I have succeeded in getting the english description of your patent...
Ball rotor internal-combustion engine
The technical field
The invention belongs to the Thermal Motor field, relates to a Structure of Internal-Combustion Engine design, more particularly to the design of a seedball rotor Structure of Internal-Combustion Engine.
The background art
Because the wide application of small-size aircraft, robot, portable power, the internal-combustion engine that required power density is big, the reliability is high is as the power supply. At present, under present technical conditions, the rotor internal-combustion engine has the advantage than other heat engines.
In the rotor internal-combustion engine of numerous types, the typical case has a wankel rotor internal-combustion engine, advantages such as it has, and the operation is steady, the rotational speed is high, the moving component is few, compact conformation, power intensity are big.Nevertheless also coming with some shortcomings the it shows concretely as follows: the volumetric circulation of (1) working chamber changes through rotor and internal gear and eccentric shaft and the supplementary realization of external gear, has increased the processing and manufacturing degree of difficulty, has reduced the operational reliability.(2), built-in position relation and rotational speed relation between rotor and power output shaft make the power output shaft rotate only acting process of a week, and the power output shaft moment of torsion is little when resulting in this internal-combustion engine low-speed, and the further improvement of power intensity has also received the restriction.
The disclosure of the invention
For the weak point of overcoming wankel rotor Structure of Internal-Combustion Engine scheme, the purpose of the invention provides a seedball rotor Structure of Internal-Combustion Engine and a design.
The invention mainly realizes through providing following technical scheme. Ball rotor internal-combustion engine, its structure mainly includes stator cylinder body, rotor, air inlet, gas vent, spark plug, power output shaft. Characterized in:
The mounting of rotors is in the stator cylinder body, and rotor peripheral face and stator cylinder body working face are worked in coordination, forms six working chambers, and along with the rotation of rotor, the volume of every working chamber takes place periodic change, thereby accomplishes four strokes of breathing in, compressing, doing work, exhaust.
The working face of stator cylinder body comprises most spheres, two interior fraction spheres in two the unsmooth curved surfaces, one.
The rotor peripheral face comprises two bead curved surfaces, an outer most sphere, two outer fraction spheres.
Air inlet, gas vent are opened on the unsmooth curved surface of stator cylinder body, and the spark plug is installed on the unsmooth curved surface of stator cylinder body.
The power output shaft passes through the bearing with the stator cylinder body to be connected, and through a minor axis and rotor flexible connection.
The ball rotor internal-combustion engine that adopts invention design has following advantage: its simple structure, and the moving component is few, and the compact conformation makes the operational reliability high, and it is miniaturized still to be convenient for; The rotor rotates a week internal-combustion engine acting six times, and making the power intensity, big and the output shaft moment of torsion is big.
The description drawings
Fig. 1 is the ball rotor internal-combustion engine front view of invention design.
Fig. 2 is the ball rotor internal-combustion engine longitudinal profile sketch map of invention design.
Fig. 3 is the working face sketch map of stator cylinder body.
Fig. 4 is the unsmooth curved surface formation method sketch map of the working face of stator cylinder body.
Fig. 5 is the sketch map of the working face of rotor.
Fig. 6, Fig. 7, Fig. 8, Fig. 9, Figure 10 are the cycle of operation sketch mapes of ball rotor internal-combustion engine.
Reference numeral in the picture expresses 1 respectively, the air inlet, 2, the gas vent, 3, the stator cylinder body, 4, the power output shaft, 5, the spark plug, 6, the bearing, 7, the rotor, 8, the working chamber, 9, the minor axis, 10, interior most spheres, 11, unsmooth curved surface, 12, interior fraction sphere, 13, the bead, 14, outer most spheres, 15, outer fraction sphere, 16, the bead curved surface.
Further elaboration is done to the invention to following combination figure.
The detailed description of the invention
The ball rotor internal-combustion engine that the invention designed is worked with the four-stroke-cycle mode.
Show like Fig. 1, Fig. 2, the structure of ball rotor internal-combustion engine mainly includes stator cylinder body (3), rotor (7), air inlet (1), gas vent (2), spark plug (5), power output shaft (4).
Shown like Fig. 2, Fig. 3, the working face of stator cylinder body (3) be by: two unsmooth curved surface (11), an interior greater part bulb separation
Face (10), two interior fraction sphere (12) common component. Stator cylinder body (3) go up to open has air inlet (1), gas vent (2), installs spark plug (5) on stator cylinder body (3). The working face of stator cylinder body (3) is the geometric center of stator cylinder body (3) about central symmetry, the centre of symmetry.
It is as illustrated in FIG. 4,To the formation method of unsmooth curved surface (11) that are called in the invention,Explain as follows: the initial point O that uses rectangular axis O-xyz as the centre of sphere,Use R for having minor arc NM, minor arc MP on the radial sphere,Meet a condition minor arc NM's arc length is less than or equal to the minor arc MP's of third arc length,And minor arc NM's arc length adds the big circumference that minor arc MP's arc length is lighter than the quarter,Wind the z axle as minor arc NM and rotate with angular speed ω 1,While minor arc MP winds an axle OM and uses angular speed to rotate as ω 2,Satisfy the relation and equal the ω 1 o'clock of burden twothird for ω 2,A point P's of formation orbit 1 on the sphere,The line of having a few on centre of sphere point O and the orbit 1 constitutes a curved surface,Two surfaces about this curved surface has,The lower surface removes and uses O to use r for the part that radial sphere contained as the centre of sphere,Be exactly unsmooth curved surface (11) that are called in the invention; Interior fraction sphere (12) that are called in the invention,Be exactly that the said O that uses r partly for the internal surface of radial ball as the centre of sphere in fact; The interior most sphere (10) that is called in the invention,Be exactly that the said O that uses R partly for the internal surface of radial ball as the centre of sphere in fact.
The working face of rotor is by two bead curved surface (16), an outer most sphere (14), two outer fraction sphere (15) common component. All have three radially to arrange and evenly distributed bead (13) on every bead curved surface (16), the shape of the curved surface between per two beads is confirmed by unsmooth curved surface (11) and the compression ratio of ball rotor internal-combustion engine stator cylinder body (3). The working face of rotor (7) is the geometric center of rotor about central symmetry, the centre of symmetry.
Rotor (7) are as illustrated in FIG. 2 with being connected of stator cylinder body (3), and the working face of rotor (7) is worked in coordination with the working face of stator cylinder body (3).Wherein, interior most sphere (10) of outer mostly sphere (14) of the working face of rotor (7) and the working face of stator cylinder body (3) are sliding fit closely, outer fraction sphere (15) of the working face of rotor (7) and interior fraction sphere (12) of the working face of stator cylinder body (3) inseparable sliding fit, and every bead (13) on every bead curved surface (16) of rotor (7) and unsmooth curved surface (11) of stator cylinder body (3) are the sliding fit closely.The connection of rotor (7) and stator cylinder body (3) makes ball rotor internal-combustion engine form six working chamber (8), and along with the rotation of rotor (7), the volume of every working chamber (8) takes place the periodic variation, accomplishes four strokes of breathing in, compressing, doing work, exhaust.
Mechanical energy is externally exported in power output shaft (4), and it is connected through bearing (6) with stator cylinder body (3), and it is connected with rotor (7), is to realize through minor axis (9) be connected with rotor (7) bearing that it was realized through the hinge with being connected of minor axis (9).
Shown like Fig. 1, Fig. 3, on unsmooth curved surface (11) on stator cylinder body (3) were opened to air inlet (1), gas vent (2), in rotor (7) pivoted process, air inlet (1) is continuous supplied with the burning mixture for every working chamber (8), waste gas after gas vent (2) continuous discharge acting.
It is a cycle of operation sketch map of working chamber (8) that this internal-combustion engine is shown with four-stroke mode work, as Fig. 6, Fig. 7, Fig. 8, Fig. 9, Figure 10.
Show like Fig. 6, Fig. 7, along with the rotation of rotor (7), the suction stroke from air inlet (1) inspiration burning mixture, is accomplished to the volume of working chamber (8) increase.
As illustrated in FIG. 8, along with the rotation of rotor (7), the volume of working chamber (8) reduces, accomplishes the compression stroke. Light a fire spark plug (5), and the mist detonation produces the gas of high temperature high pressure.
As illustrated in FIG. 9, the gas promotes rotor (7) and rotates, accomplishes the acting stroke.
Shown like Figure 10, along with rotor (7) rotates, working chamber (8) volume reduces, accomplishes the exhaust stroke. The next cycle of operation of beginning.
The cycle of operation of other five remaining working chamber (8) is the same with this.
Adopt the ball rotor internal-combustion engine that the invention designed, have following advantage:
(1), have six working chambers, the rotor rotates a week, does the merit six times, makes that the power intensity is big, the power output shaft moment of torsion is big.
(2), the structure is simple, the moving component is few, need not the valve actuating mechanism, the failsafety is high.
Unfortunately, I don't have the drawings and figures... Perhaps you could send it to me or Pascal, and we could publish them on this sujet to make it easier for you.
