,LPG,natural gas,uranium,fusion.
http://www.new4stroke.com/images/bigboy.wav
Regards Andrew
New 4 stroke engine (en anglais)
- inventor
- J'ai posté 500 messages!
- x 82
All about story pivot piston engine in one place:
http://www.new4stroke.com/new%20engine% ... iston1.pdf
Pivot cylinder are made possible extrude big aluminium profile
Regards Andrew
Regards Andrew
Andrew Feliks
- inventor
- x 82
Half-rotate engine:
Mutations: hydraulic half-rotate engine.
Version "big loader".
Advantages: lover pressure, complete closed "piston".Full protection.
Some other interesting mutation half rotate- engine
With torsion bar, end hydraulic absorber.
If need change McPherson , next pictures see:
Mr. Citroen are happy?
Andrew Feliks
- inventor
- x 82
Hydro-électrique:production d'électricité par dynamo oscilla
New oscillating dynamo
[quote=Feliks]Pull story ocilating suspension
http://forums.autosport.com/showthread.php?s=7c429beb0a2c269033c2739ea7037d1a&threadid=74960&perpage=40&display=&pagenumber=5
Andrew :yes:[/quote]
Same in the picture:
Are possible 100 pcs in 1 square meter, =~~ 5 KW one meter
1 km ^2 = ~~ 5000 MW ;);)
Regards Andrew :wavey:
ps. sail -boat with this innovation obvious name wave-boat :coffee:
In cars are possible electric variable last absorber shock or computer current digital regulated :coffee:
How much KW (or HP) power have simile waves?
Or, how much this wave eqivalent CO2 in climate change ?
What to make countries lack for sea ?
If you no like a very cold water in electricity service:
Regards Andrew
Regards Andrew
Andrew Feliks
- inventor
- x 82
A Christmas present:
New oscillating stepper engine:
Version "Stephenson 3 E"
For modifications "old machines" without gears
or new car or new machines
Regards Andrew
ps. http://www.new4stroke.com/stepper.wmv
left ,right, bulbs 22V 0.05A
Regards Andrew
Andrew Feliks
Neant a écrit :Heu, l'energie pour comprimer les ressorts des soupapes est jamais perdue, puisqu'elle est renvoyée quand les ressorts se décompriment. Et puis ça représente pas grand chose en perte, c'est ridicule.
Essaye voir de virer un moteur en particulier à 4 soupapes par cylindre distribution déconnectée et non déconnectée: tu verras alors que l'absorption de puissance de la distribution est très très loin d'être négligeable d'ailleurs ce n'est pas par hasard si certains moteurs de F1 ont une distribution à mouvement électromagnétique et rappel pneumatique...
Je suis un peu dubitatif devant le principe décrit dans ce moteur, personnellement je serait plus convaincu par une modernisation de la distribution par fourreau louvoyant (aussi appelé "sans soupapes" ou "sleeve valve": les chemises oscillaient, découvrant des lumières) qui offrait un très bon rendement et un remarquable silence de fonctionnement, avec pour seul inconvénient une consommation de lubrifiant plus élevée et un régime limité à ~4000tr à cause de l'inertie du système... voir les moteurs d'avion Bristol...qui furent utilisés notamment sur le Noratlas...
- inventor
- x 82
Block stepper engine:
One complete/ coil magnet give Continuous Force 50 Lbs [222N]
Linear stepper
50 pc cake - about 2500 Lbs [11100 N]
On picture are 56 cake. Sum 56 X 2500 =140 000 Lbs
70 000 KG [621600 N]. Speed 2 m/sec.
Ship, press, train.
Regards Andrew
Linear stepper
Ship, press, train.
Regards Andrew
Andrew Feliks
Revenir vers « Econology forum in english »
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 59 invités
