[PDF][PDF] Effect of deoxidized Glutathione (Tathion) on Excretion of
Y Oshiumi, K Matsuura, S Komaki - ir.library.osaka-u.ac.jp
| 1_Ecos" Hg-MHP 33 o 3, 5% k co:):, v 5 Jijih fi--Z 5 Glutathion: t,* Hg-MHP cofkitiju-33 Hi-jj--
v Z3, fj: t-ok. 5. Ojjefā 35 Z.(3f U,* Hg øy ft):*" Hg-MHP, E Scaner és 34-ti E-rju:,) J 5 fr 35 …
Tunneling Spectroscopy of the Superconductor-Insulator Transition on and
QT Meng, S Komaki, T Tsuneoka… - IEEE Transactions …, 2014 - ieeexplore.ieee.org
… So we normalized them at the temperature of 250 K. In our data generally speaking samples
with x ≤ 1.0 are in the superconducting state while ones with x ≥ 1.1 are in the insulating …
Species diversity of insects in Japan: their origins and diversification processes
Japan is considered a global hot spot of biodiversity. With regard to species diversity, insects
are no exception. To date, more than 32,000 insect species have been identified in Japan, …
Adaptive modulation/TDMA scheme for large capacity personal multi-media communication systems
S Sampei, S Komaki, N Morinaga - IEICE Transactions on …, 1994 - search.ieice.org
… ,) is a probability that a modulation (mod,) is selected, k, is the number of symbol rate to be
used, and M, is the maximum modulation level. k = 1, 2, and 3 correspond to full-rate QPSK, …
Analysis of cap-and-trade mechanism represented by a piecewise dynamical system
S Komaki, T Hayakawa - 2023 62nd Annual Conference of the …, 2023 - ieeexplore.ieee.org
In this paper, we derive the dynamics of cap-and-trade mechanism between firms considering
corporate values associated with the carbon dioxide emission reduction. The relationship …
Optical fading analysis considering spectrum of optical scintillation in terrestrial free-space optical channel
…, K Tsukamoto, S Komaki - … Conference on Space …, 2011 - ieeexplore.ieee.org
This paper proposes a Butterworth-type spectral model of optical scintillation to design a
terrestrial free-space optical (FSO) link. It enables us to estimate the power spectral density (…
Techniques to achieve texture in permanent magnet alloy systems
N Makino, Y Kimura - Journal of Applied Physics, 1965 - pubs.aip.org
… superconducting VaSi (Tc= 15.8K) and VaGa (T.= 14.6K) have been made and yield the …
of the applied field, all at 14 kOe and 1.8K. Such a spatial variation in the flux penetrating a hard …
[CITATION][C] Contributors, Jun. 1976
…, N Kawamura, H Kohzu, S Komaki… - IEEE Transactions …, 1976 - ieeexplore.ieee.org
… Si RF power transistors, K%, and MOSFET’S.In 1967 he invented and developed the Mesh
Emitter Transistor. Since 1972 he has … From 1965 to 1969 he was a Lecturer at the University …
Tunneling spectroscopy of the Superconductor-Insulator Transition on Bi2Sr2Ca1−xYxCu2O8+δ and (Bi1−yPby)2Sr2Ca1−xYxCu2O8+δ
QT Meng, S Komaki, T Tsuneoka… - 2013 IEEE …, 2013 - ieeexplore.ieee.org
The purpose of our present study is to understand the Superconductor-Insulator Transition.
In this paper we report tunnel experiments on Bi 2 Sr 2 Ca 1-x Y x Cu 2 O 8+δ (Y-Bi2212) …
TDM intercell connection fiber-optic bus link for personal radio communication systems
…, S Kajiya, K Tsukamoto, S Komaki… - IEICE transactions on …, 1995 - search.ieice.org
… When the coupling coefiicient of k-th optical coupler is 3;, and the total loss of optical coupler
and fiber is 01L [dB], the optical signal power transmitted from i-th RBS at the output of the …
