Autre "moteur magnétique" original
tagor
par tagor » 28/02/08, 14:24
c'est aussi quelque chose qui devrait avoir la peche :
Re: F.B.D.I.S.S.M - Flux.Boosted.Dual.Induction.Split.Spiral.Motor.
« Reply #203 on: February 24, 2008, 10:27:22 AM » Quote
Some calculations and observation notes:
I'd like to add that the rotor magnet have a totaly free pass at 165W input per Solenoid in the latest set of tests.
The activated Solenoid time is approx 0.25% of each full rotor turn and this equals 82.5 watts going into the motor.
But the calculated torque/rpm output from a motor using this size of magnets is most probably higher than the input.
The average torque under load is calculated to 3,13 ft-lbs
At 100 RPM under load I get = (3,13*2*3,14*100)/33000 = 0,059 Hp = 44 watt output from the shaft.
At 200 RPM under load I get = (3,13*2*3,14*200)/33000 = 0,119 Hp = 88 watt output from the shaft.
At 300 RPM under load I get = (3,13*2*3,14*300)/33000 = 0,178 Hp = 132 watt output from the shaft.
At 400 RPM under load I get = (3,13*2*3,14*400)/33000 = 0,238 Hp = 177 watt output from the shaft.
At 500 RPM under load I get = (3,13*2*3,14*500)/33000 = 0,297 Hp = 222 watt output from the shaft.
You can see for yourselves. Already at 200 RPM I've got more out than in.
Don't forget how torque behaves in an electrical motor.
At No Load I get Maximum RPM at Zero Torque and I'll get Maximum Torque when stalled at Zero RPM.
And there is a linear relationship between these two points.
Meaning that I'll get Half the Torque when the Maximum Free Spinning RPM is loaded to Half the RPM.
And I do expect to hit a lot more than 400 RPM when the Sticky Spot is passed without loosing any momentum at all.
If I'll hit 1000 RPM at free spinning I'll get 222 watt output on the shaft when loaded down to 500 RPM.
But this is just some calculations on a small motor.
The big one I'm building is calculated to deliver approx 4500W output at 200W input.
4.5kW délivrés pour 400W en entrée c'est impressionnant
quartz
par quartz » 28/02/08, 14:25
Oui bien sur intéressé qu'il le monsieur,
magpowersystem@free.fr
tu peux me faire parvenir les infos directement, le Message perso semble avoir des ratés !!
Merci à toi tigrou_838
A+++
tigrou_838
macder
par tigrou_838 » 28/02/08, 14:27
pour repondre rapidement au personne qui parle de batterie ou accumulateur, je tiens a preciser que ce moteur n'a besoin d'aucune source de courant pour tourner.
capt_Maloche, a ma connaissance, il n'y a pas de bobine pour faire tourner l'engin, juste des similaire alternateur pour produire differente tension.
tagor, il n'existe pas de brevet pour l'engin, mr goldschmidt n'a jamais deposer quoi que ce soi.
bien sur tout cela sous tout reserve.
tagor
Re: macder
par tagor » 28/02/08, 14:31
tigrou_838 a écrit :pour repondre rapidement au personne qui parle de batterie ou accumulateur, je tiens a preciser que ce moteur n'a besoin d'aucune source de courant pour tourner.
bonsoir,
je comprend votre intéret, mais pour infos, j'ai racheté les droits
(l'entièreté)
et je suis en train de terminer ce moteur magnétique et la pile...
quartz
par quartz » 28/02/08, 14:55
La photo de Harry Goldschmidt il y a 20 ans
tigrou_838
macder
par tigrou_838 » 28/02/08, 15:15
bonjour monsieur tagor.
autant pour moi, je n'etais pas au courant que mr Heens avait racheter tout les droit de mmonsieur goldschmidt sur cette invention.
heureusement que je precise bien sous toute reserve.
oliburn
par oliburn » 28/02/08, 16:21
JONULE a dit :
et ça ?
le lien :
http://overunity.ifrance.com/
des réplications :
http://www.theverylastpageoftheinternet.com/research/replicate/replicate.htm
http://www.theverylastpageoftheinternet.com/ElectromagneticDev/Ron_Classen/acpower_files/gensetmenu.htm
moi, je ne demande qu'a y croire :cheesy:
beaucoup de schémas, plans,vidéos trainent sur la toile
sans jamais une réalisation qui marche à 100%
il est venu le temps ou on peut tout partager, il est venu
le temps ou les petits copains de james bond ne seront
pas assez nombreux pour nous descendre tous.
je pense sincerement que l'humanité ne peut avancer
qu'à travers le partage, et sans que ce putain de pognon
vienne foutre la merde à chaque fois !
moi, je ne vends rien, je donne avec plaisir ... :cheesy:
et crois moi si un jour je trouve une recette miraculeuse
c'est avec plaisir que je donnerai la recette, même si
en la vendant elle m'aurait rapporté des milliards !!!
je sais, les mecs comme moi on les enferme !!! :cheesy:
mais je suis comme çà !
alors, allons-y, je serai, dans la limite de mon savoir et
de mes moyens, le premier a participer ...
Soyez à vous-même votre propre flambeau, votre propre refuge, votre propre maître... "
quartz
par quartz » 28/02/08, 16:39
Je suis bien d'accord avec toi oliburn, je partage tout se que je trouve,
simplement je viens de découvrir le moteur Macder et je m'aperçois que certain on des infos depuis des années et n'en on pas fait plus cas que cela.
Je trouve cela dommage attention je ne dis pas qu'il y a de mauvaises intention derrière, mais bon il faut que les infos circules.
Perso j'ai récupéré les infos depuis à peine 12h00 et je suis à la tête de 3 contacts Plus que pertinent,
je m'apprête à appeler l'inventeur, dés que possible.
si tout va bien nous serons fixé avant se week end.
Pourtant j'ai pas fais grand chose.
Le partage et la générosité c'est notre seul sortie possible.
A+++
lejustemilieu
x 4
par lejustemilieu » 28/02/08, 19:05
Trouvé sur le net;
http://totokoma.ifrance.com/
elephant
par elephant » 28/02/08, 19:20
ce site existe depuis longtemps, n'apporte pas grand chose de neuf et est mal réalisé ( pauvres internautes à faible débit )
Utilisateurs parcourant ce forum : Bing [Bot] et 115 invités
