La recherche a retourné 570 résultats
- 21/09/22, 23:56
- Forum : Econology forum in english
- Sujet : New 4 stroke engine (en anglais)
- Réponses : 838
- Vues : 357860
Re: New 4 stroke engine (en anglais)
Yes, along the way .. I am a member of the Organization of which the Queen's Husband, until his death, was the Patron . :cry: https://rsgb.org/main/blog/news/gb2rs/headlines/2021/04/09/rsgb-patron-sk/ https://new4stroke.com/rsgb1.jpg https://new4stroke.com/rsgb.jpg Andrew :cry:
- 21/09/22, 23:55
- Réponses : 838
- Vues : 357860
Well, that's how you go beyond your imagination ... that's real new inventions ... It will have this power for several reasons. Namely, in the figure you can see that the new engine with the same displacement as the 109,000 shp has much smaller dimensions and weight .. its weight is about 70 tons, w...
- 05/09/22, 01:50
- Réponses : 838
- Vues : 357860
On another maritime forum: Well Merlyn, I see Half Rotate being adapted for marine use. long shafts with propellers at the end must be attached to each wheel with the weight. This type of engine does not become popular quickly, because no one has shown its good technology .. I show possible technolo...
- 01/09/22, 01:43
- Réponses : 838
- Vues : 357860
This is my way to "help" the atmosphere... :lol: With combustion/vapor machines ? Thanks ! :) No, in pressing the piston... :lol: :lol: besides, as the same amount of fuel burned in a power plant is still twice as much electricity from "waste" heat, I think you should say thanks...
- 31/08/22, 15:43
- Réponses : 838
- Vues : 357860
So outside the box, only the water to be cooled is transmitted to the cooler and back and the resulting electric current. The heat can be supplied outside the box at normal atmospheric pressure. The efficiency of the device increases 10 times (or 100). The steam does not go anywhere, because it is ...
- 29/08/22, 06:56
- Réponses : 838
- Vues : 357860
Simply put, Obamot, you have mixed up all concepts, engine, sun, boat, ice etc. You have forgotten that the second rule of thermodynamics no longer applies in its entirety .. Since in this engine there is no loss of the working medium, we can use various, even more expensive liquids. It can be Meth...
- 28/08/22, 00:13
- Réponses : 838
- Vues : 357860
Simply put, Obamot, you have mixed up all concepts, engine, sun, boat, ice etc. You have forgotten that the second rule of thermodynamics no longer applies in its entirety .. Since in this engine there is no loss of the working medium, we can use various, even more expensive liquids. It can be Metha...
- 21/08/22, 05:00
- Réponses : 838
- Vues : 357860
Here is the thermodynamic problem .. We have in a box, in a vacuum is a set of thermal engines with generators ... Will this set be more efficient than it would be normally installed without a box? it's about how laws of thermodynamics work on the Equator, and how on the Pole. Different temperature...
- 19/08/22, 03:21
- Réponses : 838
- Vues : 357860
Well, Feliks -Newcomen can also make electricity from a low-temperature heat source ! Well, for example, from geothermal energy, the cooling heat of internal combustion engines, and other industrial sources that can produce this temperature of 70 degrees Celsius .. But as we pump the air out to 1/3 ...
- 17/08/22, 23:14
- Réponses : 838
- Vues : 357860
thank you Andrew you put regenerator on the first picture and get back the Stirling engine. :) Well, probably not really. Newcomen was 300 years ago, stirling a little later .. :roll: This is also how they felt at English Universities that the steam atmospheric engine could be the future ... But th...
