Entre rêves et réalités d'Allemagne
moinsdewatt
x 554
Re: Entre rêves et réalités d'Allemagne
par moinsdewatt » 23/08/20, 15:25
Calendrier précis de sortie des centrales à charbon et lignite en Allemagne.
Spelling out the coal exit – Germany’s phase-out plan
Coal Climate & CO2
Germany has passed legislation to end coal-fired power generation by 2038 at the latest and agreed on a shutdown schedule for individual lignite power plants as well as compensation payments for operators. For hard coal, meanwhile, the coal exit law foresees auctions for plant operators to take capacity off the grid according to the government's timetable. (UPDATES Parliament adopts coal exit law on 3 July)
Tous les détails : https://www.cleanenergywire.org/factshe ... -law-draft
moinsdewatt
x 554
par moinsdewatt » 02/09/20, 14:28
Welcome to the Energy Charts
The website for interactive graphs displaying electricity production and spot market prices in Germany
https://www.energy-charts.de/index.htm
Sur le lien vers production on a les courbes de production de la semaine en cours.
https://www.energy-charts.de/power.htm
Par exemple la à 11h45 ils ont près de 25 MW de solaire PV.
En France sur le site de Rte on voit 6.1 GW à 11h45, soit 4 fois moins.
moinsdewatt
x 554
par moinsdewatt » 02/09/20, 14:33
L'Allemagne entend ajouter 13.5 GW de parcs solaires PV d'ici 2028, et aussi 5.3 GW en toiture.
Germany to tender 18.8 GW of PV by 2028
The German government is planning to tender 5.3 GW in the rooftop segment and 13.5 GW for large-scale PV projects.
SEPTEMBER 1, 2020 SANDRA ENKHARDT
A first draft of what the amendment to Germany’s renewable energy law, the EEG, could look like has leaked from the Federal Ministry of Economics. pv magazine Germany has obtained a copy.
The new law, which is expected to come into force on January 1, 2021, includes a tender scheme for solar and other renewables that could result in the deployment of 18.8 GW of PV power capacity from 2021 to 2028, with a minimum of 1.9 GW and a maximum of 2.8 GW being planned to be allocated per year.
Of this total capacity, 5.3 GW will be tendered in the rooftop segment, while another 13.5 GW will be assigned for large-scale PV projects. Tenders for the rooftop segment will apply to systems larger than 500 kWp, while systems up to 500 kW will be eligible for a feed in tariff.
Through these new tenders, the German federal government wants to further reduce final prices for PV technology. According to the draft, the maximum price ​​in the tenders should drop from the current €0.0750/kWh to €0.0590 for ground-mounted systems. For roof systems, a maximum value of €0.090/kWh is envisaged.
Popular content
Furthermore, the German government seems to be favorable to increasing the size limit for solar projects from 10 MW currently to 20 MW. The EEG draft also shows that there will be separate tenders for big rooftop projects in the future. So far, these projects had to compete with ground-mounted solar plants in tenders for PV plants ranging in size from 750 kW to 10 MW, and usually had little chance.
Moreover, the draft also defines a framework for PV projects that will see their 20-year FIT contract expire. The operators of these systems will be entitled to receive a special tariff in the future, as the government recognizes that direct sale to the spot market is still unprofitable. However, it is also stated that the federal government wants to promote the expansion of renewable energy sources “as far as possible, market-driven”.
Other core elements of the EEG draft include anchoring the goal of making Germany gas neutral by 2050. In addition, implementation of the Climate Protection Program 2030 will begin when the new law comes into force. The program will include the 65 percent renewable energy target in German electricity consumption. For this purpose, expansion paths are defined for the individual technologies in order to achieve the goal. For photovoltaics, the aim is to increase installed capacity from 52 GW currently to 100 GW. The target for onshore wind power is 71 GW and 20 GW for offshore wind power.
https://www.pv-magazine.com/2020/09/01/ ... v-by-2028/
moinsdewatt
x 554
par moinsdewatt » 02/09/20, 14:35
L'Allemagne atteint 52 GW de capacité de solaire PV à fin juillet :
Germany deployed 447 MW in July
According to the latest figures from the Federal Network Agency, the country’s cumulative installed PV power has now reached 51.98 GW.
AUGUST 31, 2020 PETRA HANNEN
Germany deployed around 447 MW of new PV capacity in June, according to new figures released this week by the Federal Network Agency (Bundesnetzagentur). May and June saw newly installed PV power reach 446 MW and 437 MW, respectively. In July 2019, new additions totaled 292 MW.
In the first seven months of 2020, developers connected 2.80 GW of solar to the grid compared to 2.38 GW in the same period a year earlier. The country’s cumulative solar capacity topped 51.98 GW at the end of July.
Almost 355 of the 447 MW deployed so far this year are attributable to PV projects that were implemented outside of the tender scheme for solar plants exceeding 750 kW in size. The ground-mounted systems with an output of up to 750 kW, which can be built outside the tender scheme, made up a total of 32.7 MW of the total new capacity for July.
In September, feed-in tariffs and market premiums will again fall 1.4%. Depending on type and size of system, FITs range between €0.0669 and €0.0877/kWh. In the direct marketing system category – mandatory for arrays with a generation capacity above 100 kW – the payment is €0.0603/kWh.
https://www.pv-magazine.com/2020/08/31/ ... w-in-july/
x 3271
par sicetaitsimple » 02/09/20, 14:49
moinsdewatt a écrit :L'Allemagne entend ajouter 13.5 GW de parcs solaires PV d'ici 2028, et aussi 5.3 GW en toiture.
Il fallait que l'Allemagne fasse quelque chose, car l'EEG actuelle prévoyait un plafond de 52GW installés de PV au- delà duquel tous les systèmes d'aide s'arrêtaient pour les nouveaux projets, ce qui explique les niveaux assez impressionnants de MW mis en service ces derniers mois, pour passer avant le "couperet".
Le niveau d'environ 2GW/an prévu d'ici 2028 parait techniquement raisonnable.
x 6146
par Obamot » 02/09/20, 17:59
Source ?
x 3271
par sicetaitsimple » 02/09/20, 18:19
Source ?
L'EEG.
x 11621
par Christophe » 02/09/20, 18:36
sicetaitsimple a écrit :Il fallait que l'Allemagne fasse quelque chose, car l'EEG actuelle prévoyait un plafond de 52GW installés de PV au- delà duquel tous les systèmes d'aide s'arrêtaient pour les nouveaux projets, ce qui explique les niveaux assez impressionnants de MW mis en service ces derniers mois, pour passer avant le "couperet".
Cela fait des mois qu'il n'y a plus besoin d'aide pour que les PV soit rentable...d'autant plus en parc industriel !
Les aides tombent trop souvent dans la poche des installateurs et corrompent le marché...cela fait 15 ans qu'on le dit !
Donc à MORT LES AIDES AU PV !!
x 3271
par sicetaitsimple » 02/09/20, 18:48
Va l'expliquer aux allemands, que veux tu que je te dise?
Ceci dit tu confonds peut-être des petits projets individuels en autoconsommation dans des pays où l'électricité est très chère et des projets "industriels" qui ont besoin d'une prime quelconque leur assurant une rémunération plancher quand les prix de marché s'écroulent, ce qui sera de plus en plus souvent le cas la journée en été.
x 11621
par Christophe » 02/09/20, 18:56
Je confonds rien du tout...le Wc part actuellement de Chine à 0.2 - 0.3 $/Wc !! Voir moins en grosse quantité...
1 Wc va produire (au Nord de la France ou de l'Europe) 1 kWh par an...rentabilité brute sur le Wc en France 1 à 2 ans sans prix installation, sans intermédiaire...SANS AIDE !!
En Allemagne la rentabilité est de quelques mois...car l'électricité plus chère...
Alors le discours d'assistanat à l'investissement est ridicule et puéril "Ze ve de zaides" et finalement ne fait qu'engraisser les intermédiaires...
Bref le prix d'une installation actuelle complète en France ne devrait pas dépasser les 1.5€/Wc tout tout compris...
Quand je vois que des GROS PORCS vendent encore 1000€ le m2 (soit 6 €/m2)...ca me fait gerber !
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 296 invités
