New 4 stroke engine (en anglais)
Topics about this forum and the econology in english speaking language for people who are not not understanding french language.
inventor
x 82
par inventor » 16/11/08, 10:28
Advantages of half rotate pumps are additional possible regulations.
In normal piston pump, we have two elements definition pumps – diameter of piston and stroke piston In half rotate pump we have too same elements: diameter “pistonâ€￾ and long “pistonâ€￾ and additional important possible regulations TORQUE of drive pump on arm with some hole...
This regulation are without additional gear .
For salt water I think better solution made aal this pump PCW , or ABS, or propose - ceramic
Regards Andrew :mrgreen:
Andrew Feliks
inventor
x 82
par inventor » 23/11/08, 13:42
A bit nostalgia, for specially cross-heads and high precision of execution of cylinder
Regards Andrew :D
Andrew Feliks
x 6245
par Remundo » 23/11/08, 16:40
Hello Inventor,
nice roding systems with automatic sliding valves !
Double-effect pistons and amazing synchronizations :idea:
Our ancestors were nearly as clever as we :cheesy:
Bye !
bpval
par bpval » 23/11/08, 19:38
C'est vrai qu'il est épatant ce système
Mono-soupape
Tringlerie sophistiquée
Ca me fait penser à du BatMan :mrgreen:
Ciao
PIF PAF POUM
inventor
x 82
par inventor » 03/12/08, 03:23
Without any cogged gear .Last I don't prefer cogged gear.
Animation drive truck without any cogged wheel.
Rod differ, two clutch ( maybe hydraulic)and half rotate engine ,same parameters "Hercules C130" - Vintake= 250 liter. Without any gearbox.
For truck are good parameters.
Regards Andrew :D :D
BatMan In Poland =Janosik,but at French??
Andrew Feliks
inventor
x 82
par inventor » 05/12/08, 15:24
I like mono temat : Haf rotate engine.
My grandfather worked as engineer on railroad .......
Unfortunately, it has died before I have been born ..
Andrew :D
Andrew Feliks
x 6245
par Remundo » 05/12/08, 16:29
Wow !
Nice modern idea for railways : cheap, clean, no smoke, automous... :cheesy:
inventor
x 82
par inventor » 06/12/08, 19:13
What is this?
This is a hydraulic pump of widmill :bowtie:
Manner of utilization is next my proposal instead of mechanical transmission
in producing windmills electric current :Hallf Rotete Pump
Main principle of operation on following drawing and has enclosed animation
Solution has many advantages from haf rotate pump. Expensive
substitute is first most important and noisy, emergency transmission
of mechanical windmill .
It is presented next advantage on former drawing
for one dynamo driven manner of connection
of whole farm of windmill hydraulic engine serious too.
This way, we save several most expensive elements of windmills,
treating such farm windmill as integrity .( Complex design)
Regards Andrew Santa Claus :D :D
Andrew Feliks
x 6245
par Remundo » 06/12/08, 22:11
This is the oscillating piston pump powered by wind turbine. Useful to irrigate cultures in windy and arid countries :idea:
inventor
x 82
par inventor » 13/12/08, 17:30
Nihil nove sub sole.
Star hydraulic or oscillating dynamo.
Regards Andrew :D
Andrew Feliks
Revenir vers « Econology forum in english »
