New 4 stroke engine (en anglais)
Topics about this forum and the econology in english speaking language for people who are not not understanding french language.
inventor
x 82
par inventor » 14/09/10, 21:40
There is a way to shorten a bit of flexible hydraulic tube...
Well, if it accidentally escaped gas from the balloon and so it can be
Regards Andrew :D
Andrew Feliks
x 6245
par Remundo » 15/09/10, 10:02
Hi Andrew !
What's up ?
Now you are engineering some wind turbine...
A lot of work... 8)
inventor
x 82
par inventor » 15/09/10, 13:01
Hi Remundo !
Are you like music ? :cheesy:
Name : Jazz Big Band
Regards Andrew :D
Andrew Feliks
inventor
x 82
par inventor » 17/09/10, 03:32
Rotating Dixieland Yoda.
Regards Andrew :D
Andrew Feliks
inventor
x 82
par inventor » 17/09/10, 15:05
Next Dixieland :
In some tubes can be hidden anti-missile ..
Regards Andrew :D :D
Andrew Feliks
x 6245
par Remundo » 17/09/10, 21:57
Hi Andrew,
Wow !
Nice hybridization between wind energy and secret weapons...
And how much does it cost ? :P
inventor
x 82
par inventor » 20/09/10, 11:23
Remundo a écrit :Hi Andrew,
Wow !
The costs will depend on how much modern weapons will be mounted
:cheesy:
To those dixielnds can efficiently drive Hydraulic, it may have, no peaks of specialized software, use the links below.
http://www.hippocampus.org/homework-help/Physics-B/Fluid%20Mechanics_Venturi%20Tube%20-%20Simulation.html
http://www.ce.utexas.edu/prof/kinnas/319lab/applets/venturi/venturi.html
http://www.globalsecurity.org/military/library/policy/army/accp/al0966/le2.htm
The lower pressure propeller spins quickly ....
And review of the fact that it's not worth double the turbine insert...
Regards Andrew :cheesy: :cheesy:
Andrew Feliks
inventor
x 82
par inventor » 20/09/10, 21:51
Mistake..!!
Andrew Feliks
x 6245
par Remundo » 21/09/10, 10:34
Hi Andrew
We shall cut at the bottom these wind-aerocoolers...
... to make an huge wind turbine at the top of the giant building. :D
inventor
x 82
par inventor » 27/09/10, 11:14
A new way of sailing through a balloon which has the wind, and transmits energy to the propeller using hydraulics
And sailing version of the Venturi jets:
Regards Andrew :D
Andrew Feliks
Revenir vers « Econology forum in english »
