Run Car On Water - Stanley Meyer Resonant Electrolysis Cell System Collection
System:
1. Introduction
2. History of Stan Meyer
3. Stan’s Memos
4. Peter Lindermann – System Explained
5. Water Fuel Cell and the First and Second Laws of Thermodynamics
6. Stan Meyer Patents
7. Stan’s circuits
8. Aaron’s posts on Stan’s Circuit
1. Introduction by MDG nov07: Stanley MEYER is the most famous inventor in the
'Super-efficient Electrolysis' field, and many took inspiration from his work. His
original Electrolysis Concept was able to produce many times as much hydrogen gas
as permits the Faraday's Law of electrolysis, and the Law of Conservation of Energy,
then he brought it up to a still un-understood high level he called 'Thermal Explosive
Energy'. We can say that he was at least 50 years in advance of his time ... The
evidence, then, is that his concept of electrolysis is tapping in another source of
energy, not 'recognized' yet in the classical physics, that must be in another dimension,
outside our three dimensions, and it must be a non thermic form of energy, because
Stan Cell is not producing heat while electrolyzing.
There is still not a complete concensus of the Experts in Zero Point Energy, Peter
Lindermann, John Bedini, Thomas Bearden, Moray King, Allan Sterling and many
others, on HOW Stanley Meyer was catching this ZPE. May be he was using Radiant
Energy High Voltage Pulses (Back Electro Motive Force) to charge his Capacitor/Cell
(two Stainless Steel pipes isolated by a fine layer of pure water as strong dielectric)
almost without current, until the breakdown level of the water layer was reached, at
which moment the accumulated voltage in the capacitor would be converted to
amperes that would split the water molecules, realising the hydrogen and oxygen, and
the power supply sensor would cut the input pulses, to stop any current flowing from
the source.
After all the electricity stored in this capacitor/cell would be used, the water would
take place again between the two ss tubes, reforming the insulating layer, the power
supply sensor would send again power for a new cycle of charging the capacitor/cell
to its dielectric breakdown level ... Electrolysis would be done with 'Pure Voltage
Potential' and almost no Amperes (current). See below the Peter Lindermann
explanation.
Radiant Pulses can be created by sending unidirectional (that's may be why Stan had a
rectifying diode in his circuit) short pulses in a coil/choke, they are called also Back
EMF, and are of a many times higher voltage level compared to the original pulses
sent. Tesla, Gray, Moray, Bedini, Bearden and many others are using this technical
trick to distrub the Vacuum Energy Field and organize and collect the ZPE to do 'free'
electric work in their apparatus. Perhaps Stan Meyer did the same, and this web page
is a collection of information I found on the fantastic internet, that should make it as
clear as possible to understand.
About the successful suppressed replications done by Dave Lawton and Mr. Ravi
from India, the calculations of their efficiency give around 200-600% (400 for
Lawton, 600 for Ravi, see 'replicas' page) of the theoretical Faraday maximum, while
Stan Meyer was at 1,700%, 17 times the Farady's maximum (Meyer interview,
Channel 4, UK, 17 dec. 1995). Perhaps we need to step up the original pulses to an
higher voltage, a few thousands volts at least, and then only we send this high voltage
pulses in a coil/choke or Tesla/Bedini bifilar coil (1 to 1 ratio, see below why) to
obtain consequent high back EMF Radiant Energy pulses to charge the capacitor/cell
to the voltage breakdown level of the water layer between the electrode pipes (in the
tens of thousands volts, Stan stipulated using 20.000 Volts in his 'memo1' (see
below)).
Or may be Stan Meyer is not even using back EMF Radiant Spikes for its super-
efficient electrolysis, but just direct unidirectional high voltage pulses to charge the
capacitor/cell up to its breakdown limit, through the help of the chokes ; quote: 'the
resonant chokes being specifically to damp the voltage spikes that could prematurally
set this thing off' from Peter Lindermann video, see below.
In this case it could be the very short pulses that would trigger a Radiant Effect in the
capacitor/cell itself, increasing the value of the original pulses, like Bedini explained
about his Simplified School Girl (SSG) circuit: there is a Radiant Effect in the coil by
the reaction to the pulse sent, this creates a Back EMF, when the electromagnetic field
collapses abruptly in the coil, AND there is also a Radiant Effect when the Back EMF
pulse hits the battery electrodes, and this one is also present when we use a capacitor
in place of a battery, like in his Window Coil Motor.
Another possibility is that Stan Meyer didn't revealed in the patent that he actually did
connect his 2 chokes in a bifilar configuration (Tesla/Bedini coil), and then that's
where he was creating the Radiant Energy Spikes ... see article below.
Which one is the right explanation ? Off course it may be a 'mix' of different effects,
but for sure it induces the existence of new phenomenons that are not yet described in
the classical physics books. But it's real, and it's just next to full systematic
reproductability. We can see that only off the shelf or low cost components are used,
and then it will be quite easy and cheap to manufacture.
Considering the large choice in sytems and technologies that could provide us with
'free power' for all, Stanley Meyer's process seems to be the most 'open source' and
near to completion of all, to furnish a considerable power with a wide range of uses,
technically simple and affordable. The Hydroxy gas that comes out from water
electrolysis is well known for its high power, and is already commercialized as
welding gas, cooking gas, domestic heating gas, industrial burning gas, vehicle fuel
saver gas and more. Off course the generalization of Stan Meyer's process with a very
high efficiency, many folds the one available now from standard Faraday electrolysis,
will boost the development of the use of Hydroxy (HOH) in our daily life.
Stan Meyer's secret looks finally accessible and simple to understand and reproduce.
That would be the BEST SOLUTION for free power NOW, at very low cost to
manufacture, with off the shelf material, AND FREE OF PATENT RIGHTS, being a
technology in the Public Domain now, after expiration of Stans' patents in 2007!
Please take all the necessary precautions if you intend to research in this high voltage
fields, because it can be lethal.
http://www.rexresearch.com/meyerhy/meyerhy.htm
Where normal water electrolysis requires the passage of current measured in amps,
Meyer's cell achieves the same effect in milliamps. Furthermore ordinary tap water
requires the addition of an electrolyte such as sulphuric acid to aid current conduction;
Meyer's cell functions at greatest efficiency with pure water.
According to the witnesses, the most startling aspect of the Meyer cell was that it
remained cold, even after hours of gas production. Meyer's experiments, which he
seems to be able to perform to order, have earned him a series of US patents granted
under Section 101. The granting of a patent under this section is dependent on a
successful demonstration of the invention to a Patent Review Board.
Meyer's cell seems to have many of the attributes of an electrolytic cell except that it
functions at high voltage, low current rather than the other way around. Construction
is unremarkable. The electrodes - referred to as "excitors" by Meyer- are made from
parallel plates of stainless steel formed in either flat or concentric topography. Gas
production seems to vary as the inverse of the distance between them; the patents
suggest a spacing of 1.5mm produces satisfactory results.
The real differences occur in the power supply to the cell. Meyer uses an external
inductance which appears to resonate with the capacitance of the cell --- pure water
apparently possesses a dielectric constant of about 5 --- to produce a parallel
resonant circuit. This is excited by a high power pulse generator which, together
with the cell capacitance and a rectifier diode, forms a charge pump circuit. High
frequency pulses build a rising staircase DC potential across the electrodes of the
cell until a point is reached where the water breaks down and a momentary high
current flows. A current measuring circuit in the supply detects this breakdown
and removes the pulse drive for a few cycles allowing the water to "recover" .
(MDG nov07: that's a very CLEAR explanation given by Stan himself on the HOW
IT WORKS ! So it was known in 1991 already ... )
Research chemist Keith Hindley offers this description of a Meyer cell demonstration:
"After a day of presentations, the Griffin committee witnessed a number of important
demonstration of the WFC" (water fuel cell as named by the inventor).
In contrast with normal high current electrolysis, the witnesses report the lack of
any heating within the cell. Meyer declines to release details which would allow
scientists to duplicate and evaluate his "waterfuel cell". However, he has supplied
enough detail to the US Patents Office to persuade them that he can substantiate his
'power-from-water' claims.
One demonstration cell was fitted with two parallel plate "excitors". Using tap water
to fill the cell, the plates generated gas at very low current levels- no greater than a
tenth of an amp on the ammeter, and claimed to be milliamps by Meyer - and this gas
production increased steadily as the plates were moved closer together and
decreased as they were separated. The DC voltage appeared to be pulsed at tens of
thousands of volts.
A second cell carried nine stainless steel double tube cell units and generated much
more gas. A sequence of photographs was taken showing gas production at milliamp
levels. When the voltage was turned up to its peak value, the gas then poured off at a
very impressive level.
"We did notice that the water at the top of the cell slowly became discolored with a
pale cream and dark brown precipitate, almost certainly the effects of the chlorine in
the heavily chlorinated tap water on the stainless steel tubes used as "excitors".
He was demonstrating hydrogen gas production at milliamp and kilovolt levels. …
"The most remarkable observation is that the WFC and all its metal pipework
remained quite cold to the touch, even after more than twenty minutes of
operation. The splitting mechanism clearly evolves little heat in sharp contrast to
electrolysis where the electrolyte warms up quickly."
"The results appear to suggest efficient and controllable gas production that responds
rapidly to demand and yet is safe in operation. We clearly saw how increasing and
decreasing the voltage is used to control gas production. We saw how gas
generation ceased and then began again instantly as the voltage driving circuit was
switched off and then on again."
"After hours of discussion between ourselves, we concluded that Stan Meyer did
appear to have discovered an entirely new method for splitting water which
showed few of the characteristics of classical electrolysis. Confirmation that his
devices actually do work come from his collection of granted US patents on various
parts of the WFC system. Since they were granted under Section 101 by the US
Patent Office, the hardware involved in the patents has been examined
experimentally by US Patent Office experts and their seconded experts and all
the claims have been established."
"The basic WFC was subjected to three years of testing. This raises the granted
patents to the level of independent, critical, scientific and engineering
confirmation that the devices actually perform as claimed."
The practical demonstration of the Meyer cell appears substantially more convincing
than the para-scientific jargon which has been used to explain it. The inventor himself
talks about a distortion and polarization of the water molecule resulting in the H:OH
bonding tearing itself apart under the electrostatic potential gradient, of a resonance
within the molecule which amplifies the effect.
Apart from the copious hydrogen/oxygen gas evolution and the minimal temperature
rise within the cell, witnesses also report that water within the cell disappears
rapidly, presumably into its component parts and as an aerosol from the myriad of
tiny bubbles breaking the surface of the cell.
Meyer claims to have run a converted VW on hydrogen/oxygen mixture for the last
four years using a chain of six cylindrical cells. He also claims that photon
stimulation of the reactor space by optical fibre piped laser light increases gas
production.
## To get the article in pdf format, get 'Meyerless+World.pdf' (42 Ko) available at
http://my.opera.com/h2earth/blog/cybrarium
# USP # 4,936,961- Method for the Production of a Fuel Gas - Stanley Meyer
FIGS. 3A through 3F are illustrations depicting the theoretical bases for the
phenomena encountered during operation of the invention herein.
# Circuit useful in the process:
FIG. 2 shows a perspective of a "water capacitor" element used in the fuel cell circuit.
… The hydrogen and oxygen atomic gases, and other gas components formerly
entrapped as dissolved gases in water, are released when the resonant energy
exceeds the covalent bonding force of the water molecule.
A preferred construction material for the capacitor plates is stainless steel T-304
which is non-chemical reactive with water, hydrogen, or oxygen.
# Patents Granted : USP # 4,936,961 - Method for the Production of a Fuel Gas /
USP # 4,826,581 - Controlled Production of Thermal Energy from Gases / USP #
4,798,661 - Gas generator voltage control circuit / USP # 4,613,779 ~ Electrical
Pulse Generator / USP # 4,613,304 ~ Gas Electrical H Generator / USP #
4,465,455 ~ Start-up/Shut-down for H Gas Burner / USP # 4,421,474 ~ H Gas
Burner / USP # 4,389,981 ~ H Gas Injector System for IC Engine / USP #
4,275,950 ~ Light-Guide Lense / USP # 3,970,070 ~ Solar Heating System / USP #
4,265,224 ~ Multi-Stage Solar Storage System / USP # 3,970,070 - Solar heating
system .
# The energy contained in a gallon of water exceeds 2.5 million barrels of oil
when equated in terms of atomic energy.
Water, of course, is free, abundant, energy recyclable.
# Eighteen microliters of a water droplet per injection cycle is all that is required
to run the experimental dune buggy at 65 m.p.h. down the road.
To run a truck, for example, it would take only 148 microliters of a water droplet to
equal the on-road performance of the dune buggy, Meyer said.
# Normally, gasoline has 0.5 pounds of hydrogen in it; whereas water has 1.7 pounds
of hydrogen-or 2.5 times that of gasoline. Running a car under the Water Fuel Cell
method, you would go 2.5 times farther than on gasoline.
# The Water Fuel injectors that replace the conventional spark plugs in an internal
combustion engine form the resonant cavity which allows water to be converted to
thermal explosive energy. This technology allows the car to run both safely and under
control.
… "When you ignite gases from water, the by-product is a de-energized water mist
which goes out the exhaust," Meyer explained. "It's an open energy system. The water
mist is then re-energized by absorbing photon energy from the sun and then returning
to the earth's water supply in the form of rain for energy re-use…
## To get the best, more complet and latest info to replicate Stan Meyer Cell,
visit the page of H2EARTH/David Wenbert, on this website, at
wf_meyer_h2earth.html
One of his pipe electrode arrangements is shown here, and while it is taken directly
from one of his patents, it should be understood that the pipe specers shown in red are
actually very narow as the spacing between the pipes is very important for gas
production and is usually set at 1.5 mm:
It should be understood that while Stan's system of splitting water is very high
efficiency indeed, it is not easy to maintain it's tuning at the optimum level. The
resonance of the cell is very sharp indeed (MDG nov07: I think it is the famous 'sweet
spot' on the Bedini and other Radiant systems), and can generally only be found by
careful monitoring of the current while adjusting the pulse frequency very, very
slowly. The diagram shown here indicates how narrow the resonance 'notch' is.
Even at frequencies very close to the resonant frequency, there will be no indication
whatsoever that the frequency has almost been reached. When the correct tuning point
has been found (at water level A), the water-splitting accelerates to a high level, and
unless the water supply is being pumped through the cell as Stan shows in his patent
drawings, then the water level starts to drop. Unfortunately, as the water level drops,
say to water level B, the resonant frequency of the cell alters and the pulse train is
then at the wrong frequency and the process stops to perform correctly. To maintain
maximum low-current gas production, either the cell conditions have to be held
constant to a high degree of accuracy, or sophisticated electronic control is needed to
keep re-adjusting the pulse frequency to the exact resonant frequency, faster than the
cell charachteristics can change.
This is probably the reason why Stanley Meyer moved away from this type of cell in
favour of direct water injection into his car engine, creating the combustion conditions
inside each cylinder just before ignition. The injection system has the enormous
advantage of not needing to handle gases of any type but just move and manipulate
ordinary water. Stan died suddenly just after perfecting and demonstrating his water
injection system and before it went into production - an amazingly convenient
occurence for the oil industries. As far as I am aware, nobody has managed to
replicate Stan's injection system, in spite of there being patent information on it.
Henry Puharich aslo used a pulsed signel to split water molecules in an efficient
manner. His technique is rather different in that he starts with a modulated audio sine-
wave signal and uses half-wave rectification to cut off the negative voltage
components. The result is a pulsed DC signal which has a whole range of different
amplitudes...
In this memos written by Stanley Meyer himself, resuming his patents and processes,
HYDROGEN FRACTURING PROCESS you will clearly understand that he was
using Zero Point Energy to split the water; he called it like others, "Pure Voltage
Potential", so I put a html version of this memos in the ZPE part of this website, in the
index page, at MEYER, Stanley ...
# Memo 2 original:
http://users.skynet.be/fa272699/Energie/Meyer/memos/section2.pdf
Memo 421 - Quenching Circuit Technology, 01/25/90 ; Rendering Hydrogen Safer
Than Natural Gas - Spark-Ignition Tube - Gas Injection Process - Flame Temperature
Adjustment - Quenching Circuit - Quenching Nozzle - Catalytic Block Assembly -
Internal Combustion Engine -
# Memo 3 original:
http://users.skynet.be/fa272699/Energie/Meyer/memos/section3.pdf
Memo 422DA- WFC Hydrogen Gas Management System, 04/15/91 ; Water Fuel-Gas
Injection System - Laser Accelerator Assembly - Acceleration Control Circuit -
Analog Voltage generator - Voltage Amplitude Control Circuit - Variable Pulse
Frequency Generator - Voltage Intensifier Circuit - Electrical Polarization process -
- Resonant Action (extract): Subjecting and exposing water molecule (85) to even
higher voltage levels (xxx Vn) (up to and beyond several thousand volts) causes water
bath (91) of'Figure (3-30) as to Figure (3-25) to go into a state of ionization by
allowing opposite polarity forces (TT') and (UU') to eject one or more electrons (92a
xxx 92n) from water bath atoms (93). Intensified electrical attraction force (TT')
causes dislodged negative charged electrons (92) to migrate to positive voltage-plate
(El) while electrical attraction force (UU') causes positive charged atom nucleus (94)
to travel toward negative voltage-plate (E2). Applied electrical attraction force (TT')
and (UU') always being of equal voltage intensity but opposite in electrical polarity as
voltage amplitude (65) is attenuated.
# Memo 4 original:
http://users.skynet.be/fa272699/Energie/Meyer/memos/section4.pdf
Memo 423DA - Water Fuel Injection System, 07/03/91 ;(with pictures of the engine
on the water buggy)
# Memo 5 original:
http://users.skynet.be/fa272699/Energie/Meyer/memos/section5.pdf
Memo 424 - Atomic Energy Balance of Water, 11/14/91 - Using Water as Fuel
(MDG nov07: Be sure Meyer was using ZPE !
# Memo 6 original:
http://users.skynet.be/fa272699/Energie/Meyer/memos/section6.pdf
Memo 425 - Water Fuel Injector: Taper Resonant Cavity, 08/13/92
# Memo 7 original:
http://users.skynet.be/fa272699/Energie/Meyer/memos/section7.pdf
Memo 426 - VIC Matrix Circuit, 07/07/93 ; Instant Explosion of Water
# Memo 8 original:
http://users.skynet.be/fa272699/Energie/Meyer/memos/section8.pdf
Memo 427 - Voltage Wave-Guide Propagating, 08/10/93 ; "Resonant Action" By
Voltage Tickling of State Space
# Memo 9 original:
http://users.skynet.be/fa272699/Energie/Meyer/memos/section9.pdf
Memo 428 - Reclaiming Our Air ... For Healthy Living 06/18/94
# Memo 10 original:
http://users.skynet.be/fa272699/Energie/Meyer/memos/section10.pdf
Memo 429 - Optical Thermal Lens: A Miniature Controllable Sun, 11/03/95 -
Propagating Electrical Stress - Voltage to Amp Differential Ratio - Optical Thermal
Lens - Quartz Tube Configuration & Operational Parameters - A Technique Called
"Easer"
# Memo 11 original:
http://users.skynet.be/fa272699/Energie/Meyer/memos/section11.pdf
Memo 430 - WFC Steam Resonator, 05/18/96 ; Particle Oscillation as a Energy
Generator - Voltage Flexing Process - VIC Switchover Circuit - Electrical Crossover
Switching Circuit
# Extracts from Memo 1, about the 'Pure Voltage Potential':
... The Hydrogen Fracturing Process is systematically activated and performed in the
following way:
The Inductance (C) and Capacitance (ER) properties of the LC circuit is therefore
"tuned" to resonance at a certain frequency. The Resonant Frequency can be raised or
lowered by changing the inductance and/or the capacitance values. The established
resonant frequency is, of course, independent of voltage amplitude, as illustrated in
Figure (1-3) as to Figure (1-4). The value of the Inductor (C), the value of the
capacitor (ER), and the pulse-frequency of the voltage being applied across the LC
circuit determines the impedance of the LC circuit
(see formulas on the original document)
# LC Voltage : The voltage across the inductor (C) or capacitor (ER) is greater than
the applied voltage (H). At frequency close to resonance, the voltage across the
individual components is higher than the applied voltage (H), and, at resonant
frequency, the voltage VT across both the inductor and the c:apacitor are
theoretically infinite. However, physical constraints of components and circuit
interaction prevents the voltage from reaching infinity.
During resonant interaction, the incoming unipolar pulse-train (H) of Figure (1-1) as
to Figure (1-5) produces a step-charging voltage-effect across Excitor-Array (ER), as
illustrated in Figure(1-3) and Figure (1-4). Voltage intensity increases from zero
'ground-state' to an high positive voltage potential in an progressive function. Once
the voltage-pulse is terminated or switched-off, voltage potential returns to "ground-
state" or near ground-state to start the voltage deflection process over again.
Voltage intensity or level across Excitor-Array (ER) can exceed 20,000 volts due
to circuit (AA) interaction and is directly related to pulse-train (H) variable amplitude
input.
# RLC Circuit : Inductor (C) is made of or composed of resistive wire (R2) to further
restrict D.C. current flow beyond inductance reaction (XL), and, is given by (Eq 8)
# Voltage Performs Work : Unlike voltage charges within an electrical circuit sets up
an "electrical attraction force" ; whereas, like electrical charges within the same
electrical circuit encourages an "repelling action". In both cases, electrical charge
deflection or movement is directly related to applied voltage. These electrical "forces"
are known as "voltage fields" and can exhibit either a positive or negative electrical
charge.
Likewise, Ions or particles within the electrical circuit having unlike electrical charges
are attracted to each other. Ions or particle masses having the same or like electrical
charges will move away from one another, as illustrated in Figure (1-6).
(MDG nov07: Explanation continue, explaining that the applied high voltage alone
separates the hydrogen and oxygen atoms, through electrons liberation. No mention of
the 'dielectric breakdown effect' participating in the process.)
... next process for production of free hydrogen is the Stanl Meyer patent. Here a lot
of people have not understood really what stan was doing. So it's a method for
obtaining the release of a fuel gas including hydrogen and oxygen from water, during
which the water is processed as a dielectric media in an electrical resonant circuit
Then he shows the cell, here, which basically consits of concentric cylinders and this
... ; but here is the circuit, and basically there is not much to at what he is saying he is
putting 50% duty cycles pulses into this transformer and creating pulses that are going
to the fuel cell wich is designed to be a capacitor.
Now, the obvious problem with this situation is this, he is using the word resonant
here, like salt and pepper all the way through.
This is not a resonant circuit, this was part of the diversion about how to keep
people, how he protected the idea without actually leading people to understand what
was going on, and the proof that this is not a resonant circuit lyes in the bloking
diode ! huuuuuuu gushh
so what you can see here is what he is really doing is this, this system works without
electrolyte (MDG: Air being the dielectric layer to breakdown) ; so the purpose of it
is, he wants his water to have a fearly high resistance in it, and so, here is what he
is gona do, he got this chokes, this chokes are very important because when he puts
this inductive spikes on, here, ... with the diode, what he is doing is, he is charging
this capacitor, and the resonant chokes are specifically to damp the voltage spikes
that could prematurally set this thing off.
So what he is doing, he is making sure that he can charge this capacitor with kind
of soft pulses and pulse the thing up, so he can get this capacitor to charge to the
maximum degree before the dielectric material, in this case water, creates a
catastrophic dielectric failure in the capacitor
At which point, all the charge in the capacitor, all the voltage in the capacitor is
converted to amps as a shorts out internally, and orderly destroys the water it
moves through and creates massive quantities of hydrogen and oxygen.
(showing of patent page drawing progressive water molecule stretching under pulses
train)
again this types of drawing were made to confuse people, you know the idea of
drawing this things are that these were increasingly large resonant pulses and
everything, this is all a bunch of ... , all he is doing is just like any other voltage
multiplier that's used in pulsing, all you are looking up is a step ramp charger on a
capacitor until it reaches it's catastrophic failure, that is the method of the Stan
Meyer's system, and it does produce massive amounts of gas for a very small amount
of electricity.
Here is the website Xogen.com. And you can see here Xogen's process does most
significant promesses that it will make economical for hydrogen to replace carbon
based fuels, and could consivibly reduce atmospheric pollution.
So again here is a new company moving forward with the same basic technology. Will
Xogen provide a full disclosure of their technology ? No we won't.
This technology is real guys, you know all the chemistry books thast say it takes
more electricity to crack water than you can get out of it. Thraw out this books in the
fire and try to get some BTU out of it !
Free Energy, so basically the methods for what we call superefficient electrolysis,
which can create unlimited amounts of free hydrogen for fuel
Second one is the Meyer/Xogen process where you use the electrolysis cell as a
capacitor which you charge untill you reach a catastrophic breakdown of the
dielectric material at which point your voltage is just converted to amperage and
you get a gigantic blast of gas, and you can just repeat it many times a second.
And again it goes back to Gray, it goes back to Tesla, it goes back to all this things
that's the way into this systems, as a unidirectionnal application of a voltage, which
then resolves as a free energy impulse of current.
This is exactly what is going on in the Muller (Ion Back EMF Generator), so an
unidirectionnnal impulses.
(minute 7.00 of this video)
The third way again, ... Muller is doing this, he's got is Ion Back EMF generators
sitting on a bid engine which only takes a few horsepowers to turn it. He is taking all
the electricity from that, creating hydrogen and after that runniing the engine and plus
the big loads.
They are doing now, at industrial level, and off course you can also take all your
outputs from permanent magnet transformer, damped in an electrolytic cell of any
type you want, making free hydrogen, and also Bedini's system, where we show that
he was pulsing the light bulb when he was charging his battery, if you put an
electrolysis cell and that on, you can make hydrogen while you are charging your
batteries.
(minute 8.00 of this video) Not all the end of this video is transcripted because I found
it not important on a technical consideration.
Ok, lets talk about emerging markets ... free energy systems are reaching the market
today, ... things are changing in the wold ... we are not going to ask them, if you don't
ask for permission, they can't say no.... on remote mining, and other remote activities,
oil companies are going to take power plants based on Muller system, and they are
running the onboard electrical generation on big oil platforms, in place of staff like
petrol, they are running on superefficient electrolysis.
This things are going in now, don't expect the government to sanction this ... the
government can't admitt it's happening, but it can't stop it anymore ...
Peter Linderman DSc became interested in Free Energy in 1973, when he was
introduced to the work of Edwin Gray. By 1981, he had developed his own free
energy systems based on variable reluctance and pulsed motor designs. During the
1980’s, he worked off and on with both Bruce DePalma another researcher whose
devices was suppressed and Eric Dollard. In 1988, he joined the Board of Directors
at Borderland Sciences Research Foundation, and served until 1999.
During this period he authored more than 20 articles on various alternative topics such
as Radionics, Jet-Lag, Lakhovsky’s MWO, and Free Energy. Currently, Dr.
Lindemann is a research associate of the late Dr. Robert Adams another pioneer in
alternative energy devices in New Zealand, and Trevor James Constable in the USA.
He is also Director of Research for his own company, Clear Tech, Inc..
## Water as Fuel, by Admiral Sir Anthony Griffin, Sept 1993 from 'Waterfuel
Tech Adm[1]. Griffin on WFC P56.pdf' (303 Ko) at
The following is an extract from the lecture given by Admiral Sir Anthony Griffin to
the Marine Division of the Southampton Institute, Warsash, UK, as part of the
symposium on the Impact of New Technology on the Marine Industries, September
1993.
# The 1980 Patent: The first and probably the most frequently demonstrated patent is
based on the actual equipment used in 1980 to support Meyer's claim for his hydrogen
fracturing process. I have now personally witnessed it 4 times.
Electrical power with opposite polarities is applied in pulses to the inner and outer
cylinders and at a power of 10 watts, i.e. 5 volts at 2 amps. A considerable
quantity of gas immediately accumulates in the top of the vessel and, within 10
seconds, reaches a pressure of about 10 pounds per square inch.
When the valve is opened, a jet of cold gas can be felt, but on this being lit with a
match, the temperature instantly rises to about 3,000oF and the flame burns
through a stainless steel wire in about 2 seconds. The glass vessel and its attachements
remain at room temperature throughout, thus ruling out any normal electrolytic
process. Plainly, the generation of such a quantity of gas and its immediate
application at such a high temperature, demands more than 10 watts of electrical
energy. Furthermore, as the stainless steel cylinders have not noticeably been
consumed over several years, the balance of the energy required can only come
from the Zero-Point Energy in the water.
Meyer points out that all the parameters involved in this demonstration have been
deliberately de-optimised, e.g. 5 volts instead of 20,000 volts and 2 amps instead
of 0.5 milliamp, 14 inch tubes instead of an optimum of 27 inch tubes, etc. in
order to allow the principle of the water fracturing process to be demonstrated without
risk of explosion.
# The 1985 Dune Buggy: In 1985, a dune buggy powered by a standard 1,600 cc
Volkswagen engine was modified through Water Fuel Cell technology to run on water
fuel. It was a breadboard quality experiment which was successfully demonstrated as
broadcast on American TV and reported in the press. A video tape record is held by
London University.
# The 1993 Dune Buggy: This will be the first demonstration of a complete system,
manufactured to a pre-production standard as a conversion kit for a typical car. The
rig is designed for powers up to 400hp and, in production, Meyer expects to market it
for 1,500 USD. The date has yet to be settled, but is expected to be within the next 2
months in Ohio.
Pictures from youtube video 'Original Meyer Water Fuel Cell c.1990'.
# The Theory of Water Fuel Cell Technology: This begins with the basic structures
of hydrogen and oxygen atoms and how they are combined in the water molecule.
Note the orbital paths of the electrons and their 'shells'; the magnetic polarity of an
electron and a nucleus; and the space occupied by the so-called vacuum.
Note the presence of the two hydrogen electrons in the 'L' shell of the oxygen atom.
These are known as the covalent electrons which are bonded in position by
considerable electrical force. In the case of normal electrolysis, the energy needed to
break these bonds and produce separate hydrogen and oxygen atoms from water, is
roughly three times the energy of the hydrogen released. It is thus a highly inefficient
process because of the considerable amount of waste heat which is generated.
The energy extracted from water by the Water Fuel Cell derives from two distinct,
but virtually simultaneous processes. The first is the hydrogen fracturing process
which dissociates the hydrogen gas from the water molecule. The second is the
electron ionisation process which enhances the explosive energy of the gases released.
(MDG nov07: may be an explanation of the Hydroxy gas strange properties ...)
# The Hydrogen Fracturing Process: The basis of this process is the subjection of
the water molecule to very high voltage (20,000+) pulses at a particular
frequency and within positively and negatively charged voltage zones at a very low
current of less than 1 milliamp.
The effect is to attract the negatively charged electrons towards the positive voltage
zone and the positively charged nucleus towards the negative zone. The electron
orbital path is changed from a circle to an ellipse and this, coupled with the effect of
pulsing, causes such electrical stress on the molecule that the covalent bonds between
the hydrogen and oxygen atoms are broken and the 2 gases separated. Thereafter, they
require substantial energy to be applied before they can be recombined. Because the
current is so low, very little heat is generated. It is worth noting that, weight for
weight, hydrogen contains about 2.5 times the energy of gasoline and the latent
energy in the hydrogen content of a pint of water amounts to over 9 million Joules, or
enough to run a 1KW heater for 2.5 hours.
The answer to the first question is the so-called vacuum within the electron shells. For
many years this vacuum was regarded as a void. But James Clerk Maxwell, in his
'Treatise on Electricity and Magnetism' published in 1873, pointed out (vol 2 pages
472 and 473) that the vacuum in fact contains a considerable amount of energy.
Subsequent work bears this out and it is now generally accepted that the vacuum is in
fact seething with energy which has variously described as, for example, 'universal
energy', 'gravity field energy', or 'zero-point energy'. John Archibald Wheeler of
Princeton University, a leading physicist who worked on the US atomic bomb project,
has calculated that the flux density of zero-point energy is of the order of 1093 grams
per cm3. It is also recognised that the state of this so-called 'sea of energy' is chaotic.
Hence it needs to be 'engineered' or made coherent before it can be translated from a
microscopic to a macroscopic state. In other words, it requires special treatment
before it can be tapped and controlled for normal external use.
Various answers, mostly theoretical, have been given to the second question. Recent
examples include Ilya Prigogine's book 'Order Out of Chaos' which describes the
work which won him the Nobel Prize for Chemistry in 1977, Moray B. King's
'Tapping the Zero-Point Energy', Dr. J. Huber's paper 'Phenomena of the Free Energy
in Nature and Technology', John Davidson's 'The Secret of The Creative Vacuum' and,
from the Kansas State University, Gary L. Johnson's 'Electrically Induced Explosions
in Water'. Some 30 supposedly practical devices have been made or suggested over
the past 80 years, but although some have been demonstrated, none has been
developed or engineered to a pre-production standard.
Meyer's Water Fuel Cell technology stands out as the only apparent exception. It has
encounteres deep scepticism but no argued rejection. Indeed, an increasing number of
scientists and engineers in the USA, Europe and Asia, accept the technology and are
prepared to invest in it on the basis of current evidence. A practical demonstration is
in fact due to take place within the next few weeks, based on a fully designed system,
engineered to a pre-production standard and fitted to a running 'dune buggy'.
The technical basis for Meyer's extraction and control of zero-point energy lies mainly
in the effect produced on an atomic nucleus by continuation of the same high voltage
pulsing that causes the dissociation of the water molecule. The nucleus consists of one
or more positively charged protons bound together with a number of neutrally charged
neutrons. The electrical effect of the electron pumping action mentioned earlier,
causes an annulus to appear in the middle of the nucleus. The zero-point energy is
drawn through the annulus in an helical motion and in so doing, becomes coherent
and hence a usable source of energy. The voltage dictates the size of the annulus, and
hence controls the energy obtained. Since the basic structure of the atom is retained,
no alpha or gamma radiation occurs. The effect might be illustrated by a bath full of
water. So long as the plug is in place, the water remains still and apparently
powerless. However, when the plug is removed, the water swirls away with a helical
motion down the plug hole and, under the influence of gravity, forms a powerful jet
which can be directed to do work.
Meyer further stimulates the energy yield by injecting laser energy into the ionised
water vapour. A diagram of the energy enhancement system is shown in Figure 9:
The hydrogen fracturing process and the energy enhancement of the gas occurs almost
simultaneously within the fuel injector. This, in an internal combustion petrol or diesel
engine, replaces an existing spark plug or diesel fuel injector, and the output is ignited
by a high voltage pulse on entry into the cylinder. Consequently, the hydrogen does
not have to be stored and the fuel tanks of land or air vehicles contain nothing but
water. Vessels floating on water need no fuel tanks. The system is thus not only
extremely safe, but also inexpensive. Meyer has quoted the in-production cost of a
conversion kit for a 1,600cc Volkswagen engined car as 1,500USD (1993 USD
values).
5. The Water Fuel Cell and the First and Second Laws of
Thermodynamics:
The Water Fuel Cell technology encounters a credibility gap because it appears to run
counter to the long established laws governing our interpretation of Nature. Some
people therefore reject the Water Fuel Cell because it appears to be un-natural and just
one more spurious claim for perpetual motion. In fact, the Water Fuel Cell is entirely
natural. It merely demonstrates a new and revolutionary way of harnessing what
nature has always had on offer. It does not infringe the two main laws of
thermodynamics, i.e.:
- The First Law: 'The total energy of a thermodynamic system remains constant
although it may be transformed from one form to another'.
In the case of WFC technology, the system is global. The energy required to drive the
engine comes from the ZPE contained in the water, a virtually inexhaustible source.
The exhaust from the engine is water vapour which returns to the atmosphere.
- The Second Law: As originally formulated by R. Clausius in 1865, this law states
that 'The entropy of the World strives towards a maximum'. As recently formulated by
Prigogine and Stengers, this law 'contains two fundamental elements: (1) a negative
one that expresses the impossibility of certain processes (e.g. heat flowing from a cold
to a hot source) and (2) a positive, constructive one. It is the impossibility of certain
processes that permits us to introduce a function, entropy, which increases uniformly
and behaves as an attractor for isolated systems'. It is at maximum when the system is
in equilibrium. Non-equilibrium is the source of order and brings order out of chaos.
# The vehicle System: The system starts with a normal 12V car battery and a tank
full of water (salt, frsh or distilled). Under computer control, the Voltage Intensifier
Circuit is energised by the battery to generate high voltage pulses at a very low
current, <1 milliamp, the voltage being responsive to the throttle. Simultaneously,
water and ambient air are mixed into a water mist which is injected with laser energy
and fed to each fuel injector. There it is subject to high voltage pulses which, virtually
simultaneously, lead to the separation of the hydrogen and oxygen gases, and the
explosive energy enhancement. A special high voltage pulse, applied at the exit of the
fuel injector, ignites the gases as they enter the cylinder. The system is outlined in
figure 10.(see schema Figure 10)
- The Fuel Injector: This highly innovative development accounts for the
compactness of the vehicle conversion kit (MDG nov07:see picture below on the
webpage). It replaces the 'resonant cavity unit' which formed a relatively bulky and
expensive component of the system as originally designed; eliminates the need for a
special hydrogen conduit between the cavity unit and the fuel injection system; and
reduces the variety of such systems by allowing any adjustments to be made through a
newly designed universal computer. A schematic diagram is shown here:
# Applications: In this current state of development, which is to a pre-production
standard of engineering, the WFC technology can provide a safe, economical and
pollution free source of universal energy for all internal combustion petrol or diesel
engines of up to 400horsepower. In addition, it can be readily adapted to gas turbines
(both marine and aerial), to desalination plants, home heating boilers and industrial
furnaces. A Dublin food processing company is now, with Irish Government
support, manufacturing a water-fuelled furnace under licence from Meyer. When
WFC technology reaches its full production stage, Meyer intends to market a range of
conversion kits.
Given some conventional engineering development, Water Fuel Cell technology could
be applied to very much higher powers, such as electricity generating plants (both
fossil and nuclear fuelled), slow speed diesels, and space rockets.
In all these cases, energy would be in the form of hydrogen, obtained from the
dissociation of water, coupled with Zero-Point Energy itself through energy
enhancement. Meanwhile, Meyer has a further development in hand he calls
'hyperdrive'.
# Hyperdrive: This new development does not require the generation of hydrogen
and its subsequent combustion. It applies the energy, made available electrically from
high voltage pulsing of the Zero-Point Energy Field, directly to the generation of a
water jet. It does not require an engine and has no moving parts. The power level is
governed, as before, by the applied voltage. Direction is controlled by feeding the jet
through manoeuvring nozzles such as those fitted to the Harrier Vtol aircraft and to
space rockets. It is therefore of special significance to marine transport.
# Author's Biography: Admiral Sir Anthony Griffin was a regular executive officer
in the Royal Navy for 42 years, the last 5 of which were spent as Controller of the
Navy with responsibility for the development and construction of all surface ships,
submarines, aircraft and weapons. Retired from RN in 1975 to become first Chairman
of British Shipbuilders from 1975-1980; President of the Royal Institution of Naval
Architects 1981-1984, and founder member of the British Maritime League and the
British Maritime Charitable Foundation in 1982.
See -
http://www.osen.org/Technologies/Hydrogen/RelatedPatents/tabid/374/Default.aspx
- Have it : Management system for IC engine using hydrogen gas 1990 US-5293857-
A WO-9208046-A1 AU-9168870-A
- Have it : Fuel gas production with enhanced thermal energy release 1987 US-
5149407-A EP-381722-A, EP-381722-A4 WO-8912704-A JP-3500042-W AU-
8938623-A
4936961-A EP-381722-A, EP-381722-A4 WO-8912704-A JP-3500042-W AU-
8938623-A
- Have it : Controlled thermal energy production from gases 1986 US-4826581-A EP-
333854-A, EP-333854-A4 WO-8901464-A
- Have it : Generator producing hydrogen-oxygen mixture from water 1985 US-
4798661-A
- Have it : Electrical pulse generator for power supply 1983 US-4613779-A
- Have it : Gas electrical hydrogen generator 1984 US-4613304-A
- Have it : Start-up/shut-down system for hydrogen gas burner 1982 US-4465455-A
- Have it : Hydrogen gas burner with controlled recirculation 1982 US-4421474-A
- Have it : Hydrogen gas injector system for IC engine 1982 US-4389981-A CA-
1233379-A EP-86439-A, EP86439-B DE-3381176-G
- Doesn't have it : Light-guide lense assembly for solar energy concentration 1980
US-4275950-A
- Doesn't have it : Multi-stage solar storage system 1980 US-4265224-A
- Have it : Solar heating system 1976 US-3970070-A
- Have it : Converting water to fuel containing hydrogen - by subjecting water mist to
unipolar pulsing electrical signal 1991 CA-2067735-A WO-9222679-A1 JP-7505186-
W AU-9184471-A
- Have it : Combustion system with controlled mixing of (non) volatile gases 1984
CA-1231872-A EP-122472-A
- Have it : Hydrogen oxygen generator - has direct current voltage applied to pair of
non-oxidising metal plates immersed in water 1982 CA-1234774-A EP-111573-A JP-
59129791-A
- Have it : Electrical generator employing hydrogen gas generator 1982 CA-1228833-
A EP-106917-A JP-59132784-A, JP-59148584-A
- Have it : Hydrogen-oxygen generator with controlled gas burning 1982 CA-
1235669-A EP-101761-A, EP-101761-B DE-3280143-G
- Have it : Electrical power transformer using magnetised particles 1982 CA-
1213671-A EP-98897-A JP-58207610-A
- Have it : Non-electrolytic separation of hydrogen and oxygen from water 1982 EP-
103656-A
- Have it : Control and driver circuits for fuel gas cell 1990 WO-9207861-A1 AU-
9174852-A
- Have it : Apparatus for non-electrolytic production of hydrogen from water 1984
CA-1234773-A JP-59059889-A, JP-910450001-B
- Have it : Combustion system using hydrogen-oxygen generator
For a coil with NORTH field at the top, wind like this:
When putting PLUS to the top and NEGATIVE to bottom, you get the NORTH field
at the top
During the active process of charging the coil while current is moving, LENZ LAW
exhibits itself as BACK EMF
What is LENZ's LAW?
'The magnetic field of any induced current opposes the change that induces it'.
What is BACK EMF or CEMF (counter EMF)?
'EMF the pushes against current which induces it, is caused by a changing
electromagnetic field.'
So we see that 'BACK EMF' is happening DURING the ACTIVE process of charging
a coil.
Here is a visualization of BACK EMF DURING the APPLIED ON PULSE.
AFTER the power to a coil is disconnected or turned OFF, the field collapses in
reverse polarity causing a 'spike'.
1. Power applied to coil and BACK EMF opposes it
THEN
2. Power is turned off anf field collapses
When the coil is being charged, the loop is CLOSED for that moment. When closed,
current can flow.
When power is disconnected from coil, the loops is OPEN and when open ...
Ask yourself: 'How much CURRENT can flow when loop is open?'
Ask yourself: 'If no current can flow, how much BACK EMF is opposing no current?'
Ask yourself: 'If the loop is open and there is no current, how can there be any BACK
EMF?'
When power is disconnected, magnetic field collapses very fast with high voltage
potential and no current.
BACK EMF happens DURING application of power to charge coil. THEN, field
collapses AFTER power is disconnected.
Many people tinkering in the 'free energy' field is often talking about the collapsed
spikes as BACK EMF
Refer them to this video OR have them visit: www.energeticforum.com/renewable-
energy
# Transcription of Aaron youtube video 'Water Fuel Cell (WFC) - conditioning the
tubes', added August 22, 2007, 4.50 minutes:
http://youtube.com/watch?v=qXRMVZWrgSk
T304 SS Tubes, Positive (+) outside tubes ; Negative (-) inside tubes ; 1mm gap
spaced w/wire insulation
Power hitting the cell is: 120Hz (pulsed DC), 4.74 Volts @ 2 Amps = 9.48 Watts
White powder coating visible on inner tubes, which are negative polarity. You must
have good coating for optimum efficiency.
More info, visit ... www.energeticforum.com/renewable-energy
or the FREE Members Only section www.energeticforum.com/energy ; I posted
schematics and other info there
White Dragon Press www.whitedragonpress.com ; Book coming soon to explain the
science in simple terms
# Transcription of Aaron youtube video 'Stan Meyer WFC Bifilar Chokes', posted
August 27, 2007: http://youtube.com/watch?v=ozpRNpM6FqM
That was the bare bones pic in fig 3-22 in the tech brief
You can see the chokes at the top and bottom before the cell
page 6-3 in tech brief: 'which are axially (spiralled) Bifilar wound about core bobbin'
page 7-5 in tech brief: 'Both Inductors (L1/L2) are Bifilar wound in equal length'
page 7-11 in tech brief:'each choke-coil (L1/L2) being of the same impedance value
since both coil-wraps (56/62) are Bifilar wound together onto a single spool-bobbin.'
page 10-1 in tech brief: 'The Amp Inhibiting Circuit (970) of Figure (10-1) as to (690)
of Figure (7-8) is composed of two copper wires 'Bifilar' wound (wrapped)'
page 10-2 in tech brief: 'VIC Bifilar Wrap Coil-Assembly (10-3B) and VIC Dual Coil
Wrap-Assembly (10-3A) both utilize'
Here is a simple diagram that shows it clearly based on what appears to be in the tech
brief
Positive pulse goes through blocking diode
Positive pulse then hits one of the bifilar choke coils
This coil becomes NORTH charged at the end the diode is attached to
The positive pulse hits the positive outside tube
Positive pulse hits the water
Positive pulse potential hits the negative inside tube
Positive pulse potential hits the other choke coil wire connected to the negative tube
making that end NORTH
Both wires are wrapped the SAME way. Meyer's diagrams show the coil will be
NORTH at the end of the positive potential.
The positive pulse then hits the negative side of the secondary transformer coil during
the ON pulse
The positive choke has NORTH AT ONE END and the negative choke has NORTH
AND THE OPPOSITE END. THESE FIELDS OPPOSE EACH OTHER.
Get more details at: http://www.energeticforum.com/energy
# Transcription of Aaron youtube video 'Water Fuel Cell - Gas | Stan Meyer
Replication Free Energy', added August 10, 2007:
http://youtube.com/watch?v=pSFpBW8_v8o
Energy The how to of free-energy technologies. Including Bedini, Stan Meyer and
other circuits and more. Peter Lindemann projects and other info you won't find
anywhere else on the internet.
Upon further examination, these are my comments, which may be right or wrong, I
don't know but they make sense to me
Here is the tech brief on the wfc by Meyer: (given internet address is uncomplete)
Below are a few tidbits from the tech brief on the bifilar, arrangement, purpose,
construction, specs, etc...
Page 6-3:
"Resonant Choke Coils (56/62) of Figure (3-23) (Memo WFC 422 DA) are composed
of 430F or 430FR inductance stainless steel film coated (hi dielectric value) wire
(typically .004 Ga. or smaller) which are axially (spiralled) Bifilar wound about core
bobbin (502), forming individual spiral-wrap (inner to outer circumference and being
equally-length) coils (501a xxx 501n) electrically connected in sequencial order to
form resistive pickup coil (503)."
[Figure 3-23: PULSING CORE CONFIGURATION, Meyer 190]
choke #56 is drawn incorrectly - they are wrapped in the same direction. I'll get to that
later.
[Figure 3-22: VOLTAGE INTENSIFIER CIRCUIT, Meyer]
page 7-11:
"each choke-coil (LIIL2) being of the same impedance value since both coil-wraps
(56/62) are Bifilar wound together onto a single spool-bobbin,"
page 10-1:
"The Amp Inhibiting Circuit (970) of Figure (10-1) as to (690) of Figure (7-8) is
composed of two copper wires "Bifilar" wound (wrapped) about a magnetic induction
core to allow amp restriction (minimizing current leakage) while encouraging
"Voltage Potential"(Va xxx V n) across the water molecule to perform WFC
"Electrical Polarization Process", as so illustrated in Figure (7-1) WFC memo (426)
titled VIC Matrix Circuit."
[Figure 10-1: VOLTAGE INTENSIFIER CIRCUIT, Meyer 970]
page 10-2:
"VIC Bifilar Wrap Coil-Assembly (10-3B) and VIC Dual Coil Wrap-Assembly (10-
3A) both utilize either "E"& “I” and "U" Inductance Core configurations to
concentrate Mutual Inductance Fields (Rp l/Rp2) in order to optimize Amp Inhibiting
Process (750) of Figure (7-14). "E" “I” core shape (10-3B) is most preferable since
amp spike surge is minimize during repetitive pulsing operations."
[Figure 10-3B: VIC BIFILAR-WRAP ASS'Y , Meyer ]
page 10-4:
"Increasing energy-yield (16/gtnt) still further (xxx 16/gtntnl+ 16/gtntn2 + 16/gtntn ...
etc.) is accomplished by increasing the number of Resonant Charging Choke Stages
(xxx 56/62n + 56/62n 1+ 56/62n2 + 56/62n ... etc. -S- xxx SS56/62n + SS56/62nl +
SS56/62n2 + SS56/62n ... etc.) of Figure (10-4) in "Sequential Order" ( -S-) since the
total number of Multi-Coil Magnet bifilar coils (56/62a xxx 56/62n) serially
electrically connected together are sequentially electrically linked to an equal number
of serially electrically aligned Stainless Steel Resonant Coils (SS/56/62a xxx
SS/56/62n) ... allowing eachlboth bifilar coil assembly (56/62a xxx 56/62n -SSS56/
62a xxx SS56/62n) to be electrically and magnetically energized in the same
progressive direction toward Water Gap (Cp) and away from blocking diode (55) of
Figure (3-34) as to Figure (10-1) and Figure (10-3) '" keeping amp-surge (inhibiting
amp flow) to a minimal level [See Voltage Performance Graph (750) of Figure (7-14)]
while enhancing Voltage Potential of Electrical Stress (64/RU-RU'a xxx 64/ST-ST'n)
as additional Dual Choke Coils (56/62 _ SS56/62) are included in the stacked coil-
array forming Voltage Intensifier Circuit (970) of Figure (10-1) as to (620) of figure
(7-1) ... see Dynamic Voltage Waveform (770) of Figure (8-1), once again."
[Figure 10-4: DUAL-LAYERED MULTI-SPOOL CONFIGURATION, Meyer 1000]
above pic if only you want to put more bifilar chokes in series
Generally, magnet coil-wire length is longer than the Stainless steel coil-wire length
and magnet bifilar-coil (56/62) is placed on top of Stainless Steel bifilar-coil
(SS56/62) to maximize mutual inductance coil-field (Rp2) (adding Rp1 +Rp2) of
(690) of Figure (7-8) to cause coil capacitance (Cda xxx Cdn) to help maintain and
even increase pulse voltage amplitude (xxx Vn + Vn 1 + Vn2 + Vn .... etc.) while the
resistive value (Rs2) of SS Coil-Wire (SS56/62) performs the work of further resisting
the flow of amps not inhibited by both self-Inductance fields (Rpl + Rp2), as so
illustrated in (690) of Figure (7-8). In all cases, bifilar coils (56/62 - SS56/62) are
electromagnetically orientated in the same direction."
The above pic I drew shows the bare bones bifilar choke system. Top is the secondary
transformer coil.
Output through blocking diode goes into one of the bifilar choke winds.
In figure 10-3B, it is easy to see that the direction the winds are coming off the core
that when the positive hits that coil, north is at that side.
The potential follows through to the outside positive tube through water to negative
inside tube.
Positive potential moves to the other bifilar choke coil (wound the same direction)
meaning that north will be at THAT end (opposite of the north on the other coil) and
through this coil and to the negative on power supply.
Both choke coils on the pos and neg tube create opposing magnetic fields against each
other. On the on pulse, the pos side choke coil is north by the diode side and south by
the pos tube side... the neg side choke coil is north by the tube side and south by the
power supply neg. On the OFF pulse, they both reverse and also oppose each other.
In many diagrams in the tech brief, this exact configuration shows that the choke coils
are in opposition at all times on the off and on pulse.
My picture shows the bare bone system without the electron extraction circuit (EEC)
or any coils being tapped.
Meyer says that the I core (rectangle with line down middle) as shown in fig 10-3B is
the best core for the choke since this configuration restricts amps the most.
More to come and comments and observations on the above very welcome... With
Gratitude! Aaron Murakami
If you notice also in the beginning of the FEG book of Bedini ('84), you see the
energizer coils in series. My thought is this increases capacity as well as significant
potential to be released. With this in mind, make 10-3B as a quadfilar. Two or more
strands opposing two or more strands with each opposing pairs in series.
What’s interesting …is the aligned fields of the Bifilar w/ wfc load in between creates
a larger compressed potential of the LEM wave. When cathode is properly insulated
or conditioned this should further the compressed potential LEM wave. This will
cause a larger imbalance allowing the vacuum to interact freely. I have a strong
feeling that the Lawton circuit should use a Bifilar or more coils instead of two
independent inductors. I may be wrong. But from what I gather from Aaron’s
experiment, the field must be aligned. The D12.pdf does not show this! Also, the
Lawton circuit does not pick off the electrons furthering the imbalanced high-energy
state of the atomic atom. We are only seeing on half of the picture here.
Meyer went from individual inductors to bifilar on same core. Definitely a stronger
gradient created here.
(Follow a full transcription of Nikola TESLA patent on his BIFILAR FLAT COIL:
see original document. )
I found the same thing about 3-4 years ago with a single inductor on pos side and
diode, discharge is in same direction...I got no reversal in polarity..it was same as
initial pulse. I deduced it was as if the switch is open before inductor so it can only go
find ground - towards cell.
Same gain as the flat pancakes? I don't know. But if both coils are on 1 core, there will
definitely be more strength in the field than 2 single coils. This is also a known with
Bedini coils. 1 coil with 4 power wires is stronger than 4 individual coils. They all
pulse together, there is a synergy and the sum is more than the parts. So, I would say
in this geometry with these kind of coils, yes, there is a benefit.
The off pulse lets coil discharge towards the cap again so you get almost twice the
bang for the buck. This seems to evidently help water cap prevent discharge by having
that extra pulse keep the voltage up.
The open switch means that on the off pulse, it is the same as being disconnected so it
has to go somewhere and finds its way to ground and the only way it can do that is by
going towards the cell.
So we know
1. Diode keeps potentials and current in one direction only acting as switch to
"disconnect" inductor from circuit on off pulse.
2. Diode is obviously between secondary and charging choke
3. Collapsing inductor causes UNIPOLAR pulse..so polarity stays same in the
forward direction.
4. Collapsing unipolar pulse is "pulse-frequency doubler" so cell gets 2 pulses for 1
pulse input.
5. Sounds like when off time exceeds on time, off time is adjusted to ensure that the
unipolar pulse train continues with consistency.
The first reference of bifilar in the tech brief on page 6-3 states:
Sounds like the inductors you had are too small for battery application but maybe big
enough for wfc.
Also, I saw a reference that the capacitance of the inductor should be more than the
capacitor.
I see absolutely no proof of this claim. Probably idea for taking advantage of concept
but.... That isn't Meyer's words, that is from some stuff posted at: OS:Water Fuel Cell
- PESWiki
page 6-3
"axially (spiralled) Bifilar wound about core bobbin (502), forming individual spiral-
wrap (inner to outer circumference and being equally-length) coils (501a xxx 501n)
electrically connected in sequencial order to form resistive pickup coil"
That means PRIMARY, SECONDARY AND BIFILARS (can be) on same core so
they are wrapped around a core and not flat style. At least in this description. The tech
brief is a compilation of just about all his chronological events.
7-4
The circular-spiral turns of wire (forming parallel electrical surfaces) is separated by
an Insulated Dielectric Coating Material which forms a series of capacitors (Cda xxx
Cdn) when magnetic flux-lines (619a xxx 619n) produces Electromagnetic Coupling
Field (621) during pulse on-time (Tl), as illustrated in (640) of Figure (7-3) as to
10-2
The resultant Amp Inhibiting Circuit Figure (10-1) as to Figure (10-3 A/B) further
allows amp restriction (minimizing current leakage) to be continued even if applied
"Voltage Amplitude" is increased. The length and diameter size of the copper-wire
spiral wrapped coil (56/62) of Figure (10-1) being paired together and electrically
energized in conjunction with applied Voltage Pulse-Frequency determines how
much "Amp Leakage" will occur across capacitor Gap (Cp) while "Voltage Pulse-
Potential" (Va xxx Vn/49a xxx 49n) of "Opposite polarity" (B+/B-) is/are allowed to
be applied across "Electrical Voltage Plates" (Voltage-Zones) (66/67). To reduce amp
leakage still further, the copper wire of both Resonant Charging Chokes (56/62) can
be replaced with an magnetically ~ductive stainless steel wire (430F/FR) having a
resistive value (Ohms) to the flow of electrons while taking on the capacitance and
inductance characteristic of a coil wire. VIC Bifilar Wrap Coil-Assembly (10-3B) and
VIC Dual Coil Wrap-Assembly (10-3A) both utilize either "E"& “I” and "U"
Inductance Core configurations to concentrate Mutual Inductance Fields (Rp l/Rp2) in
order to optimize Amp Inhibiting Process (750) of Figure (7-14). "E" “I” core shape
(10-3B) is most preferable since amp spike surge is minimize during repetitive
pulsing operations.
Many examples he gives of primary/secondary and both inductors on same core. NOT
pancake style...so misinformation by anyone who says it is?
When primary is pulsed ON, the magnetic field in the core that is created will cause
the inductors to charge instantaneously and NOT just from the + potential moving into
the inductors. It will be both. Also the OFF pulse inductive collapse moving forward
is NOT just the from the inductors alone but the field created by primary coil turning
off collapsing.
I think this is the direction to go... too many references by Meyer himself where all
the coils are on the SAME core.
If both are bifilar, then primary/secondary are wrapped together and the 2 chokes are
wrapped together.
When + pulses into primary at the top into the light blue wire, the primary coil will
have a NORTH field at the top...you can see how the wire comes off the core and are
wound that there will be north at top so SOUTH at bottom of primary in this situation.
If secondary is wound together, the BOTTOM wire will need to go through diode to
POSITIVE CHARGING CHOKE, which will give a NORTH field at the BOTTOM
of the pos charging choke...like in the square coil.
The right diagram with the pole core is just a visualization easier of what is really
happening with magnetic field in core.
Anyway, the charging pos choke will have south at top. The negative choke will have
the identical field as the pos choke.
A BENEFIT of this arrangement and the only one that makes common sense is that
when the primary is charged with north at top that follows around to the south part of
charging chokes and up through the chokes and back to south on primary. so in the
SQUARE coil diagram, you see that the magnetic field goes north in the
CLOCKWISE DIRECTION.
Not only does the chokes charge from the potential going into the chokes from the
secondary, BUT, they also get a kick from the magnetic field of the CORE being
charged from primary will will give a BOOST to what is happening in the chokes.
THIS AMPLIFIES THE CHOKES.
When pulse turns OFF, charged chokes collapse in SAME DIRECTION because of
blocking diode, which is the same thing as opening a switch and disconnecting the
chokes there. Therefore, they will find ground in the FORWARD direction to
"negative"on secondary.
During OFF pulse, primary also collapses and secondary directs that into the chokes
also in the forward direction.
For each time you pay for ONE pulse into the system in this arrangement, you get
TWO pulses to the WFC capacitor.
Kenny, I have not tested any common core systems yet. Just been looking exactly at
what Meyer was doing and this seems to be it based on his own words.
If I were to do the one on the right with the straight open ended core, I would
probably start with bundled welding rod...should let go of magnetic field pretty quick.
That is all I used in the Bedini coils.
Ok, first I am going to start off saying that Meyer's used some energy. Meyer's states
in the tech brief that he uses 12Volts@3.3Amp =40w on the primary side of the
step up transformer, and at the wfc he is using 40kv@1ma=40w, so TOTAL
POWER USED IS 40 WATTS. You can also watch Meyer's New Zealand lecture
to verify this, witch Murray has so kindly embedded in the top right of his web site,
witch I think is awesome, because it is Meyer's most informative lectures and gives
the most clues on the VIC construction.
I have come to the conclusion that the chokes are the only part of the VIC that
restrict the amps and keep the amperage at a minimum even when out of
resonance. When you get the VIC in to resonance simply by tuning the frequency(no
need to tune the chokes or cell) the voltage will over come the resistance of the
VIC(meaning voltage will go to it's maximum).
I believe this is the most important thing the understand and remember about the
chokes; Meyer's states in the New Zealand Lecture and the tech brief that the chokes
are restricting the amperage using MAGNETIC FIELD, and any amperage that
the magnetic field does not restrict the RESISTANCE will!
So now we know that magnetic field is the big player in stopping the amps and
resistance is the next biggest player in stopping the amps. "Now you have to learn to
ask the right questions"(one of my favorite quotes from Stan). So, how do we create
the strongest magnetic field? This is were the bifilar coil comes in and your
knowledge of inductor. I will get in to this in a little bit... So, how do you increase
the resistance of the bifilar chokes and still comply to KISS and the law of
economics? Well, since Meyer's clearly states that stainless steel wire is NOT
necessary to increase the resistance you just have to use smaller gauge copper
wire.
Ok, now that you know my understanding of the chokes I will go in to more detail
about its physical construction. I am not going to give you exact measurements
because I have none yet. I am still working on this myself, but I have done some
experiments to know that this is correct.
First I will explain the bifilar coil. The bifilar coil is wired to the wfc so that the
coils will be electronically and magnetically oriented in the same direction
(Meyer's states this all over the tech brief). Meyer's has a diagram with the chokes
orientation (the dots at the end of the cokes north pole) on figure 7-1 on page 155 of
the tech brief. I also included a diagram of how you connect the wfc to the chokes
called "NEOGEN BIFILAR with wfc (this does not show the right physical
construction of the chokes just how to connect it)".
Now I will give you guys an idea on how much resistance and what size wire should
be used for the chokes. Meyer's states that 11,600 ohms per choke is a typically
enough resistance to inhibit the amps. I am think about using 44awg wire to
construct the chokes. Since 44awg is 2,593 ohms every 1,000ft
(11600/2593=4.473*1000=4473) that would be 4,473ft of wire per choke. Now you
might think that is a lot of wire to wind (lol, by hand yes it is.), but if you construct
the chokes correctly you should be able to fit it all on, and Meyers states that the
more wraps on the chokes the more voltage you will get out of them. Now you
don't have to stop at using 44awg wire, you could go smaller but it just get more
difficult to work with. Sound like to small of wire huh? But it's not because we just
want voltage not amperage.
Last but not least the physical construction of the chokes. I am just going to point you
guys to a couple of figures in the tech brief and just get you a little explanation on
them.
First look at figure 10-4 on page 200. Figure 10-4 is actually two pictures in one. The
skinny black wires are the schematic for the chokes (ignore all label on this schematic
for how to connect the choke because it is very unclear and almost misleading). The
Picture behind the schematic where the coils are cut in half so you can see the cross
section of each section is how the chokes would be physically wound. Keep in mind it
is still just a diagram so it is not the actual size of the wire nor the only amount of
wraps you can put on each section.
Now look at figure 6-1 on page 135. I know this diagram can be really confusing,
because you have to look through all of the magnetic field lines that Meyer's drew.
This diagram is also when Meyer's was starting to refine his VIC to be compact and to
cause instant explosive energy from the water (his spark plug injector), but it is not
necessary to include the step up transformer for just making enormous amounts
of gas, and still possibly causing instant explosion of water. This will give you a good
idea about how to construct bobbin for the chokes. Notice how close the section
are to each other.
Ok, last comment. Because the chokes are electronically and magnetically oriented in
the same direction this means that the positive and negative will be aiding each other
and causing about double the voltage. Meyer's has a good diagram figure 10-5 on
page 200 of what the voltage is doing at the end of the chokes.
IF THE CHOKES ARE NOT BUILT RIGHT THE WFC WILL NOT WORK RIGHT
AT ALL. AMPS HAVE TO BE INHIBITED TO GET THE VOLTAGE TO GO
TO MAXIMUM BECAUSE THE WFC ACTS LIKE A SMALL RESISTOR
MORE THAN A CAPACITOR!
"the VIC allows the water to become a component part of the circuit as resistance" .
Hope this helps you guys understand what I have learned. Good Luck to ALL!!!!
- this is a very good schematic of the chokes and electronic reactants minus the
resistive properties. By JH:
Hi Gary, The definition of 'resonance' that I like is Tesla's definition of resonance and
it is this resonance that applies to these devices: The frequency at which the least
amount of current is necessary.
Basically, the whole circuit is SYNCHRONIZED for optimal performance. When the
circuit is in resonance, everything is synchronized optimally. Has nothing to do with
the common idea of a resonant circuit. This includes every single component in the
whole device ... everything from the initial input to the water cell. Same applies to the
battery charging device I'm talking about.
By 'regular electrolysis', I meant that it sounds like the gunk is coming from common
current electrolysis. Not implying that there is an uncommon electrolysis. The most
current test I did, I used a variable AC which has a 5Amps max and 150V max.
Output through bridge and pulsed DC through a diode and that straight to my tube
setup. This was only to test the cell. Without the inductor, current of course jumped up
to 3-4Amps at only about 7Volts. When I put the inductor after the diode, I could
crank it up to about 25Volts and the amps were only as low as about 400-
500milliAmps. Just had to see for myself that this was happening.
Not charge batteries to overunity, but compared to the input joules and the work in
joules I get out of the battery after it is charged ... it is overunity! Nothing magical
about it. It is because it is being charged with voltage potential ... virtually no current
is leaving the input source, only voltage potential. I can explain more details soon.
The battery can be charged with wall AC or from another battery. Before the input
battery dies (which it will at 98% efficiency), you can charge at least several batteries
of the same capacity. That is because it isn't taking power from the first battery and
putting it into the secondary batteries. The input battery is ONLY sending a trigger
pulse to a transistor that self oscillates at hogh frequency pulsing an electromagnetic
coil that is a 1:1 ratio and the reverse wire catches all the potential spikes (NO
CURRENT) and puts it into a capacitor. When the capacitor is up to a high enough
voltage potential, it is dumped to a battery needing charging. You charge the battery
with all that potential energy and NOT with current. Sound familiar with Meyer's
circuit doesn't it?
Imagine this and you can all test it for yourself. Hit a capacitor at high frequency with
nothing but the voltage potential spikes and it WILL charge up, however, there is no
current moving. Sounds strange but I can go into details later. Just thry it and you will
see. How can a capacitor charge up without current? That is what you're all trying to
do with the water cell. You're charging it with pure voltage potential and NO current.
Imagine having an input that is voltage potential spikes as well and no current ... very
very very efficient! I will share schematics soon.
I'm talking about pure radiant energy. Radiant energy ARE the voltage spikes you
make. Those spikes are radiant energy with NO electrons. There is a small amount of
current in these systems and that little bit is just enough to rip the molecules apart and
it is pulsed so there is no steady current. On the collapse, all those molecules have
access to a sea of potential radiant energy that have been pumped into it.
the radiant energy comes from vacuum energy. The virtual photon flux of the quantum
mechanical vacuum. The dipole (battery, etc...) breaks the symmetry of the virtual
photons and they move towards the pole on a battery and flow over the wire. The
power to power a lghtbulb from a battery does NOT come from the inside of the
battery. The electrolytes do ONE thing and ONE thing only. Separate thair internal
charges to create a high and low potential at the electrodes. It is the vacuum energy
form 3d space and time that move toward the electrodes and over the wires. This flow
is what induces the electron movement to have current. That flow can be manipulated
to move over wires in a way that induces NO electron movement, therefore there is
NO current, only voltage potential moving over a circuit! Very exciting!
Meyer's is an overunity system. If you calculate joules of energy that went into the
system, that would be input joules. If you calculate the joules of work that a certain
amount of produced gas can perform, it will dwarf the input joules. This is overunity,
he isn;t going to come out and say it but it should be obvious to everyone. Hope this
helps.
In a following post, page 19: ... I am confident though about the concept of what
Meyer was doing. Pumping radiant potential into the water with no current or at least
a bare minimum. 4,798,661 patent has the schematic that is nearly identical to the one
used for battery charging.
The coils I'm using are 1:1 turn. 12Volts in and the collapsed pulses are nothing but
pure potential spikes of about 250-300 volts but virtually no Amps. Those are going
through a bridge to charge a cap. When the cap is charged up, it is discharged into
dead batteries. How can that be if the turns are 1:1? 1:1 is the most efficient coil for
producing the radiant spikes that are devoid of electrons. ...
(MDG no07: I remember reading about Stanley Meyer that met with John Bedini in
the 80's. Off course being in the same country, working both in the small world of
'exotic' energies, it was easy for them to come to discuss about the subject ... Bedini
was and still the leading expert that practicaly harnesses Radiant Energy in many
ways, and I wouldn;t be surprised to discover that he taught a few tricks to Meyer, and
that may explain the confusion in the differences of processing between patents of
Stanley. Could it be possible that first he used the 'potential breakdown level' of his
capacitor/cell, and then after getting breefing from John, he improved his system to
harness Radiant Spikes. Also, his third stage of improvement, the 'Nuclear Thermal
Energy', could come from meeting with David Hudson that discovered the ORMES,
also in the 80's, that are present everywhere, especially in water, and that have a
potential of nucleus explosion, through the 'maximum chagre breakdown level' known
to exist in superconductors ... too much energy accumulated inside and they explode
in a nuclear blast, as Hudson discovered... But have to say that this explosion
produces dangerous gamma rays, when Meyer said there were none of them produced
in his technology)
This pdf covers Qiman13 posts from 'Fri Sep 10, 2004' to 'Sun Mar 13, 2005', for a
total of 509kb, 81 pages.
- qiman13, Posted: Fri Sep 10, 2004 3:31 pm Post subject: Secrets of the Water
Cell Explained!!!:
Hi Everyone, new to the board but have somethongs I want to bring to the surface.
Below was posted in Dave's Cell folder. I added more below that.
Hi Gary, what material is your plates or tubes made from? I use t304 steel tube setup
and I get no gunk. The only thing that even appears to corrode are the non ss leads
that connect to the positive tubes.
Also, if getting gunk, then most likely you are getting too much regular electrolysis.
The idea is to prevent current from doing that. Therefore, no oxygen can go to your
positive plates/tubes and oxidize them.
I'm new in the group and would like to tell you that I have a circuit virtually
identical to SM's. It was developed by someone that I have learned from over the
years. It isn't used to make fuel from water but is used to charge batteries
overunity. I can post the schematics soon as appropriate. I also have other info to
share if you're interested.
The circuit is not a resonant circuit. The water doesn't go into some magical
resonance. The blocking diode should be telling you all something. No resonance
(at least not the circuit). The voltage never drops to negative.
3 very good basic examples. Unidirectional DC pulses are not transverse waves.
They are longitudinal impulses. The whole secret is sending TIME IMPULSES to
the water. What the goal is is to pump the water with radiant energy. This is
nothing but pure voltage potential with no current. When it is done right, you can
create the voltage potentials without ever inducing electrons to flow to begin
with.
How? We'll get to that. Imagine not having all the problems of having to restrict amps.
I will be happy to share this with anyone who is serious. Let me know what you think.
I've observed in this board some comments I would like to comment on. I saw that
someone mentioned that Meyer was flawed in saying the inductor increases
frequency. That isn't a flaw, of course it increases frequency when a pulsed input is
put into it and there is a blocking diode. One pulse is given and it goes through the
blocking diode, charges the inductor and gets to the cell with less amps. That is one
pulse. When the pulse is cut off, the inductor collapses in the SAME direction because
the blocking diode prevents it from going opposite polarity and this is pulse #2 going
to the cell. You paid for one and got 2 pulses.
For example, lets just stick to straight wall cycle. 60hz going into the bridge to turn it
into pulsed dc will be 120hz pulsed dc. Remember that there is one dc pulse for each
half othe ac. 120 hz pulsed into the inductor will get 240hz at the cell. So, the
freuency is increased by using the inductor. Of course we want higher frequency than
this, but this is only for an example.
The secret is pumping radiant energy into the water and this puts it into a higher
energy state. You're swelling the water up with the Aether.
Each time a coil is given a pulse, there will be a certain volt and amp over a certain
time. When the pulse is shut off, the collapsed SPIKE is pure voltage potential with
no current. That is why it is virtually a straight line.
You're converting work back into potential. The spike is time compressed
energy...pure Aetheric potential or radiant energy. Think about it...you're turning work
back into potential. It is the radiant potential that you are wanting to pump into the
water unidirectionally.
Frequencies are important but that is a case by case situation. Based on cell spacing,
material of it, voltage, etc... there will of course be optimal frequencies for each
system and they will all be different. It has nothing to do with a magical frequency
that water will mysteriously separate at. There are frequencies that can do that but that
isn't what Meyer was doing I don't believe.
It is essential to understand what energy is and that energy is NOT the capacity to do
work, what electricity is and to realize that there is no such thing as
electricity...electricity is truly an adjective to describe an event...where the source
charge comes from and for example if you power your system with batteries, the
charge does NOT come from the inside of the battery...it is important to understand
what a dipole is and how a dipole gets a flow over wires. It is a myth that we don't
know where the source charge comes from. These things are really necessary to
duplicate something but if you understand the above and a little more, it will be
overwhelmingly obvious what Meyer was doing. It is obvious he didn't know but he
still got results.
The patents are there to give the concept, not the actual working model. Same as the
xogen patents. It will not work using the exact same circuit and input of 12v, etc... that
shows the concept of what they are using but that doesn't mean their working models
are that same circuit.
For example, the battery charging method I'm using for overunity gain...this is how to
measure it. measure the joules of input energy from the input source over a given
time. When the battery is charged, power a resistive load (light bulb) from it and
measure the joules being used to light that bulb until the battery is back down to the
voltage that it was before charging. The joules will be more than what left the input
source. This is overunity. Hundreds of % in fact and up to a few thousand is possible
without a doubt.
This is what the fakes out there want you to measure: Well lets measure the input and
hook meters to the output of the circuit and measure that hundreds of volts, etc... that
is all BS. The ONLY honest way to test this kind of thing is measuring WORK.
Measure work in and then measure usable work AFTER the battery is charged. You
can't directly measure potential like this with devices becaue there aren't any devices
that can measure pure Aether. The devices we use .... and this is important... only
measure wasted energy. They all want to hook the output of the circuit back into the
input source (battery) or whatever and have it run itself. That is ridiculous...that closes
the loop and kills the dipole. Anyway, this is my 2 cents.
There is one book that spells out word for word what Meyer's is doing, what Gray did,
etc... that is chapter one on Tesla in this book:
http://www.amazon.com/exec/obidos/ASIN/0932813801/yokotahighschool
That book was used as a Rosetta stone to cracks Grays patents and therefore revealed
some of Teslas secrets.
- qiman13: Posted: Fri Sep 10, 2004 4:58 pm Post subject: correction:
I meant to say that it is NOT necessary to know about what a dipole is, etc... to make
the things work. It is only necessary to easily see what Meyer and other were doing.
Qiman, you can see that the frequency is NOT doubled, but the dc supply voltage
across the capacitor is! You can see what Meyer was trying to achieve with this,
doubling the supply voltage pulses while the inductor naturally limits the current - it
even shows the step charging sequence. This explanation of the circuit is far, far better
than anything Stan ever wrote in his wild babblings.
The blocking diode simply serves to stop the capacitor discharging in the opposite
direction through the inductor once the capacitor is fully charged.
As I see it, the flaw with this circuit when applied by old Stan to his wfc is that of
course, the wfc is NOT much of a capacitor, more of a resistor.
Pure water makes a great dielectric, with a dielectric constant of around 80 and a
breakdown voltage in the order of thousands of volts per mm, but tap water conducts
very well as we all know. Just 240v mains provides a very healthy current - or
unhealthy if you happen to be in the bath when the hair dryer drops in!!!
Having said all that I intend to play about with the dc resonant charging circuit and do
some proper tests as it might be there is enough of a capacitance to still provide a
substantial step charging effect. I don't really expect this to be the case tho as the
resistance offered by my electrode set up is at best much less than 1 ohm!
However, I find that putting things actually into practice often throws up info, ideas
and insights that don't always reveal themselves on paper. All the best
- qiman13, Posted: Sat Sep 11, 2004 1:40 pm Post subject: What a dipole really
is:
Gary, I can understand your explanation of charge carriers, etc... Let me ask you
this...when you measure voltage...what are you measuring? Electron charge or voltage
potential? They are two totally different things.
First of all, where does the source charge come from? Isn't that the big mystery with
"electricity?" We all are told and we can all observe what this mysterious charge does
but no textbook can explain where it comes from?
It is claimed that the electrolytes in a battery create some chemical reaction that
produces an electrical charge and this electrical charge is what goes out of the battery
and over the wires and powers whatever is connected to the battery. This would of
course be a bare bones explanation of what a battery is. Is this really what is
happening?
Now, we are immersed in a sea of energy...then what? This sea of energy is filled with
virtual photons - called virtual because as soon as they are there, they instanly
dissapear. So they are in a state of flux...popping in and out and ridiculous speeds.
Perhaps they are traveling like a mobius strip..1/2 here and 1/2 there, whereever that
may be. Anyway, by the fact that they have a positive charge, there must be a virtual
negative charge as well for obvious reasons. How do we tap this energy? We do it all
the time and don't even know it.
When you have a battery with electrolytes, the electrolytes do ONE thing only. That is
to separate internal charges so that + is on one side and - is on the other side. Each
terminal on a battery is connected of course to each side of the electrolytes by
connections. The terminals will be + and -. That is a potential difference and that is
what makes a battery a dipole. The electrolyte charges that were separated are NOT
the charge carries of some mysterious charge that goes out the battery to power
something. That is a myth. They only establish a dipole.
Now that we have a dipole, then what? The vacuum energy is very symmetrical in
nature. Pretty much the same throughout in all directions (generally). With a battery -
a dipole - sitting inside of 3d space and time where this Aether or vacuum energy is,
the symmetry of the photon (different from regular light photon that we see) energy is
broken. One polarity of the Aether goes to one pole and the opposite to the other pole.
If nothing is connected to the battery, the Aether radiates outward spherically in all
directions at the speed of light.
If a light bulb is connected to the battery, you close the circuit. The Aether at the +
terminal flows over the wire towards the - terminal and induces the electrons to flow
that pile up at the filament of the bulb and turn to photons that radiate out as light.
There is ALSO the opposite polarity flow that goes out the - terminal towards the +
terminal butting heads against the flow. This is what breaks apart the electrolyte
charges so that the strength of the potential difference of the electrolytes get less and
less. This is what kills the battery because the loop was closed and the circuit is
caused to kill its very own dipole. It was not killed because some mysterious charge
was used up in the battery.
This flow is called the Poynting flow usually designated a j-phi I believe. Heaviside
also knew of this flow but he actually got the vectors right. I'm please to see that Dave
understand Heaviside. Also, the amount of flow that goes over the wires...only 10 to
the -13th power (1/11trillionths) of it gets diverged into the wire to move electrons to
the surface from the copper atoms 3rd electron field. Imagine that!
Every atom is literally a perpetual motion device. Where do you think the electrons
get the energy potential to sustain their perpetual motion? Look at the mass of the
electron, it sure wasn't given some incredible push that keeps it in motion. It is
sustaining by interacting with the Aether.
Once something is set into motion, it will stay in motion unless it is acted upon by
something else. This literally permits perpetual motion.
It never said that once something is in motion that it will stay in motion until
something acts on it, which most definitely will happen.
Anyway, overunity doesn't have to have a single thing to do with perpetual motion.
Anyway, That is where the flow comes from to light a light bulb and NOT some
charge carriers inside the battery. I don't blame you for your explanation of that
because that is in fact what is taught. Does that mean that they are correct? They first
tell you that is what holds the charge and turn around and tell you it is a mystery
Take a bathtub, fill it up and put a plug in the hole. It is all nice and symmetrical. pull
the plug...make a potential difference and the water goes towards the hole and down
the pipe. You broke the symmetry of the water. This is EXACTLY where the battery
gets its source charge from except not a pipe..flowing over a wire at light speed while
the electrons that are induced into movement only move at inches per hour literally!
You can read Lee and Yang's presentation speech as they were given the Nobel Prize
in Physics in 1957. http://nobelprize.org/physics/laureates/1957/index.html
"for their penetrating investigation of the so-called parity laws which has led to
important discoveries regarding the elementary particles"
It is because of their work that we understand that a dipole breaks the symmetry of the
Aether. That is where the source charge comes from and not electrons.
The Aether moves like a gas under pressure. It is a conductive gas that is conductive
to + and -. If you have a battery and you put a voltmeter on it, you get a volt reading.
12vdc for example. That reading has nothing to do with a charge in the battery. When
connecting the leads to the meter, the Aether flows to the terminals and over the wires
on the meter and that induces electron flow in that circuit. You are literally taking a
pressure reading of the gas. Voltage is nothing more than the pressure of the flow of
the Aether over wires. It has NOTHING to do with electron charge.
To clarify, a battery can be charged with hot current..electron current and you will
have electrons piling on plates. You CAN also charge a battery in a superior way by
charging it with cold current, which is void of electrons. This is a fact. The battery
never warms and either does the circuit charging it.
Likewise, you can charge a cap with hot current or electron flow and those pile on the
plates. Depending on the potential difference between the plates because of the
electrons you will get a potential difference. That is true.
However, you can charge a cap with "cold electricity", which is void of electrons by
spiking the cap with PURE VOLTAGE POTENTIAL and NO ELECTRONS and the
cap WILL charge up. The pressure of the aether here is what is measured when using
a voltmeter. It is not measuring a potential difference between plates on the caps
based on electrons on one plate. You can charge the cap both ways. One, you will
have a cap that will be warmed up and one will be room temp.
Think about this. You have a little bitty battery and you have a monster battery. They
obviously would have an enormous difference in the amount of charge if it was like
the establishment teaches. Both batteries can read 12volts brand new. Therefore, it is
not really measuring a charge at all because if it was, the bigger the battery, the bigger
the charge and the reading would be higher. We know that is not the case.
I hope this clarifies what voltage potential really is and what a dipole is and what the
voltage is NOT. This understanding jeopardizes oil money as it has all along.
Remember, Morgan said to Tesla...that's nice Mr. Tesla, but where do we put the
meter? They want everyone to believe energy must be a non-renewable consumable
and have everyones mindset tuned to scarcity and lack of instead of abundance.
- qiman13, Posted: Sat Sep 11, 2004 3:46 pm Post subject: inductor frequency:
My understanding may be off on this. I'll put a scope before the blocking diode and
check the frequency and put one after the inductor. I guess that will be the easy way to
really tell what the difference is in frequency if any at all.
If the frequency is not increased after the inductor, that means the collapsed field is
seamless with the initial applied pulse. I find that hard to believe but maybe that is
what is happening.
If that is what is happening, that means there may be a steady DC flow to the water
cell and that means that no matter what frequency you put to the water cell, there will
be only steady dc if the inductor is not giving a separate pulse on the collapse. If it is
seamless.
Another possibility is that on the applied pulse,the water gets hit. When the pulse is
off, the inductor collapses seamlessly at the end of the initial pulse so the pulse given
to the water is longer than the initial pulse by itself and the voltage goes up. When the
collapsed pulse is done, then another applied pulse comes and does the same thing so
the frequency wouldn't increase but yes the voltage would.
- qiman13, Posted: Mon Sep 13, 2004 1:57 pm Post subject: inductor test:
Gary,
I read page 1-1 in Meyer's book. First line "Using VOLTAGE POTENTIAL." I think
nothing else is necessary to read in that book. Iwill though. That is the whole secret.
That is time impulses, which are unidirectional dc longitudinal impulses. That is what
POTENTIAL is. All his info is only about how he is creating voltage potential to
pump into the water. If you know what voltage potential is, you got it.
If electrons pile on plates and this makes the difference between the other plate and
this is what the voltage is. Please explain this. With X amount of volts and X amount
of amps going into the water cell, you're going to get X amount of electrons piling on
one side. However, when putting an inductor after the blocking diode, you can get a
higher voltage with less amps. The inductor reduces the electrons in the cell but the
voltage can be higher?
The voltage is not directly tied to electrons on the plates. Doesn't this simple thought
experiement show that voltage doesn't have to have anything to do with a certain
amount of electrons on a plate that has a certain socalled "charge?"
On page 1-2, Meyer says the LC circuit "tuned" to resonance @ certain frequency...
This doesn't have anything to do with LC resonance. This is what he means: Based on
a given cap and a given inductor, there will be a certain frequency that the whole
system will operate at "peak effieiency" meaning that at that frequency, the minimum
amount of current is used meaning the minimum amount of electrons. That would be
EXACTLY Teslas definition of resonance. For a given cap and inductor, there will be
a frequency that minimum amount of amps is used. To see what the resonant
frequency is for a given setup. Monitor amps input.
Turn the frequency up and down. Whatever frequency the amps is at minimum going
to the cap from the inductor, that IS your resonant frequency and will be different for
everyones setup.
- qiman13, Posted: Mon Sep 13, 2004 2:50 pm Post subject: inductor test:
I got results that were unexpected. The frequency was not increased after the inductor
that I used. The interesting thing was that the voltage remained identical. However, it
was negative spikes on the output of the inductor of the same voltage.
To read the other posts from Qiman13 on the subject, see the html version of this
file click here (same in the menu on top of page): Qiman13 Posts 1 - Qiman13 Posts 2
- Qiman13 Posts 3
INTRODUCTION: On August 27, 2007, as part of the PES Network Free Energy
Now http://freeenergynow.net radio series, Sterling D. Allan
http://peswiki.com/index.php/Congress:Member:Sterling_D._Allan conducted a 1-
hour interview with David Wenbert
http://peswiki.com/index.php/Directory:David_L._Wenbert with H2Earth Institute
http://H2Earth.org regarding his work with Water Fuel Cells
http://peswiki.com/index.php/OS:Water_Fuel_Cell , and his theory that the "over
unity" being observed in various electrolysis
http://peswiki.com/index.php/Directory:Electrolysis set-ups is closely related to the
reason for "over unity" being observed in some electromagnetic
http://peswiki.com/index.php/Directory:Electromagnetic set-ups.
- The following transcription and video were prepared by Matt Imber. (Complete
transcription in .doc format (for Word), 15 pages, 96 ko, is available from this link:
http://www.pureenergysystems.com/news/Radio/Free_Energy_Now/shows/2007/Tran
script--David_Wenbert--
Water_Fuel_Cells_and_Electromagnetic_Overunity_Similarities.doc )
- The Audio file of the interview, MP3, 13 Mo, at
http://pesn.com/Radio/Free_Energy_Now/recordings/2007/070827_H2EarthWaterFue
lCells_DavidWenbert.mp3
Our guest today is David Wenbert. He is the Founder and Executive Director of
the H2Earth Institute, and has been involved with advanced research for more than
20 years in energy research. H2 Earth Institute is in the process of replicating the
water fuel cell technology of the late Stanley Meyer, who ran vehicles on water,
and whose patents have just now become public domain. Mr. Wenbert is now in
the Washington D.C. area and is developing the H2Earth Institute and the companion
Trade Association for the emerging water fuel industry. In particular, he has a
theory or concept that these over-unity electric systems have a tight correlation to
the over-unity electrolysis systems that are being observed, that he’s been involved
in founding.
- Sterling Allan: [...] hundreds if not thousands of people have replicated what appear
to be over-unity electrolysis scenarios, where they’re getting more energy out than
what traditional electrolysis equations would say is possible, and apparently, there
may be some tapping into zero-point energy or some other energy source in the
process - and you’re saying that this over unity observed in electrolysis - and you’ve
been heavily involved in an open source project tool, to publish plans of how to do
these things as Stanly Meyer’s plans and others, and facilitating this massive
proliferation of the replication of this effect. But you’re saying that this is quite
similar to what’s going on with the over-unity electromagnetic systems.
- David Wenbert: Yes, the Hearth Institute has formed a group over 60 research
associates in 16 countries around the world. These researchers have all been
replicating the Stan Meyer Water Fuel Cell - the patents on which expired June 26th
(2007). We’ve had a number of successes; our members have been producing gas
at down at 1 ½ watt hours per liter and down below that -- 0.38 watt hours per
liter. Anything below 2.4 watts hours per liter is over-unity.
- David Wenbert: Yes, and the water fuel cell is a lot more complex than it seems.
There are many processes going on within it at the same time. Many people have been
confused by the way Stan Meyer referred to the use of resonance as the mechanism
that splits the water. It’s not a molecular resonance in the way most physicists or
chemists would refer to it. It’s more of an electrical resonance between the
resonance charging choke coils on either side of the water fuel cell in the circuit.
And we’ve found that the way those coils interact is virtually identical to the way the
coils in Tom Bearden’s motionless electromagnetic generator interact. And we’ve
traced this further, and it appears pretty conclusive that the electrodynamics that are
happening within the water fuel cell in Stan Meyer’s circuit, are the same that
are observed in not only Bearden’s, but Joseph Newman’s energy machine, John
Bedini’s motors - it’s all the same. [...]
- Sterling Allan: For the sake of those who are sitting at their computers listening to
this right now, or through the archives, let’s give out your website domain name.
- David Wenbert: It’s actually pronounced Hearth, the Hearth Institute is:
www.H2Earth.org
- David Wenbert: [...] Dr. Peter Lindemann, I think made a major contribution to this
field with his book: Free Energy Secrets of Cold Electricity. It’s really a detective
story, where he went back and found the connections between original works by
Nicola Tesla - which had nothing to do with Tesla’s more well-known contributions
like A.C. current and so forth. But some of Tesla’s lab notes referring to radiant
energy and electro-radiant events that were anomalous, and didn’t fit in with any of
the rest of electrical theory, but were reproducible. Dr. Lindemann then traced that to
the work of E.V. Gray and the Gray Motor, which definitely employed the same
mechanism -- and then, traced that further to Stan Meyer and the water fuel cell. And
the more we look at Joe Newman and John Bedini, and a hundred other inventors out
there - it’s the same circuit, it’s doing the same thing. These are not different devices.
And Dr. Lindemann and Tom Bearden, in his book Energy From the Vacuum, I think
-- just in the last few years -- are really bringing this together - to coalesce to the point
where industry can pick up this technology and begin turning it into profit.
- Sterling Allan: At the recent extraordinary technology conference, by Tesla Tech in
Salt Lake City in July 26-29 (and this is the year 2007 for people who are years
ahead of us, listening back, years behind), anyway -- Peter Lindemann was there with
a demonstration of a number of circuits that he’s come with that are actually very
similar to the Bedini circuit, but don’t involve the Bedini patent. And he has
actually published those, and that’s a story I’ve been sitting on and need to get around
to. I’ve been procrastinating a little bit, because it’s hard work to pull together
something like that in a comprehensible way. But he has done similar work in
showing some very amazing electrical phenomena that go far outside what
classical physics describe in text books, and which can make motors so much more
efficient, so you’re not fighting back EMFs, you can actually use the back EMF’s,
and get more mechanical output from your motor using much less energy. And he has
not published a complete set of plans about how to build an over-unity motor, but he
says if you piece together what he has out there, you can do it, he’s just not going to
tell you how to do it.
- David Wenbert: Exactly -- we call it the IDU, or Irrefutable Demonstration Unit,
and it will consist of a 3 kilowatt portable generator - just an off-the-shelf Honda
generator, running itself off of a water fuel cell. And the water fuel cell will be
plugged into the 10 amp (12 volt, 10 amp) DC auxiliary circuit. So, it won’t even
be running off the AC. And we should be at that point in the next few months - it’s
just a question of building a final cell that incorporates everything that we’ve learned
so far. Our findings to-date are generally posted on that page (at
http://www.watercell.info ), and if you look at the bottom of that page, there is a
graphic showing the input waveform that the water fuel cell requires (from Stan
Meyer), and above that, some oscilloscope tracings of the output waveform of the
Joseph Newman energy machine. And you can see at a glance that they are virtually
identical.
- David Wenbert: Anyway, that was the first clue, but since then we’ve found several
others. For example, if you go to Tom Bearden’s book: Energy From the Vacuum, on
Page 401, there is a diagram of the MEG coil assembly (Figure 7.5 on Page 401).
Well, that image is virtually identical to the voltage intensifier circuit in Stan Meyer’s
documents.
- David Wenbert: Now, I don’t think the word water appears anywhere in the 900
page book by Tom Bearden, and I don’t know if he ever talked to Meyer at all. And
Stan Meyer didn’t have the benefit of the work that Tom Bearden has done over the
last 10 years, in analyzing free energy, but, they still seemed to have arrived at the
same conclusion.
- David Wenbert: [...] That’s why I haven’t updated our website in a while because
this emerging understanding has been unfolding, and we’ve been trying to figure
out what’s the best way to present it. Various things like the Tesla switch are also
public domain technology, and we believe that, at some point, a master design can
come together that incorporates this into one practical device. The bottom line of the
water fuel cell is -- it really is a fuel cell. It’s not a misnomer. You just add water,
expose it to the universe, in the form of that radiant energy pulse, and it gives
you electricity. And you get combustible gas out of the byproduct.
- David Wenbert: Yes, properly constructed, according to what we know now, the
water fuel cell will consume no current. It will produce net current. What’s
actually happening there is, you’re achieving dielectric breakdown in the water,
over and over again - doing it with voltage. You’re not allowing any current to enter
the cell. When the voltage spike grows to a certain magnitude, it forces dielectric
breakdown. If no current is entering in from the cathode (which Meyer’s cathodes
were insulated, by the way), the electrons are ripped from the water to fill the
holes in the anode. And as you pull electrons out of water, water molecules break
down. First, you have ionization when they lose one electron, and then you have
disassociation when they lose 2 electrons. And that’s what happens in the water fuel
cell - over and over again. And all those electrons build up, and they’re drawn off
by what Meyer called the electron extraction circuit. And, so you’re getting DC
current out of the water fuel cell, and that electron extraction circuit -- in direct
proportion to how much gas you produce. Now if you want more gas, you fix it so
it pulls out more current, and vise-versa.
- David Wenbert: [...] - the simplest depiction of all of this is in a document that
was released on July 27th, 2007, by Patrick Kelly. Patrick Kelly, as you know, is
the editor of The Practical Guide to Free Energy Devices, which is now hosted at
http://www.panaceauniversity.org And his document - Number D3, (and it’s easy to
find at www.panaceauniversity.org), that document goes into various similarities
between the Bedini motor, the Tesla switch, and a patent by Harold Aspden (the
British physicist). On pages 25-36, of that descriery document, you see a walk-
through of the Tesla switch, which John Bedini first presented at the Tesla Centennial
Symposium in 1984. But, you’ll see diagrams that show just how the Tesla switch
circuit works between 4 batteries - keeping the batteries charged, while you draw off a
load. The more load you draw off, the faster the batteries charge. It’s completely
the opposite of a normal electrical circuit. It depends on the switching. But that is
the single, simplest embodiment of this same principal. And what’s going on in that
Tesla Switch was just a handful of transistors and capacitors. What’s going on in that
Tesla Switch is the same thing we’re seeing in the water fuel cell, it’s what Joe
Newman’s motor does, it’s what John Bedini’s motors do, it’s what the MEG does - in
the final analysis. Now, Joe Newman uses, what is in effect, a rotary mechanical
switch - his commutator. And Newman’s commutator is the secret to the Newman
energy machine. The coils and the magnets are amplifiers. That’s not where the magic
happens. It’s happening in the switch.
- David Wenbert: [...] Now, it’s also true that that commutator is probably a better
way of doing this than transistors and other discreet modern electronic components.
There’s certain things about this energy flow that may be difficult for elements like
MOSFETs and so on, to accommodate.
- Sterling Allan: Peter Lindemann’s circuit also has a transistor. It’s really quite
nifty how he’s redesigned that circuit to accomplish the same thing, but outside of the
Bedini patents. So that’s more of an open source type of beast than what Bedini’s is --
where there’s a patent protection.
- David Wenbert: And, there’s enough of it now in the public domain. You know,
even the foreign patents, which Joe Newman was awarded in various counties under
the patent cooperation treaty in 1988 - that patent has expired. So, with all do respect
to Joe Newman, his technology is in the public domain - at least what he’s exhibited
so far.
- David Wenbert: And Meyer’s and the Tesla Switch and so on. And from all this, it
should be possible for anyone whose got the fabrication and assembly capability to
organize a practical device. And that’s something that we’re looking at right now.
- Sterling Allan: M-hmm. What about the theory that’s put forth by Moray King,
who says that these electrolysis scenarios are somehow tapping into zero-point
energy. The gas clusters on an atomic level are creating a self-organizing criticality
that somehow gets the zero-point energy moving, and that’s the true source of energy
in these scenarios - NOT the water itself.
- David Wenbert: Well, yes. Like I said, the water fuel cell is complex. Not only does
the circuit behave like a Tesla Switch or the MEG, but in the water itself, when that
voltage spike is applied, but no current is allowed though it - what is happening in the
water is the same thing that’s happening in the circuit. It’s just happening all over
again. And that appears to be where you get this ingression of energy from the
vacuum -- in the quantum vacuum.
- David Wenbert: Stan Meyer, in one of his lectures, actually described it that way.
He said with that pulse, we’re opening a door, and as long as we can keep that
door open, the energy will continue to come in. But it’s very hard to do, and you
have to keep pulsing it, and keep opening the door over and over again. Well, that’s
the same thing as the Gray Tube in E.V. Gray’s Motor, and the same thing the
Newman Commutator is doing.
- David Wenbert: Well, yes and no. I mean at the simplest level, water fuel cell
seems the best description. It’s also been referred to as a water capacitor, although
there are more mundane, closed water capacitors for other purposes. I think that as the
understanding of these things comes together, and I’m talking just over the next 3 to 6
months, you’re going to see some very reliable, replicable demonstrations that are
going to make it irrefutable that the excess energy is real, and that it’s being used in
these devices. And then grudgingly, you’ll see the scientific establishment start taking
a more serious look at it.
- David Wenbert: [...] You have to remember, Stan Meyer died in 1998, and we’re
just coming up on the 10th anniversary of his death. He didn’t have Tom Bearden’s
papers to go by.
- David Wenbert: He didn’t have.. well, virtually everything that’s on the internet
now, in the field of free energy, didn’t exist 10 years ago. And I think that by finding
the keys to the phenomenology that we think we have now, the water fuel cell can
be made simpler and more reliable. And ultimately, you won’t need -- for a home
power system for example… you know, we were envisioning: you’d have a water fuel
cell, and you’d take the gas and you’d run it through a microturbine, and the
microturbine would generate electricity, and with the waste heat, you’d heat your
water. So you’d have a home power system not unlike a Generac - or one of these
things on the market today for backup power that you can buy at Home Depot. A
microturbine would be better than a piston engine for reliability reasons, but that’s
beside the point. Anyway, that’s where we were, looking at doing with the water fuel
cell - was getting it to the point where it can be used for home power, in that regard.
But now, as we’ve studied it further - in the relationship to the electrical power
that comes out of the cell, in the electronic extraction circuit, it could be a lot
simpler than that. It could just be a question of having a battery bank, like you
would if you had solar PV panels on your roof - where you have a dozen
batteries, or 20 batteries, and an automatic transfer switch, and inverter, a
charge controller, and voltage regulator. You know, all this stuff is off-the-shelf in
the solar industry. (36:34) You’d have that same system, but there would be a water
fuel cell, and the current thrown off by the water fuel cell would keep your
batteries charged, and the batteries would go to a 12 volt inverter, and convert it
to 120-volt AC, to run your home.
- David Wenbert: In that case, it’s almost like the gas becomes irrelevant, but yeah,
you can use it in your HVAC system, you know, in an absorption chiller or something
like that. In an automobile, it’s just the opposite. There, you would use the gas in the
internal combustion engine, and the fact that it’s generating a lot of electrical power,
well, you’ll make use of that in some way, perhaps a hybrid vehicle is ideal for use
with this.
- Sterling Allan: So, you said it a number of times that apparently bears repeating - I
had not appreciated - that the water fuel cell is not only generating gas, the
hydrogen/oxygen coming off of the broken bonds from the water, but you’re
saying it’s also generating current.
- David Wenbert: Yes, as a matter of fact, one of the things that became apparent in
our research is that you can not neglect that electronic extraction circuit -- you
NEED to pull that current out of there, because every electron that’s left in the
water is inhibiting ionization and disassociation from occurring. That’s why the
pulses are timed in such a way that they keep the current from entering the cell.
And the cathode that the electrons would normally come out of, is insulated in
Delron. Stan buried that in his documentation. It was hard to figure out he was
doing that, but yeah, the sort of bounce-back and the resonant effect is the
primary factor in keeping the current from entering, and the Delron insulation
prevents any leakage beyond that. But meanwhile, as the result of ionization and
disassociation, you have this free electron current that arises in the solution. And
the way the circuit works is, when the high voltage pulse is off on the anode, the
Electronic Extraction Circuit kicks in; because the electrons can’t all move
through the water fast enough to get to the anode during the pulse. So the EEC
draws off this free electron current, and you can power a light with it; we’ve had
people use it to run motors & fans and pumps and so on. But it’s very important,
because otherwise those electrons will build up and change the nature of what’s
happening chemically, and inhibit the process.
- David Wenbert: I think that if a home power system based on free energy, whether
it’s the Tesla Switch, or whether it’s a version of that involving the water fuel cell -
either way, you’re going to be able to do with a little green box for $2,000 what you
would otherwise need $20,000 worth of solar panels to do. Now, the balance of the
system is all pretty much going to be the same, and we’re fortunate our friends in the
solar industry developed this to a high art - and there are a thousand installers around
the country, who put these things in every day. You know, the battery bank, and its
associated electronics is now something you can buy out of a catalog from a dozen
vendors. That wasn’t the case way back in the 20th century.
- Sterling Allan: In our video that we’re putting out here in a couple of days, there’s a
snip showing Xogen technology (spelled Xogen.com is their website). Or, actually, I
think it’s dot… (David & Sterling together: it’s dot CA I believe). Yeah, they lost their
dot com. Anyway, they are claiming to use the technology not to produce gas, but to
purify water.
- David Wenbert: Well, yes, and you can do that with high voltage in water. It
doesn’t mean that they have real water fuel technology though, unfortunately. You
know, there are a number of companies doing that sort of thing, and we refer to it as
exothermic plasma synthesis. They all have different trade names for it. You’ve got
companies like StarTech.net, and U.S. Magnagas.com. There are a dozen others, and
they use a high voltage discharge under water to produce combustible gas. And what
they’re doing is - carbon based. Most of them are using carbon, or graphite electrodes,
and the electrodes ablate and you get COH2 out -- carbon monoxide and hydrogen in
a loose bind, and it is fairly clean and very efficient. But the graphite electrodes are
expensive. That is a field that we’re interested in, but that’s not really the same thing
as the water fuel cell per say.
- Sterling Allan: Ok, so the idea that water fuel cells could be used clean the water,
while also providing energy is a bit misplaced?
- David Wenbert: Well, no. I mean, one of the things we’ve uncovered is that you
can use any water in this thing. I mean, first, when we realized that Peter
Lindemann was correct, and that the dielectric break-down in the water was the
key, our people started all using distilled water, and triple distilled water, and
isotopically pure water, and so on. But, that only matters if you’re passing
current through it. And we realized that, no - there is no current being
introduced into the water fuel cell, because the cathode is insulated. Then we
realized that Stan Meyer really was correct when he said you can use sea water.
It doesn’t matter, you just adjust the parameters. But when the water is…
whatever it’s resistively is, or how conductive it is - it doesn’t matter. You can still
achieve dielectric breakdown if you drive it with enough voltage fast enough.
- David Wenbert: Well, Stan Meyer and Yule Brown were contemporaries. They
were rivals. They were going around the same time in the ‘70’s and ‘80’s promoting
their technologies. There’s conflicting evidence about whether the gas coming out of
the water fuel cell is really Brown’s Gas or whether it has the same unique properties
as Brown’s gas. That’s going to take some spectroscopy to really get a handle on that,
and we plan to do that in the future. Brown’s Gas machines typically operate at about
3 watt-hours per liter. With the water fuel cell, we’re seeing at least twice as efficient,
and ultimately, many times more efficient in producing the gas, although studying
Brown’s Gas has told us a lot about what is going on in the water fuel cell. Brown’s
gas is ionized. And the Brown’s Gas flame is impinging on something - it’s
transferring a charge. That’s what accounts for all the bizarre properties of Brown’s
Gas. A normal flame, whether it’s a torch or a candle, or whatever - it’s a plasma. All
fire is plasma, but it’s neutral. The total number of positive charges and negative
charges are roughly equal in an ordinary flame. Not so in the Brown’s gas. And that
tells us that when you create this gas in an electrically asymmetrically fashion, you
draw off the electrons. You start seeing unusually effects occur, and indeed that’s the
case.
- Sterling Allan: Are you observing the similar effects to what Brown’s Gas is
observing? You, know, you can take a torch and you can wave across your hand and
it doesn’t burn your hand, but you can then take that same torch, on the same setting,
put it to tungsten and it will sublimate it almost immediately.
- David Wenbert: Right, that’s due to the fact that the flame is highly charged.
- Sterling Allan: And you’re seeing that same effect with the gas coming off the water
fuel cell?
- David Wenbert: Well we haven’t been analyzing its combustion characteristics yet;
we’ve been concentrating on gas production efficiency.
- Sterling Allan: The other is, how does this relate to people who are using hydrogen
injection systems into their air intake in the vehicle they have in an onboard
electrolysis scenario -- producing brown’s gas, which then goes into the air intake,
and increases the fuel efficiency and decreases the emissions.
## Water Fuel Cell Open Source Project, OS:Water Fuel Cell, from Peswiki
Stanley Meyers electrolysis. This project seeks to replicat what he accomlished before
his untimely death. This is a publicly editable site. You are welcome to participate in
its development.
- While corrosion is not apparent in a mature operating WFC, it can occur during the
cell's initial burn-in phase. Consequently, tubes of the 316L stainless steel alloy are
preferred.
- While welded tubes are less expensive, and can be used for the inner electrode, the
outer tube should be extruded, to avoid any inner weld bead which might provide a
conductive path to short out the interelectrode gap between them.
- A thorough cleaning, to include an overnight soak in HaOH (lye) solution has been
shown to enhance performance, most likely by dissolving any machine oils picked up
on the tube surfaces in shipping (or carbon weld residues).
- In procuring tubes, one generally selects the outer diameters of 3/4" and 1", and
adjusts the inner diameter of the outer tubes for the desired interelectrode gap. While
a smaller gap is preferable, water flow issues impose practical limitations on this.
Some cell designs with forced water flow seek to overcome this limitation.
- It is believed that there may be acoustic resonance factors participating in the Meyer
Effect, as well as electrical. Consequently, tubes are lightly mounted and allowed to
vibrate, provided the inner and outer tubes are separated by spacers composed of a
high voltage insulative material, such as teflon. When gas production peaks, a
characteristic ringing of the tubes is audible; it is not known if this is a cause or effect
of the process. (See Theoretical Considerations).
- A WFC is not grounded, and the cell container itself should be insulated from any
conductive path leading to ground.
- Cell operating characteristics will change with the level of water in the cell; hence,
an auto-fill system should maintain the water level on a constant basis as closely as
possible.
- The incremental current draw for each additional tube set in the Cell is less than that
which came before, with new tube sets producing an equivalent amount of gas to
those previously in the system, consequently, larger arrays are preferable and more
efficient.
The frequency generator for the unit will accept straight DC input at 12v/10a, and,
produce a variable pulsed output of between 2Khz and 100Khz, in gated pulse trains
of 4 to 10 pulses per train, with a variable gate width, enabling a duty cycle which can
be throttled down from 90% to 10% during cell operation.
- A relationship is known to exist between the length of the tubes and the frequencies
used, which appears to observe the equations for Acoustic Resonance in metal tubes,
used in the design of musical instruments, such as organ pipes.
- While 555 timer MOSFETs have been used successfully, there are indications both
from Meyer himself and from the work of independent researchers, that more
primitive pulse forming circuits may in fact be better suited to the requirements of the
system.
- The circuit has been found to reach high voltage levels - in excess of 35,000v - in
pulses with a duration of under 75 nanoseconds. Initial observations missed this, but
faster instrumentation confirmed that multi-kilovolt levels were being achieved by
Lawton, and that this is in keeping with Meyer's lectures and writings about his work.
- The 555 MOSFETs can easily be blown by these high voltage spikes, and may give
no outward indication of doing so (no 'snap, crackle, or pop', no discoloration or
smoke), where the failure is only detectable if the right pin is being actively
monitored. This can lead to researchers finding a 'false negative' result in their
experiments. Protecting the timer with a 10v Zener diode is advised; a simple 10a fuse
is insufficient.
Two Inductor Coils, placed on either side of the WFC electrically, amplify and reflect
impulses through the Cell, and establish an electrical resonance between them. It is
believed that the high voltage potential exchanged between them - which can translate
instantaneously - is able to interrupt the flow of current before it crosses the Cell, thus
conserving amperage and reducing net energy input requirements.
- There is a relationship between the size of the RCCs in number of turns, and the
length of the tubes in the Cell.
- It is believed that a detail which Meyer left out of some patents to protect his design
may have been the use of bifilar wire in the RCC coils.
# Voltage Intensifier Circuit, The Missing Piece: The VIC transformer coils were
bifilar:
The Voltage Intensifier Circuit is a bifilar pancake coil transformer which provides
distributed capacitance and inductance to the tube sets in the Cell. Its function is to
manage the transfer of potential through the Cell, while inhibiting the passage of
current by the circuit.
- The challenge is to trigger the sudden catastrophic dielectric breakdown within the
Cell, between electrodes, while inhbiting the passage of current between them. When
this occurs, all current required to effect the breakdown must be pulled from solution.
- Meyer left a subtle element out of the patents, to protect his technology; the fact that
the VIC coil is wound of bifilar wire, as found in many Tesla devices.
- The free electron current drawn from solution is substantial and has the ability to
perform useful work. Bright incandescent bulbs and muffin fans providing practical
cooling have been powered from EEC outputs in WFC experiments. Since this current
is necessarily directly proportional to the number of water molecules processed by the
Cell, the greater the current which can be extracted, the more combustible gas is
produced.
- That the water carries a strong electrostatic charge is evidenced by visable changes
in surface tension, meniscus, froth, and other factors.
# Theoretical Considerations:
The Meyer Effect has been established through circumstances which expressly
exclude the operation of normal electrolysis. The water is not conductive, and no
electrolyte is added to increase conductivity. The amperage used is insufficient to
produce the gas volumes observed, and, when the effect is evident, there is a
relationship between the net voltage (and frequency) reaching the cell, rather than its
amperage.
- All polarity in the Cell is in one direction, at least per tube set, and never crosses the
centerline. The objective is to produce the maximum possible unidirectional
electrodynamic stress on water molecules within the interelectrode gap, and not allow
their reorientation or return to equilibrium.
- This polarization affects the quantum state of the water molecule, as does photonic
(light) input, but to a much greater degree, extending and elongating the
electronsphere of the outer valence electrons.
- Meyer correctly anticipated the work of Scragg, Mills and Santilli, with respect to
photokinetic effects, fractional quantum states and magnecular bonding in Hydrogen,
and these are all directly relevant to the oepration of the WFC.
- Pulsed potential impacts on the polarized, aligned water molecule not only extend its
electronsphere, raising its quantum state, but also affect the photoelectron yield of the
water, in effect rendering it more susceptible to photodissociation than it is in a
normal ground state. With photon emission occuring from Oxygen upon liberation,
the quantum efficiency of photolysis becomes greater than one, with each dissociated
water molecule triggering the dissociation of others. The peak absorption point of this
photosensitivity is believed to be in the Infrared, around 900nm, which does not
correspond with that of normal water, which is in the UV portion of the spectrum.
- Electrical resonance occurs with in the circuit between the RCC coils and VIC
transformer, and also within the Cell, between the tubular electrodes, while there also
appears to be an acoustic resonance at work. There may be a phase relationship
between these three resonant phenomena.
* The acoustic factors could be as simple as vibrating gas bubbles loose from the
electrode surface faster, thereby exposing more effective surface area per unit time.
Whatever else applies, this is probably also happening.
* Another possibility strongly indicated by the dynamics of the process is that a
standing acoustic wave arises between the electrodes, inhbiting ion transport and
delaying dielectric breakdown until higher potentials are reached.
* Other researchers (Keely, et al) have reported phonodissociation of water at various
acoustic frequencies, as low as 42.8 Khz; other harmonics may also be possible and at
work in this system.
- Indications are that the VIC and RCC coils in the circuit behave in the same
relationship as coils in the Bearden Motionless Electromagnetic Generator, and that
currentless potential is switched in an analogous manner, with the water serving as the
'degenerate semiconductor'. The voltage potential is pulsed at rates inside the
relaxation time of the water, and similar effects are observed.
# Replications:
Dave Lawton :
- Dave's Cell Without Inductors or Alternator
http://www.youtube.com/watch?v=Kf_nFQBBzmc 32sec posted 5th September 2007
"the WFC generates just as much gas as with the alternator or Inductors"
- Dave Lawton replication information and cold current information from
Panaceauniversity http://panaceauniversity.org/D14.pdf
Ravi Raju : Stanley Meyer Replication with 9 inch, 9 tube sets. with an input current
of 0.51 Amps from the frequency generator.
- using Panacea University Instructions http://www.panaceauniversity.org/D14.pdf for
the Dave Lawton replication of the Stanley Meyer Water Fuel Cell.
- proper discussion at http://oupower.com/phpBB2/viewtopic.php?t=1602
- Ravi's Stanley Meyer / Dave Lawton Replication Water Fuel Cell video#001]
47seconds, posted 15th August 2007 ; This video shows the innards of the WFC
without water.
- Ravi's Stanley Meyer / Dave Lawton Replication Water Fuel Cell video#002]
10seconds ; This video shows Freshly filled Tap Water. No other impurities added.
- Ravi's Stanley Meyer / Dave Lawton Replication Water Fuel Cell video#003]
01min:37 ; This video is after the top is sealed and with an input of 0.5 Amps from the
Frequency Generator. Produces really large bubbles (approx from 4mm to 10mm) not
like the small ones we see in other videos including Stans setup....which shows a lot
of small sized bubbles. You can see this in the video...this goes on from the start of the
WFC till you stop after which traces of small bubbles keepleaving the top for about
20 to 30 secs....this is probably the capacitor (WFC) discharging. I have absolutely no
idea why im getting large bubbles.
- Ravi's Stanley Meyer / Dave Lawton Replication Water Fuel Cell video#004]
01min:32
- Ravi's Stanley Meyer / Dave Lawton Replication Water Fuel Cell video#005] 18sec
- Ravi's Stanley Meyer / Dave Lawton Replication Water Fuel Cell video#006] 11sec
- Ravi's Stanley Meyer / Dave Lawton Replication Water Fuel Cell video#007]
01min46sec ; This was the first and second generation after the leads were changed.
The light in these videos is good. These videos are about 5 or 6 days old.
- Ravi's Stanley Meyer / Dave Lawton Replication Water Fuel Cell video#008]
02min45sec ; This was the first and second generation after the leads were changed.
- Ravi's Stanley Meyer / Dave Lawton Replication Water Fuel Cell video#009]
02min39sec ; I had made this video in the night so the light is not so good, but the
volume of gas the WFC makes is very clear. The output also is higher. The collection
was for 20 secs....1.31min to 1.51min of the video and the volume of gas collection
was @ 160/165CC, even if you take the volume as 150CC with balance as steam and
other losses....it amounts to 7.5CC/sec of HHO....thats about 0.45 lits/min (minimum)
- Ravi's Stanley Meyer / Dave Lawton Replication Water Fuel Cell video#010]
03min09sec ; I was asked for the voltage and the connections so I made this video and
posted it a little before I got the call. I've switched off the left part of the circuit with
the switch on the pin 3 of the 555 and you can see that the current draw increases over
fourfold and you cant see any pulsing on the right LED. The left LED is connected
before the switch on pin 3 as in [D14 http://panaceauniversity.org/D14.pdf].
- Tuning the Frequency of a Dave Lawton replication , not by Ravi RAju] 9min53sec
- added 22th August 2007
Aaron Murakami :
- Aaron Murakami Replicates Stanley Meyer's Water Fuel Cell
http://www.youtube.com/watch?v=pSFpBW8_v8o - Using a plastic pasta jar with
stainless steel concentric tubes filled with tap water from his kitchen sink, and no
added electrolytes, with an input power of 36 watts (12 volts at 3 amps) pulsed, Aaron
produces enormous amount of "Brown's Gas " Stanely Meyer style. (YouTube; Aug.
10, 2007)
- I updated the video clip with a few more tidbits of info about what I did:
http://www.esmhome.org/library/stan-meyer/wfc.wmv
- video on conditioning the tubes...I have 7 tubes setup and in this vid I am putting
LESS THAN 10 watts into it. You can see the inner tubes are being coated with the
white powder coating. http://www.youtube.com/watch?v=qXRMVZWrgSk
- Video on the Bifilar chokes - info taken from tech brief:
http://www.youtube.com/v/ozpRNpM6FqM
- WFC White Powder Coating on Cathodes - no conductivity
http://www.youtube.com/watch?v=Rx2uEsbTt8Y
Crux_wfc :
- Electrolysis in distilled water with no electrolyte
http://www.youtube.com/watch?v=mnPakaI701Y (34 seconds) - Crux_wfc
electrolysis cell makes hydrogen gas in distilled water, with no electrolyte, which is
supposed to be impossible. (YouTube; July 11, 2007)
- Aaron's circuit
http://www.freeenergynews.com/Directory/Electrolysis/StanleyMeyers/Aarons_WFC
_circuit.pdf) (pdf; 12 kb)
username at http://waterfuelcell.org/ is "crux_wfc"
- Videos: http://www.youtube.com/h2earth
- Blog: http://my.opera.com/H2earth
- Downloads: http://my.opera.com/h2earth/blog/cybrarium - The Waterfiles Archive
- Forums: http://my.opera.com/h2earthbeat
- Overview Video: Water as Fuel (via ZPE)
http://peswiki.com/index.php/Video:Water_as_Fuel_(via_ZPE) (3 min) - While
academia has been spurning the topic, hundreds, if not thousands of hobbyists and
independent investigators worldwide are working on various electrolysis-like projects
which put out more energy than was required to run the electrolysis unit. (PES
Network Video; Aug. 31, 2007)
- Special Waterfuel Acceleration Team: This report represents the ongoing work of
a global Open Source collaboration of independent researchers, Associate Fellows of
the H2earth Institute's International Research Fellowship Program. Through a teaming
relationship with the Pure Energy Systems Network, the invitation to participate in
this project is now extended to the broader FE/OU community. Various schematics,
documents, images, video, and data will continuously be added to this report, until
waterfuel technology becomes universally available.
- Videos: http://www.nextenergynews.com/fuelcells/fuelcells1.html
- Public Domain Waterfuel Technology: http://www.h2earth.org/
On June 27th, 2007, U.S. Patents 4,936,961 and 5,149,407 by the late Ohio inventor
Stanley A. Meyer expired, and his technology for the Water Fuel Cell fell permanently
into the public domain in the United States. As what many consider the most
sophisticated approach to "Hydrogen-on-Demand" technology (running a vehicle or
genset on water alone), the Water Fuel Cell ("WFC") may be the most practical free
energy device to introduce on a widespread basis. While it is alone among waterfuel
devices in being accompanied by a reasonable theoretical foundation as to why it
works, it is also among the simplest and least expensive waterfuel systems to
construct. For these and other reasons, on January 1st, 2007, a new nonprofit research
& education foundation, the H2earth Institute (http://h2earth.org) was organized to
explore waterfuel technology generally, and to re-launch the Meyer WFC in
particular, once it became free of intellectual property rights issues, upon expiration of
the patents.
Notably, the 5,149,407 "Design" patent, which issed more than two years after the
4,936,961 "Methods" patent, was deliberately truncated by Meyer so that it would
expire coterminously with the primary one. Disclaiming the remaining term of a
patent is an almost unheard of step for an inventor to take, and indicates the later
patent to contain some critical improvements that Meyer wanted the world to have
when his basic technology became public domain. Meyer, who died in 1998, was
working on more involved and exotic implementations of the technology, involving
water injecting spark plugs, which is embodied in other Meyer patents which remain
in force until 2011. This project is not concerned with that architecture, but only with
the body of Meyer's work which is now in the public domain.
In June of 2006, retired U.K. Research Engineer Dave Lawton released a report,
compiled by PGFED Editor Patrick Kelly http://www.panaceauniversity.org, detailing
Lawton's success in constructing a working Meyer WFC, which has produced gas at
3x the Faradic equivalent rate for the power consumed. Lawton, who spent much of
his career at Britain's Rutherford Labs (equiv. U.S. Lawrence Livermore) designing
and constructing instrumentation for high energy particle physics research, is far from
the average 'tinkerer'. Videos of his two WFC units, one with an alternator based
circuit, and one employing solid state timing logic, were posted on YouTube, and have
received over 50,000 hits. The cells operated at 12-13v/3-4a - averaging
approximatley 57 watts of input power - producing gas aggressively in distilled water
with no electrolyte. On February 23rd, 2007 (the 18th anniversary of Cold Fusion),
the H2earth Institute initiated an International Research Fellowship Program to
facilitate realtime collaboration between waterfuel researchers around the world,
working to decypher the keys to building a functional WFC, based on these Lawton
WFC replications.
This platform on PESN is intended to publish the technical findings of the H2earth
Institute with respect to the WFC, in a public format which allow the documentation
to grow over time as the design is further refined and "Best Practices" in constructing
replicating units become known and confirmed. In the descriptions below, Bulleted
items constitute findings generally accepted by the Institute (as of June 27, 2007) as
having been found to be indicative of success in WFC theory, design, construction,
and operations.
# Preambule: This paper sets out to describe why experimental apparatus, namely:
- Mitsubishi Cyclone (1)
- Honda TC 1600 (2)
engine(s) runs on electrolytic (3) gas. That is not strange in itself as it is well known
that Hydrogen is a fuel*. The benefit of using Electrolytic Gas is that the Hydrogen
has with it, its own oxidiser - Oxygen. Already perfectly proportioned, no gas mixing
is required and so complete combustion is accomplished without the need for
additional air. Here's the rub; the car engine uses a separate belt driven three phase
marine alternator in a 'Y' winding with output rated at 150 Amps at 24 Volts which is
fed into three electrolysis cells, each cell gets a single phase. Beginning at 12 Volts the
cells are heated partly by hot exhaust gas and partly by way of voltage on the plates
within acting as heating elements, additional electrolyte haeting is provided with one
600 Watts mains rated elements within. When the cells get up to temperature (about
75 deg.C) the alternator tickle supply is reduced to a range between 1.24 to 3.00 Volts
which then serves to increase electrolysis efficiency in accordance with Faraday's
Law(s) of electrolysis and thus efficiencies in the order of 97.5% (4) are achieved, the
cell consuming circa 600 Amps each, the process becomes endothermic and provides
gas (more than) sufficient to fuel the engine.
Thus engine generates its own fuel (and oxidiser) with ample power to spare. Most
argue that this is an impossible situation; at best the engine becomes a dynamic brake
and at worst it just won't work. The explanation being that you can't get more energy
out than what you put in and in citing various texts, at first glance appears quite
correct. The fact of the matter - as this paper will prove - is that the texts are either
wwrong or fail to supply all of the information.
# Definitions: Various figures are provided in texts for the energy value of the
Hydrogen bond stength (5) of 104 kcal/(1/mole) or 104 kcal/mole-1. So far as the mole
fraction is concerned some express such as the inverse function and others as a
reciprocal (mole-1) and (1/mole) respectively. In any case the purpose is to detail a part
of the mole or indeed one molecule at a time over time. Following lectrolysis the
demised atoms may be at their lowest, or induced to increased energy their electrons
orbiting above the lowest energy state. In order to reveal the correct figures for all
sides of the reaction(s), there is wisdom in beginning with the elemental gases and
their oxidisation reaction and finish with decomposition in order that the results
comply with Thermodynamic law. For the remainder of the paper kcal will be
converted to kjoule (kj) so that 104 kcal = 435 kj and unless specified otherwise molar
quantities are 1/mole (mole-1), denoting singular molecules as opposed to Avogadro's
Number which denotes 6.02 x 1023 molecules. When this approach is taken the energy
content latent in the oxidisation is realised, not so when the calculations start with
water - something appears to get lost.
The heat flame (plasma) total energy is calculated by multiplying the respective
atoms' ionisation energies for the process. The ionisation energies (6) of H= 1312.06
kj and O= 1313.95 kjie1, (3388.33 kjie2, 5300.51 kjie3) upon combustion the (outer in
Oxygen) electron orbits interact, merge and settle down to stable orbits:
Hie1 + Hie1 Oie1 = 3,447,962.47 kkj (e1)
Where ie is Ionisation Energy and n the energy layer (three in Oxygen) and only one in
Hydrogen.
In the discussion of thermodynamics relating to the subject matter the question of heat
is a very important one, there being two types of heat. On the one hand is heat due to
molecular motion and on the other is the heat of photons coming and going during
reactions.
(MDG nov07: inthe following part, symbols are not readable on the original pdf file,
so I can't transcripte them here)
In order of energy strength ... The formation of Hydrogen is a nuclear reaction there
being two well known modes of its coming into existance; primordial Hydrogen and
neutron decay. Neither of which are relevent to this discussion. Oxidisation (burning)
of Hydrogen is a physical reaction of the middle energy order. And electrolytic
decomposition is a[n] [electro]chemical reaction. The notion of co-efficience rests in
Electrolysis, of the low energy order - a chemical reaction and Combustion - a
physical reaction of the middle energy order being vasstly disproportionate. This can
be shown to be the case; let ?= 870kj be the total energy consumed in splitting H2O
and ? be the oxidisation expenditure in equation (e1) of [combustion] energy.
?/? = 3963.18 (e2)
This does not describe some 'hidden' energy, nor do special-pleading of over-unity
claims have any relevance. The calculation reflects the starting position of the two
gases. Even if the bond strength is subtracted from both sides"
(?-?)/?= 3962.18 (e3)
... it is apparent that the combustion product is highly energetic. So which is it? The
chemical equation given:
H2O(1) + 435kj --> H + H + O(g) + 435kj --> H2O(1) (e4)
is clearly mistaken because, a/ only half the required energy is given and b/ there is a
continuing addition of energy on both sides and appears not to factor-in any energy
release. In any case equation (e6) plugs in the correct values to the formula provided
in the text (footnote #2) and equation (e7) enlarges to include the enrgy release.
H2O(1) + 435kj --> HO + H + 435kj --> H + H + O(g) [+870kj --> H2O(1)] (e5)
On the one hand energy is expended to break the bonds and on the other hand energy
must be expended to remake them and clearly this imbalanced situation leaves a lot to
be desired. What actually happens is that 870kj/mole-1 is expended to begin the
recombination process and 3962kj/mole-1 is liberated as a net gain. The reason for this
is that the ionisation process in electrolysis is [electro]chemical, the initiating energy
is [electro]chemical however the resuktant ionisation (combustion) process is
physical.
H + H(g) + O(g) + 870kj --> (H2O(ion) - 3962kj --> H2O(1) (e6)
... and then multiply this reaction by the gas volume denoted by Avogadro's number.
The author of this paper is not in isolation insofar as these apparently anomalous
results are concerned, others have addressed the issue. (7) 'The smallest amount of
energy needed to electrolyse one mole of water is 65.3 Wh at 25 deg.C (77 degrees
F.). When the Hydrogen and Oxygen are recombined into water during combustion
79.3 Wh of energy is released. 14 Wh more energy is released in burning Hydrogen
and Oxygen than is required to split water. This excess must be absorbed from the
surrounding media (environment) in the form of heat during electrolysis.' [...] 'At 25
deg.C, for voltages of 1.23 to 1.47 Volts, the electrolysis reaction ABSORBS HEAT.
At over 1.47 V at 25 deg.C, the reaction gives off heat.'
The electrolysis cell voltage, overvoltage may be 1.3V therefore 1.47V + 1.3V =
2.77V is the voltage supplied.
1 mole of gas = 24.450 liters of gas at room temperature, 'T' and atmospheric pressure
'P'.
55.55 x 24.450 = 1,358.3 liters of Hydrogen (and 679 liters of Oxygen from 1 Liter of
H2O.
Before there was ever water there was only gas. Three electrons are involved in the
process of combination and at each juncture the combining electrons produce
photons:
Two electrons are introduced to break the bonds but those electrons are ions and so do
not add to the resulting atoms electron number. At the same time IR photons are being
absorbed by the molecules increasing their energies and adjusting the bond lengths:
Shown opposite are the main vibrations occurring in water. The movements are
animated using the cursor. The dipole moments change in the direction of the
movement of the Oxygen atoms as shown by the arrows (9):
The main stretching band in liquid water is shifted to a lower frequency (v3, 3490 cm-1
and v1, 3280 cm-1 [8]) and the bending frequency increased (v2, 1644 cm-1 [942])
What this means is that the energy required to break the bonds increases or decreases
proportionately to the bond lengths which may be altered by such things as magnetic
fields or heat.
# Gibbs Free Energy: Do the rules comprising Gibbs Free Energy reconcile with the
energy shown in equations (1 - 6)? No. Provided there are energy co-efficients
involved does GFE get turned on it's head? The Wien effect does it to Ohms Law.
Why not here as well? Some reactions are spontaineous because they are exothermic ?
H<0, and others are spontaineous because they are entropic ?S>0. The combustion of
Electrolytic Gas is exothermic but the question of entropy is a moot point. Two
disordered gases ignited combine to make water which is not an increasing entropy
proposition, therefore in our calculation ?S<1. Provided the GFE of a system at the
end of the reaction is defined as the enthalpy of the system less the product of the
temperature multiplied by it's entropy.
H = Enthalpy ; S = Entropy ; Del.G = Del.H- Del.(TS) (e8)
THe usual standard-state free energy of this system ?G cannot be applied herein due
to the rapidly changing temperatures involved in the reaction and the Enthalpy is:
?G = Hg+ Hg + Og(1S) = -318.402 kcal/mol = ?H = - 151.81 = ?S x 6000Deg. = ?H-
-910,860 kcal/mol (e9)
Following combustion of the gases at 6000 Deg.C the resulting oxide cools until it
reaches ambient temperature, the molecules return to their lowest energy and the
amount of energy released persuant to GFE is close to the energy taken by the other
route in earlier equations, in other words - a lot more than the Hydrogen bond
strength.
Alas it is not that simple though. One cannot say that the “heat” of electrolysis is
equivalent to this heat of combustion there being crossovers of photonic and
molecular heat during the exchanges.
If for example you have 7 cells in series and put 11A through the electrolyzer,
according to Faraday’s Law you would produce:
0.627//Ah *11A*7= +- 48.3 Liters per hour at STP conditions. (e13)
Note, however, that this applies only at a certain temperature (0 deg.C) and pressure
(1 atm). The produced gas volume will scale with ratio of temperatures in Kelvins
(higher temperature = higher volume) and inversely with the ratio of pressures (lower
pressure = higher volume).
If at 0 Deg.C (273.15 Deg.K) the production rate is 0.627 l/Ah, then at 25 Deg.C:
273.15 Deg.K + 25 Deg.K = 298.15 K (e14)
The production rate is : 298.15 / 273.15 = +- 109% (e15)
larger or about 0.685 l / Ah. With 7 cells and 11A this would be 52.5 Liters per hour.
On the other hand is the output gas has a temperature of 40 Deg.C while it is being
measured and the ambient pressure of 0.75 atm (about 1.5km elevation above sea
level), the electrolyzer that produces 48.3 liters per hour at STP will produce:
313.15 Deg.K / 273.15 Deg,K * 1atm/0.75atm * 48.3l/hr = 73.8 l/hr (e16)
So even though the volume of the gas is larger at higher temperature and lower
pressure, the energy contained in the gas or the energy required to electrolyze it is the
same. If you produce the gas at 40C and 0.75ATM and bring it to 0C and 1ATM, the
volume will reduce by about 35%. Thus it is very important to include the pressure
and temperature in calculations.
What may not be immediately clear is that different experimenters report various
results that are prima facae out of step with cherished laws. Some experimenters
report efficiencies that appear in excess of Faraday's Law yet others no matter how
hard they try attain only low levels of efficiency. Are the over unity claims due to
errors in method or calculation?
Probably!. But then one has to consider consistent variances shown by experimenters
as detailed in the analysis of their results which ultimately culminates in the
preponderance of combustion energy output many times more than expected.
When conventional diatomic (tank gases) oxygen (O2) and hydrogen (H2) are ignited,
the bonds between the gas atoms in the diatomic gas molecules have to be broken
first. This consumes energy. Energy is then released§ when the H and O atoms
recombine into H2O. The total amount of energy released is the sum of these two
energies, where the other one has '+' sign and the other one '-' sign.
(13) Dissociation of diatomic hydrogen gas into hydrogen atoms (consumes energy):
H2(g) ? 2H(g) ... ?H = 217.998 kj (e17)
Dissociation of diatomic oxygen gas into oxygen atoms: (consumes energy): O2(g) ?
2O(g) ... ?H = 249.18 kj (e18)
Combustion of diatomic H2 and O2 to form water as steam (releases energy): H2(g) +
1/2O2(g) ? H2O(g) ... ?H = -241.826 kj (e19)
Dissociation of diatomic H2 and O2 molecules into monoatomic form (consumes
energy): H2(g) + 1/2O2(g) ? 2H(g) + O(g) ... ?H = 217.988 + 1/2*249.18 kj =
342.578 kj (e20)
Combustion of monoatomic H and O to form water as steam (releases energy): 2H(g)
+ O(g) ? H2O(g) ... ?H = -(342.578 + 249.18) kj = -591.758 kj (e21)
Combustion of diatomic oxyhydrogen into water in the form of steam (releases
energy): H2(g) + 1/2O2(g) ? H2O(g) ... ?H = -241.826 kj (e22)
Combustion of monoatomic oxyhydrogen (releases energy): 2H(g) + O(g) ? H2O(g)
... ?H = -591.758 kj (e23)
Combusting a certain amount (by weight) of oxyhydrogen releases about 2.45 times
more energy if the oxyhydrogen is monoatomic instead of diatomic. Monoatomic
oxyhydrogen has twice the volume for the same weight than does diatomic
oxyhydrogen. This means that igniting one liter of monoatomic oxyhydrogen releases
only about 1.23 more energy than the same volume of diatomic oxyhydrogen.
However the theoretical energy consumption to dissociate one liter of monoatomic
oxyhydrogen from water is half of that required to dissociate one liter of conventional
diatomic oxygen and hydrogen gases.
It may also be noted that when the two Hydrogen atoms merge photons in the UV
band are released. In order to inhibit this merger it may be possible to subject the
Hydrogen to strong UV (class C) radiation. Here also is a curious dichotomy; whereas
water absorbs IR radiation during efficient electrolysis and whereas it releases UV
radiation when the electrons spin down to their lowest energy state and combine into
molecular Hydrogen (2H). The initial part of this process is of a lower energy order
than the latter. To all intents this is a thermodynamic breakage and proves the authors
earlier hypothesis that the electrochemical equations must be performed in their
correct order to make proper sense.
In the left column are voltages read at various times and in the right column are
theoretical voltages to apply for electrolysis (see original document).
The cells are comprised of disc interleave stacked electrodes. Potassium Hydroxide
(KOH) 1:30, distilled water, 30 Deg.C, 1.27 MOhm (with electrolyte) from 120
MOhm (without electrolyte). Calculating Ohms Law says that at the higher
impedance more current can be supplied:
1 - E=IxR ; I=E/R ; R=E/I
2 - 12 volts (nominal) / 3 cells = 4 volts per cell
3 - TO determine current: E/R ; E =4, R= 12x106, I= 10x 36 (e24)
When lowering the electrolyte impedance to c.l.2 kOhm the current will be 300 Amps,
theoretically ..
...takes no consideration any voltage drop at the electrodes. On Mk1.1 the reactor
experienced an 8 to 10 Volt drop when powered at 12 - 14 Volts. If three cells are
connected in series the voltage at each is 4 volts, the voltage drop therefore renders
the reactor inoperative and in series only the centre cell produces significant quantities
of gas. As electrolyte is added and the cell impedance drops the power consumption
increases as does the gas output.
Ohms Law dictates the current and voltage levels in the cell are relative to resistance,
however clear signs emerge during testing that there is a kink in this Law. Whereas
the cell resistance at 10kOhm , 1.23 Volts - load should equate to 0.13 milliAmps in
fact the reciprocal of this value is obtained. In all electronic/electrical circuits heat is
generated. When powering the cell with increased voltages ranging from 6 to 40 volts
heat is generated and the cell warms up as would be expected in an exothermic
system. When voltage is reduced to that dictated by Faraday's Laws of Electrolysis the
cell cools and begins to absorb energy from the surrounding atmosphere, that is; the
circuit becomes endothermic. In order to keep the cell temperature at that required for
highly efficient electrolysis IR radiation must be introduced to keep the electrolyte
warm.
This breakage in Ohms Law is repugnant to most and many have stated that it is
impossible. The clamp meter does not lie, how can Ohms Law be rent asunder in this
manner? The answer lies within thermodynamic systems reported by Willhelm Wein
in studies of Black Body radiation and is defined in the Wein Displacement Law (15)
The increase of the mobility of an ion in high electrical field. The mobility of an ion
is somewhat decreased by the presence of the ionic atmosphere because the
predominantly oppositely charged ions surrounding the central ion will tend to hold it
back. This effect is included in the normally measured mobility. However, when the
ion is exposed to very high electrical field, it will move so fast that it will, in effect,
leave behind its atmosphere which does not have time to reform, and the mobility of
the ion (consequently the electrical conductivity of the solution) will increase. See
also the Debye-Falkenhagen effect.: b=lmax T=C2/4.96511423 (e25)
And that electrolysis does not follow the usual VI curve usually associated with
electronic circuits. 16"The v-i transfer function always applies. Impedance is the
instantaneous slope of that function". Mathematically this can be stated resistance: R
= dV / dI . Ohm's law, as stated, is just a specific case of the above were dV / dI
remains constant for a (in practice limited) range of voltage and current. Materials
where R is constant over a useful range of voltages are sometimes referred to as
'ohmic'. The "big R" in R = dV / dI is NOT intended to denote a constant, since the
differential term dV / dI (or slope) is only a constant in the linear case. R is a variable
representing a variable resistance. R is a constant r is a variable. The issue is that the
resistance of a cell is nonlinear which means that it exhibits different resistances at
different operating points of voltage and current. At any given point of current and
voltage, ohms law very much does apply. When you measure the resistance with a
simple ohmmeter, you are measuring it at one point, a point with a very low sense
voltage. The resistance is high at this voltage, the cell is barely in conduction. At a
different, higher voltage, say several volts, the cells conduction increases, the
resistance drops and the current comes on as observed. If you had an ohmmeter that
measured at that higher voltage, it would show the appropriate low resistance. There
are many electrical devices that exhibit non- linear behavior besides electrolytic cells.
The common diode comes to mind. There the resistance is a function of polarity in
addition to being nonlinear in the forward direction. At a few millivolts of forward
voltage, most diodes have a resistance of megohms. This decreases down to an ohm
or below as the voltage exceeds .7 volts. Note that these nonlinearities have nothing to
do with reactance as applied to AC circuits with inductors and capacitors.
# Satefyt: From a safety standpoint it may be propitious that when Hydrogen goes off
there is little risk of colateral fire the event being over so quicky that in most cases
nearby combustables cannot get enough heat for a long enough period to
spontaineously catch alight. Certainly there will be colateral damage to surrounding
materials, but then-again; the event is so rapid that the force accelerates past and
heavier items will remain largely unaffected. Hardware involved in the event, the gas
containment device - for example, will exhibit fractures and other effects of explosive
energy. Protective equipment shouls be used including hearing and eye protection.
# The Infrastructure Hobgoblin: In our consumer society much ado is made of our
dependence on multinational corporations to provide materials for our sustenance and
advancement. Notwithstanding anecdotal stories of cloak-and-dagger conspiracies, I
contend that ill fate suffered by inventors in the energy field has been perpetrated by
other jealous inventors and not by way of corporate shenanigans. Even if, in times
past such corporations have embarked on criminal activities the world has changed
dramatically. The political assemblies becoming more representative of a wider range
of populace are somewhat more enlightened than was the case in the relatively recent
oil crisis in 1974, dodgy dealings are less likely to be perpetrated now.
In 2005 the world faces new energy crises. On one hand the globe is nine (19) times
over-subscribed in electricity generation the detraction being found in transmission
inefficiencies and on the other hand global conflict and excessive demand has had a
negative effect on oil supply thrusting the price of oil to record highs. There is no
evidence that the world is running out of oil and there is also no evidence that it is not.
Petrochemicals will always have a place in society providing us with useful products
including industrial chemicals, lubricants, fuels and plastics. What is a moot point is
whether recent discussions about the “Hydrogen Economy” bear any relevance
insofar as Hydrogen Infrastructure is concerned. Hydrogen may be produced in
almost any location on Earth, the Author envisages appliance sized gas plants placed
in homes, plugged into the wall and generating Hydrogen and Oxygen by electrolysis
for automotive use. The proponent drives the vehicle into the garage and connects to
the Hydrogen source which replenishes the tank(s) thus emptying the stored
Hydrogen. After driving off again the appliance continues operating 24/7 refilling
tanks for later use.
The foregoing becomes academic in the face of on-board, on-demand fuel systems
contained within the engine bay which produces all of the engines' needs in which
refueling is accomplished either by way of introduced distilled water or by the rain
water falling on the vehicle during use that is then collected and distilled in a heat
exchanger also within the engine bay. The question then is; what point infrastructure?
# Credit where it;s due: For the most part the prototypes constructed to demonstrate
the power and practicability of EGas as a fuel rest with work done in the 1970's by an
English immigrant to New Zealand, namely; Archie Blue. What this writer has done is
to take the kernels of Mr. Blue's work, develop and improve upon it in order to bring
about devices that not only work but that also may be held up for meeting or
exceeding industrial standards, materials safety data sheets and for dissemination of
the information to a world-wide audience.
In this section the writer will discuss the originating invention and the work
performed to improve upon it.
In the early 1970's Archie Blue demonstrated his electrolysis device to engineers in
both New Zealand and Guernsey. Practical limits where the Mini that it ran on would
only accomplish low speeds, use copious amounts of water and dissolved aluminium
electrodes such that, although it worked, it did not work for long periods.
The original devices sighted by the author were in Agee preserving jars. Clearly the
wrong material to use. Furthermore, the power supplied to the electrolysers was taken
straight from the vehicles electrical system which caused excessive heating and
melted wires. No work was performed by Mr. Blue to explain the devices in terms of
Faradays Laws of Electrolysis. The electrolyte was Sulphuric Acid (Battery Acid) and
on the application of electrical current the aluminium electrodes began to dissolve
releasing EGas in the process. This EGas was then fed into the modified S.U. brand
carburettor for direct induction to the combustion chambers.
What has this author done to improve upon and develop the original invention?
- The electrolysis units have been constructed of stainless steel
- Heavy duty check valves are placed at the top of each cell
- Potassium Hydroxide is added as electrolyte
- Sacrificial electrodes have been dispensed with in favour of stainless steel.
- The pressure source is added from the bottom of the cells
- The electrical supply is induced at the bottom of the cells so that no surfaces are
exposed to EGas
- The pressure source is provided by gas from the exhaust
- A seperate power supply has been added that allows for voltage adjustment
- Electrical characteristics have been defined
- Harmonic resonance has been added to electrodes
The crux of the invention has been retained as it relates to using three electrolysis
cells, the output from the one cell feeding the input to the next which appears to
enrich the gas evolved from the output of the third and final cell. Direct injection to
the modified S.U. brand carburettor has been dispensed with in favour of using an
Impco brand natural gas regulator. The new and improved unit also has safety features
built into it such as pressure relief valves
Electrolysis can be made very efficient and high nineties (percent efficiency) is not
difficult to accomplish. With the combination provided by way of Faradays Laws
wherein temperature is maintained at c.75 Deg.C, voltage at 1.27 volts (above
electrode overvoltage) and power in the kilowatts efficiency of 97.5% is not
unrealistic. It must be pointed out that at these parameters the electrolytic process
tunnels into an exothermic state. Although, stricktly speaking all circuits generate heat
and therefore losses, they operate endothermically and all physical laws are complied
with. Not-so electrolysis, clearly this state of change has an effect - in particular Ohms
Law appears to break. One must now approach the calculations vis-a-vis efficiency
within the bounds of Blackbody Radiation and the Wein Effect. Coming back to this
“combination”; whereas Tero Ranta's data shows that better than 100% efficiency can
be accomplished without addition of any other tricky bits, the notion of providing
electromechanical motion using small quantities of power to release larger amounts of
gas in this system will add to the output efficiency.
# Summary: Before there was water there was only gas. In space water is formed by
electrical discharges through reasonably dense atomic/molecular clouds. Terrestrial
water was formed by three routes:
1 - Water captured from space
2 - Electrical discharges, and latterly;
3 - Cellular metabolism.
A small electrical discharge sets in motion chain reactions between Hydrogen and
Oxygen in a physical event that releases orders of magnitude more energy than is
required to then, in an electrochemical reaction, break apart the resulting oxide - there
being no detractions from physical law when these facts are processed in their correct
order. The oxide does not exist prior to the gas!.
# Further Discussion: The most popular forum in which the vicissitudes of all things
“Electrolytic Gas” are discussed may be found at
- http://groups.yahoo.com/group/watercar
- http://groups.yahoo.com/group/egas
- http://groups.yahoo.com/group/gobox
- nttp://groups.google.com/alt.sci.hydrogen
- nttp://groups.google.com/alt.energy.homepower
Please note that the terms “egas” and “egaspower” are proprietory, copy protected -
the trademarks owned by the author.
# References:
(1) 2006 ; (2) 2002 ; (3) Also called: Water Gas, Rhodes Gas, Browns Gas ; (4) Other
formulations appear to show this figure may increase to 120% and more.
(5) Organic Chemistry, Morrison & Boyd, Allyn and Bacon, Inc. LCCCN:66-25695.
(6) www.ktf-split.hr/periodni/en
(7) 'Fuel from Water' M.A. Peavey. Merit, Inc. LCCCN 88-188956 ISBN 0-945516-
04-5 Page 22.
(8) http://www.physics.ohio-state.edu/-lvw/what/ads/adxe.html
(9)http://www.lsbu.ac.uk/water/vibrat.html ; (10) Courtesy Tero Ranta ; (11) 'L' =
Litres ; (12) Courtesy Tero Ranta ;
(13) CRC Handbook of Chemistry and Physics, 84th ed. ; (14) Faraday's Law requires
a temperature of circa 75 degrees Celcius ;
(15) http://electrochem.cwru.edu/ed/dict.htm#w01 ; (16) http://sci.energy.hydrogen
(17) Reproduced, see Apendix 1 ; (18) Proprietes of Hydrogen Combustion. NACA
report 1983.
(19) http://www.wired.com ; (20) De Rivas
The DC current supplied is less than one amp while the pulsed current to the
electrolysis cells is much higher. When a snap-on ammeter surrounds the wires to the
cells, a current of 800 amps is displayed. It is likely that this style of ammeter is
calibrated for sine-wave alternating current, and so the actual RMS (average) current
is almost certainly different to the displayed value. What is certain, is that the current
supplied to the cells is enormously higher than the DC input, and it may be in excess
of the 800 amps displayed.
A point of particular interest is the inductor placed between the electrolysis cells and
the windings of the alternator. Peter describes this as a choke out of 3-phase industrial
power supply. It is comprised of a laminated steel core with a sheeet of copper wound
around it. This is remarkably like the arrangement used by Edwin Gray's power tube
which picked up sufficient Radiant Energy to power an 80 horsepower electrical
motor. Edwin's device used two or three cylinders of perforated copper sheet
surrounding a conductor which was fed with 80 microsecond unidirectional pulses.
This inductor is so similar in construction that it might not be unreasonable to suspect
that the steel core mught have very short electrical pulses induced in it, generating
radiant waves of Radiant Energy which are picked up by the copper sheet winding
and fed into the system providing a major additional source of energy for the
electrolysis. This may well be the reason that this system produces easily enough gas
mixture to run an engine.
As the motor is supplying mechanical power to the alternator shaft, it is not possible
to say that there is a current gain of 800 times. What is certain, is that there is indeed a
pick-up of external energy in this system. This can be expected, as a sudden pulse of
large current into each cell will generate a major magnetic pulse which in turn may
well tap the external energy field. This is very like the effect experienced by Ed Gray,
Robert Adams, Tom Bearden, Floyd Sweet and others, when they produced large
rapidly-changing magnetic fields. As remarked above, Peter's engine couldn't run on
water alone without gaining extra energy from somewhere - don't forget that the
engine produces the mechanical and DC power fed to the electrolysis units. To sustain
the engine running, the system has to be over 100% efficient. As an engineer, I can
assure you that Peter's engine is not over 100% efficient, and yet it does run, which
shows condusively that it is picking up extra energy from somewhere. I expect that in
the near future, we will be able to say from where the extra energy is coming.
A comment from a member of the Yahoo 'egaspower' Group: 'When I joined this
group in March, I saw for the first time Peter Lowrie's statement that the power out
was 8 to 11 times that of the electricity required. I didn't quite believe it but thought
that you might just get the engine to idle based on George Wiseman's calculations that
the monoatomic molecules where giving almost 4 times the energy of diatomic ones.
When I first tried it, my motor ran at the full 5,500 rpm and not at an idle as I had
expected. The power generated in Peter's mode of operation is about 39 times what
you put in if you allow for the fact that the motor is only about 25% efficient. I then
loaded my motor to the full rated load and found that there was no lack of power. I
have not completed the last step of returning the exhaust to the input of the cells, but I
have every confidence that what he says he is doing is indeed a fact.'
It is not a device whose output power exceeds it' input power. However, this device is
very significant in that it raises the efficiency of an internal combustion engine, and in
doing so, achieves a reduction in the amount of fossil fuel being burnt in the engine.
This makes it unpopular with the oil companies whose objective is to sell as much
fossil fuel as possible, at as high a price as possible.
# Adds from 'D9.pdf' page 8-9, a Patrick Kelly file on different Electrolysers,
available at http://www.panaceauniversity.org/D6.pdf
If the engine stalls, the trigger impulses to the impulse valve stop immediately and the
electrolysis current stops as the alternator stops running. The electrolysis cells are
intended to run hot at about 85 deg.C. When the engine is started from cold, the
pulsed voltage applied to the field coil of the alternator is set at 24 volts. When this
increased power level starts to heat up the electrolyte in the cells, the voltage to the
field coil is reduced proggressively, until it reaches the 2 volt level, where very little
power is taken up in heating the electrolyte.
An electronic circuit (not shown) is arranged to fire the very powerfull Silicon
Controlled Rectifiers (SCRs or Thyristors) at the voltage peak of each output cycle for
its electrolyser cell. The coil shown between the cells and the earth (engine chassis
voltage) comes from an industrial 3-phase power supply. It is of very heavy
construction to ahndle the very large current, made with insulated copper strip wound
around a steel core. Each cell will have a controlled water-supply system as the water
levels will fall rapidly due to the very large volume of hydroxy gas being produced.
It has been suggested that the circuit would be more efficient if the half-wave SCR
circuit shown above were replaced with a full-wave arrangement. This has not been
tried yet, but a number of problems arise with that idea. Firstly, the cables carrying the
current to the electrolyser cells, show a reading of 900 amps when a standard clamp-
ammeter is placed around the cable. That is a very large current, requiring
exceptionally large cables to carry it effectively. If a full-wave circuit is introduced,
then the power diisipated in the cables will be doubled. This is liable to cause
problems unless the already expensive cables are increased in size. Secondly, the
frequency of the field coil electronics will be doubled as there will be twice as many
voltage peaks per second, so the circuit timing components will need to be changed.
Thirdly, the SCRs are already very expensive due to their very high current handling
capacities. If full-wave operation is introduced, either there will need to be twice as
many expensive SCRs, or Triacs of even higher specification will need to be used.
Since the design works well in its present form, there does not appear to be any reason
to modify it.
Intimidation in India:
We are familiar with the suppression of free-energy devices. In the USA there have
been literally thousands of cases - for example, Bill Williams for running his truck on
a Joe Cell, T Henry Moray for pulling kilowatts out of the environment and Ed
Gray for daring to have a power tube with an output power 100 times the input
power.
In Australia there is intense opposition to anyone using the Nitro Cell on any engine.
In New Zealand, to the magnetic motor of Robert Adams which is 700% efficient. In
the UK, to devices for water-splitting and permanent magnet motors. In Japan to
Teruo Kawai’s patented magnetic motor which is 160% efficient.
But in the last week there has been an instance of it in India, in spite of the fact that
the bus service in Mumbai has been run on hydrogen for some years now. A man,
who wishes to remain anonymous in order not to aggravate the current situation, has
just been picked on. He has been running a business for the last 23 years and has a
good relationship with his local Commercial Taxation Office staff.
That shows clearly that the “raid” had nothing whatsoever to do with taxation and the
Tax Office was just being used as an excuse to invade the privacy of an individual.
They spent six hours checking everything eventually left, taking commercial records
with them, and subsequently requested that our friend attend their local office on
Wednesday (the day before yesterday). He attended, sensibly taking people from his
business as witnesses. The six local officials were there and they returned the records
taken, stating that there was nothing wrong with the records or the tax position. They
also said that they were bewildered by the whole affair. He asked them about the other
three men, and they said that the Commissioners office had asked them to take them
along....and they have no idea who they were!
He then had a long conversation with the Deputy Commercial Tax Officer who had
came over to his place. He also seemed confused as to why they were hurried up to go
over to my place from the Commissioners office. He said that the Commissioners
office received a complaint from some higher authorities and these people were given
written instructions (an unusual thing in itself) to go to his office and make some
checks, usually this happens but the visits are done after 3-4 days of the receipt of the
letter from the Commissioners office based on the time allotment, but in this case
there were 4 calls directly from the Commissioners office to go over to his place
immediately !!
The raid in India is very interesting in that it shows clearly that the opposition are very
much afraid of Stan Meyer’s Water Fuel Cell. This implies that the cell is capable of
producing serious amounts of free-energy and can break our dependency on fossil
fuels. Patrick Kelly-2nd February 2007.
Update :
It Seems the spooks are trying to scare Ravi again ; Quote from a recent email sent to
panacea:
"I have just received a call about 5 mins ago on my land line asking me to stop
posting on the forums and youtube. If I still do they said that someone will have to
visit me personally to take care of it. I dont have a caller ID on the line. This person
had a British accent.
Please try and save all the posting till now on I dont know if I can post anymore...but
i'll try keep in touch".-End
Ravi and any one experiencing this is to file a complaint with the local police so that
it is on record and give them all details. Send us (panacea-bocaf.org) the address of
the police station and the name of the officer and the time he logged the report.
The other thing is to get Ravi the find out the names of the people who visited him
from the Tax Office and the positions they hold. Give the names to us and the name of
the person in charge.
The good news is that the device has serious potential if they are trying to stop Ravi
from finishing his research and development. You too can help by learning all there is
to learn about the Stanley Meyer Water Fuel Cell, the Dave Lawton replication of it,
and the available information on Ravi's replication. We would recommend consulting
Overunity.com , Youtube (search for Ravi Water) and getting in touch with Panacea-
BOCAF when your research starts progressing.
# Topic: Stanley Meyer replication with low input power (Read 18168 times)
http://www.overunity.com/index.php/topic,3079.0.html
You could copy all the info i've posted there under the user name ravzz and post it
here if need be. Just thought i'd help as many people to replicate my WFC before im
stopped again. Regards, ravzz
Now the reason why i wanted to post the replication info.......(Ive posted the following
for Bob Boyce on oupower)....
Its time we did something about the environmental mess the world is in.....its
accelerating by the year and it wouldnt be long before that the powers be would
realize that most of these changes are irreversible ......Vanishing Glaciers......melting
polar caps.....Europe has seen the hottest summers in living memory.......and now Asia
is going through the worst floods in the living memory.......we are heading for a
disaster and have already reached a point of no return with the fossil fuel
addiction.......time we make ourselves count....by helping others to make this
technology feasible and easy to replicate......whatever small contribution.....no matter
how much ever small to improve the air we breathe would go a long way for our
childrens future......
We need people to know this side of science before its too late.......look at the change
in the environment in the last 100 years......in the garb of development were ruining
the world we live in for the future generations and we are shown a picture of
development as prosperity.....actual fact being more the prosperity more we ruin the
environment for our creature comforts......its a vicious cycle....we could introduce the
alternate science at places where its hurting the environment the most atleast in a
small way....
Bob lets see how they take this experiment and what they make of it...I wouldnt be
surprised if some hooter comes onto the forum and starts rubbishing the work to make
atleast a few people stay away from experimenting this setup....
I'm just hoping that the risk im taking in teaching people how to make this expt work
wouldnt be for nothing!! I've been through some harassment before and can go
through some more if its for the greater good.
Guys ive posted all the info needed for replication if you want to or not is upto
you!.....well my work here is done!! GOOD LUCK!!
But this pulsed (probably resonating) setup proves that Faradays law can not be
applied with pulsed DC: production of O2 H2 is allmost identicall with 1A as I am
producing at 30A.
incase this link doesnt work then go here to the main page for hydrogen forums
http://www.oupower.com/phpBB2/viewforum.php?f=1
then go to 'Ravi's Meyer Replication - Tap water to H2'
Most of the questions you might have would have already been answered
there....incase you need to know something else post it here or on the oupower forum
so that I wouldnt have to answer the same thing again.
Any Ideas on why the efficiencies coming down when higher amps are given to the
freq gen?
The circuit given on page 7 with the inductors is what gives the highest efficiencies.
The inductor on both positive and negative is a must. Why would you want to build
one with the alternator? from what I can remember the page 7 circuit doesnt have an
alternator and you can power the circuit with a DC 10A converter like I did or use a
plain heavy duty battery for getting the output. If you want to experiment with the
other circuits in the document then its ok.... Good luck!!
The gap in between the pipes was: Outer Pipe OD : 25.317 mm ; Thickness : 14 SWG
or 2.032 mm ; Outer Pipe ID : 25.317 - (2.032 x2) = 21.253mm
Inner Pipe OD : 19.930 mm ; Thickness : 14 SWG or 2.032 mm ; Gap is 1.323mm
( 21.253 - 19.930 ) and this adjusted to both the sides as the inside pipe is centered is
1.323/2 = 0.6615 mm on either sides of the inner tube.
So effectively the gap between the pipes is less than 0.670 mm. I went for a lesser
gap by increasing the thickness of the outer tube.
If you go through Stans Canadian Patent he mentions that the lesser the gap
between the pipes more the efficiency. I had a lot of difficulty in the alignment of
pipe as they were shorting. Had to get them straightened on pipe alignment machine.
Wouldnt advice people without engineering skills to go for this small a gap. The
higher output of my setup could be due to the smaller gap aswell.
Your cell efficiency : 0.36 Wh/L ; Faraday efficiency : 2.3516 Wh/L (varies
depending to atm pressure) = OU : 644.62%
No doubt on efficiency. Just need to push the system a little bit further to produce
more gas while maintaining the efficiency. Great job.
If you go through Stan's patent 4,798,661 on page2 Figure 1 these variable resitors are
designated by the numbers 60a to 60n which are individually connected to each of the
inner tubes.
I have not tried the immersed excitor array in figure 1 this could probably increase the
efficiency even more!
There should be very high voltage at the cell as I remeber Dave saying something
about seeing a glow from between the tubes when WFC is run in the
dark.....could be HV discharging.....I havent checked for this though...
... Yes I used 12 Volt 10 Amp AC to DC coverter as the input to the Freq generator and
the reading you see in the videos are the current draw from this converter (the wires
are the input leads of the freg gen).
I dont know if im right but I seem to be generating 550% excess ; as the above works
out to 40.2/6.12 x 100 = 656.86% ; 656.86 - 100 (Faraday) = 556.86% OU !! Correct
me if im wrong with the calculations.
I remember watching on one of Stan Meyer Videos where they mention the Output
to be over 1700% faradays....I guess there's more work needed to be done in this
direction.
Dave's unit was 250% OU mine looks a little higher....one of the reasons I think is
because my unit is comparitively bigger 9" length 9 tubes compared to Dave's 5"
length 6 tubes. Stans was 18"length 9 tubes...double the size of my WFC.
Another reason for higher efficiency could be Dave's gap between the tubes was 1/16"
or 1.5875 mm and mine was lesser at less than 0.670 mm....calculations posted by
Stefan above. I'm using individual leads to each pipe in the WFC.
Actually, what about the Water Fuel Cell even resembles electrolysis? 1) There is
no electrolye; 2) There is NO current admitted to the water, in a proper system;
3) No heating occurs in the water as it produces gas; 4) The gas produced is
Hydroxy (aka HHO or "Brown's Gas"), not differentiated Hydrogen & Oxygen;
and 5) All of the work is performed by voltage potential alone.
1. http://www.youtube.com/watch?v=-WsKOdxLIJU
2. http://www.youtube.com/watch?v=u9XrLOudwRw
- Third pic is scum at the end of the conditioning...when you need to change the water
times.)
- Seventh and Seventh pics are the scum holding on to the tube edges which need to
be cleaned with a brush only...do not touch the pipes with bare hands. photo_116.JPG
- ravzz, Reply #38 on: August 25, 2007, 06:08:43 AM:
About http://www.youtube.com/watch?v=u9XrLOudwRw
Yes the current draw by the freq gen is 12V 0.5 Amps its from 12 Volt 10 Amp DC
converter that I use. The current reading you see is the input draw to the freq gen from
the DC converter. Everything you need to make this unit is in the updated D14.pdf in
the link below http://panaceauniversity.org/D14.pdf
including the inductors....which are very very important. Then comes the conditioning
which is crucial....how to is posted on oupower. Its a specific procedure that has to be
followed!
Dave who was the first to replicate stan meyer system had got outputs in the range of
250% OU (without the inductors, should be more now...he hasnt talked about the
outputs with the inductors). I have made my system based on his inputs and all these
inputs on how you can get these kind of outputs are already posted on the oupower
forum and partially here.
No I dont have a scope. My system was slightly modified and I have so many leads
going in as I can control the number of tubes that can be operated without opening the
WFC. I have 18 leads coming out of the WFC 9 +ve and 9 -ve.....with this I can run
on one tube or six like daves or all 9....you basically have an easier control on the
number of tubes to be used for experimentation without dismantling the WFC. Dave's
and Stanleys systems had a spacing of 1/16" (1.5875mm) and my pipes have a gap of
less than 0.670mm (could be the main reason for the higher efficiency in my unit) and
im using 9 tube sets of 9" length and the inner being 1/2" more than the outer for
connections. Dave used 6 tubes of 5" length for his 250% OU. Stans were 9 tubes of
18" length on his demonstration electrolyzer and in one of the videos available, there
are claims that he's making 1700% OU over Faradays. When compared to this
efficiency I still have some more work to do. Dave's electrolyzer generating HHO
with inductors as per the updated D14..... video link...
http://www.youtube.com/watch?v=OiA4z_Kpgg4
Stefan the excess gas outputs were documented quite sometime ago by Dave. There
are a few people who have connected the D14 system to vehicles.....here's a link....this
guy claims his mileage increased from 28 miles/gal to 45 miles/gal....thats an increase
of 17 miles per gallon.....he's even showing you how you can tune a WFC with an AM
Radio!!... http://www.youtube.com/watch?v=9fFp3CJZMTw
Everything you need to make this system is in D14 and the data which is required to
make this system efficient and how to go about it has been posted by me on the
oupower and here. You get very very low gas generation in the beginning when you
are conditioning like you see in the pictures above and below. I dont know why it
works the way it works or the theory behind why or how it works.......it just
works!......Make it follow the procedure and you will achieve OU over fardays!!! I've
put in efforts without thinking it would fail and it didnt...
I'm posting a few pictures of WFC under construction and progress.... The wall
thickness of both the pipes is 14 SWG or 2.032 mm
#1. Yes the SS wires act as resistors. The specificresistance of 316L is around 75
Micro-Ohm-cm and that of copper is 1.72 Micro-Ohm-cm. The leads heat up when
higher amps are drawn by the freq gen....you can see this in the videos I posted. I've
replaced the leads upto the bottom of the WFC with 4 Sqmm double insulated copper
wire and the heat generation did come down. I need to check if theres any increase /
decrease in generation.
#2. I have spot welded the 316L wires to the tubes. Used silicone to keep them in
place and avoid shorting. The tubes are plastic for insulation. Yes you can use copper
wire sealed in silicone sealant. Cover the exposed copper leads in the water with
silicone sealant as well.
#3. Stan's patent 4,798,661 figure 1 has variable resistance connected to each of the
inner tubes with numbers 60a....to 60n, this was what I was talking about. This is a
variation you can try much later on.
Hydro: When I tried conditioning the tubes at 3A to 5A range.....the resistors got burnt
so I got them replaced with higher wattages. Its as simple as that.
Well Hydro looks like you were right the WFC seems to be producing more!!
1.31min into the video the gas collection was started and stopped at 1.51min of the
video......20 secs to be exact. The gas collected was over 150CC could be 160 /
165CC.... As some might say that there could be Steam / Vapour / Mist......lets just
take the output as 150CC in 20 Secs.
This comes to 7.5CC of HHO/Sec at 0.48A - 0.50A. Last I checked with the old leads
was 7.0 CC HHO without any thing removed from the generation.
(MDG nov07: 7 cc HHO/sec => 420cc/minute = 25.2 L/hour for 6 Watts/hour => 0.24
Wh/L, exactly 10 times better than Faraday's maximum (2.4Wh/L) = 1.000%
efficiency !)
- Reply #88 on: August 29, 2007, 11:43:36 AM :
There is no reason For Ravi to Compile anykinda List and txt's etc for you, Ravi
Came out into the open with his findings, and if you where listening you'd know how
to do it,.
He said, Anneal your pipes, he said condition them, i'm not posting the instruction
because they're findable on the forums, he said do not use any resistance when
conditioning. he said use the lawton schematic thats been updated. He said the
conditioning of the tubes Is time consuming, you want get rid of the brown muck in 2
days!
It took him 3 months to condition his tubes based on what you see in the video. He
said Sand the inside and out of the tube after anealing, also to anneal in N type of gas.
The inside is Negative, The out Positive. Change water after every cycle, Dont leave
muck, Change water TIll you think you're about to fall over dead. The .50 amp high
hydrogen output can be achieved with the lawton circuit alone. he just bettered it.
Now, i say. Condition your tubes, you'll notice a White haz look to the Negative
electrode over a periode of time, you'll prolley notice the water looking orange, and
also that the positive electrode is ugly, and has no white haze. you should then Switch
polaritys for a while to get the positive tube to match the negative one, when you have
gotton this for you'll notice the water is still orange, and you can look into the
container and wow yourself with how much hydrogen it's producing. The goal is to
get the orange out of the water.
He has instructions for how to condition after being annealed. i have them to, so add
this to his instuctions because their totaly different. Start with 3 amps if you can
handle it, if not then 2, run the shit out of it till you see about an half inch of muck,
change water and repeat for 2 days. after everything apears to be normal, take the
tubes and run them under water, looking threw them to make sure they're not clogged,
if they're then dissasemble, clean with detergant and start over. dont worry, you can
clean without removing the white haze.
repeat repeat repeat . if you would have noticed he did take the time to tell you the
volts and amps used, and when you are farting around with phisics and making water
glow orange anythnig is possible.
Take this, save it, don't loose it, spread it, GOOD LUCK, I hope you'll listen to this
post rather than obviously not reading his post, thats why i know what you dont.
Good luck with the conditioning and don't pull all your hair out. Oh, my opinion is
when you start getting cleaner water you can start droping the amps to condition, but
he also has a diy condition instruction guide, i havent tried it.
Material used is 316L seamless pipes. Annealed for 3 hours in inert amosphere of
Argon to remove all residual magnetism and cold work stresses before they are
assemled. Leads used are 316L 1.2mm dia wires to all 18 pipes individually spot
welded. The inner pipe is 1/2 inch longer than the outer at the bottom for the setup for
connections. You need to be very patient with the conditioning of the pipes.....it took
me months to get the generation you see.
Volts x Amps = Watts ; 12 x 0.51 = 6.12 watts the generation is around 7 cc/sec ;
which coverts to 16.776 Lits / hour ; 16.776 x 2.4 watts (Faraday/lit/hour generation)
= 40.262 Watts
Well I seem to be generating the equivalent of 40.2 watts as per Faraday with just 6.12
Watts.........I hope this answers Kumaran's question aswell.
Alright now to the crux of the situ... I dont know how long i'll be allowed to post this
stuff over the net as initialy when I was in touch with Dave I had sent some pics to
him and my place was raided within a few hours after the mail to him. I was kind of
helped out during this time by Dave and Patrick Kelly.Though ive had success a few
months ago I had not come out in the open but now Ashtweth of Panaces Bocaf has
convinced me to go public as this could save me any more future harassment.....Im
taking a huge chance by posting this right now.... you can see more details of the
problem at
The above writeup is on a few other sites aswell. This had happened some time in Jan
this year. I'll try and post a few more videos using 12 Volts 1 amp 1.5 amp.... at the
earliest and post the links. Try and save the vids incase theyre removed.
- Mon Aug 13, 2007 6:36 am ; Generation of H2 + O2 was 7CC per sec ; the H2
generation was 4.66 CC/sec and this works out to 16.776 lits of H2/hr
- Mon Aug 13, 2007 9:20 am Post subject: Hi again, Posted new video a while ago.
Its almost 1 amp and look at the way the leads to the WFC get heated up and burn the
protective tubing. The tubing is in place so that the leads dont get shorted out. I have
individual leads coming out of the WFC for each of the pipes.
http://www.youtube.com/watch?v=fiyfwWuA9gA
- Big-bubbles: The conditioning would take time...just keep lugging and you would
end up with bubbles like the ones I get. The lights are pulse timing circuit visual
indicators.
- Mon Aug 13, 2007 11:09 am : For Markin: I think the suface area for higher amps
needs to be increased to get similar outputs as that of 0.5 Amps......so more number of
pipe sets should inrease the efficiency at higher ameparages. Its a presumption but
could be given a try in the future....any more ideas on increasing eff. at higher amps??
- Tue Aug 14, 2007 1:35 am : I would firstly advice you to go through all of stan's
patents to have better understanding of the process.
There is a lot of important stuff in the US and International patents wherein in one of
the patents he mentions higher efficiency of a tube setup compared to a plate setup for
his proces (so I just didnt want to experiment with the plate setup on his process but I
guess it works better with Bob's process). This answers your question Simon.
I could just give you everything but it could work for some and not work for some as
the voltages and frequencies vary as per the WFC build and the impurities in tap
water. I'm saying this coz till I made the changes when the components blew up on
Dave's circuit i didnot get the right combo. The exposed surface area of my setup is
much larger as compared to Dave's. He has 6 tubes of 5" lengths and mine is 9 tubes
of 9" length so there had to be variations and the thickness of his pipes is different
from mine...I have a gap of 1 mm between the pipes the outer tube thickness varies
this gap. The gap used by stan meyer was 1.587mm (1/16").. As per stan the lesser the
gap higher the efficiency.
Incase you are thinking of this gap youll have to use use three spacers of flexible foam
on either end at 120 degree angles in the gap.I say fexible because you would not
want any vibrations induced to be restricted as these vibrations help dissipate the
bubbles from the surface. If you are not that well versed with mechanical skills, I
would advice you to go for a higher gap as the space is very restricted and you might
end up shorting the pipes. In longer lengths you should look for slight bends in the
pipes as the pipes may get shorted. 1.5mm or 2mm gaps are also OK.
Patents show a variable resistor on the -ve side in between the WFC and the freq
generator which everyone seems to have missed out (incl dave) in the '996 patent.
This I had asked Dave about and he said it restricts the current going to the WFC.
Kumaran I had subtracted 100% Faraday efficiency from the total and what you get
then is the OU %. Your figure is for total efficiency of the WFC.
- Tue Aug 14, 2007 1:39 am ; You could always build Dave's setup without making
any changes including the pipe thickness, height and diameters and achieve the same
results as Dave did. His circuit should work for his WFC build size. Conditioning is
the key to his generation.
- Tue Aug 14, 2007 2:49 am ; DONOT USE 316L AS LEAD WIRE THEY HAVE
TOO HIGH A SPECIFIC RESISTANCE TO BE USED AS LEADS ; approxmately
46.8 times that of copper...incase you want to introduce a resistance you could always
used a wire wound variable resistance.
This seems to have been the problem of leads heating up. Specific Resistances:
Copper : 1.63 MICROHM-cm ; 316 : 75 MICROHM-cm
- Tue Aug 14, 2007 7:33 am ; I'm realy sorry about the patent number. its 4,798,661
and the variable resistance I was talking about is in Figure 1 with numbers
60a...to....60n on the inner tube.
I dont use a blocking diode. No there is no dramatic increase when you vary upuntil
you condition the tubes. When I initially started off I could hardly see any bubbles
emerging. But as the conditioning proceeds over a period of time you see the gas
generation gradually increase. At a point where i was generating a lot of small bubbles
I thought I reached the peak but I just wanted to see what would happen if I condition
a little more and what I ended up with was making these large 10mm sized bubbles.
Its not that the small bubbles accumulate to a bigger bubble but the moment the gen is
switched on the large bubbles come rushing out, you can see this in the vids. I wonder
if I condition some more I might endup with large bubbles only. Lets see how it goes.
The key to the whole process in my point of view is conditioning and this should go
on for a while even after you stop making the brown muck and you end up with large
bubbles like mine. It will take time but at the end of the day its worth it!
The dramatic gas increase happens in the range of 0.1 to 0.2 Amps in my WFC but
above that you just need to keep checking as to where you get the highest efficiency
for that particular WFC and it would be less than an Amp in any case. Look at my
outputs the efficiency decreases as you increase the ampearage to the freq generator.
- Tue Aug 14, 2007 9:46 am Post subject: CONDITIONING OF TUBES!!!!! Alright
guys make a note of this and save it some place
The conditioning process below was given to me by Dave Lawton and its what I
followed religiously for months to reach the outputs. Consider this as the holy grail
like I did and still do...
1. Donot use any resistance on the negative side when conditioning the pipes.
2. Start at 0.5 Amps on freq gen and switch off after 25 mins for 30 mins
3. Goto 1.0 Amps for 20 min and stop for 30 min
4. Goto 1.5 Amps for 15 min and stop for 20 min
5. Goto 2.0 Amps for 10 min and stop for 20 min
6. Goto 2.5 Amps for 5 min and stop for 15 min
7. Goto 3.0 Amps for 120 to 150 secs. need to check if WFC getting hot...if it does
you need to reduce the time.
AFTER THE 7 STEPS ABOVE LET THE WFC STAND FOR ATLEAST AN HOUR
BEFORE YOU START ALL OVER AGAIN. I used tap water for conditioning and no
vinegar or any additives.... I donot know if adding something might work or not.
You would hardly see any gas generation at the beginning but it makes a lot of brown
muck.....change the water after every cycle initially. DONOT touch the tubes with
bare hands if the tube ends need to be cleaned of muck use a brush but donot touch!!
As per my experience the brown muck if left in water for the next cycle heats up the
water and you need to avoid this.
Then you see the reduction in generation of the brown stuff over a period of time and
at a point the pipes dont make any brown stuff atall. You would have had very good
generation of gas by now. You get a whitish powdery coat on the surfaces. Never
touch the pipes with bare hands once this comes on.
The above process to be done after annealing the pipes....see to it that no oxide
formation is left on the pipes...use a detergent to wash off the pipes and rinse them
thoroughly with fresh water.....assemble the setup including the leads and
base.....finally flush the pipes with lots of fresh water......donot touch the pipes with
bare hands after this.......
Good Luck and happy conditioning......RAVI
Its a short time process so you need to passivate the pipes once they are assembled so
that you dont disturb the layer formed which is usually less than a micron thick.
If this doesnt work you could always revert back to the regular conditioning process
but you will have to disassemble the whole setup and sand paper the outside of the
inner tube and the inside of the outer tube to get rid of the passivated surface and
expose a fresh surface then reassemble and start.
Let me know if this works. PLEASE NOTE THAT POLISHED TUBES ARE NOT
TO BE USED IN MAKING THE WFC
If they are the only ones you can find make sure they are not Nickel plated or Hard
Chrome plated pipes and if they are Plain SS 304L or 316L but polished you could
always use a sand paper.
You can use most of the 300 series Nickel-Chromium Steels but 316L would be the
most preferrable and next would be 304L.......never go for 310 as this has the highest
resistivity among the 300 series. Avoid Inconel grade pipes aswell.
Is there a possibility that some thing like the Joe's Cell aether stuff is happening
here?? Even Joe's cell takes a long time to condition and even that produces brown
muck and doesnt do so after a while.....both have concentric tubes.. Needs very low
amps...there are similarities....
Is there a possibility that the extra work is being done by Aether? Is joe's cell
conditioning similar to the one mentioned above??
( 21.253 - 19.930 )
and this adjusted to both the sides as the inside pipe is centered is 1.323/2 = 0.6615
I had a lot of difficulty in the alignment of pipe as they were shorting. Had to get
them straightened on pipe alignment machine. Wouldnt advice people without
The higher output of my setup could be due to the smaller gap aswell.
You could try the above till you are successful to an extent and then start
experimenting with the variations and let everyone know if youre getting better
outputs.
O rings are a definite no no!! you will end up trapping some of the gas within the
tubes if you restrict the outflow....effectively this would end up reducing the exposed
tube surfaces to water in between the pipes and when you cut slots youre again
reducing the surface area !! small flexible foam cut to a length of 5 to 6 mm and a
width of 3mm.....insert the length inside the tube so the 3mm width is what you see
from the top...this way you can increase the gap for the gases to leave the pipe end.
Insert three foam pieces at 120 degree angles on both ends.
... You need to get the tubes annealed once they are cut and finished to lengths
before being assembled. Its done in a separate inert atmosphere furnace of N2 or
Argon. You have people who do heat treatment for metals .... they'll give you the
procedure if you tell them the grade you're using.
His method seems to work!! and he's connected it to his car aswell.....he claims to
have gotten an increase from 28 miles/gal to 45 miles/gal!! Thats an increase of 17
miles to a gallon!!
Check the video on how he tunes his WFC and his claims.
... You were asking me about the resistance on the inside tube sometime ago......as per
stans Patent each inside tube is connected to an individual variable resistance.....you
cant make those connections with two leads coming out of the WFC. I have 18 leads (
9 +ve and 9 -ve) coming out of the WFC. This way you can do all sorts of variations
you need without opening the WFC.
The transformer thing you're talking about are diode heat sinks of previous WFC trials
and experiments....but the diode setup is defunct ....im using the connectors at the
bottom of that setup which connects to the WFC there.....most of them are all old
wirings from previous trials....I was trying a lot of combinations and almost all of
them failed except the one recently posted....its all a mess up there.....Dont look too
much into it hydro....its as simple as it was in the updated D14.....conditioning is what
helped me get higher efficiencies and now check the link on top as to how this guy
tunes it and he talks about the white powdery coat he has!!.....this comes only after
conditioning!!
I had followed his postings and videos for a long time now....actually he's been one of
the inspiring factors for me to build my system....thanks again Aaron.
He goes by the names Aaron Murakami / a1c3m / Qiman13 on the net. He has his
forum postings on the WFC: http://www.energeticforum.com/renewable-energy
If youre looking for the exact technical language and the process...he's the man!!
- Ravzz, Posted: Wed Aug 22, 2007 8:46 am ; Post subject: Important
conditioning info :
Another thing I remembered after watching Aaron's conditioning video was, when
the power is switched on you see bubble formation on the external surfaces of the
outer tubes just like in the video ..... this happens all along during the conditioning
process.
I remember Dave saying that you know the tubes are conditioned when these
bubbles stop forming on the external tube surfaces and you see a white powdery
coat on the tubes.
I went on conditioning even after that and ended up with larger bubbles.
Has anyone seen someone using neutral electrodes with voltage potential? well I
havent.... looks like you have a new idea Kevin.... Definitely worth a try.
... Well youre almost spot on! The resistance wire restricts the current draw into the
WFC. Try it before the inductor and after the inductor...see which gives the highest
output. You dont need the resistance wire during the conditioning of the tubes its
only for reducing the current draw.
Even I didnt know what this was for.....Dave told me that it would reduce the current
draw when used.
Tell them that you need a bright anneal in nitrogen or argon atmosphere.
Annealing is done after every cold work operation and at the finishing stage to reset
the lattice structure. As we are cutting the pipes and slightly finishing the surfaces
with sand paper to remove any imbedded impurities during tube drawing.... its all cold
working .... so you need to relieve these induces stresses in the lattice through
annealing. I'm a metallurgist Hydro so you can stay assured about this. Its normal
manufacturing procedure.
316L composition: %
- Carbon : 0.03
- Manganese: 2.0
- Phosphorous : <0.45
- Sulphur : 0.03 max
- Silicon : 1.0
- Chromium : 16 to 18
- Nickel : 12 to 14
- Molybdenum : 2.0 to 3.0
304 SS has lesser % of Nickel and Chromium and doesn't have Molybdenum at all.
so judge for yourself which grade you would want to use.
Well if bright finish wasn't a criteria you could just use a gas torch to heat it up till red
hot and let it cool off slowly...but you would end up with a blackish bluish
discoloration. This is due to the oxide layer formation on the surfaces. I dont know if
oxidised pipes work better but they do have high corrosion resistance. For all we
know you might end up getting better outputs than any of us or the other way round
but definitely worth a try.
If it doesnt work that well you could disassemble the pipes and use sand paper to
remove the oxidised layers. They are usually a few microns thick.
By the way High Carbon Steels go through another heat treatment process called
patenting .... these are high tensile strength steels and widely used in spring making.
Please stay assured that we do anneal Stainless Steels at our plant. If you didnt know
even the copper wires you use everywhere are annealed....this is done on the wire
drawing machines itself.
... Being a Mechanical Engineer I dont know too much about electronics. i got my
circuit made by somebody and when ever there were problems I got them rectified by
the same person and kept track of what changes he made and I've told you what the
changes were.
Ravi, Do you know the approximate frequency at which you are applying the square
wave pulses to your WFC? The reason why is related to some research I did with a
well known 'water as a fuel' research group.....
Here was the crux of my interesting finding: The findings are based on this youtube
video from Dave Lawton: http://www.youtube.com/watch?v=miwbvsya3Ek ,
WATCH IT!
[4/1/2007 3:40:25 PM] Tao says: Just doing a simple calculation a tube in plain fresh
water, the equation from http://en.wikipedia.org/wiki/Acoustic_resonance shows
f=(n*v)/(2*L) where n corresponds to the harmonic, v is the speed of sound in the
water, and L is the length of the tube....
So, lets simplify this equation, n can be always 1, v is 1435 m/s in fresh water
according to Wikipedia.
So, f = (1*1435)/(2*L) = 717.5 / L = f , Just for fun, lets take the frequency Dave was
producing Hydroxy at in his latest video on Youtube: 3425.781Hz
So, 3425.781 = 717.5 / L , L = 717.5 / 3425.781 = 0.21 meters , So that would be 8.27
inches long.... So, how long in inches are Dave's tubes? Just curious........
[4/2/2007 11:26:20 PM] Tao says: So, I asked how long Dave's tubes were, well, I
looked up how long they were from an old post Dave did on the original forum back
in 2004...
[4/2/2007 11:26:44 PM] Tao says: Dave said that his tubes were about 12.5-13cm
(which is about 5 inches long)
[4/2/2007 11:27:39 PM] Tao says: so, calculating that into the equation: 717.5 / L = f ,
we have 717.5 / 0.1275 = f , so f = about 5650Hz
[4/2/2007 11:28:21 PM] Tao says: So, based on what it says at the END of that video
on youtube, it says that the hydroxy was being produced at 3425.78Hz
[4/2/2007 11:29:00 PM] Tao says: BUT, they acoustic frequency came out to be
5650Hz, so I said, 'oh, too bad' seems there isn't much of a connection, I guess I need
to do more research'
[4/2/2007 11:29:10 PM] Tao says: UNTIL, I just watched that video again..........
[4/2/2007 11:29:50 PM] Tao says: Look at what Dave was pulsing his DC at in the
video: 5714Hz!!!! At 1:11 in the video you can see what he was pulsing at.......
[4/2/2007 11:30:58 PM] Tao says: Based on the equation for acoustic resonance, Dave
was pulsing his tubes at the EXACT frequency at which those tubes will resonate
ACOUSTICALLY in FRESH WATER...
So, my finding was basically this: Dave found the BEST gas production at the
VERY SAME frequency that just so happens to be where his tubes resonate
ACOUSTICALLY IN WATER ... HMMM...
Maybe it is nothing at all but a coincidence, but maybe there is just something to
it........................
For now, here is the entire overunity.com Ravi thread in a zip file, all manually edited
html files, enjoy. 'ravi-overunity-posts.zip' , 2074.78 KB
http://www.overunity.com/index.php?action=dlattach;topic=3079.0;attach=12354
It was the origin of Dave Lawton's release of his replication of Meyer's system. It was
also the origin for the radianth2o yahoo group and qiman13
( http://youtube.com/qiman13 ) who has also been releasing videos just recently along
with Ravi's.............. Have a good read guys, this is the GENESIS material to all these
Meyer replications!
- Daves_Cell.pdf, 399.83 KB ;
http://www.overunity.com/index.php?action=dlattach;topic=3079.0;attach=12355
- Daves_WFC_Setup.pdf, 83.19 KB
http://www.overunity.com/index.php?action=dlattach;topic=3079.0;attach=12356
- Stanley_Meyer_Theories_and_Circuits.pdf, 496.09 KB,
http://www.overunity.com/index.php?action=dlattach;topic=3079.0;attach=12357
- Secrets_of_the_Water_Cell_Explained.pdf, 508.58 KB,
http://www.overunity.com/index.php?action=dlattach;topic=3079.0;attach=12358
- Bedini_SG_-_THE_Key_to_Meyers_circuit.pdf, 517.95 KB,
http://www.overunity.com/index.php?action=dlattach;topic=3079.0;attach=12359
PS - I was just looking up similar 83,000uF 50V caps to see what they could look
like, and they look very similar to the one in Dave's pic there...
Quote on the attached: "Paul estimates that he is getting the same output as Dave. He
intends to improve substantially on that, but he has to fix a leak in the base of the cell
before he continues development. His web site is "
Hydroxy post: "I am using a meyer cell with a Dave Lawton circuit. I increased my
gas milage in my ford escort to 45 MPG from 28 MPG. The Lawton circuit fryed my
alternator. My solution was a $20 dollar boat battery charger that plugs into a car
cigarette lighter. I use that to power my Lawton circuit now.
"I'm afraid that papers of that nature just leave me cold (no pun intended) as I gain
nothing from them. I don't think in mathematical structures.
The subject of radiant, or "cold" energy is not well defined at this time. Our familiar
conventional electricity appears to be a transverse oscillation while the "cold"
component appears to be a longitudinal oscillation. Consequently, none of our
instruments react to cold electricity and while it can power lights, motors, heaters,
etc., the only way to actually measure it appears to be to charge a lead-acid battery
using it and then measure the power stored in the battery by discharging it. John
Bedini remarks that after forty years of searching, that is the only mechanism which
he has found.
Electromagnetic pulsing appears to be the main way of accessing this energy. Bob
Boyce's electrolyzer gets 10 x Faraday's supposed maximum, through magnetic
pulsing of a hundred stainless steel plates in a row. This is effectively pulsing a
hundred capacitors in series as the electrolyte is essentially a dielectric. Bob gets a
major power gain by pulsing windings on a toroid, which is definitely a significant
shape for cold electricity. The power gain can be 10,000 amps of hot electricity, and
as that is effectively the "losses" where cold electricity is concerned, the real "cold"
power is so much greater that it can trigger a ground feeder leading to a lightning
strike. Bob found that out the hard way and was very lucky to survive being hit by
that lightning strike.
The toroid is at the heart of many different COP>1 devices and its effect can be
simulated by generating a rotating magnetic field without a toroid (devices like the
Adams Motor for example). That of course, is not the whole picture, as Thomas
Henry Moray achieved massive power input without anything like that, so how do
you explain input from an aerial as that appears fairly passive?
So, the bottom line is, that while I know that cold electricity can be tapped with
rotating magnetic fields, strong dipoles (including sharp DC pulses and permanent
magnets) and passive devices like aerials, Coler devices and the Joe Cell, it is clear
that I really don't understand anything significant about it.
In the first image, Meyer's simple EEC is shown. In this setup, the 'amp consuming
device' is analogous to Lawton's light bulb. When the water in the WFC is being split,
electrons are dislodged from the water and as successive positive pulses happen the
electrons are effectively 'sucked up' by the amp consuming device. So, there are
electrons in the water free, and when a positive pulse comes, the electrons move to the
right electrode and move through the 'amp consuming device'.
In the second image, Meyer upgraded his setup and included a triggering mechanism
whereby he can choose when he applies the positive pulses to the 'amp consuming
device'. So Meyer could send some pulses to the WFC plates and split up the water,
then he could trigger the switch and send pulses to the 'amp consuming device'
whereby the electrons from the water would flow through it.
See large size image: eec-meyer-lawton1.gif, 98.65 KB, 800x1150
attach=12479
See large size image: eec-meyer-lawton2.gif, 136.93 KB, 800x1150
attach=12481
Lawton on the other hand, has modified Meyer's EEC a bit with the addition of those
extra high capacity caps. These caps would, by thinking about it, charge up via the
continued HV pulses that are being applied to the WFC, analogous to a Bedini type
setup. The electrons would then move to and from the caps and cause fluctuating
current to hit the bridge rectifier and power his load.
I have done just that on my pipes... the extra lenght sits at the bottom and flush at the
top. I calculated the surface area of the inside of the the outer pipe and adjusted the
lenght of the inside pipe to have the same surface area. They sound identical when
struck like a tuning fork..
Because of the electrical activity, a bifilar coil does not work against itself in the form
of a counter - e.m.f., the potential across the coil quickly builds to a high value. The
difference between the turns becomes great enough that the energy is practically
all potential, at this point, the system becomes an electrostatic oscillator.
Minimal work is done in my radiant energy system due to the absence of wasted
displacement currents. As small heat losses occur, oscillations are maintained by
surplus charge generated by atomic catalytic reactions, energy is siphoned from the
kinetic moments of these charges.. After an initial input of energy from an outside
Very low energy expenditure allows power delivery to an electrical load over an
extended time period without an external fuel supply source, the radiant energy
electrical generator will operate as a very efficient device.
The parts highlighted in red seem very very relevant in WFC context. So bifilar
inductors are worth a try.What do you think?? any ideas on how we should try it??
Also Could you check up on the following link and see if it actually works for a
WFC? http://jnaudin.free.fr/html/parabifc.htm
In regard directly to the Tesla bifilar patent and setup itself, I mention in the above
thread a Mr. Milan Manchich. He used a flat Tesla pancake coil, and applied a HF
voltage to the inner or outer wire of the pancake coil, and on the opposite wire of the
pancake coil, he placed an 'Avramenko's Plug'.
http://www.keelynet.com/energy/milan.htm Please see the thread directly for the links
to Avramenko and the like.
Tesla was the KING of voltage POTENTIAL, so I think these paths of research are
good to follow to potentially lead us to the best WFC control circuitry.
Seems logical to add EXTRA calcium to the water to speed up the layer forming. You
can just buy it at the the pet shop. Used to add to RO water for fishtanks... Robert
- Gh. J., Reply #245 on: September 07, 2007, 11:26:48 AM:
Calcium Oxide coat is Aaron's presumption/deduction and he says it could be
anything ! It hasn't been analysed ! There are a lot of mineral salts present in natural
water.
There is a possibility that with the increase in Amp process mentioned by Ravi, there
are different kind of mineral / deposits layers formed on the inner tube surface! Don't
know if Aaron used pulsed 10V 2Amp DC or straight. Ravi's was pulsed! So just be
careful which process you follow! It's not just a layer that you need to create but the
RIGHT kinda layer!
This could be proven if it works or not by Aaron himself if he checks for the
difference in gas output, before and after the conditioning ! Gh. J
So guys just build dis n you'll know it works!! U have a replicated proof now!
Message: There is increase in production for same input. Actually, I will post msg
about it. The amps reduce over couple hours by couple hundred ma's meaning that
there is more restriction and gas "appears" to be identical. Didn't measure gas but with
amps reducing with dial on variac same...same production for less.
Please follow the overunity forum aswell........ there seems to have been a success
with the conditioning reducing the Amp draw with the same gas production!!!
The same questions are still being answered as to why this can happen!! Just build it
follow the conditioning procedure and youre on!!........it works people....dont think too
much about how or why it works.........IT JUST WORKS!!
we can ascertain whys or hows after you have a working prototype....the science can
follow later. Please check the new updated Sept 4th D14 for the conditioning process I
posted on this forum.
I've taken enough risk again posting on this forum.....dont let this technology die
again! RAVI RAJU
Anyways, had also a maybe silly thought of just making some test tubes and try to
coat with different materials and see if the effect might be similar to conditioning....
havent put it into practice yet.
The oxide layer is now quite thick on the inner tubes and a greyish white, but whats
interesting is that the more I condition the tubes the more frequent the larger hydrogen
bubbles are becoming.
The buz-350 has a reverse recovery time of 180 ns and the 32n20c has a reverse
recovery time of 265 ns witch is slower. This should work fine in this circuit. Also,
the 32n20 has half of the internal resistance .06 ohm so it should run even cooler than
the buz-350..Looks like a good choice and it is cheap. Most ultra high speed diodes
have a 50ns on time or less witch should work well in the d-14 circuit. The diode
could somewhat effect the tuning of this circuit.
Ask people on the forum to follow the Conditioning procedure that I gave as you
get very uneven coat formation on the surface if you use High Amps for long
periods....and when you go above 3 Amps theres a possibility of the coating flaking
off...the bonding between layers would not be that strong....these layers form one over
the other after every cycle of conditioning.......the small time high Amp conditioning
gives you an uneven coat and the long time low Amp conditioning evens out
this....more or less. The longer you use Low Amp conditioning the better the end
outputs!
You could end up blocking the space in between the tubes and you'll have to
dismantle the pipes and start all over again. We dont yet know exactly as to what the
coating comprises of! As there are some High Voltage discharges
(Probably....reason...glow in the dark) they could be some very exotic alloy
compositions formed....as the temperatures for a fraction of a second at the point of
discharge go into thousands of degrees C.
Tuning is likely to remain an individual task, in terms of getting the given unit to
operate. This is likely to be true, until the exact operational parameters are well
understood. At that point..it is likely that broad levels of 'repeatability' can be
achieved.
Of course, the AMP CONSUMING DEVICE refers to any loads (preferably resistive
loads) which use power in a normal fashion.
I think another example of what Stan Meyers is talking about is the Kanzius affect. So
the radio waves cause the water to split with the salt serving as a catalyst. Once the
water is turned into HHO and it is lit, it starts to attempt to combine back into water.
This would usually lead to a small explosion and the recreation of water but that does
not happen in the Kanzius experiments. Instead as the HHO attempts to form H2O it
is unable to do this because the radio waves are exciting the gas and it is staying in a
plasma state giving off 3000 degrees heat as Stan Meyer's said. Is anyone working on
a Kanzius recreation?
now we are finally getting to the root of things, impulse tech. gerry vassilatos has
written quite a bit about these fast interruptions of DC, pulsing them to a specific
frequency, and what Tesla discovered he was able to accomplish.
when you print it out you will need to mirror image it ie horizontal
flip it
- Runningbare, Reply #378 on: September 20, 2007, 04:33:36 AM :
Very interesting, of course I had not considered the obvious, the tubes are in fact
capacitors to the the current flow and since its straight DC or pulsed DC they will
charge impeding current flow, so adding more tubes will not substatially increase
current flow, only the initial current will be high at turn on until they reach potential.
btw, this can also be found in the "Stan_Meyer_Full_Data.pdf" page 230 paragraph 4.
- Gh. j., Reply #397 on: September 20, 2007, 06:25:11 PM:
i'm sorry but if you are using the lawton circuit alone this will not do anything but
limit current, the back emf is wasted, if you are going to use this whith out a use of a
transformer you should use this circuit, therfor it does not wast the back emf as the
first picture, if you was to use the first picture you pasted it would work fine with a
transformer, but the second added diode is not doing anything, and the direction of the
chokes must be hooked the right way.
using the same core means sharing a magnetic field, if hooked improperly you loose.
the core inside the choke takes on a discharge effect, when sharing cores the discharge
emf effect falls faster, it is better to use single cores so each chokes can fall at it's on
electro magnetic field rate.
it is very important that the 3rd cycle of the transformer hits the chokes at a discharge
level, if the transformer hits the chokes on the 3rd cycle and they have already been
dishcharged caused by using the same core, then you loose again.
Try to use a ferrite core torroidal to step up voltage connect to the inductors
(individual and regular wound) as mentioned by Spewing on Overunity thread as of
now as the bifilars are creating some problems...I blew up both the 1200V 40A
diodes....looks like one of the tubes ( no.7) has shorted...no gas production. The
voltages might have gone very high with the bifilars connected and theres a
possibility that this is creating problems for the smaller gap to short out. Dont use the
bifilar inductors till we have a proper understanding of how they can stably work.
each time the cell is step charged the voltage across the cell increases, each time the
cell increases in voltage the output from the transformer to the chokes is increased,
and stronger emf is emitted. once the cell reaches its peak the transfromer is now
putting out over its maximum thousand volt rating because of the series positioning of
the chokes. the second side of the circuit is now resonating, meaning the circuit, not
the water fuel cell.
each time the cell takes on a step charge the amount of amps in pulses applied to the
primary side of the coil drops, when the cell becomes completely charged hardly any
amps is consumed from the primary side of the transformer.
## Mars 2004, First Meyer's Public Replica, by Dave Lawton, Extracts from
downloadable pdf file:
I used 304 ss tubes 13cm length, outer tubes 25mm diameter, 1mm wall, inner tubes
22mm diameter, 1mm gap spaced with plastic tiwraps. They were mounted on a
acrylic disc which had holes cut to match so the outer tube was a tight fit also set in
epoxy. It was then mounted on spacers and screwed with ss screws to the screw on
base. Also wrapped a copper wire coil which is hidden by the lower plastic coupler to
sync the protons and see what effect that has, a bit like a proton precession
magnetometer.
Welded ss cheese cutter wire to bottom of each tube using a car battery, works well it
you are quick ! The case was made up from two 4inch diameter waste pipe couplers
with two screw on end cap I bought from a builder merchant for about L7. The clear
12 inch Polycarbonate tube cut to size was L26, ... gllued with polyzap to secure. I
need to design a multiplexer switcher next for it and also condition each tube before
use
... I still experimenting with the Tesla cell and have used many configurations to drive
it including Meyer VIC. I am begining to finalise a circuit. ... 2n3055 power transistor
in common collector mode. This is driven from a 555 timer at frequency of 11KHz
with a Mark/Space 78%, the timer is buffered with a couple of low power transistors.
... To get results the tubes have to be conditioned over time, it is an alchemical
process, a film is formed on the surface, that is only one of the key processes going
on.
Hi, for those who have tried to replicate the xogen.com patent this may be of interest.
Here are my test results that show the xogen claims are true.
Gas = 137cc, Current true RMS = 0.1875Amps, Time = 21mn, Volt across Cell true
RMS = 1.5V + 2.4V Cell Potential = 3.9V, Power = 0.73Watt. Hydrogen = 91.3cc,
Oxygen = 45.7cc. By Faraday calcs for current 0.1875A @ 21 minutes =
Hydrogen=27.7cc and Oxygen=13.8cc
Compared with Faraday calcs we have 3 times more GAS. Xogen claim 3 times more
Gas, this replication backs that claim up.
... Watts = True RMS current 0.1875A x 3.9V= 0.73125 Watt ; Waveform accross cell
= square wave, frequency 11.33 Khz, duty cycle Mark 78%, space 22%.
... Tubes spaced with pieces of plastic tywrap to give 1mm gap. As regars to Xogen
patent, that works but I don't like the design and have improved the output by using a
medium power transistor BUX87P forming a Darlington pair with the 2n3055
Transistor but in common collector mode to give a low impedance output. I have pics
and a video of my Test Cell on icube forum if you are interested:
http://www.icecubenetwork.com/files/watercar/non-commercial/dave/
... Ran a straigth DC test to compare: for 480secs @ 300mA and 4.2Volts and
produced 25cc of Gas ; by Faraday predicts 16.9 Hydrogen+ 8.45 Oxygen = 25.35cc
gas. Pulsing appears to increase gas production. At the moment I am trying to
replicate Stanley Meyer's System, I get any results positive or negative I will post
them.
23 October 2004, in a post from LaserLine, p20 of this pdf file: Dave gave this to me
today and I'm assuming a lot of you might be interested in this considering this is the
2nd highest viewed thread in the forum.
... A post from Freedomfuel, Oct 24, 2004: Daves comment about having to condition
the cell by allowing a film to develope on the electrodes is interesting because this is
what the cold fusion guys do with their cells. They sometimes use dual concentric
electrodes like Dave's one of which is made of polished aluminium. The electrolyte is
Potassium Carbonate. A 12V DC supply is connected to the cell with the positive lead
going to the aluminium electrode. A very thin, insulating anodic film developes on the
aluminium electrode. Then the polarity is reversed so that the aluminium electrode
becomes the cathode during the experiment. Since the electric field strength is the
gradient of the potential across the anodised film the electric field is strong enough,
despite the low voltage, to enhance the production of charge clusters at the cathode.
This is visible as a pink glow in the electrolyte and if you look carefully you can see
tiny sparks coming off the cathode as the charge clusters leave an ionized trail through
the solution.
In a previous post I suggested that you could make the cathode a wire inside a tube for
the anode. Due to the much smaller diameter of the cathode compared to the anode
the field lines converge towards the cathode giving a high enough potential gradient
near the surface of the cathode to facilitate the production of charge clusters.
(The next article below this one was also extracted from this file a few months ago)
You may generate H2 with the circuit referenecd above, but it does not wholly
conform to Meyers' teachings, and will not enable one to achieve the necessary
resonance for Meyers-Fracturing of the water molecule. He used high voltage AC, via
a torroidal core transformer. Further, his electrolysing circuit was isolated from the
primary side (MDG nov07: like in Bedini circuits, to protect against the Radiant
Energy Spikes, that like to fry electronic components), and importantly, two chokes
are employed (one adjustable) to achieve a special resonance condition when coupled
with the concentric tube capacitors (WFC's). Resonance is the key to the whole
matter, and without the chokes, which are absent in the above circuit, no resonance is
possible (MDG nov07: without choke, no back EMF = no Radiant Energy).
... The resonance frequency depends on the gap between the plates, composition of
the water, tube length, and the inductors you use.
This info should easily get one close to the resonance condition for a given WFC;
using an adjustable choke for one of the chokes is of high utility.
MDG feb07: Personnal Remark: It seems that Stanley Meyer was using John
Bedini's concept of short pulsed DC current in coils, like in his patents where John
uses coils and batteries as dipoles, that create Back EMF, 'pumped' ZPE that comes
and makes the electrolysis job in the cell, without heat; and that seems the easiest
way to produce liters of Hydroxy per minute with an input of less than a Watt ...
Off course the pure resonance of a volume of water could also be found, applied
directly to this water, like in Mateiro electrolysis, or John Keely's experiments for
example through sound waves, but it looks much more difficult, because of much
more parameters involving, and always changing (ex. temperature, acidity, volume
total, ...), and may be the need of multiple waves sent simultanously.
A bit of Maths: Dave reported the production of : GAS = 137cc ; CURRENT TRUE
RMS = 0.1875 Amps ; TIME= 21 Min ; VOLTS ACROSS CELL TRUE
RMS=1.5Volts+2.4 Volts Cell Potential =3.9 Volts ; POWER WATTS =0.73
That gives: 137 cc of gas / 21 minutes = 6.52 cc of gas / min with 0.73 W of power. 1
Watt of power would give 6.52 / 0.73 = 9 cc of gas/min
If we compare this production with our standard 2x6 cells in serie, straight DC
electrolyser, described above, giving 1 L of gas per minute for 210W of power (15
Amp x 14 Volts),
An add on can be another 555 standed astable circuit with its output connected to pin
4 of the 555 so to toggle it on and off. The 555 s can be run from 12v but the mosfet
can be 35v. Best Regards Dave
- Hi Simon, First step is with new tubes is to clean with a detergent ie washing
detergent, this will remove any film which bubbles cling to, it will act as a wetting
agent. I then run the reacter in short bursts say 5 to 15 mins, remember you need to
vent the gas outside. I have done this over a few days until you build up a polarization
on tubes so that it looks like a battery , my tubes have a potentional of about 2.2 volts
across them that is for two in parallel. hope this helps, Best Regards, Dave.
- No nothing to do with the Hydrostar just a choke in series the same as Stan
Meyer`s method. The Hydrostar ferrite in my opinion is nonsense because the flux
will all be contained in the core. There seems to be a bit of fog about this I think the
idea came from proton precession magnetometers, the angle of the precession of the
hydrogen protons can be brought into phase on application of a magnetic pulse. Best
Regards, Dave.
- Yes you can do without a gate resistor, but if you do and remove the drive the fet
buz350 will stay switched on, in a test circuit I can do without that. And viceversa you
can still obtain the same amount of current as without a resistor by increasing the
mark pulse .
- Hi Gary What you are saying is true. "The Real Problem in Answering your
Question is What water was he Using. Conventional Tap water is Quite Low in
Resistance. Distilled water is Higher in Resistance. Water with Baking Soda is Really
Low Resistance". But in practice the space is filled with gas bubbles, on switch on the
cell will draw a couple of amps, you get a high speed flow of gas. The trick is to
back off the current, if you get it right you will see high voltage spikes of a few
hundred volts across the cell. Best Regards, Dave.
- ... what I found is that a few amps of current is needed to condition the cell. When
conditioning is completed you can back off the current. I saw a good idea somewere
of someone using a modified power converter, if you can get it off the shelf use it, I
think it was using a pulse width modulator chip KA3525A Fairchild driving Fets to
high frequency transformer. Thats the way I am going at the moment. The nice thing
about this chip is that it has a shut down pin for the relaxation time as in Stan
Meyers circuit.. Only using one choke at the moment, still exploring other
posibilities.. Best Regards Dave
; http://www.ee.surrey.ac.uk/Workshop/advice/coils/
- This may be of interest to John, its a test I did last year using Kanarev`s information:
One litre of hydrogen weighs 0.09 gram:One litre of oxygen weighs 1.47 g. It means
that it is possible to produce 111.11/.09=1234.44 liters of hydrogen and
888.89/1.47=604.69 litres of oxygen from one litre of water.One gram of water
contains 1.23 litres of hydrogen
Energy consumption for the production of 1000 litres of hydrogen is 4 kWh and
for one litre 4Wh.It is possible to produce 1.23 litres of hydrogen from one gram of
water,1.23x4 =4.94Wh is spent for hydrogen production from one gram of water.
Energy Efficency of this WFC is 349 % or overunity ; Date of Test : 15 June 2004
Done by D. Lawton
- This is trying to replicate Stan Meyers method of driving a WFC using a car
alternater as in US Patent 4,798,661 Fig 5 "Pulse voltage frequency generator". Also
shown in the UK channel 4 documentary "IT Runs On Water". There is clip of this on
the web site wasserauto.de showing the alternator and wfc. The alternator input being
pulsed by The rotary pulse generator. I think it was a bit economical with the truth
although it showed less than an amp into the alternator there was no mention of the
current into the cell.
The setup I used was a modified alternator, cut the connections to the rectifier
stack and regulater and made three new connections to the phases which were brought
out to a new set of rectifiers and wired up as fig 5 in above patent.
The current being drawn by the cell was 4.5 amps average.The driver I used was a
power fet with a 555 timer generator to drive the rotor of the alternator. The
Scopeshot shows the waveforform across the cell, 20 volts peak. Frequency 500hz,
pulsed at 2 Hz. My power supply to the driver was at 12 volts and a input to
alternator rotor 800 milliamps average. Best regards, Dave.
That's one way to check your results. If the pH of your test cell increases as hydrogen
is liberated over time, then you're doing conventional electrolysis. The precipitation of
carbonates and hydroxides will eventually cake up and cause you a mess.
The fact that Meyer's direct H2 injectors functioned so long and had such tight
tolerances, seems indicative that he wasn't producing precipitates which implies
that his pH was constant.
Also, Meyer mentioned using seawater as a water source. But electrolysis of seawater
will produce hypochlorite, a.k.a. bleach, until the point is reached where there are no
cations present to counterbalance the charge of additional hypochlorite, at which such
time chlorine gas will evolve at the cathode. Free Cl2 is not a good thing to expose an
engine to. Whatever fraction of it doesn't react with the hydrogen in the fuel or the
interior components of the engine, will be expelled as aqueous gaseous hydrochloric
acid, which is hardly an environmentally-benign substance !
- If you produce HCl, the acid will eventually build up to a concentration that will
destroy your electrodes, and of course, anything it touches. Maybe even your engine.
Considering the downside of using saltwater, it might be better if you found a way to
use the exhaust heat from your engine to distill the saltwater.
Hydrogen won't strip lubrication, it just doesn't provide any lubrication. Diesel
engines are designed with a dependency on the lubricating qualities of diesel fuel.
High carbon steel is less flexible than regular steel. High hydrogen steel is less
flexible than high carbon steel, to the point of being brittle. If engine parts don't flex,
they break. Metals within most engines contain plenty of carbon due to the high
carbon content of most fuels. In order to maintain the protective carbon content within
the metals comprising your engine, you will probably have to continue to use some
fossil fuel as you have indicated.
As I recall, Meyer did have to clean his system if he used anything other than
distilled water in it. Coffey.
- Something curious about Stan Meyer's cell was brought up by Peter Lindemann in
a KeelyNet conference (you can google video for it under 'free energy' about 1:34
into the video). He said Stan Meyer's design was simple enough, in that all it did was
build up a charge in a capacitor (i believe that would be the cell itself) that reached
catastrophic peak, then dumps that charge resulting in the fracture of water. This of
course is repeated several times in the course of a moment (very vaguely speaking
with my zero knowledge).
(MDG nov07: See below my transcription of this video, the part concerning Stan
Meyer, that is also on Youtube.com)
- I can see the need for the dual frequencies when using the high voltage designs.
Particularly when using Meyer's rapid-fire pulsing. Shutting off the pulsing at regular
intervals as Meyer does, allows for a settling time (or a re-gauging time) for the water
to settle back down to a lower voltage. Since Meyer is using high voltage AC at a
mostly positive potential (due to the duty cycle), the water will eventually charge to a
high positive potential, at which point the electron flow will become thinner and
thinner. To put it another way, since the electron flow created by the single polarity
application of a high positive voltage is the catalyst for excess gas production, the
pulsing has to be shut off on a regular basis to allow the water to regain its lost
electrons.
But in the low voltage AC designs, the low voltage AC current is allowed to make a
complete circuit, so that electrons are fed into the water as fast as they're removed.
Thus, there is no reason for a re-gauging period since the water is constantly getting
all the electrons it needs to maintain the electron flow. The water also remains at an
overall potential that's fairly close to zero volts.
So, if one uses the pulses of the three phases of an alternator, one shouldn't need any
timers at all. Coffey.
- I know a patent has been applied for on a device that uses two radio frequencies to
fracture water. The guy uses both a UHF and a VHF frequency to do the job. RF being
what it is, the effect only takes place on the surface of the water. In order to create
more surface area, he uses a spray nozzle to create a mist inside the reaction chamber.
He also heats the water to near boiling.
Seems to me that Stan Meyer used a pulsating magnetic field and LED light at certain
wavelengths to augment production. I know he used a pulsating magnetic field and
LED light to help raise electron orbital paths on individual oxygen atoms so he could
strip more electrons off. My understanding of the results of doing this is the oxygen
and hydrogen can't easily recombine, and attempts to bond during ignition create even
more heat than normal. Coffey.
- My question is this: With the blocking diode, doesn't that prevent resonance?
You also mentioned somewhere that you could tell no difference with the choke or
without. Also, if it cannot resonate with the blocking diode, doesn't that mean that you
are really pulsing the + on the water cell with longitudinal pulses and that is more
important that resonance? Maybe it can resonate with the diode, but I'm not sure how.
With the pulse on, the inductor is charged. When the pulse is shut off, the inductor
relaxes and its charge in the same direction towards the + on the cell. So wouldn't the
cell + be getting spiked with a frequency double that of the pulse generator? One from
the initial spike and one from the inductor when it relaxes? So maybe the effect has
nothing to do with resonance really but frequency is definitely important. If not
resonance, then a straight longitudinal "wave" pulser? Everything is unidirectional.
Qiman13.
- Thought of using a pump to circulate the water thru a filter, but have found that if I
use powerful magnets at the bottom of the cell the water spins. This could be a no
external energy way of accumulating the crap. Still playing about with this idea as
pulse coils will probably have the same affect. Gary.
- Hi Gary, what material is your plates or tubes made from? I use t304 steel tube setup
and I get no gunk. The only thing that even appears to corrode are the non ss leads
that connect to the positive tubes.
Also, if getting gunk, then most likely you are getting too much regular
electrolysis. The idea is to prevent current from doing that. Therefore, no oxygen
can go to your positive plates/tubes and oxidize them.
The circuit is not a resonant circuit. The water doesn't go into some magical
resonance. The blocking diode should be telling you all something. No resonance.
The voltage never drops to negative.
3 very good basic examples. Unidirectional DC pulses are not transverse waves. They
are longitudinal impulses. The whole secret is sending TIME IMPULSES to the
water.
What the goal is is to pump the water with radiant energy. This is nothing but pure
voltage potential with no current. When it is done right, you can create the voltage
potentials without ever inducing electrons to flow to begin with. Imagine not
having all the problems of having to restrict amps. I will be happy to share this with
anyone who is serious.
- The most current test I did. I used a variable ac which has 5 amps max and 150v
max. Output thru bridge and pulsed DC through a diode and that straight to my tube
setup. This was only to test the cell. Without the inductor, current of course
jumped up to about 3-4 amps at only about 7 volts. When I put the inductor after
the diode, I could crank it up to about 25 volts and the amps were only as low as
about 400-500 milliamps. Just had to see for myself that this was happening.
... Imagine this and you can all test it for yourself. Hit a capacitor at high frequency
with nothing but the voltage potential spikes and it WILL charge up, however,
there is no current moving. Sounds strange but I can go into details later. Just try it
and you will see. How can a capacitor charge up without current? That is what you're
all trying to do with the water cell. You're charging it with pure voltage potential
and NO current. Imagine having an input that is voltage potential spikes as well and
no current...very very very efficient!
I'm talking about pure radiant energy. Radiant energy ARE the voltage spikes you
make. Those spikes are radiant energy with NO electrons. There is a small amount
of current in these systems and that little bit is just enough to rip the molecules apart
and it is pulsed so there is no steady current. On the collapse, all those molecules have
access to a sea of potential radiant energy that have been pumped into it.
The radiant energy comes from vacuum energy. The virtual photon flux of the
quantum mechanical vacuum. The dipole (battery, etc...) breaks the symmetry of the
virtual photons and they move towards the polse on a battery and flow over the wire.
The power to power a lightbulb from a battery does NOT come from the inside of the
battery. The electrolytes do ONE thing and ONE thing only. Separate their internal
charges to create a high and low potential at the electrodes. It is the vacuum energy
from 3d space and time that move toward the electrodes and over the wires. This flow
is what induces the electron movement to have current. That flow can be manipulated
to move over wires in a way that induces NO electron movement, therefore there is
NO current ... only voltage potential.
... I am confident though about the concept of what Meyers' was doing. Pumping
radiant potential into the water with no current or at least a bare minimum. Meyer
4798661 patent has the schematic that is nearly identical to the one used for
battery charging of Bedini...
The coils I'm using are 1:1 turn. 12 volts in and the collapsed pulses are nothing but
pure potential spikes of about 250-300 volts but virtually no amps. Those are going
through a bridge to charge a cap. When the cap is charged up, it is discharged into
dead batteries.
How can that be if the turns are 1:1?
1:1 is the most efficient coil for producing the radiant spikes that are devoid of
electrons.
- According to my research extended periods of water electrolysis will cause the build
up of an insulating film on the plates which will cause the apparatus to heat up. The
film may originate from impurities in the water such as calcium which could
explain why Xogen required tap water for their cell to function fully. In a science
experiment in which pure water is used the explanation provided is that Hydrogen
at the cathode (have I got this right?) could combine with say Nickel in the
cathode to make a Hydride compound.
- If you do a Google Search, you will come up with Hundreds of these Ignition coil
circuits. Most of them just use a 555 driving a Mosfet.
But if the Purpose of this is to Produce hydrogen through Electrolysis, I suggest you
stick with Low Voltage and a PWM Circuit. Even Though you might have a High
Voltage coming out of that Ignition Coil, You will NOT have High Voltage going
through the Cell. The Relatively Low Resistance of the cell, Verses the Very Low
Current of that High voltage will Pull the actual voltage down to no more than your
voltage is now. Probably even Lower. "Basic Ohms Law". Take the Output from an
Ignition Coil, Place it across even a Small Flashlight bulb. It will NOT Light the Bulb.
And if you put a Meter Across it to measure the Voltage it will be Almost Nothing.
(MDG nov07: In the case of Stan Meyer, the electrolysis cell is used like a capacitor,
with pure as possible water as DIELECTRIC, so IT HAS A STRONG RESISTANCE
to electron flow, until the breakdown level is reached ... so may be an ignition coil
used as step up transformer, to send high voltage pulses in a choke/coil/bifilar coil is a
GOOD IDEA ... )
- One of the Reasons for Pulsing is to give Allowance for the Bubbles to Rise,
Allowing for better Conduction in the Solution.
- I think that I may have figured out the function of the torroidal coil in Daves cell
and which first appeared in the Xogen patent. I never believed that it had anything
to do with changing the proportion of Ortho to Parahydrogen. My hypothesis is that
the coil acts as an antenna to focus energy from the environment and improve the
efficiency of the electrolysis. I reached this conclusion after reading about two 'free
energy' scams on the internet which use torroidal coils as antennas for the wireless
transmission of electrical energy. It was Tesla who first demonstrated the wireless
transmisson of energy using longitudinal/scalar waves from a spherical antenna. Later
in the 1930s a Tesla fan demonstrated an electric car powered from a remote
transmitter using the same techniques. Any type of coil can be used as antenna if it
does not produced an induced emf from a changing magnetic field. This is because
these longitudinal/scalar electric waves do not contain a magnetic field vector. Other
types of coil you could use are caduseus coils and bifalar wound coils shorted at one
end.
- Yes a Coil can act as an antenna, But Typically it works best if it Open Ended and at
a Resonant point of the Origional Frequency. If a Closed circuit it can Radiate
Electromagnetic Energy, basically an Air Core transformer sending it into another
coil.
- I've been following Daves cell for a while now in the shadows and looking at
qiman13's developments as well (recently banned) and I am deffinetly liking Daves
setup being solid state as apposed to bedini's wheel of magnets over a coil.
- I will do some DC Pulse experiments with just 926Hz based on Mateiro specs.
Dinu http://www.oumachines.com/
- The Meyers cell seemed a little complicated until I recenlty watched the Peter
Lindemann video on free energy devices.
http://video.google.com/videoplay?docid=6183263096342406828&q=chemalloy ;
Forward the video to about 1 hour and 34 minutes. He starts talking about
Chemalloy then moves on to explain how Meyer's cell works. You can find the
video here: http://www.icubenetwork.com/files/watercar/non-
commercial/dave/videos/Wfcrep.WMV ; Make sure you download the file and don't
stream it, so click Save As...
(MDG nov07: See article below on this video, from Youtube.com)
Meyer’s hydrogen water fuel cell technology has been suppressed due to the murder
of the inventor and the inventor's business incompetence. This is mentioned in more
detail in both the 'where they went wrong page' and further under Panaceas 'media
script' on the energy suppression page.
Meyer's technology has since been resurrected by two open sourced engineers.
Panacea can directly create more public benefit from their replication results from the
Panacea facilities.
Patrick Kelly one of the founding members and helping hands of Panacea together
with another open sourced engineer Dave Lawton have collaborated together to
disclose the worlds first open sourced successful replication of the Meyers device.
Shots of the Meyers hydrogen water fuel cell replication taken from
the video.
With out going into too much technical detail of how the water fuel cell operates, the
technology is much like Xogen's technology - being unconventional electrolysis.
Both open sourced engineers are known to Panacea, their open sourced contribution
can thrive in the granted center's conditions which can help with manufacture and
provide further public benefit.
This public benefit involves submitting the technology at the faculty level in the
Panacea facility to display a proof of principle towards upgrading the current
conventional water electrolysis theories towards cleaner FREE ENERGY production.
Then there is the social reform the Panacea facility will create by providing public
security and access to the technology, as will be the case with all the other principles
mentioned on the panacea page. Panacea's granted facilities can also secure a
manufacturing assistance in production of the units.
The grant conditions in Panacea allow for quicker public dissemination of the
technology via this route.
All profit from Panacea's role in this route must by law go back into an environmental
cause, and or into charitable contributions. All the funds by any licenses created from
this technology must by law go back into environmental benefit.
The Meyers technology will be studied and submitted into the centre for public
security and access.
## Full details, photos, diagrams and components list to reproduce the Dave
Lawton Replication, 4 sept 2006 download the Patrick Kelly's excellent file named
'D14.pdf' available at http://www.panaceauniversity.org/D14.pdf
... The tubes in this replication are made of 316L grade stainless steel, five inches long
although Stan's tubes were about three times that length (14 to 23 inches). The outer
tubes are 1 inch in diameter and the inner tubes 3/4 inch in diameter. As the wall
thickness is 1/16 inch, the gap between them is between 1mm and 2mm. The inner
pipes are held in place at each end by four rubber strips about ine quarter of an inch
long.
The container is made from two 4 inch diameter plastic drain downpipe coupler
fittings connected to each and of a piece of acrylic tube with PVC colvent cement...
It should be noted that shiny new stainless steel is not suitable for use as an electrode
in any form of electrolysis. This can be seen in Joe Cell construction where the
stainless steel cylinders need to be conditioned through repeated short periods of
electrolysis. The same applies to flat plate electrolysers, where Bob Boyce points out
that no serious volumes of gas will be produced until the stainless steel plates have
received a white coating, produced by leaving them to sit unused in the Potassium
Hydroxide solution for a few days. The same applies to this replication of Stan
Meyer's electrolysis unit. When the power is first applied, very little electrolysis takes
place as the active surfaces of the pipes get covered with bubbles which stick to them.
However, if they are left for a while with the bubbles in place, a brown scum forms on
the surface of the water. The scum is cleaned off and another short period of
electrolysis carried out to cover the plates with bubbles again. After this process has
been carried out repeatedly, the brown scum no longer forms and the active tube
surfaces have a white coating. At this point, the 'conditioned' tubes produce the kind
of rapid electrolysis shown in the video.
... The electrical connections to the pipes are via stainless steel wire running between
stainless steel bolts tapped into the pipes and stainless steel bolts running through the
base of the unit:
The bolts tapped into the inner tubes should be on the inside and the bottom of the
two tubes aligned in spite of them being spread out as shown above. The diagram
shows the inner connection on the oustide, only for clarity. The bolts going through
the base of the unit should be tapped in to give a tight fit and they should be sealed
with Sikaflex bonding agent or some similar waterproofing material.
While the above circuits have been assessed as operating at about 300% of the
Faraday assumed maximum efficiency, further experimentation has shown that the
inductors used by Stanley Meyer form a very important role in raising the operating
efficiency still higher. Dave has recently introduced two inductors, each wound with
100 turns of 22 SWG (21AWG) enamelled copper wire on a 9mm (3/8") diameter
ferrite rod 25mm (1 inch) long. The improved circuit is now, as 20 sept07:
Circuit operation: Each NE555 timer chip is placed in an oscillator circuit which has
both variable pulse rate ('frequency') and variable Mark/Space ratio which does not
affect the frequency. These oscillator circuits also have three frequency ranges which
can be selected by a rotary switch. The variable resistors each have a 100 ohm resistor
in series with them so that their combined resistance cannot fall below 100 ohms.
Each oscillator circuit has its supply de-coupled by placing a 100 microfarad capacitor
across the supply rails and feeding the capacitor through a 100 ohm resistor. This has
the effect of reducing any pulsing being carried along the battery connections to affect
the adjoining circuit.
The first NE555 circuit has fairly large capacitors which give it comparatively slow
pulses, as represented by the waveform shown above it. The output from that NE555
is on pin 3 and can be switched to feed the waveform to pin 4 of the second NE555
timer. This gates the second, higher frequency oscillator On and Off to produce the
output waveform shown just below the pipe electrodes. The switch at pin 3 of the first
NE555 allows the gating to be switched off, which causes the output waveform to be
just a straight square wave of variable frequency and Mark/Space ratio.
The output voltage from pin 3 of the second NE555 chip is reduced by the 220 ohm/
820 ohm resistor combination. The transistor acts as a current amplifier, capable of
providing several amps to the electrodes. The 1N4007 diode is included to protect the
MOSFET should it be decided at a later date to introduce either a coil ('inductor') or a
transformer in the output coming from the MOSFET, as sudden switching off of a
current through either of these could briefly pull the 'drain' connection a long way
below the 0 volt line and damage the MOSFET, but the 1N4007 diode switches on
and prevents this from happening by clamping the drain voltage to -0.7 volts if the
drain is driven to a negative voltage.
The BUZ350 MOSFET has a current rating of 22 amps so it will run cool in this
application. However, it is worth mounting it on an aluminium plate which will act
both as the mounting and a heat sink. The current draw in this arrangement is
particularly interesting. With just one tube in place, the current draw is about one
amp. When a second tube is added, the current increases by less than half an amp.
When the third is added, the total current is under 2 amps. The fourth and fifth tubes
add about 100 milliamps each and the sixth tube causes almost no increase in current
at all. This suggests that the efficiency could be raised further by adding a large
number of additional tubes, and as the gas is produced inside the tubes and the outer
tubes are connected electrically, they could probably be bunded together.
Although the current is not particularly high, a six amp circuit-breaker, or fuse, should
be placed between the power supply and the circuit, to protect against accidental
short-circuits. If a unit like this is to be mounted in a vehicle, then it is essential that
the power supply is arranged so that the electrolyser is disconnected if the engine is
switched off. Passing the electrical power through a relay which is powered via the
ignition switch is a good solution for this. It is also vital that at least one bubbler is
placed between the electrolyser and the engine, to give some protection if the gas
should get ignited by an engine malfunction. It is also a good idea for the bubbler(s)
lid to be a tight push fit so that it can pop off in the event of an explosion, and so
further limit the effect of an accident.
Further Developments: When producing hydroxy gas from water, it is not possible
to exceed the Faraday maximum unless additional energy is being drawn in from the
surrounding environment. As this cell runs cold and has substantial gas output, there
is every indication that when it is running, it is drawing in this extra energy.
This idea is supported by the fact that one of the key methods of tapping this extra
energy is by producing a train of very sharply rising and sharply falling electrical
pulses. This is exactly the objective of Dave's circuit, so it would not be too surprising
if that effect was happening.
This remarkable occurence has the most unusual effect of actually reducing the
amount of conventional power needed to drive the circuit, if the output load is
increased. So, increasing the load powered by the circuit causes additional energy to
flow in from the environment, powering the extra load and as well, helping to drive
the original circuit. This seems very strange, but then, 'cold' electricity operates in an
entirely different way to our familiar conventional electricity, and it has its own set of
unfamiliar rules, which are generally the reverse of what we are used to.
To test his cell system further, Dave connected an extra load accross the electrodes of
his cell. As the inductors connected each side of the cell generate very high-value,
sharp voltage spikes, Dave connected two large value capacitors (83,000 microfarad,
50 volts) accross the cell as well. The load was a 10 watt light bulb which shines
brigthly, and interestingly, the current draw of the circuit goes down rather than
up, in spite of the extra output power. The gas production rate appears
undiminished.
This is the alteration to that part of the circuit which was used:
... Dave, who built this replication, suggests various improvements. Firstly, Stan
Meyer used a larger number of tubes of greater length. Both of those two factors
should increase the gas production considerably. Secondly, careful examination of
video of Stan's demonstrations shows that the outer tubes which he used had a
rectangular slot cut in the top of each tube:
(MDG nov07: see specific article about the tubes resonating subject, below)
Some organ pipes are fine-tuned by cutting slots like this in the top of the pipe, to
raise it's pitch, which is it's frequency of vibration. As they are thinner, the inner pipes
in the Meyer cell will resonate at a higher frequency than the outer pipes. It therefore
seems probable that the slots cut by Stan are to raise the resonant frequency of the
larger pipes, to match the resonant frequency of the inner pipes. If you want to do
that, hanging the inner tube up on a piece of thread and tapping it, will produce a
sound at the resonant pitch of the pipe. Cutting a slot in one outer pipe, suspending it
on a piece of thread and tapping it, will allow the pitch of the two pipes to be
compared. When one outer pipe has been matched to your satisfaction, then a slot of
exactly the same dimensions will bring the other outer pipes to the same resonant
pitch. It is said that Stan ran his Lolkswagen car for four years, using just the gas from
four of these units.
A very important part of the cell build is the conditioning of the electrodes tubes,
using tap water. This is done as follows:
1 - Do not use any resistance on the negative side of the power supply when
conditioning the pipes.
2 - Start at 0.5 Amps on the signal generator and after 25 minutes, switch off for 30
minutes.
3 - Then apply 1.0 Amp for 20 minutes and then sstop for 30 minutes.
4 - Then apply 1.5 Amp for 15 minutes and then stop for 20 minutes.
5 - Then apply 2 Amps for 10 minutes and afterwards stop for 20 minutes.
6 - Go to 2.5 Amps for 5 minutes and stop for 15 minutes.
7 - Go to 3.0 Amps for 120 to 150 seconds. You need to check if the cell is getting
hot... if it is you need to reduce the time.
After the seven steps above, let the cell stand for at least an hour before you start all
over again.
You will see hardly any gas generation in the early stages of this conditioning process,
but a lot of brown muck will be generated. Initially, change the water after every
cycle, but do not touch the tubes with bare hands. If the ends of the tubes need to
have muck cleaned off them, then use a brush but not touch the electrodes !! If the
brown muck is left in the water during the next cycle, it causes the water to heat up
and you need to avoid this.
Over a period of time, there is a reduction in the amount of the brown stuff produced
and at some point, the pipes won't make any brown stuff at all. You will be getting
very good gas generation by now. A whitish powdery coat will have developed on the
surface of the electrodes. Never touch the pipes with bare hands once this coating has
developed
But there is more. Ron, we are with a lot of people focussing on the electronics and a
bit on the pipes. After all kinds of configurations with coils and trafo's I have made a
conclusion. As Stanley said many times: Its all about securing his patents. In other
words: CRAP.
Yes, you can double frequency with the VIC and Yes you can get higher voltage. And
he is smiling in his grave, if you ask me.
In all his patent with the VIC you see less info about his pipes/tubes. But if you read
well, I think that there is the real thing happening. He talks about resonance. The
resonant cativy!!!!
I tryed to find any info or tread in many forums about the Resonant Cavity stuff.
NOT much to find as well! This is also a clue.
Stanley published a formula how to calculated his pipes with care............. I try to find
out what to do with that.
Focus: 20Khz is a nice frequency for getting Hydrogen. So how would pipes look like
for resonanting on 20Khz? Its about lenght and spacing between the 2 pipes. Perhaps
also about some kind of form of the pipe-ending. (sorry for my poor english)
Ron, what do think about my theory after all the time you spend with this subject?
(and all you other guys as well, of course......)
My thoughts have been to "tune" the pipes to the same tone and then hang them in
such a way that lets them vibrate with the frequencies being pumped into them. My
thoughts were to drill holes through the paired pipes near the top and to notch the
bottoms and then use ceramic rods to suspend them in the tank. They'd hang from the
top rod while the bottom rod would act as a "swing stop" with the pipes notches being
over it. Small rubber washers (or something else that won't conduct) could be used to
keep the tubes separated. To me this would allow the pipes the easiest chance of
"ringing" with the frequency needed without huge amounts of power being needed.
We need to be thinking "musical instrument" and not "industrial vibrator".
The voltage wave should bounch between the innerpipe and the outerpipe as if the
frequency of the wave matches the space between them.
Another theory: At this moment we all put one wave in one pipe and the other pipe is
ground. Perhaps we have to start thinking of 2 waves. One in each pipe.
Try to get resonance between two frequencys, like 20khz and 60Khz. I read
something about the 20Khz is nice to Hydrogen and the difference should be 1/3
Not saying this would stop them from ringing at all... but would effect it considerably.
Stan had his set up to where all the tubes were tied together with a mounting plate.
- stevie1001, Posted: Mon Sep 24, 2007 3:37 am Post subject: NEW TREAD
ABOUT THE RESONANT CAVITY IS STARTED:
Lets continue burning our brains cells out about the pipes/tubes and the Resonant
Cavitys of Stanly Meyer on a new tread. I opend it already.
i find icl8038 wave generator.This IC is very basic and adjustable, if you can
download this IC's datasheet from this adress, may be you can develope your pulse
circuits
http://www.datasheetcatalog.com/datasheets_pdf/I/C/L/8/ICL8038.shtml
- http://www.intersil.com/data/FN/FN2864.pdf
Although he doesn't support the 555 chip with fact, here is the datasheet on the 555s
that I use... NE555P by texas intruments....
I have no idea whether if this means anything but I found this: The Output-pulse rise
time and the Output-pulse fall time is 100 to 300 ns tested with a capacitor of 15pF
and a Temp of 25 C
The data sheet discribes the 555 as "These devices are precision timing circuits
capable of producing accurate time delays or oscillation."
Ref: Texas Intruments datasheet on NE555.pdf
http://waterfuelcell.org/phpBB2/download.php?id=423
I do not know why you are having problems with the 555, but in my own experience
with cars, computers, chemistry, software, women, jobs, life as we know it, there are
general rules to follow, they're called Murphies laws..
rule #1: Anything that can go wrong, will go wrong. Just remember that Murphy was
an optimist...
Double check everything and test all components individually...sometimes ive seen
the 4007 not working and maybe the mosfet is blown..sometimes Ive just had to
replace the 100ohm resistors, but sometimes Ive replaced all of the diodes just
becuase I couldnt find the problem..(it worked)...anyways use the original DL PWM
setup and do not connect anything from the input (pin 4 or 8) to the Output (pin 3) as
the unedited revision of the DL PWM that include inductors in the solid state circuit
diagram...If you are having problems on finding the original version that included the
notched tubes...here it is...
I am interested in the icl8038 though as it does look like it has cool fuctions, like
individual pins for different shaped waves...Maybe some experimentation could be
done to see if a different shape waves would work better...but I am not knowledgeable
about electronics enough to know how to design a circuit using the icl8038, maybe if
someone came up with something, I could model it in B2 spice to see if it works....
Where the rotory 3 turn 4 pole swith is connected to the the 3 capacitors, add a 2 or
more pole switch and connect it to the existing capacitors and 3 extra capacitors at
smaller capacitances, and connect the extra 3 capacitors to another pole of the 3 turn 4
pole of the rotory switch ..as there are 4 different poles, these capacitors will not be
connected to the other capacitors, Dave was a right to use the 3 turn 4 pole switch as it
allowed more capacitors to be connected for a total of 12 capacitors....I included a
drawing to visualize what Im saying.
If anything more is needed, and if anyone has any ideas on how to modify it to handle
the higher freq, or if anyone has any ideas on what the capicatance values of the extra
capacitors could be in order to give ranges of like 20 khz to 50 khz, 50 kHz to 100
kHz, 100 kHz to 200 kHz, 200 kHz to 300 khz......etc...it would be greatly
appreciated...
I always wondered why he used those 4 pole 3 turn switches as I was connecting the
capacitors... anyways, again 8038 is not nessacary, tlc555 can produce output
frequencies of 2 Mhz..
You gotta see it to believe it! i only used one ss tube cell as in my other post. Must
try! Gotta try!
Maybee somebody can take this further, this is definitly the right way...
i don't know how it works, it just does! haha
This circuit doesn't produce alot of hydrogen, however i don't know how it is
working, it is unexplainable how it does what it does...
i don't get it, i unplugged the freq generator, and i was working on it about to rearange
some stuff and i got shocked, i touched it again, i got shocked again, i finaly realized
that no matter what, im getting shocked, the circuit is resonating! and you can feel it
lol.
if you put a charge on the caps, and remove the water fuel cell, after you remove the
power source you can touch the probes where the wfc hooked, you can feel it
oscilating, it hurts, but you can feel it, i can bare the pain, its not all that, but i like to
feel it oscillate or resonate.
To observe resonation do this. Get you a coil, all coils do not work. Use a magnetic
core and the wire size around 22 or smaller seems to work best. The winding around
the core should have a resistance of around 6.1 ohms. If you want to get the results i
am getting.
Do this simple test. You will need 1 led, 2 diodes, any should work but i guess smaller
would be better, and a capacitor, i have a 470 uf cap about the size of a quarter and
about an inch tall, it works great, i also have a 470 uf cap about the size of an, well its
about as round as a tip of an pool stick, not hardly that big, but any big cap should
work, and some small ones.
I will make the schematic in text right now, the led should stay lite for over 20
seconds, and even longer if you don't use a led.
The led will stay lit as long as it is resonating, there is no need for a Frequency
Generator, It don't Do anything to the circuit. You wanted resonation, Here it is, Have
fun!!
Make the circuit,, i want your comments. common, i know you got diodes and coils
lying around the house hehe
I wonder how stable this will work. Small changes in the WFC should not effect the
resonance in this setup.
wrote it down, somehow it was hooked differently than the way on the breadboard,
"hardly noticeable".
Now, the reason it is working is because the diode is breaking down and reversing, i
cant hardly explain it, i need a little help with it.
i do know it works, because when i moved a magnet around the coil when it was
emitting light it did change the behaviour of the light. i know it was resonating
because of this. and i also checked it with a dvm, and with my fingers.
each time the circuit was working, it was only because one of the diodes was broken,
its very flusterating trying to figure out whats going on, and why it is working, i'm on
it, if a broke down diode can make a circuit resonate then something is going on here,
the diode is acting as a resistor but it's still doing something strange, i have yet to
replicate it but i am looking into how to do it without a broken down diode.
i still don't see how a broken diode can do this, but if you hook your stuff up the way i
had it in the schematic, your diode will probley break down, so i wouldn't do it.
this circuit also explains the magnet effect i was getting. Hrm, i was still getting good
results with this circuit on the water fuel cell?? hrmmm, i'm clueless if this sends
straight DC to the water fuel cell or not?
i did seem to get wacky readings with it, what was it, something like 4 volts 12 amps?
that would be good if it was pulsed dc, but that i don't know, so frusterated.
this circuit can not resonate, any circuit that has a diode of any kind between a coil,
and an none bipolar power source can not resonate, i'm sorry guys but with a diode its
not resonating, the only resonating is between the frequency generator, and the
primary and secondary side of the coil.
i think we need high volts, NOT TENS OF THOUSANDS with amps behind it, Good
Amps, If you pulse it with that, i think it would be what everyone is looking for. Sorry
but true! don't hate me
The power is unbelievable. It almost feld like a 230V blow. Now trying to get that
power in my testcell.
Thanks, Sukhoi Company (JSC) - If the world should blow itself up, the last audible
voice would be that of an expert saying it can't be done.
No larger than little over half amp. This is about all the experimenting i'm doing
right now, there is no need to look any futher, its figured out now.
A few things you should know before you continue your water fuel cell adventure.
1. A coil of any kind in parallel or series with a ("none BI polar") capacitor seperated
by a diode in any direction CAN NOT AND WILL NOT RESONATE!
2. A ("None BI Polar") Capacitor Can Not resonate with a inductor in any kind of
Pulsed DC OR AC. ("Only bipolar ones can do this")!
4. The Patent "stanley meyers", which shows the 5 spikes seperated by a delay where
the pulses start at a lower voltage, and workes its way up to the 5 Spike then comes to
a delay was simply to confuse you!!! it's not true.
Faqs, There is a Pulse needed at a desired Frequency, but it's nothing like you think,
its not what you think. i hardly refer to it as a frequency, its much slower ("has
nothing to do with the resonate or water molecule".
The unite works off of COLD ELECTRICITY google that with inventors.
WOOOOOOOOOOOOHhhhhh
I can clearly see why stanley used a alternator now. His transformer that stated 200
wraps of 22 gauge wire with 600 turns of 36 awg wire was complete bull, it was used
to throw you for a loop just like the frequency, stanley "is" a smart man, i admire him
for that, and i respect him!
CHOKES : They're very very important, the wrong chokes will get really hot really
fast, i just figured all this out, so you guys need to help me on them.
More to come if i don't get bashed, But remember, Forget the dave lawton circuit, its
not needed, and is a complete wast of time if you're trying to use it with the wfc, drop
it, it dont work. There is no frequency.
Think to yourself, ask yourself, back then if you was stanley meyers, would you
patent the complete truth?? would you not do as he did???
today is a differnt day, there is no patent, now its public and money is not an
object, the truth shall come out now!
The construction of my results are ready for you to experience, what ya waiting on?
you guys with me or not??
_________________
When the Water is Orange, you know you're doing something Right! That just
Dawned on me lol
I am not new here, been reading here quite a wile, but now i would like to share what
i think about the VIC.
What hydrocars says is what i also think now, it`s so easy. I had been "blindet" also
for a wile, but while reading the newest results here last week, it really hit me:-)
May be Stanley Meyer was forced to complicate it, because it's so easy and so
wouldn't get his patent granted. Who knows...
Well for me this works exactly like a ozon generator, only with water. The high
voltage potential creates a corona/ cold plasma field with almost no current and
transmutes the oxygen in the air to ozone.
Remove the insolator between the plates or bring them to close together, the HV arcs
over- currentflow. The corona potetialfield collapses instantly!
Same when using tapwater or water with minerals (conductive) with the VIC, then
you get current electrolysis, which isn't that efficient and hot chokes...
You only need to hit the self-resonance of the choke (which all coils with airgapped
ferrit-/metalcore should have), that's why i would and will put all windings on the
same core (Step up & Charging choke)
At that selfresonance the choke will generate the strongest corona/cold plasma
field/voltage potential in the water between the tubes and transmutate/split it into it's
elements hydrogen and oxygen.
So i think Stan Meyer ment this coil selfresonance (Which typicaly lays in the
audiofreq. range) and the simplest pulsing circuit should do the job!
May be there could be a visible blue-purpleish plasma glow between the tubes in a
quite dark room.
So because Currentflow will kill this plasmafield emidialy, i only will use
noncoductive demineralised water for the VIC.
This circuit is intended to Teach you, and allow yourself to gain an understanding of
what is going on.
We're still in the baby stages, Take this and learn from it. We will all work on this
together here in the forums!
the main goal is that everyone understands how and why it works, after you have
reached that level then it would be great to go larger as i did manually as you will see
how i did the video soon.
Here in this picture, you can see 1 Power inverter, 600 watts, one Transformer from
radio shack, it is 120v AC to 25 volts AC Step Down, You will also see the 470uf
THE CAP MUST BE 200v no smaller.
2 diodes rated at 1000 volts, and you will see CHOKES in tape i made, they should
be bigger. after you experiment with the schematic you will see what the chokes do,
and why you need them. Those of you without ammeter's you will need an ammeter
that will read atleast 10 amps ac and dc, you need to get you one, if you don't have
one we will do our best at describing whats going on, i know what its like not to have
an ammeter, it sucks.
Later we should be dealing with reed relays, or gas or glass tube relays, not very fast
but not slow, they are ideal and out perform todays electronics, they're very hard to
come across, be on the lookout for these.
also we need to learn to make our on caps, i want cover that here right now, very
dangerous! This is different, PLEASE BE CARUFULL
- PULSED)ReverseH/Ofuelcell, Posted: Wed Aug 08, 2007 6:50 pm :
Hydro, that’s good to hear that you are getting results! Could you give a rough circuit
that you used in your water fuel cell, The circuit that made all that hydrogen with ½
an amp? Looking forward to the video!
Now you say that the frequency has no role to play here, but for an LC circuits to
{resonate} you need a frequency, now I know that this is true because of my Tesla
coil. For me to get that high voltage arch’s I needed to tune the frequency generator
and the spark gap (witch made the frequency even higher). It seem that you have
found something new,
On the other hand, if you are saying that there is no “fixed” frequency, this opens up a
whole new can o’ whoop ass. If that [is] what you meant then you are also right (you
win either way), there is no fixed resonating frequency, it is all dependant on the
chokes and capacitors values. You also can find the resonating frequency by doing
some easy (hard) math’s, I think I will pass and do some frequency tuning.
If you look at what crux has done then you can see how the frequency is indeed
needed; now I am going to try two tests, the LC circuit test, this needs the step charge
effect and high voltage resonating pulses with the blocking diode and I’m going to try
and replicate what you have done.
That is why the original circuit has the blocking diode [before] the choke and the
capacitor and not in-between them, this allows for resonance between the inductor
and capacitor, thus proving more that a frequency is needed, (I am not saying you are
wrong, it is just that you have found something new! That’s great!).
There is no fixed resonant frequency that depends on so many factors. You need the
frequency generator though for an LC circuit.
My [12] v battery is arriving tomorrow and then I can get started with my LC tests!
I’ll let you all know how that goes
With regards to high voltage, I love relating the Tesla coil to the water fuel cell. I
think there is no arch in the water between the positive and negative electrodes that
would be shorting and would affect the water molecule. But this process applies to the
browns gas generator, the one with carbon rods and the under water arc.
Rather the high voltage affects the water molecules because of the high voltage field.
In a Tesla coil there are arches and sparks but there are very high voltage fields to. If
you can get the voltage field under water in the plates, and put the plates as close
together without arching, you will get a pretty intense voltage field. No amps would
be consumed just like a magnetic field.
The way to generate a high voltage field would be through LC resonance, this means
high voltage so be careful. The resonance builds up the voltage field in the water
capacitor, and, just before a dielectric failure (arching) occurs the high voltage pulses
stop, only to start again and so the process goes, no amp flow no electricity being
used. Sure some amperage will be used, nothing is perfect, but if we can get it as low
as possible low wattage will be used.
yes you could, but it is important that the primary side is fused with about a 2 amp
fuse. the inverter is less dangerous.
yeah, the transformer is hooked up as it is built for. 120v to 25v, 25v to the water fuel
cell.
the black things are diodes. yes the circle is the wfc unless it's drawn like a cap
symbol. 1 inch tube od, inside tube 3/4 od, gap 1/16th.
I am having issues, i'm hoping that the caps i ordered will work for this but i am
having my doubts after watching Xogens Video at youtube, they seem to have it
figured out, and they mentioned that the proper frequency was needed, where i was
leaning toward cold electricity because i have had no luck with a frequency, and also
there is a video at youtube and they guy that stands up sounds just like stanley
meyers, they said on that video the frequency was just to confuse you also, i'm so
confused right now and flusterated.
you dont know what to believe because Xogen isn't gonna want you to get it working,
it would be a money thing for them, and you dont know what to believe when you
watch them kinda video's, they seem to put in our heads what they want us to think,
they could be leading us in the right direction, or they could just be throwing us a loop
of lies, who knows
i think it is more important to get a good working circuit first, but thats what i used so
knock yourself out, i didn't use chokes in the video.
This is not even Stan Meyer’s process! Stan’s process needs [two] amps and [five]
volts, that’s 10 watts of electrical input!
It then turns this into tens of thousands of volts by electrical “resonance”, charging the
water capacitor in series with a choke at a resonant frequency, multiplying the
voltage.
This works the same way as a Tesla coil, using low input and using electrical
resonance to generate very high voltage.
I am going to ask Muzza to put a forum section for water fuel cell skepticism, or
doubts.
If you have any questions, feel free to ask, I am not trying to be mean, cutting, or a
know it all, if you stay like that you are just going to get worse reception here, lighten
up a littlie, were here to help [you], not put you down!
You know what “non directional pulses” means? That the frequency is not alternating,
but direct currant, witch means that the water will stay charged and will not drain.
You also say that Stan Meyer did not give clear instructions, you know why? It is
NEW you can’t understand is overnight, it has taken us a long time to get an
understanding of this technology, but, thanks to the input of many helpful and up
building people we can and are replicating it.
This group here is a good start to understanding radiant energy. You can build a
working device that will positively enhance your understanding to RE and you might
even want to explore other possibilities.
- http://www.youtube.com/watch?v=56Lcyp8X75g
- http://www.youtube.com/watch?v=Tf7uaPylkgo
- http://www.youtube.com/watch?v=tBAk6xlcOYg
- http://www.youtube.com/watch?v=IdCLdv9Nhfs
- http://www.youtube.com/watch?v=x62E-ZjnUD8
youtube is doing a sorry job, this was over 8 hours ago i uploaded this.
In the Example of a fuel cell circuit of FIG. 1, a water capacitor is included. The step-
up coil is formed on a conventional toroidal core formed of a compressed
ferromagnetic powered material that will not itself become permanently magnetized,
such as the trademarked "Ferramic 06# "Permag" powder as described in Siemens
Ferrites Catalog, CG-2000-002-121, (Cleveland, Ohio) No. F626-1205". The core is
1.50 inch in diameter and 0.25 inch in thickness. A primary coil of 200 turns of 24
gauge copper wire is provided and coil of 600 turns of 36 gauge wire comprises the
secondary winding.
In the circuit of FIG 1, the diode is a 1N1198 diode which acts as a blocking diode
and an electric switch that allows voltage flow in one direction only. Thus, the
capacitor is never subjected to a pulse of reverse polarity.
The primary coil of the toroid is subject to a 50% duty cycle pulse. The toroidal
pulsing coil provides a voltage step-up from the pulse generator in excess of five
times, although the relative amount of step-up is determined by preselected criteria for
a particular application. As the stepped-up pulse enters first inductor (formed from
100 turns of 24 gauge wire 1 inch in diameter), an electromagnetic field is formed
around the inductor, voltage is switched off when the pulse ends, and the field
collapses and produces another pulse of the same polarity i.e., another positive pulse
is formed where the 50% duty cycle was terminated. Thus, a double pulse frequency
is produced; however, in pulse train of unipolar pulses, there is a brief time when
pulses are not present.
The pulse train is then switched off; the voltage across the water capacitor drops to
the amount of the charge that the water molecules have taken on, i.e., voltage is
maintained across the charged capacitor. The pulse train is the reapplied
# from : rexresearch.com/meyerhy/4936961.htm
In the process, the point of optimum gas release is reached at a circuit resonance.
Water in the fuel cell is subjected to a pulsating, polar electric field produced by the
electrical circuit whereby the water molecules are distended by reason of their
subjection to electrical polar forces of the capacitor plates.
The polar pulsating frequency applied is such that the pulsating electric field induces
a resonance in the molecule. A cascade effect occurs and the overall energy level of
specific water molecules is increased in cascading, incremental steps.
The hydrogen and oxygen atomic gases, and other gas components formerly
entrapped as dissolved gases in water, are released when the resonant energy exceeds
the covalent bonding force of the water molecule. A preferred construction material
for the capacitor plates is stainless steel T-304 which is non-chemical reactive with
water, hydrogen, or oxygen.
By varying the pulse shape and/or amplitude or pulse train sequence of the initial
pulsing wave source, final gas output is varied. Attenuation of the voltage field
frequency in the form of OFF and ON pulses likewise affects output.
The overall apparatus thus includes an electrical circuit in which a water capacitor
having a known dielectric property is an element. The fuel gases are obtained from
the water by the disassociation of the water molecule. The water molecules are split
into component atomic elements (hydrogen and oxygen gases) by a voltage
stimulation process called the electrical polarization process which also releases
dissolved gases entrapped in the water.
From the outline of physical phenomena associated with the process described in
Table 1, the theoretical basis of the invention considers the respective states of
molecules and gases and ions derived from liquid water. Before voltage stimulation,
water molecules are randomly dispersed throughout water in a container.
When a unipolar voltage pulse train such as shown in FIGS. 3B through 3F is applied
to positive and negative capacitor plates, an increasing voltage potential is induced in
the molecules in a linear, step like charging effect.
The electrical field of the particles within a volume of water including the electrical
field plates increases from a low energy state to a high energy state successively is a
step manner following each pulse-train as illustrated figuratively in the depictions of
FIG. 3A through 3F.
In the first stage of the process described in Table 1, because the water molecule
naturally exhibits opposite electrical fields in a relatively polar configuration (the two
hydrogen atoms are positively electrically charged relative to the negative electrically
charged oxygen atom), the voltage pulse causes initially randomly oriented water
molecules in the liquid state to spin and orient themselves with reference to positive
and negative poles of the voltage fields applied.
The positive electrically charged hydrogen atoms of said water molecule are attracted
to a negative voltage field; while, at the same time, the negative electrically charged
oxygen atoms of the same water molecule are attracted to a positive voltage field.
When the potential difference applied causes the orientated water molecules to align
themselves between the conductive plates, pulsing causes the voltage field intensity to
be increased in accordance with FIG. 3B. As further molecule alignment occurs,
molecular movement is hindered.
Because the positively charged hydrogen atoms of said aligned molecules are
attracted in a direction opposite to the negatively charged oxygen atoms, a polar
charge alignment or distribution occurs within the molecules between said voltage
zones, as shown in FIG. 3B. And as the energy level of the atoms subjected to
resonant pulsing increases, the stationary water molecules become elongated as
shown in FIGS. 3C and 3D. Electrically charged nuclei and electrons are attracted
toward opposite electrically charged equilibrium of the water molecule.
In a more specific explanation of the "sub-atomic" action the occurs in the water fuel
cell, it is known that natural water is a liquid which has a dielectric constant of 78.54
at 20 degrees C. and 1 atm pressure. [Handbook of Chemistry & Physics, 68th ed.,
CRC Press(Boca Raton, Florida (1987-8), Section E-50. H20(water)].
When a volume of water is isolated and electrically conductive plates, that are
chemically inert in water and are separated by a distance, are immersed in water, a
capacitor is formed, having a capacitance determined by the surface area of the plates,
the distance of their separation and the dielectric constant of water.
When water molecules are exposed to voltage at a restricted current, water takes on an
electrical charge. By the laws of electrical attraction, molecules align according to
positive and negative polarity fields of the molecule and the alignment field. The
plates of the capacitor constitute such as alignment field when a voltage is applied.
When a charge is applied to a capacitor, the electrical charge of the capacitor equals
the applied voltage charge; in a water capacitor, the dielectric property of water resists
the flow of amps in the circuit, and the water molecule itself, because it has polarity
fields formed by the relationship of hydrogen and oxygen in the covalent bond, and
intrinsic dielectric property, becomes part of the electrical circuit, analogous to a
"microcapacitor" within the capacitor defined by the plates.
secondary winding.
maintained across the charged capacitor. The pulse train is the reapplied.
Because a voltage potential applied to a capacitor can perform work, the higher the
voltage the higher the voltage potential, the more work is performed by a given
capacitor. In an optimum capacitor that is wholly non-conductive, zero (0) current
flow will occur across the capacitor.
Thus, in view of an idealized capacitor circuit, the object of the water capacitor circuit
is to prevent electron flow through the circuit, i.e. such as occurs by electron flow or
leakage through a resistive element that produces heat.
Electrical leakage in the water will occur, however, because of some residual
conductivity and impurities or ions that may be otherwise present in the water. Thus,
the water capacitor is preferably chemically inert. An electrolyte is not added to the
water.
In the isolated water bath, the water molecule takes on charge, and the charge
increases. The object of the process is to switch off the covalent bonding of the water
molecule and interrupt the subatomic force, i.e. the electrical force or electromagnetic
force, that binds the hydrogen and oxygen atoms to form a molecule so that the
hydrogen and oxygen separate.
Because an electron will only occupy a certain electron shell (shells are well known)
the voltage applied to the capacitor affects the electrical forces inherent in the
covalent bond. As a result of the charge applied by the plates, the applied force
becomes greater than the force of the covalent bonds between the atom of the water
molecule; and the water molecule becomes elongated. When this happens, the time
share ratio of the electron shells is modified.
In the process, electrons are extracted from the water bath; electrons are not consumed
nor are electrons introduced into the water bath by the circuit as electrons are
conventionally introduced in as electrolysis process. There may nevertheless occur a
leakage current through the water.
Those hydrogen atoms missing electrons become neutralized; atoms are liberated
from the water. The charged atoms and electrons are attracted to the opposite polarity
voltage zones created between the capacitor plates. The electrons formerly shared by
atoms in the water covalent bond are reallocated such that neutral elemental gases are
liberated.
In the process, the electrical resonance may be reached at all levels of voltage
potential. The overall circuit is characterized as a "resonant charging choke" circuit
which is an inductor in series with a capacitor that produces a resonant circuit.
[SAMS Modern Dictionary of Electronics, Rudolf Garff, copyright 1984, Howard W.
Sams & Co. (Indianapolis, Ind.), page 859.]
Such a resonant charging choke is on each side of the capacitor. In the circuit, the
diode acts as a switch that allows the magnetic field produced in the inductor to
collapse, thereby doubling the pulse frequency and preventing the capacitor from
discharging. In this manner a continuous voltage is produced across the capacitor
plates in the water bath; and the capacitor does not discharge. The water molecules are
thus subjected to a continuously charged field until the breakdown of the covalent
bond occurs.
As noted initially, the capacitance depends on the dielectric properties of the water
and the size and separation of the conductive elements forming the water capacitor.
Spacing from the outside of the inner cylinder to the inner surface of the outside
cylinder was 0.0625 inch. Resonance in the circuit was achieved at a 26 volt applied
pulse to the primary coil of the toroid at 0 KHz, and the water molecules disassociated
into elemental hydrogen and oxygen and the gas released from the fuel cell comprised
a mixture of hydrogen, oxygen from the water molecule, and gases formerly dissolved
in the water such as the atmospheric gases or oxygen, nitrogen, and argon.
In achieving resonance in any circuit, as the pulse frequency is adjusted, the flow of
amps is minimized and the voltage is maximized to a peak. Calculation of the
resonance frequency of an overall circuit is determined by known means; different
cavities have a different frequency of resonance dependant on parameters of the water
dielectric, plate size, configuration and distance, circuit inductors, and the like.
Control of the production of fuel gas is determined by variation of the period of time
between a train of pulses, pulse amplitude and capacitor plate size and configuration,
with corresponding value adjustments to other circuit components.
The wiper arm on the second conductor tunes the circuit and accommodates to
contaminants in water so that the charge is always applied to the capacitor. The
voltage applied determines the rate of breakdown of the molecule into its atomic
components. As water in the cell is consumed, it is replaced by any appropriate means
or control system.
Variations of the process and apparatus may be evident to those skilled in the art.
What is claimed is: [ Claims not included here ]
# Keelynet/Vangard Notes :
1N1198 Diode is also a NTE 5995 or a ECG 5994. It is a 40A 600 PIV Diode (the
40A is over kill and may not be needed).
Stainless Steel "T304" is a type of weldable Stainless, but other types should work the
same. "T304" is just the more common type of Stainless tubing available.
The outer tube figures out to be 3/4" 16 gauge (.060 "wall") tube (a common size) cut
to 4 inch length.
The inner tube figures out to be 1/2" 18 gauge (.049 "wall", this is a common size for
this tube, but the actual gauge cannot be figured from this patent documentation, but
this size should work) cut to 4 inch length.
You should also attach the two leads to the Stainless, using Stainless solid rod (1/6 dia
would do) and USE LEAD FREE SOLDER ! (you may want the purified water that is
returned to drink some day).
You also need to figure out a way to keep the two tubes separated from each other.
This could be done with small pieces of plastic. They cannot block the flow of water
into/out of the tubes.
It was not indicated if the inner tube is full of water or not. The guess here is that it is
full of water, and this doesn't effect the device at all.
The Patent doesn't say but I would think that insulating the leads with some type of
tubing up to the tubes would be electrically correct (and probably wouldn't hurt).
The pulse frequency was not printed, it is estimated from the size of the coils and
transformer that the frequency doesn't exceed 50 Mhz. Don't depend on this being
fact, it's just a educated guess.
The circuit to do this is not shown, just empty boxes. It's time to get out your SCOPE
and try things! Don't forget to share your results with others ! GREED is why this
type of thing never gets out into the world to do some GOOD. If you want to make
some money, make something PRACTICAL that WORKS and that PEOPLE can use
in their every day lives, then sell it! Holding onto information like this only hurts ALL
OF US !!
i would like for you to run this test for me, use both chokes and pulse them as usual,
make sure you have a diode on the chokes like in the picture, dont worry about
rewraping your chokes, just run the test and get back to me.
Please take note, you can hook the choke up backwards, it is important to get the
polarity of the chokes right, if i am not mistaken one choke hookes backwards, it dont
matter witch choke you choose to hook backwards, as long as one of them is.
i assume you have installed a diode on your lawton circuit? if so please test it to make
sure it is not defective, that diode is very important in this replication, if it is blowed
remove it, just hook your chokes up like in the picture.
if it isn't to much trouble, try different wraps on the chokes, 22 to 24 gauge is good.
i'm thinking 100 wraps is the best, i have not tried 200 wraps, i have not tried 30 or 50
wraps, i would like to hear your comment regardless how many wraps you are using.
when you do run this pulse test on the chokes, please use the capacitor on the second
lawton circuit labeled 103K, do not use the primary timer circuit. check your output at
.50 amps, and never reverse your leads, keep positive positive and negative negative,
if you reverse them you will see bubbles and not white trails.
my goal now is to better the chokes. i'm looking for a longer free cycle pulse, thanks
to the source of my oscilloscope i can take this to the next level!
http://www.youtube.com/watch?v=FY-AS13fl30
Don’t! I repeat DON’T kill your selves, with hydrogen explosions or high voltage
shocks! We need your help, read about safety, use rubber gloves and bubblers! Safety
comes before running a car on water. I’m not joking, I (you) have to take safety very
seriously, I’ve had bad accidents and don’t want any more, I have to quit launching H
rockets of my patio 1; for my safety 2: for the wildlife’s safety. Please take all
precaution.
More things arriving today, ill keep you all posted, later, Pulsed.
## Cars running with pure water! Michel’s project status (Sept 05) from
'Michel WFC Report_Sept05 .pdf' (34 Ko) at
http://my.opera.com/h2earth/blog/cybrarium
Extracts:
We believe in the S. Meyer’s concept, described in the patent 4 936 961, based on the
break of the covalent bonds between Hydrogen and Oxygen in the water molecule,
when it’s stressed by a high pulsed electrical field, in order to produce hydrogen and
oxygen gas on demand in a car running with water.
We have been studied the subject for 2 years by reading lot of documents on physics,
chemistry and electronics, and have also done lot of basic tests to understand the
project
We followed the discussions on lot of Forums (watercar, icube, OUpower …)
2. Our water fuel cell: - Parallel plates in stainless steel T304 material (70x100 mm)
- Cylindrical plates in stainless steel T304 material (dia 14/21mm, L=150 mm)
Gap is approx 1.5 mm ; Water: standard low cost distilled water and very pure water
from chemical lab
# Main conclusion of the tests: The schematics and process, as described in the
patent, cannot work, because the step charging effect is not possible with a WFC as
described by S. Meyer.
The water fuel cell (like in the patent) is not playing as a capacitor, but as a pure
resistor, even with very pure water.
We think that the WFC must be a true capacitor in order to make this patent work. We
are currently focusing on that point.
# Restriction flow current circuit: With any added component to restrict the current
flow, the applied voltage on the WFC’s “capacitor” will decrease, and the electrical
field E in the cell will also decrease !
## Cars running with pure water! Michel’s project status (January 06) from
'Michel WFC Report_Jan06.pdf' (2 Mo) at
Our main conclusion for the moment: the process, as described in the patent ... 961
doesn't work! Most information in the patent and in the notes is separately true and
seems coherent, but globally, some information seems missing, or hidden !
We understood through the video, that Meyer would have protected his invention. We
have to investigate with patience to find again his secret.
One major point in our understanding of the patent is that the WFC is not a capacitor
as explained in the patent. The WFC is in fact a pure resistor, very constant for any
frequency and wave form. The value depends on the size of the electrodes, the
distance, and the type of water.
# Consequences:
- The electrical resonance between WFC and resonant charging choke has no meaning
- The current leakage in the water is very high
- The step charging effect seems impossible.
In the next pages, you will find a sum up of the most important experiences we did,
with diagrams, explanatio, pros and cons, and conclusion. Then you will see how we
are coming back to the original patent as described by Meyer.
Before reading this document, please note that we have not yet produced any H2/O2
bubbles using the explained process of Meyer. All conditions are not yet finalized and
completed to start the fracturing process.
# Circuit description:
- Sine wave generator: output 10Vcc / 600 Ohms, frequency adjustable (used range 1
to 40 Khz)
- Electronic rectifier to have a half sine wave (home made)
- Audio Power Amplifier (HiFi or similar)
- Tranformer Tr / different versions have been tested
- Diode D: 800 V, rated for switching power supply (high frequency)
- Inductor L: the resonant charging choke: different type, from 0.1 mH to 5 mH, with
or without ferrite core; the value changes depending of the position of the ferrite core
inside the charging choke.
- WFC: replaced by a true capacitor (Y type, used in the main filter in switching
power supply; rated 400V, can absorb 2 KV
Caution: depending of the signal frequency, and core type, signal distortion could
appear.
Without discharging circuit, the voltage on the WFC (=capacitor) became constant
(DC), like a classical power supply!
Need of a discharging circuit: Resistor R=1 Kohms, carbon type, 3W ; Transistor T1:
Mos typw or Hex Fet, rated 800V, 4A.
Principle: When the capacitor is charged, after some pulses, the transistor T1 is driven
'on' to discharge the capacitor with a 1 Kohm resistor, see next page.
Objective: Our need is to define and to find the right transformer to get a 1,500 V
pulsing signal; Ratio ot 50, with 30V signal input should comply.
2 - Switching power supply from old PC or other electronic devices: Since the
core is in ferrite material, the frequency could reach 50 Khz, or more, depending of
the core type and the number of turns involved in the primary and secondary
windings. The ratio between Primary and Secondary is 15 to 30 max.
(MDG nov07: It seems that Michel and al. are not aware of the concept of charging
the capacitor WFC with high voltage (in the tens of thousands volts) Radiant Pulses.
And to look for the rupture level of the water dielectric layer. Off course the diagram
in Meyer's patent seems to miss something to achieve this objectives; how can a
transformer with ratio 3 (200 turns primary and 600 turns on secondary), bring tens of
thousands of volts from a low voltage input?)
# Results: different views of the step charging effect. Voltage can reach 800 Vp (See 6
pictures on the original doc)
2 signals: driving signal on the pulsing transformer, and step charging effect:
With the programmable counter, we can define: the number of pulses needed for the
step charging, and the numbers of pulses for the relax time.
The max voltage of the step charging is defined by the ratio of the transformer Tr, and
the adjustable input voltage. Typical value is 400V peak; higher voltages are possible,
but some problems occur: distortion, noise, ....
The shape is also adapted by tuning the charging choke L.
Note: More detailed information is of course available, but written in French.
# Conclusion: ...
But we have already identified some limitations:
- The design of the transformer to get high ratio is not so easy, given a high value of
the secondary inductance, and also distortion of the wave;
- The current in the primary is very high, the electrical yield will not be good,
- the power amplifier seems weak to drive inductive charges, ...
- We are limited in the max voltage of the step charging effect (1,200V), because the
transistor needed in the discharging circuit.
In that experience, the inductance L (resonant charging choke) has a small influence
on the step charging effect; The more the number of pulses, the higher the voltage on
the capacitor (of course limited by the max value of the pulse on the secondary of the
transformer)
With this method, it;s easy to get high voltage pulses on the pulsing transformer. The
current in the primary is very low, because the charge applied on the secondary is only
the capacitor C (no DC current). The 'step charging effect' is also easy to obtain.
# Next experiments: In the next few weeks, we would apply this signal to the
insulated electrodes instead of the Y capacitor. To follow ...
(MDG nov07: I didn't found yet more recent results on their very very interresting
experiments.
May be the solution to Meyer's cell is the thin film that is reported to form
progressively on the electrodes, like if they needed a conditioning; perhaps that film
makes a powerful insulating layer on the electrodes, the cell becoming then a real
capacitor without any current leakage. But in this case bringing the capacitor/cell to
its breakdown voltage limit has no more sens, because it would destroy this layer at
each breakdown ... )
# New analysis of the water behaviour: We read recently an article about Meyer's
invention, and some technical comments:
'... The resonance of the cell is very sharp, and can generally only be found by careful
monitoring of the current while adjusting the pulse frequency very, very slowly. Even
at frequency very close to the resonant frequency, there will be no indication
whatsoever that the frequency has almost benn reached ...'
# Future project: The idea is to get a specific generator driven by a computer, with a
sweep Hz by Hz. Frequency increment is 1 Hz, every second for instance. So, it
would take approx 20,000 sec = 5 hours.
The current observation will be automatic. If there is any drop of current at a certain
frequency, the sweep on the generator will immediately be stopped by the computer,
and the frequency memorized. This could work automatically, in the night. Several
tests could be performed with different signals, with or without DC component part,
different type of water ...
(MDG nov07: Successful replications of Meyer's cell by Lawtown and Ravi seem to
prove that there is now 'magical resonant frequency' to look for ... I remember reading
somebody affirming that the resonant frequency wouldn't appear at the exact moment
we reach it, but that we needed to stay at list 8 seconds at this frequency for the effect
to start ... I think it was about Mateiro Electrolysis, and it was bringing the all staff a
level higher in the complexity and unprobability to reproduce !)
# Charging chokes and inhibitor circuit: In the patent ... 961, there are 2 resonant
charging chokes: one is fixed, the other one is adjustable.
In the patent ...961, there are 2 resonant charging chokes: one is fixed, the other one is
adjustable. Till now, we haven't understood the exact use of the 2 charging chokes: for
us, 2 inductances in series could be equivalent to one, in a electrical point of view.
In our design, the main inductance was adjustable; and we saw clearly his action on
For example, our charging choke is 4.7 mH without ferrite rod, and 30 mH with it
inside. We have re considered the use of them, and especially in the ability to reduce
the current leakage in the WFC. In Meyer's Memo 422DA (Memo3), the resonant
charging chokes are the same (100 turns each). One is fixed, the other adjustable, to
fine tune the resonant action.
The total number of turns (200) is similar to the primary inductance ! interesting !
Considering that the primary inductance stores a magnetic energy during 1 pulse, this
energy is transferred to the secondary, and this energy goes through the 2 charging
chokes towards the WFC.
In other Memo from Meyer, the 2 charging chokes are magnetically coupled. This
sounds good.
The current Ic in the choke L1 goes through WFC and L2. But the same current in L1
produces a magnetic field, which creates in the choke L2 the same current Ic in the
circuit.
Depending on the manner the connection is done with the 2 charging chokes, the
current in the circuit will be very different:
# Circuit 1: Standard connection, Y1= 108mA, Y2= 17Volts ; The current is due to
the resistive part of the water, (157 ohms, normal value)
These values are stable in the range 500 Hz - 30 KHz, due to characteristic of the
core.
# Circuit 2: Cross connection, this is the circuit used by Meyer, called inhibitor
circuit (MDG nov07: Is it the Tesla/Bedini bifilar we were looking for to collect
Radiant Pulses?), Y1= 2.5mA, Y2= 0.4Volt ; These values are stable in the range 500
Hz - 30 KHz
# Conclusion: In our experiment, the current is 43 times less, and also for the applied
voltage on the water cell.
We tested another component, rated 2 x 15 mH, and we found quite the same values.
When the charging chokes are connected as explained in the Meyer document,
the current is drastically reduced in the resistive part of the Water Fuel Cell. End
of document.
When the ultra-short pulse voltage of less than seceral microseconds is applied to a
water electrolysis bath, the voltage application is so fast neither the electric double
layer nor the diffusion layer can be stably formed in the vicinity of electrodes.
The pulse width which is necessary for electrolysis without formation of the diffusion
layer is estimated [9] to be:
Del.t<(1/4D).(Xad/X)2 (1)
Here, Del.t is the pulse width (s), D the diffusion coefficient (cm2 s-1), Xad the density
of hydrogen ions on the cathode electrode (cm-2) and X (cm-3) is the concentration of
hydrogen ions in the solution. This equation was simply calculated under the
assumption that the total amount of adsorbed ions, Xad, is equal to the diffusion layer
thickness d (cm) multiplied by X, and d must be larger than the diffusion length (4D
Delt.t)1/2 during the pulse application, considering that the pulse application duration
must be shorter than the time necessary to fill the diffusion layer with hydrogen ions.
From this equation, taking as D=2.3x10-5 cm2 s-1 for proton diffusion coefficient [1],
X=6x1020 cm-3 for 1M for KOH solution and Xad=1015 cm-2 for platinum metal surface,
the pulse width is estimated to be about 3 microsecond. This means that electrolysis
occurs without forming the diffusion layer in the present work since the pulse
width is one tenth of this critical 3 microsec.. It is also known that the time
necessary for the formation of the stable electrical double layer is of the order of
several tens of milliseconds [1]. It is therefore evident that the stable electrical
double layer is not formed during the present ultra-short pulse application. Since an
electric field as high as 2.6-47V cm-1 can be applied in the present work, the lack of
formation of the stable electric double layer means that hydrogen ions can be moved
faster than in conventional DC electrolysis. These different mechanisms that arise
via ultra-short pulse application, leading to the absence of the diffusion layer and the
stable electrical double layer, mau open the possibility of high capacity water
electrolysis.
In the IES circuit (Figure1), the gate of the SIThy is connected to the anode through a
diode. When the FET (Field Effect Transistor) is switched on, the current through the
inductive coil (L1) gradually increases. When the FET is switched off at a certain
current level, the current flow is instantly switched off and the inverse voltage Vp1 is
induced through the coil (L1). This IES circuit is the simplest and most compact one
yet reported for generating ultra-short pulses [6-8].
Fig.1. Ultra-short pulsed power supply circuit for water electrolysis based on the
inductive energy storage (IES) circuit [6-7] with a static induction thyristor (SIThy).
In the case of water electrolysis using the above ultra-short pulse power, the water
bath electrodes are connected to the secondary reactance L2 as seen in Figure1. The
pulsed voltage Vp2 is induced in the secondary reactance L2, synchronized with the
pulsed voltage Vp1 as seen in Figure2. In the first stage, when this secondary pulsed
voltage is applied to the electrodes in the water bath, the bath acts as a quasi-
capacitor since the pulse width is too short for ions in the bath to cause a current
through the bath. This gives a very short pulsed current Ip2 in the circuit through the
secondary coil (L2). This current is too rapid to be seen in the figure. The water bath
is not a real capacitor since all electrons collected at the cathode are transferred to
hydrogen ions and high voltage does not remain as in the case of conventional
capacitors. After this pulsed voltage had been applied to the electrolysis bath, in the
second stage, the current I2 flows through the circuit. This current flows very slowly
as seen in the figure with several tens microseconds. Since the application of the
pulsed voltage Vp2 was already terminated, this current flow I2 may not be due to
electron transfer to hydrogen ions but ion transport in the bath, thus compensating the
lack of hydrogen ions in the vicinity of the cathode electrode.
# Results and discussion: The hydrogen generation rate and its efficiency are plotted
as a function of the input power between the electrodes in Figure3. In the case of DC
power electrolysis, when the applied voltage is increased, the current increases so that
hydrogen generation rate increases, but the efficiency compared with the ideal
generation rate decreases from 40% at 2.2V to 8% at 12.6V. Here, the ideal
generation rate was calculated from thermodynamical data [10], for the
thermodynamical energy for hydrogen to be converted to room temperature water.
The decrease in efficiency can be explained because an electron with high energy can
only reduce one hydrogen ion so that the difference between the applied voltage and
the decomposition voltage is dissipated as heat. Since the current itself is also
increased by increasing the applied voltage, electrons which are not used for hydrogen
reduction are also dissipated as heat.
In the case of pulse power, it is seen in Figure3(a) that the hydrogen generation rate is
increased as the peak voltage is decreased. It should be noted, however, that the
hydrogen generation rate increases as a function of the input power. This behaviour is
quite different from the case of DC electrolysis. When the input power is increased by
increasing the pulse frequency, the efficiency was not decreased in the case of high
peak voltages, and was increased in the case of low peak voltages as seen in
Figure3(b). This behaviour is contrary to the case of DC power. This increase of
the efficiency for the case of low peak voltage may be because the energy dissipation
is decreased since each electron has lower energy and the pulse waveform is sharper
for low peak voltages. For these reasons, power can be efficiently consumed for
electrolysis. This fact implies that the ultra-short power electrolysis is a promising
method in which the power application can be increased even with an increase in
electrolysis efficiency.
In the case of DC power, the electric field is always present. The electrical double
layer is also present and the diffusion layer always exist. The current flow is therefore
determined by the diffusion of ions with a driving force of ion concentration
difference. When the applied voltage is increased, the efficiency decreases. In the cse
of DC power, the power applicable for a certain volume of the electrolysis bath is
therefore limited.
Fig.2. A typical example of pulse waveforms for the first and second stages. In the
first stage, an ultra-short pulse with the width of about 300ns is applied. In the second
stage, the current flows slowly.
Fig.3. Hydrogen generation rate (a) and its efficiency (b) as a function of the input
power. In the case of pulsed power, various circuits with different voltage (Vp2),
current (I2max) and frequency ((i)-(iv)) have been compared. The input power is the
integration of the secondary voltage and current multiplied by the frequency. The
ideal line was calculated from the thermodynamical energy for hydrogen to be
converted to room temperature water. Hydrogen generation efficiencies in (b) were
calculated as the hydrogen generation rate divided by the ideal hydrogen generation
rate at the same input power.
In the case of ultra-short pulsed power, the electric field is applied for only a very
short time less than several microseconds which is much shorter than the time
necessary for the formation of the constant electric double layer. By the application
of the ultra-short pulse, electrons are collected on the surface of the cathode
electrode as in a capacitor. The electrons gathered however are quickly transferred
to hydrogen ions for hydrogen generation so that electrons do not remain in the
electrode as in a conventional capacitor. After this electron transfer, the current I2
flows slowly as shown in Figure2, probably due to the ion diffusion in the electrolysis
bath.
From the above considerations, it can be concluded that the electrolysis mechanism
for ultra-short pulse power is very different from that of DC electrolysis. DC
electrolysis is based on electrical double layer formation and is a diffusion-limited
process, while ultra-short pulse power electrolysis is based on the strong electric field
application and the electron transfer limited process. This difference seems to be very
important for the practical and industrial application of ultra-short power electrolysis
since the electrolysis power can be increased without decreasing the efficiency.
# References:
1 - T. Watanabe and S.Nakamura, Introduction to Electrochemistry: Chemistry of
Electron Transport (Japan Chemical Society, 1996)
2 - J. Nishizawa, T. Teriyaki and J. Shibata, Res. Inst. Electrical Comm. Tohoku Univ.
Tech. Rep., RIEC TR-36 (1973) 1.
3 - J. Nishizawa, T. Teriyaki and J. Shibata, IEEE Trans. Electron Dev., ED-22 (1975)
185.
4 - N. Shimizu, K.-S. Lee, M. Yuri, Y. Ikeda and K. Murdock, Proc. 10th Symp. Static
Induct. Dev., SSID-97-6 (1997) 29.
5 - R. Hironaka, M. Watanabe, E. Hotta, A. Okino, M. Maeyama, K.-C. Ko and N.
Shimizu, IEEE Trans. Plasma Sci. 28 (2000) 1524.
6 - K. Iida and T. Sakuma, Proc. 15th Symp. Static Induct. Dev., SSID-02-9 (2002)
45.
7 - N. Shimizu, T. Sekiya, K. Iida, Y. Imanishi, M. Kimura and J. Nishizawa, Proc.
Int. Symp. Power Silicon. Dev. (ISPSD) P-30 (2004) 281.
8 - W. Jiang, K. Yatsui, K. Takayama, M. Akemoto, E. Nakayama, N. Shimizu, A.
Tokuchi, S. Rukin, V. Tarasenko and A. Pachenko, Proc. IEEE 92 (2004) 1180.
9 - O. Oda and N. Shimizu, Japan Patent Pending, 2004-223595.
10 - O. Kubaschewski, E.L. Evans and C.B. Alcock, Metallurgical Thermochemistry
(Pergamon Press, 1967).
Abstract: This invention relates to the decomposition of water into oxygen and
hydrogen by the effect of ionization by collision among the water molecules. Water of
liquid dielectric characteristics is contained within a solid dielectric container having
higher dielectric constant relative to that of the water, the solid dielectric also having
thermostability. A high voltage is then applied to the solid dielectric, creating a strong
enough electric field, exceeding the covalent bond of the liquid dielectric, to
decompose the water, while the solid dielectric container maintains its stability.
This is a continuation of application Ser. No. 167,147 field July 8, 1980, now
adandoned.
In addition, in the case of non-electrolyte the electrolysis does not happen though
equipping the dielectric with the electrode. And if the higher voltage is given to the
dielectric than the withstanding voltage strength of the dielectric, the electrolyte is
broken down in the dielectric and the large quantity of electric current is flowed
between the electrodes.
We have only considered the prevention of the dielectric breakdown because when
this dielectric breakdown happens, the molecule of the dielectric are often
decomposed, but this dielectric and electrical machinery become useless.
# Description of the prior art: USP 3,674,676 about the electrode used in above
electrolysis. The cathode covered with the diaphragm is used at a regular interval
from the neighboring anode which is made by using titanium plate or expanded metal
or platinum group. And according to West-Germany Pat. 72/12225 is known to use
asbestos diaphragm with perfluoro ethylen or trifluoro ethylene sulfon acid having
positive ion exchangeability. But according to above patents, they have the weak point
that they lose exchange-ability and need much expenditure making the diaphragm
Then as low electric field strength short of the loithstanding voltage strength is
formed at both side of the liquid dielectric and the solid dielectric restrain much
electric discharge current to flow between the electrodes keeping stable state, the
water continuously receives the strong electric field strength, and therefore water-
molecules are decomposed.
It the two kinds of dielectric which are differing in dielectric constant comprise 3
layer, that is, we put two same electric plate and put another dielectric between them,
the dielectric which has high dielectric constant receives low electric field strength,
and high electric field strength is formed at the low dielectric of low dielectric
constant. Then the dielectric intruded receives stronger electric field strength than
both side of the dielectrics.
When the electric field strength exceeds the withstanding voltage strength of its own,
the molecules of the liquid dielectric is decomposed by ionization by collision, the
dielectric breakdown happens and then both side of the dielectric layer can be in
stable state because it receives weak electric field strength.
Therefore in the case of passing strong voltage to the complex dielectric layer, the
strong electric field strength can be formed at a layer and the molecules of the liquid
dielectric can be decomposed by the ionization by collision. The invention is
illustrated according to the appended figures.
# Detailed description of the preferred embodiments: From the Fig.1 and Fig.2, the
solid dielectric (D1) forms 'U', the middle interval (d2) is filled with liquid dielectric
and the both sides of the solid dielectric (D1) has the electrode.
If the strong voltage (V) for example 20kV-60kV is given to such electrodes, the
electric field strength satisfies these equations.
The withstanding voltage strength of the solid dielectric (D1) V.kV/m, the dielectric
constant of the solid dielectric: e1, the electric field strength of the solid dielectric: E1,
the interval of the solid dielectric: d1, the with-standing voltage strength of the liquid
dielectric (D2): V2 kV/m, the dielectric constant of the liquid dielectric: e2, the
electric field strength of the liquid dielectric: E2, the intervalof the liquid dielectric:
d2, the ratio of the two dielectrics: e2/e1=er.
As we can know from the above equations, if er, the ratio of the two dielectrics, is
much smaller than 1, low electric field strength is formed in the solid dielectric (D1)
in comparison with the liquid dielectric (D2).
Reversely if strong electric field strength is formed in the dielectric (D2) and the
electric field strength exceeds the withstanding voltage strength of its own, the
dielectric breakdown, that is, ionization by collision happens, and if it receives the
electric field strength lower than the withstanding voltage strength of its own, it
becomes the stable state. Accordingly to above method, the water (H2O), liquid
dielectric, can be decomposed with hydrogen and oxygen.
Now 'U', which we can see from Fig.1 and Fig.2, is made of solid dielectric of the
type of ceramics which has exceedingly high relative dielectric constant in
comparison with 80 and can resist high withstanding voltage strength and high
temperature. If we make complex dielectric layer which is filled with water in the
middle interval (d2) and tens of thousand voltage is flowed into the electrode (p),
then, as the relative dielectric constant becomes er/1 by the equation (1) and (2), the
water receives electric field strength of its own and the molecules of the water are
decomposed into hydrogen and oxygen by the ionization by collision.
As both sides of the solid dielectric receive weak electric field strength short of the
withstanding voltage strength of its own and restrain electric discharge current to flow
in the stable state, water is continuously decomposed by receiving the strong electric
field strength.
This phenomena can happen on the condition that relative dielectric constant of the
solid dielectric is tens of times or hundreds of times as high as that of the water, that
is, er<<1 and its nature is such that it can resist the withstanding voltage strength and
high temperature, and there is the system of ceramics which satisfies these conditions
and so there is no difficulty in decomposing water by using the theory of the
distributive electric field strength of the complex dielectric layer and ionization by
collision of the dielectric.
Like Fig.1 and Fig.2, we made complex dielectric layer and the voltage of 50kV
flowed into the electrode (p) installed and both sides of the solid dielectric (D1)
received the electric field strength E1=0.52 kV/mm and it became in stable state
because it is short of the withstanding electric field strength E2=22.42 kV/mm and the
ionization by collision happened and was decomposed in hydrogen and oxygen. Then,
as 7.2 cc of water was decomposed, the mixing oxygen and hydrogen gas was
collected.
2/ The method of claim 1, wherein the solid dielectric container is made of ceramic.
3/ THe method of claim 1, wherein said strong electric field strength is in the range
20kV/mm - 60kV/mm
4/ The method of claim 1, wherein said strong electric field strength is greater than
about 50kV/mm
5/ The method of claim 1, wherein said solid dielectric container comprises two
parallel dielectric slabs having a dielectric constant greater than ten times that of
water.
6/ The method of claim 5, wherein said liquid dielectric comprises pure water.
End of integral transcription. Mistakes in english language are from the original
document.
Hydrogen and oxygen ionisation… This may be one way the Water fuel cell (Satn
Meyer's one) breaks the covalent bonding of the water molecule. The two electrons
covalently bonding the hydrogen to the oxygen are stripped of when the oxygen is
ionised and looses four electrons, now because the oxygen atom needs another
electron it takes it from the much weaker hydrogen atom, when it dose this the
hydrogen looses its electron to the much stronger oxygen atom. The reason the
oxygen is stronger then the hydrogen is because the hydrogen atom has only one
proton whereas the oxygen atom has eight, so the oxygen has a stronger electrical
charge. When the oxygen atom takes the hydrogen’s electron it breaks the covalent
bond (remember we are only doing this with voltage). The hydrogen electron is the
thing that is holding the water molecule together, so when the oxygen atom takes the
hydrogen atom’s electron it is breaking the covalent bond. The oxygen normally gets
it’s electrons from amp flow, that would be the point where the high currant would
flow, but because we are now restricting electron flow the oxygen atom takes the
electrons from the hydrogen atom, this breaks the covalent bond.
If the world should blow itself up, the last audible voice would be that of an expert
As is well known, water is composed of a hydrogen atom and an oxygen atom. When
water is sufficiently magnetized, each constitutive atom is also weakly magnetized to
rotate the elementary particule in a particular direction. This rotation of the
elementary particule is generally called as 'spin'. That is, the spin function is caused
by an electron, atomic nucleous, atom and even by the molecule. When a negative
electrode is immersed in the electrolyte (NaOH solution) for applying a voltage
thereto to cause the elementary particule to react with the electric field, the coupling
state of the hydrogen with the oxygen is varried and the electrolysis is facilitated
under the function of spin.
In accordance with the present invention, vortical negative and positive electrodes are
arranged in a closed relation but in short free positions and these two electrodes are
supplied with a power through external terminals and the electrolyte is placed to flow
between the negative and positive electrodes. Thus, the electrolyte is subjected to the
electrolysis between two electrodes under the function of the potential magnetic field
formed by the coil current which is generated by the electrodes with active movement
of an electrolytic ion (Na+, OH-) so that the electrolysis of water takes place smoothly
under the spin functions of the atom and electron.
It has been confirmed that the rate of the electrolysis of water according to the
invented process is approximately 10 or more times (approximately 20 times on
calculation) as that of the conventional electrolysis.
The structural design of electrolytic cell in accordance with the invented system is
characterized in that the electrolyte flowing through the supply ports provided at the
lower portion of the electrolytic cell is subjected to the potential magnetic field in the
presence of the permanent magnet and that the electrodes for electrolysis is subjected
to the more potential magnetic and electric fields to obtain a sufficient spin effect.
It is, therefore, a general object of the invention to provide a novel apparatus for
decomposition of liquid in which an electrolyte (NaOH) solution is subjected to
magnetic field to carry out an electrolysis under the function of the spin of an element
constituting water molecule thereby to produce a great amount of gas with less
consumption of electric energy.
Others objects and advantages of the present invention will become apparent as the
detailed description thereof proceeds.
# Brief description of the drawings: The invention will be described more in detail
in the following with reference to the accompnying drawings, wherein:
Fig.1 is a partially cross-sectional schematic elevation of an apparatus in accordance
with the invention;
Fig.2 is a perspective view of electrodes arranged in accordance with the invention;
and
Fig.3 is a plan view of electrodes with magnetic materials.
These cell 10 and tanks 12, 14 are communicated with each other through a delivery
pipe 16 which communicates the top of the electrolytic cell 10 with the middle portion
of the gas-liquid separation tank 12, a feed-back pipe 18 provided with a pump 20,
which communicates the bottom portion of the gas-liquid separation tank 12 with the
bottom portion of the electrolytic cell 10, and a conduit 22, which is extended from
the top portion of the gas-liquid separation tank 12 through a valve 24 into the bottom
portion of the gas washing tank 14. To the top portion of the gas washing tank 14 is
connected a drain pipe 26 through a valve 28.
In the electrolytic cell 10, positive and negative vortical electrodes 30 of diameters as
defined in accordance with an internal diameter of the electrolytic cell 10 are arranged
coaxially, and at upper and lower positions of the vortical electrode 30 are arranged
magnet rings 32 and 34 of ferrite and the like, of which positive and negative
magnetic poles are confronted therein so that a magnetic field generated is orthogonal
to the axis of the electrolytic cell.
The vortical electrodes 30 are composed of two metal strips 36 which are wound into
vortical shapes with a plurality of cylindrical insulating spacers 38 of rubber and the
like interposed therebetween in attachment to the surface of the metal strips 36.
From the metal strips 336 are withdrawn lead wires 40, which are in turn connected
respectively to positive or negative electrode terminals provided int he inner wall of
The electrolytic cell 10 and the gas-liquid separation tank 12 are filled with a
electrolyte 44 which may be circulated by the pump 20 whereas the gas washing tank
14 is filled with a washing liquid 46 to such a preferred level that gases gushing out of
the conduit 22 is well washed.
The apparatus in accordance with the present invention may be well applicable to an
electrolysis of flowing water for production of hydrogen gas and oxygen gas at a high
efficiency. That is to say, the electrolytic cell 10 and the gas-liquid separation tank 12
are filled with the electrolyte 44 which is constrained by operation of the pump 20 to
flow through a magnetic field in an annular path in which positive and negative
magnetic poles N, S of the magnets 32 and 34 are confronted and through the metal
plates 36 of the vortical electrode 30 to impart an orientation to an electrical migration
of cation and anion with increased gas separation rate and promotion of electrolysis.
The vortical construction of positive and negative metal strips alternately opposing to
each other enables a desired reduction in bulk of the cell, while increasing a
contacting area with the electrolyte 44 with relatively short migration distance of ions
for promotion of gasification. On the other hand, insulating spacers 38 interposed
between the positive and negative metal strips 36 serves to develope desired
turbulence of the electrolyte passing through the space.
The liquid circulating system for separation of gas and liquid requires no other driving
unit except the circulation pump 20 to achieve separation of gas and liquid by
utilizing differences in water heads developed among the cell 10 and the tanks 12 and
14. In other words, a flow of gas-liquid mixture supplied from electrolytic cell 10 is
fed into the gas-liquid separation tank 12 where due to the difference in buoyancy of
gases and liquid, gas rises and is fed into the gas washing tank 14 whereas the liquid
goes down and is returned again to the electrolytic cell 10. The washing tank 14 is
filled with convenient washing liquid 46 so that gases gushing out of conduit 22 are
washed and fed into the drain pipe 26. Thus, the apparatus may be constructed at
reduced cost without complexity.
(MDG nov07: 116cc of Hydroxy per sec. = 417 L/hour (7 L/mn) for 30Ah x 2.8V=
84Wh ; That's 5 Liter of Hydroxy per Wh <=> 0.2Wh per liter !!! AMAZING
EFFICIENCY.
This concept produced 15 times more Hydroxy gas than our already well efficient 6
serie-cells car electrolyzer straight DC from alternator !
He his using 2.8V, so coupling 5 of his cells in series (5 x 2.8 = 14V) and using a car
alternator, for 30A (total power consumption 30A x 14V = 420Watts), you will get an
amazing amount of 5 x 7 = 35 L/mn of Hydroxy !)
With our 6 cells series we are getting 3Wh/L (1 L/mn for 15A) and we were already
very proud ... This design is ways over Faraday's maximum = OVERUNITY)
# What I claim is: 1/ Apparatus fro the decomposition of aqueous liquid whereby gas
is formed comprising a cell, having an inlet at one end and an outlet at the other,
positive and negative electrodes mounted within said cell between said inlet and outlet
connected to a source of elecctric current, said electrodes being wound about each
other in substantially coaxial helices to form a vortex transverse to the flow of liquid,
and magnetic means mounted with said cell at each of the axial ends of said
electrodes.
2/ The apparatus according to claim 1, wherein said inlet and outlet meansare at axial
ends of said electrodes.
4/ The apparatus according to claim 1, including a pump at the inlet for feeding the
liquid under pressure through said cell.
7/ The apparatus according to claim 1, wherein said magnetic means comprise annular
members having diametrically opposed positive and negative poles lying orthogonal
to the flow of liquid.
End of full transcription of the patent.
In the research by Sandia National Laboratories [1] there was a total of 25 point-plane
measurements taken and tabulated for the primary purpose of generating equation (1).
Additional analysis of the 25 point-plane measurements has produced equation (2),
and unlike equation (1), equation (2) has an additional parameter d, which is a
variable representing the distance between capacitor plates. The variable d is
measured in centimeters (cm).
EpTeff0.360+-0.053 d0.030+-0.077 = 0.230 (2)
The research of Sandia National Laboratories [1], that produced equation (1) and (2),
was designed to supersede equation (3) produced by Eilbert and Lupton [2] for
systems assuming infinite area capacitors. Equation (3) is an empirical relationship
specifically involving a finite area capacitor.
EpTeff1/3 A0.058 = 0.230 (3)
Another empirical equation (4) specific to a finite area capacitor has been created by
(AWRE) at Aldermaston, England [3, 4, 5, 6], and published in References [5, 6].
EpTeff1/3 A1/10 = 0.3 (4)
Equations (1), (2), (3), and (4) are the result of a century of research and investigation
into the magnitude of parameters necessary to induce water-dielectric breakdown.
Equation (1) and (2) were specifically created for the design and construction of water
based electrical insulation systems. Equation (3), and (4) are more general and have
been created for other purposes, although have been included in this publication to
especially highlight the due diligence of past researchers to document the empirical
As a result of the latter due diligence, established in equations (1), (2), (3), and (4), it
is now possible to investigate the subsequent reaction ensuing after the occurrence of
waterdielectric breakdown. This publication deals with a potential entropic
repercussion of waterdielectric breakdown, and the theorized kinetic energy (Ek) that
emerges from ionic alignment.
II. Theory: Dielectric breakdown results in the formation of positively charged and
negatively charged ions. These positive and negative charges arrange in an alternating
fashion connecting the negative capacitor plate to the positive capacitor plate in an
attempt to maintain net charge neutrality. The alternating charges form a conductive
path, capable of propagating electric current, effectively allowing the discharge of the
voltage stored in the capacitor beginning at the instant of dielectric breakdown. This
newly established conductive path is well organized, in a relatively linear fashion,
such that a low state of entropy occurs. Associated with a low state of entropy is a
high molecular kinetic energy (Ek) magnitude, whereas the typical the random
motions of particles, in a high state of entropy, tend to cancel each other.
III. Ionic Alignment and the Resulting Magnitude of Kinetic Energy (Ek): Upon
the alignment of the positive and negative charged ions, a state of low entropy is
established resulting in a quantity of kinetic energy (Ek). This quantity of energy is in
addition to the magnitude delivered by the to the magnitude delivered by the current
flow (Ein) associated with the discharging of the voltage stored in the capacitor.
IV. Energy Availability: The latter suggested kinetic energy (Ek) is summated with
the input energy (Ein) illustrated in equation (5). Equation (5) also leads into the
method of testing suggested in section V.
(2H2O + Ein + Ek --> 2H2 + O2) (5)
As a result of having these two parameters (Ein), and (Eout), a simple arithmetic
subtraction calculation can be made to determine the value of (Ek) that would be
required to balance the stoichiometry.
VI. Appendix:
[1] W.A. Stygar, T.C. Wagoner, H.C. Ives, Z.R. Wallace, V. Anaya, J.P. Corley, M.E.
Cuneo, H.C. Harjes, J.A. Lott, G.R. Mowrer, E.A. Puetz, T.A. Thompson, S.E. Tripp,
J.P. VanDevender, and J.R. Woodworth, in Physical Review Special Topics –
Accelerators and Beams 9, 070401 (2006).
[2] R.A. Eilbert and W.H. Lupton (unpublished).
[3] I.D. Smith, Atomic Weapons Research Establishment Report No.
SSWA/JCM/6511/B, 1965
[4] I.D. Smith, Atomic Weapons Research Establishment Report No. SSWA/IDS/6610
/100, 1966.
[5] J.C. Martin, Proc. IEEE 80, 934 (1992).
[6] J.C. Martin, in J.C. Martin on Pulsed Power, Edited by T.H. Martin, A.H.
Guenther, and M. Kristiansen (Plenum, New York, 1996).
[7] Thermodynamics (An Engineering Approach), by Yunus A. Cengel and Michael
A. Boles, Fourth Edition (2002).
There has been some discussion here of using radio frequency to improve the
efficiency of electrolysis. According to Wikipedia, there are two mechanisms
involved. One is known as electronic conduction where the current flow in the
oscillating field allows the material to be warmed to absorb energy as heat." This is
the essence of microwave heating.
So, the basic method of "burning seawater" is simply the placement of the seawater in
a real physical vibration of radio frequency. This can be achieved by attaching
magnets to piezoelectric quantum dots and choosing the dimensions so that they
oscillate at radio frequency. This will burn seawater. Also, a manufactured hollow
dielectric sphere with attached magnets and the dimensions chosen to vibrate or
"oscillate" at radio frequency will cause seawater to combust and continue to burn as
long as this real physical vibration continues.
Computer simulation is needed to confirm the results of such a device before it is built
so that one’s efforts are not wasted. This would save a great deal of time in the
development stage. Dielectrics naturally polarize themselves in the presence of an
electric field.
There is really no need for fossil fuel at all for powering an internal combustion
engine if natural radiant energy is converted to actual radio frequency physical
vibrations. Hydrogen on demand through dielectric heating assisted electrolysis may
be the basis of a new generation of hydrogen cars. Hydrogen on demand is a real and
plausible solution to global warming. We just need to put the plan in place.
Fine bubbles of the size required for many processes such as electroflotation can be
generated by electrolysis. A large number of factors such as electrode material,
electrode surface/morphological properties, pH and current density affect the gas
bubble size distribution. This work is aimed at studies on the effect of interrupted
current (pulsed) electrolysis on the generation of gas bubbles. A microcomputer-
controlled current source designed to generate the required pulses is described along
with typical results obtained with this system. It was observed that a decrease in duty
cycle at a given pH and average current density causes an increase in fine sized
bubbles and concomitant increase in bubble flux. A mechanism based on local
potential gradients is proposed to explain this phenomenon.
2. Literature review: The physical process of gas evolution can be divided into three
stages: nucleation, growth and detachment. Bubbles nucleate at electrode surfaces
from solutions highly supersaturated with product gas and grow by diffusion of
dissolved gas to the bubble surface or by coalescence at the electrode with other
bubbles [19]. They detach from the electrode when buoyancy or liquid shearing forces
pulling the bubbles away overcome the forces binding them.
Various mechanisms have been proposed to determine the bubble departure diameter.
Coehn [8] proposed that electrostatic attraction between the bubble and the electrode
is instrumental in determining the departure diameter. Stronger attraction requires a
larger buoyant force for detachment necessitating larger bubble diameters. Bubble
charge studies [18] conducted on platinum anodes at 10-40 kAm -2 tend to support
this mechanism. However, electrostatic forces are predominant at current densities
(106 A m-2), larger than those encountered in electroflotation [9-11, 14, 16]. Using
high speed photography, Glas and Westwater [17] observed that contact angle is not as
significant a factor as surface roughness or electrode material in determining the
growth rate of bubbles.
A relation between the hydrogen overvoltage and the bubble size has been observed
[4].
It was also observed that under clean conditions contact angle is dependent on the
overvoltage [4].
Thus bubble size and flux in aqueous electrolysis seems to depend upon (a) surface
morphological factors including donor acceptor and low overpotential sites and (b)
the inherent overvoltage property of the electrode material.
3. Experimental details: The pulsed d.c. source was designed as a circuit board to be
interfaced to a microcomputer giving the system flexibility in its configuration as a
constant current/voltage source (Fig. 1). User interface is more versatile due to
software control of the equipment. The circuit is mapped on the I/0 bus of the
microcomputer using the switch S-1 and address decoder (DEC). The micro-computer
sends data to the digital to analog converter (DA) through buffers (BUF). The timer
(TIM) is programmed to generate timing pulses to update DA under the direct
memory access (DMA) mode of the microcomputer. Thus, the requisite waveform is
generated by the computer in the background while the computer is simultaneously
available for computational and other control work. The DA output is fed to the power
amplifier (PA). The high current supply (PS) is capable of providing a peak current of
5 A. The use of a 12-bit DA operating under direct memory access of an IBM/PC
operating at 8 MHz offers a resolution of 0.024% for current (maximum current of
4A) and minimum pulse cycle time of 3.2ms with 0.5% resolution.
Software was developed for the generation of pulses (Fig. 2) of variable duty cycle at
a selected average current. The average current (iav = id/lO0) was com- puted from the
area under the curve (shaded) and the duty cycle (d) as the percentage of cycle time
(icy) during which the current flows through the celt. Thus, for a square wave, the
duty cycle is 50%. The software was designed to generate a high peak current
nucleation pulse at the start of each cycle. The contribution of the nucleation pulse to
the total energy was negligible ( < 0.2%).
Electrolysis was carried out in a quartz cell mounted on a stand backlit with a bright
light source. A shuttered video camera (1/1000 shutter speed) fitted with microscope
objective 50X to 300X) was used to record bubble dimensions on a video recorder. A
video graphic printer was used to print the picture frames for subsequent bubble size
measurement. The quartz cell was designed to circulate the electrolyte (1 M Na2SO4).
The electrolyte (pH 10.0) was circulated by means of peristaltic pump and a large
external reservoir of the electrolyte was maintained to ensure minimal pH change.
Electrolyte circulation also facilitated removal of the generated gases.
The platinum plate cathode (1 cm 2) was carefully polished and thoroughly degreased.
Care was taken to exclude surface active contaminants. The external glass reservoir
for the electrolyte was always kept covered to prevent air-borne contamination. The
bubbles were observed between 2 to 2.5 mm verticall) above the electrode.
Experiments were carried out for the electrogeneration of hydrogen bubbles with a
pulsed current having a step waveform (Fig. 2). The solutions were electrolysed with
an average current density ranging from 0.5 to 2.0Am -2 and duty cycle ranging from
5 to 100%. A cycle time of 30 ms was used and a recording period of 5min was used
at each experimental condition. Bubble size distribution was computed by examining
at least 150-200 bubbles in sharp focus.
The results obtained for bubble size distribution as a function of current density and
duty cycle are presented in Figs 3-6. Bubble diameters were computed from the video
prints by taking the average of bubbles found in sharp focus. It can be seen from Figs
3-6 that at a given average current density, a decrease in duty cycle results in an
increase of bubbles of smaller diameter. This is expected to significantly increase the
bubble flux.
5. Discussion: The chief effect of pulsing observed during electrolysis is the
occurrence of an increased number of small sized (< 10-15um) bubbles (Figs 3-5).
Thus at low duty cycle, higher current during the 'on' time forces a larger number of
bubbles to nucleate and grow resulting in an increased bubble flux. The requirement
of high current density for nucleation and growth has been observed by Brandon [18]
to be due to diffusion of dissolved gas away from the electrode. Thus an induction
time is observed for bubble nucleation. The induction time is the time required to
attain the necessary supersaturation of the electrolyte with respect to the dissolved gas
at the electrode surface.
Thus bubbles, once nucleated, require a relatively high current density for sustained
growth. Studies with platinum electrodes have shown that bubble detachment is
greatly facilitated by the interruption of current as well as by a reduction in the
potential [18].
Pulsed electrolysis provides ample opportunity for the bubbles to dislodge since the
current is interrupted after each cycle.
To study the effect of the presence of surface active reagents during pulsed
electrolysis, experiments were performed in the presence of 1 x 10-5M sodium
dodecylsulphonate, the concentration chosen being typical for froth flotation systems.
Results plotted in Fig. 6 show that the effect of surfactant at high duty cycle (50%), as
well as low duty cycle (5%), is not significant. An important effect of surfactant,
namely the modification of the bubble-electrode contact angle has been shown to have
very little effect in the case of hydrogen bubbles [17].
The following interpretation of the mechanisms is suggested for the nucleation and
growth of bubbles during pulsed electrolysis.
5.1. Nucleation : Potential nucleation sites on the electrode surface, such as scratch
edges and cavities, possess a wide variation in energy. The higher voltage required for
higher instantaneous currents under pulsed con&tions largely offsets the effect of
local potential gradients and also results in a high degree of local gas supersaturation,
thus resulting in homogeneous nucleation.
At short times i.e. t < 10ms, bubbles grow by acting as sinks for the previously
generated dissolved gas in the supersaturated solution adjacent to the electrode [18].
Such growth is hydrodynamically controlled by liquid inertia.
5.2. Growth and detachment : Growth is driven by the high internal excess pressure
inside the bubble which is related to the surface of liquid-vapour interface. From
10ms onwards, diffusion of dissolved gas to the bubble contact perimeter becomes
rate controlling [22]. Under pulsed conditions of low duty cycle, growth is either
entirely inertial or inertial and diffusion controlled. Under conditions of low current
density (high duty cycle), while most nuclei may grow in a similar manner during the
inertial phase, only nuclei at the lowest overpotential sites grow during the diffusion
control phase due to concentration polarization. Frequent interruptions in current
during pulsed electrolysis also promote bubble detachment. Bubble size increase by
coalescence at the electrode [1, 19], as well as by coalescence in bulk, results in
further increase in bubble diameter.
6. Conclusions:
1. Pulsed electrolysis can be used to regulate bubble size independent of the average
current density and other such parameters.
2. During water electrolysis, increase in current density results in finer bubbles which
may find application in processes such as electroflotation.
References
[1} P.J. Sides, in 'Modern aspects of Electrochemistry' (edited by R. E. White, J. O.'M.
Bockris and B. E. Conway) 18, Plenum Press, New York (1986) p. 303.
[2] H. Vogt, in 'Comprehensive Treatise on Electrochemistry', Vol. 6, Plenum Press,
New York (1983) p. 445.
[3] N. Ahmed and G. J. Jameson, Int. J. Min. Process. 14 (1985) 195.
[4] A.A. Mamakov, in 'Modern State and Perspective of Electrolytic Flotation', Vol. I
(edited by V.P. Schtiinsta), Kishinev (1975) pp. 3-66 (in Russian).
[5] G.B. Raju and P. R. Khangaonkar, Int. J. Min. Process. 9 (1982) 133.
[6] H. Ledesma and M. Guzman, in 'Production and Processing of Fine Particles'
(edited by A.J. Plumpton), Canadian Institute of Mining and Metallurgy, Montreal
(1988) pp. 195-202.
[7] E.A. Cassell, K. M. Kaufman and E. Matijevic, Water Research 9 (1975) 1017.
[8] A. Coehn, Z. Elektrochem. 29 (1923) 1.
[9] B.N. Kabanov, 'Electrochemistry of metals and adsorption', Nauka, Moscow
(1966).
[10] B.N. Kabanov and A. N. Frumkin, Z. Phys. Chem. 165 (1933) 539.
[11] B.N. Kabanov and N. I. Vashchenko, Electrocapillary phenomena and wettability
of materials, Proceedings Academy of Science USSR, Chemical Series (1936) 735.
[12] A. Coehn and H. Neumann, Z. fiir Phys. 20 (1923) 54.
[13] A.T. Kuhn, Chemical Processing 20 (1974), June 9-12, July 5-7.
[14] V.I. Klassen and V. A. Moukrosov, 'An Introduction to The Theory of Flotation',
Butterworths, London (1963) p. 493.
[15] N.P. Brandon, G. H. Kelsall, S. Levine and A. L. Smith, J. Appl. Electrochem. 15
(1985) 485.
[16] D.R. Ketkar, R. Mallikarjunan and S. Venkatachalam, J. Electrochem. Soc. India
37 (1988) 313.
[17] J.P. Glas and J. W. Westwater, Int. J. Heat Mass Transfer 7 (1964) 1427.
[18] N.P. Brandon and G. H. Kelsall, J. Appl. Electroehem. 15 (1985) 475.
[19] P. Sides and J. Tobias, J. Electrochem. Soc. 132 (1985) 583.
[20] R.D. Doherty, 'Physical Metallurgy Part II', (edited by R. W. Cahn and P.
Haasen), North-Holland, Amster- dam (1963) pp. 967-75. E. Murr, 'Interfacial
Phenomena in Metals and Alloys', Addison-Wesley, Reading MA (1975) pp. 259-80.
P. Brandon, Ph.D. thesis, University of London (1985).
[21] L.E. Murr, 'Interfacial Phenomena in Metals and Alloys', Addison-Wesley,
[22] N.P. Brandon, Ph.D. thesis, University of London (1985).
Bob Boyce tells about how he built a carburetor using hydrogen and oxygen split
using proper frequencies
From: "Bob Boyce" To: sterlingda@greaterthings.com Sent: October 07, 2002 8:38
PM
… into hydrogen research where I was building small electrolyzer type units that
used distilled water mixed with an electrolyte and I would resonate the plates for
optimal conversion efficiency. I discovered that with the right frequencies, I was able
to generate monoatomic hydrogen and oxygen, which when recombined, produces
about 4 times the energy output of normal diatomic hydrogen and oxygen
molecules since the process of combustion does not have to break apart the molecules
first before recombining into water vapor. Diatomic hydrogen requires about 4% to air
to produce the same power as gasoline, while monoatomic requires slightly less than
1% to air for the same power. The only drawback was storage at pressure causes the
monoatoms to start joining into diatomic pairs, and the mixture weakens, so it must be
produced on-demand and consumed right away.
I used modified LP carbs on the boat engines to deal with using vapor fuel. I even
converted an old chrysler with a slant six engine to run on the hydrogen setup and we
tested it in the shop.
…It requires a lot of plates made of 316 stainless so it will withstand the more exotic
electrolytes that are more efficient, a plastic box to contain the plates, 1/8" spacers to
keep the rows of plates apart, the electrolyte, and an adjustable frequency modified
psuedo-sinewave inverter can be used for the drive electronics. I used 61 of the 6"
square plates to give a large surface area and scoured the surfaces with coarse
sandpaper in an "X" pattern to give a fine crosshatch grain to add fine sharp points. I
found this improved efficiency as well. The top of the box had two threaded ports, a
small one for injecting replacement distilled water, and a larger one for extracting the
vapor. Under the top cover sitting on top of the plates I cut a piece of plastic matting
to prevent sloshing.
It's very important to keep the total electrolyte level at or below the tops of the plates
to prevent voltage from bypassing any cells and creating excessive water vapor. I
placed a 5 PSI cutoff switch in a tee on the water injection port that shut the drive
electronics down when the pressure in the unit hit 5 PSI. This allowed the unit to be
able to supply on demand without building up too much pressure in low demand
situations. I built a bubbler from a large home cartridge type water filter housing to
prevent any backfire from traveling back up the fuel feed to the unit. Without some
sort of bubbler you run the risk of the unit exploding if a flame front from the engine
flows back to it. I have seen copper mesh screens designed for welding gasses offered
for use on plans I seen years later online for similar devices, but hydrogen has a much
higher flame propagation speed so the copper mesh may not be reliable enough to risk
using.
Place the unit close to the engine to limit the amount of monoatom loss to diatomic
recombination and feed the fuel vapor to the vapor portion of an LP carb system. The
carb will have to be modified for hydrogen use (different mixture rate than propane)
and adjusted with the system running for best performance. The best electrolytes I
found to use were sodium hydroxide and potassium hydroxide. While sodium
hydroxide works well, it's much easier to get (red devil lye in most department stores)
than the much harder to get but slightly more efficient potassium hydroxide. Whatever
you do, be very careful of materials! Make absolutely sure they are compatible with
the electrolyte used. Never use glass containers for mixing or storing potassium
hydroxide!
To group me in with people that were, or are, out to run cars on water, is actually
kinda funny, because that was never my goal at all. My goal never was to seek
publicity or fame, far from it, I wanted to be left alone. Now, I just want to try to
educate people on the benefits of properly constructed series cells, and how to
properly condition to get an efficient catalytic reaction. Let these people take what
they learn and apply it in their own ways.
I did run an older carburated car, but it was as a test jig, up on jack stands, not driving
on the road. I regretted moving to that phase ever since. While I was running those
small marine race engines on straight DC series cells, I never had any problems with
outside interference. Nobody seemed to care. It wasn't until after I discovered the
resonance reaction by accident, then started the resonance research on the car engine,
that someone apparently took a keen interest in what I was doing.
Maybe some day, the resonant reaction effect will be fully understood. Until then,
more research still needs to be done to continue to improve upon the hardware to
make the reaction more predictable and stable. I am working towards continuing that
research.
Bob // 2H+O+Spark=BOOM!
When I discovered the resonance reaction, I was running a pair of small water-jet
powered race boats off of hydroxy on demand systems. Both boats had identical
systems, which were comprised of 2 pairs of 6-cell stacks. Both used a pair of
dedicated propane carbs with 1" vapor fuel lines coming from the bubblers.
Each cell in the stack was 4 parallel cells containing 3 cathode plates and 2 anode
plates, with 1/8" (3 mm) spacing. The cell stacks were 18" square, so plate surface are
for these was massive. It was essentially a brute force system, although I was taking
advantage of the series cell and the efficiency boost of the catalytic electrolyte. I had
discovered this design in my attempts to improve efficiency of the basic electrolyser,
and it turned out to be much more efficient than the electrolysers of the day in all of
the literature I could find in the libraries.
I had modified the battery system to use marine deep cycle batteries, with a heavy
solenoid to engage and disengage power to each unit. Power draw for each on a full
charge was about 350 amps at the 12 volts. Battery run time needed was only in the
minutes, so I just changed batteries before each heat, and kept batteries on charge
during the event.
The resonance effect happened when the alternator on one of these marine engines
failed (rectifier shorted),and superimposed an AC waveform onto the DC power bus.
The effect was limited to a particular RPM range, and was as if someone kicked in an
afterburner, it made such a difference in engine horsepower. After identifying the
cause of this unusual burst of horsepower, I set out to find ways to intentionally create
this reaction. The rest is history as they say.
The auto engine I ran was using a 60 series cell unit operating from a resonance
generator and driver. At resonance, it took about 55-60 watts to generate enough
hydroxy gas to just idle the engine, and about 160 watts to run the engine where the
speedometer read 60 MPH in gear. This was with the car rear end up on jack stands,
so no vehicle load at all on the engine. The engine was a chrysler 170 CID slant six
(inline 6 cylinder) lean burn system with a carb and a distributor type ignition. I used
a propane adapter plate on that engine to adapt it to vapor fuel.
In answer to the question on gas volume, yes, the volume increased dramatically
during resonance, while current draw went way down. I think the limiting factor on
those early 60 cell designs was the amount of gas that could evolve out of solution
and come out of the chamber given the plate area being blocked by the bubbles. It was
as if the water was boiling during resonance, and the bubbles came out of solution,
not just at the plate surfaces. I endeavored to find solutions to stabilize and further
improve reaction efficiency. Unfortunately, I was unable to continue my research after
it was so rudely interrupted.
# And:
I tried straight AC, but that seemed to destroy the catalytic surface layers on
conditioned plates. Using AC to condition produced no catalytic layer at all. It did not
seem to work well for regular electrolysis as well. I did not exhaust all possibilities of
course, but I did try enough to discourage me from heading in that direction.
Bob Boyce's Electrolyzer Plans Available to All, by Michael Couch, for Pure
Energy Systems News
... One day he started noticing that at a certain RPM his power kicked up suddenly; as
though he had a nitro boost or something.
... It turned out that one of the diodes in his Alternator had failed and was pumping an
AC into his electrolyzer. When that certain rpm was reached the output from the
electrolyzer suddenly increased.
... he found that when the frequencies kicked in he was producing much more
monatomic hydrogen. He went on to perfect his electrolysis to the point that it
generates a large volume of gas and mostly monatomic hydrogen.
... The electrolyzer cell itself is either 61 plates for torches and small motors; or 81
plates for larger gensets, ...
... he makes his own PWM3 Controller for Hydroxy torches and gensets. They aren't
for sale but you can find the info in files on the Web. The controller uses three 556
Dual 555 timers. Each dual uses one 555 for pulse width and the other for frequency,
generating 42,800; 21,400; and 10,700 cps respectively.
These frequencies drive the 25% modulation on top of the pulsed DC carrier "bias"
current. The DC Bias voltage is input at the Toroidal Transformer's inputs which gets
filtered into DC before reaching the plates of his electrolyzer with the AC Voltage
riding on it.
... Bob says this causes a magnetic circuit through the center of the plates in the
electrolyzer. The result of all these refinements is that when the water is split, the bias
voltage keeps it from recombining, and H molecules have plenty of electrons to
absorb, preventing the two Hs from joining. Thus the extra large volume of
monatomic Hydrogen molecules.
... The 6"x6" Plates are spaced 3mm apart exactly and sealed on the sides and bottom.
Water levels must be maintained in each cell. Bob's has a supply pipe with holes
drilled along it for each cell.
... Bob says, you will get another area of separation in the water between the cells as
well as on the plates.
... Mr. Boyce is a true humanitarian and has placed his system in the public domain in
the hopes of helping the planet reverse global warming, end oil wars, and deliver free
energy to the poor peoples of the world.
Water IS life... and so much more... So, why all of the excitment about common
H2O?
Water is the glue that bonds all of life together. Without it we would not exist. With
it, not only do we survive, but we may have a solution to our growing global energy
problem.
How so you may ask? Water can be transformed into a perfect energy supply. It is
abundant, non-polluting, and eternal in nature. You split it efficiently and combust it
efficiently. After harvesting that released energy, you again have H2O as the by-
product. Hard to beat!
Will the greed of big oil and big business ever be satisfied enough that they can stop
destroying this planet? I seriously doubt it.
There is energy aplenty in the wind, the sun, in flowing rivers and waterfalls... Even
in a cup of water, latent there, just waiting for the adventurous... Go for it!
# Short extracts: Bob boyce is easily the most experienced and knowledgeable
series-cell designer. He achieves a massively increased gas production rate by using
an electrolyser with a large number of cells in it. Bod uses one hundred cells (101
plates) in his electrolyser. Units with just 60 cells are inclined more to brute-force DC
electrolysis, tending to mask the gains produced by pulsing. As there is a voltage drop
across each stainless steel electrode plate, it is usual to allow about 2 volts across each
cell. However, Bob finds that for high-efficiency pulsing, the optimum voltage per
cell is about 1.5 volts. This means that a voltage of about 1.5 x 100 = 150 volts is
needed to power its to its maximum output.
To get this higher voltage, Bob uses a 110 Volt inverter.... The output from the inverter
is converted from Alternating Current to pulsing Direct Current by passing the output
through a 4 diodes bridge rectifier.
... An electrolyser with a hundred cells, built in this style will have 101 metal plates
and 10 separate bodies of electrolyte. In spite of these large numbers, the size of the
overall unit does not have to be excessive. The spacing between the plates is set to,
say, 3mm (1/8 inch) and the plate thickness might be 16 gauge (0.7 to 1 mm), so the
width of any cell is not great, being roughly the same size as a vehicle battery.
The size of the plates may be determined by the space available in the engine
compartment. It there is a large amount of spare space, then the plate size may be
selected by allowing from two to four square inches of area on both sides of each
plate, per ampere of current. Each side of every plate is in a different electrolysis cell
so a 6 inch by 6 inch plate will have 36 square inches on each face and so would carry
between 36/4 = 9 to 18 amps of current. The choice of current density is made by the
builder of the electrolyser and it will be influenced by the size and cost of the inverter
chosen to drive the electrolyser and the allowable current draw from the battery.
A 600 watt electrolyser would have an absolute maximum output current capacity of
600W/ 110V= 5.45 Amps. The inverter will run much better if not used at its
maximum load all the time, so perhaps a current of 4 Am;s might be used as the target
current. At four square inches per Amp, that indicates a plate area of 16 square inches
(103 square centimetres), say 5" x 3.5" for the part of hte plate below the surface of
the electrolyte. As the plates need to project above the surface of the electrolyte, a
plate size of 5" x 4.5" (125mm x 115mm) would be practical.
If the inverter is 80% efficient, then if you feed 100 watts of power into it, only 80
watts of electrical energy comes out of it. That lost 20 watts is 25% of the actual
output from the unit. More current goes into it than comes out of it (the remainder
being wasted as heat inside the inverter). The power taken from the battery would
then be 4A x 110V= 440W plus 25% = 550Watts. The current draw from the battery
would be 550 Watts/ 13.8V, or about 40 Amps. Bob Boyce recommends a 6" x 6" or
larger plate size, but the size and shape of the spare space in the engine compartment
would be a major consideration. It is essential that every item which contains hydroxy
gas (MDG nov07: if not build in a explosion-proof material like thick metal, William
RHODES afirm in his patent and paper, 1962, that hydroxy is safely contained in 16
Gauge thick iron pipes, and can't explode in that situation) is located in the engine
compartment. Under no circumstances should the electrolyser or bubbler be located in
the passenger area of the vehicle, even if pop-off caps are provided and a second
protective outer housing is provided, as the explosive force is so great that permanent
hearing damage would be a serious danger. ...
The one way valve shown between the two bubblers, is to prevent the water in the
bubbler mounted beside the electrolyser, being driven into the electrolyser in the event
of an explosion in the bubbler mounted beside the engine. The overall operation of
this style of electrolyser is very much like taking gas from a pressurised cylinder via a
pressure-regulator valve. The electrolyser has a pressure switch disconnects the
electrical supply from the electrolyser when the gas pressure in the electrolyser
reaches five pounds per square inch: see diagram.
... The preparation of the plates is one most important steps in producing an
electrolyser which works well. This is a long task, but it is vital that it is not skimped
or hurried in any way. Surprisingly, brand new shiny stainless steel is not particularly
suitable for use in an electrolyser and it needs to receive careful treatment and
preparation before it will produce the expected level of gas output.
The first step is to treat both surfaces of every plate to encourage gas bubbles to break
away from the surface of the plate. This could be done by grit blasting, but if that
method is chosen, great care must be taken that the grit used does not contaminate the
plates. Stainless steel plates are not cheap and if you get grit blasting wrong, then the
plates will be useless as far as electrolysis is concerned. A safe method which Bob
much prefers is to score the plate surface with coarse sandpaper. This is done in two
different directions to produce a cross-hatch pattern. This produces microscopic sharp
peaks and valleys on the surface of the plate and those sharp points and ridges are
ideal for helping bubbles to form and break free of the plate. See drawings.
Bob uses a 6 inch x 48 inch belt sander which is great for preparing the plates and the
uses it all the time now with 60 or 80 grit. Always wear rubber gloves when handling
the plates to avoid getting finger marks on the plates. Wearing these gloves is very
important as the plates must be kept as clean and as grease-free as possible, ready for
the next stages of their preparation.
Any particles created by the sanding process should now be washed off the plates.
This can be done with clean tap water (not city water though, due to all the chlorine
and other chemicals added), but only use distilled water for the final rinse.
A point which is often missed by people constructing electrolysers is the fact that
electrolysis is not just an electrical process, but it is also a magnetic process. It is
important for maximum operating efficiency that the plates are aligned magnetically.
This will not be the case when the plates arrive from the supplier as each plaate will
have random magnetic characteristics. The easiest way to deal with this situation is to
give the plates a mild magnetic orientation. This can be done quite simply by
wrapping a few turns of wire around the stack of plates and passing some brief pulses
of DC current through the wire.
Obviously, the plates need to be kept in the same direction when being slotted into the
case. The next step in the preparation process is to make up a weak solution of
potassium hydroxide. This is done by adding small amounts of the potassium
hydroxide to water held in a container. The container must not be glass as that is not a
suitable material in which to mix the electrolyte.
Potassium hydroxide, also called KHO or Caustic Potash, can be bought in small
quantities from soap making supply outlets... Always store in a sturdy air-tight
container which is clearly labelled DANGER - Potassium Hydroxide. Keep the
container in a safe place, where it can't be reached by children, ... When mixing the
electrolyte, never use warm water. The water should be cool because the chemical
reaction between the water and the KOH generates a good deal of heat ...
Plate Cleansing: Prepare a 5% to 10% (by weigth) KOH solution and let it cool
down. As mentioned before, never handle the plates with your bare hands, but always
use clean rubber gloves. Put the sanded and rinses plates into the slots in the
electrolyser case, keeping them all the same way round so that they remain
magnetically matched. Fill the elctrolyser with the KOH solution until the plates are
just covered.
A voltage is now applied across the whole set of plates by attaching the leads to the
outermist two plates. This voltage should be at least 2 volts per cell, but it should not
exceed 2.5 volts per cell. Maintain this voltage across the set of plates for several
hours at a time. The current is likely to be 4 amps or more. As this process continues,
the boiling action will loosen particles from the pores and surfaces of the metal. This
process produces hydroxy gas, so it is very important that the gas is not allowed to
collect anywhere indoors (such as on ceilings).
A fter several hours, disconnect the electrical supply and pour the electrolyte solution
into a container. Rinse out the cells thoroughly with distilled water. Filter the dilute
KOH solution through paper towels or coffee filters to remove the particles. Pour the
dilute solution back into the electrolyser and repeat this cleaning process. You may
have to repeat the electrolysis and rising process many times before the plates stop
putting out particles into the solution. If you wish, you can use a new KOH solution
each time you cleanse, but please realise that you can go through a lot of solution just
in this cleaning stage if you choose to do it that way. When cleansing is finished
(typically 3 days of cleansing), do a final rinse with clean distilled water.
... A serious issue with an electrolyser of this type is dealing with water loss. As the
plates have to be spaced closely together and since the electrolyte between the cell is
effectively isolated from the electrolyte in the other cells, driving a mile down the
raod is liable to lower the water level by half an inch (say, one cemntimeter). It is
essential to keep replacing the water which is used. ...
Simple electronics procide the answer to sensing the level of the electrolyte, and a
windscreen-washer water pump can be used to inject the additional water. ... Also Bob
recommends cutting the slots which hold the plates, 3 thousands of an inch (0.003" or
0.075mm) larger than the actual thickness of the metal plates. This effectively blocks
electrical leakage between adjacent cells but does allow a very gradual migration of
water between the cells to help maintain an evan water surface across the cell. The
water-level sensor can be just one stiff stainless steel wire run down each side of any
cell. These wires should be insulated to make sure that they do not short-circuit to
either (or both) of the plates on each side of them. They should be set so that their tips
are at the intended surface level of the electrolyte.
If the electrolyte level drops below the tip of the wire sensors, then the resistance
between the wires wil fall, indicating that more water is needed. This scan switch the
water pump on, which will raise the water level until the electrolyte level reaches the
tip of the wire again. A possible circuit for doing that is shown here:
When the level of the electrolyte falls, the sensor wires come clear of the liquid and
the voltage at point 'A' rises. Provided that this situation remains for a second or two,
capacitor C2 charges up and the voltage on the base of transistor Tr1 rises, causing it
to switch on. Transistors Tr1 and Tr2 are wired as a Schmitt trigger, so transistor Tr2
changes state rapidly, raising the voltage at its collector, and causing transistor Tr3 to
power the relay on. The relay contacts switch the water pump on, which raises the
level of the electrolyte until it reaches the sensor wires again. This flips the circuit
back into its standby state, powering down the water pump. Resistor R1 feeds
capacitor C1 to reduce the effects of variations of voltage reaching the sensor circuit.
The components shown here are not critical and there must be at least twenty
alternative designs for this circuit. A possible physical layout for this circuit is shown
here: See printable diagrams on original pdf file.
With an electrolyser of this kind, with narrow gaps between sizeable plates, shifting
bubbles off the plates is important. An importnat technique is to alter the frequency
of the inverter so that it makes the cell resonate. This can be done fairly easily with
many inverters as all it entails is replacing one capacitor with one of a lower value and
relacing one resistor with a variable resistor. Bob Boyce found that the rate of
electrolysis increased considerably when the cell was resonated, and the frequency
of HIS cell was in the 600 to 900 Hz range. If you find this hard to understand, then
may I suggest that you read through the step by step electronics tutorials which
accompany this document. They are designed to be easy for a total beginner to
understand and can take you to the level where you can read circuit diagrams, design
and guild prototypes.
# Customs Electronics: THe objective is to run a vehicle engine with water as the
only fuel. This is not an easy thing to do as the volume of gas needed is very high
indeed, especially since internal combustion engines have an efficiency in the range
of 25% to 40% typically. Also, in America, vehicle engine sizes have grown and
grown with mpg figures, dropping and dropping.
One Japanese inventor has just been granted a license to test out his new design of
engine on public roads in Japan. His method is to use a tank of compressed hydrogen
gas and a tank of water. The hydrogen is injected into the cylinder and ignited. At the
moment of ignition, a fine spray of tiny water dropplets is injected into the cylinder.
The heat of the ignited hydrogen, converts the water droplets instantly into 'flash
steam' with a much larger volume, and the pressure of the steam drives the piston
down on it's power stroke. While that system is very effective, allowing high speed
driving and considerable range on one tank of hydrogen gas, it is not a true Hydrogen-
On-Demand system where water is the only fuel.
Michael Farady investigated electrolysis and established the facts and figures for
straight DC electrolysis of water. While his meticulous work is to be admired, his
results have led to a misconception on the part of the engineers of today. They look at
Faraday's results, and conclude that it is physically impossible to run a car on water
alone as it would take too much current to produce the necessary amount of
electrolysis gas to power the engine. That is perfectly true if the electrolysis is done
the way Faraday did it. It is not true if other methods are used.
Bob Boyce used to race power boats in competitions. He charged lead-acid batteries
in his workshop, and then used heavy current from the batteries to produce large
amounts of hydrogen in his boats, producing high speed performance, running his
engines on the hydrogen/oxygen gas mix produced by electrolysis of water. That was
not Hydrogen-On-Demand as the batteries were charged on land in the periods in-
between the heats in the races.
One day Bob discovered that his system was giving much higher power, boosting the
boat performance in a most satisfactory way. On investigation he discovered that one
of the diodes in his equipment had failed and that fed a very jagged voltage waveform
to his electrolyser. This had two effects. Firstly, the volume of gas produced was
increased. Secondly, the nature of the gas was different. With normal DC
electrolysis powered by an ordinary car battery, the hydrogen gas produced was
mainly in the form of two linked hydrogen atoms, called 'diatomic' hydrogen. With his
jagged waveform, a good deal of the hydrogen produced was in separate single
hydrogen atoms, called 'monatomic' hydrogen, and that form of hydrogen produces
far more power when burnt.
Clearly, Bob was onto a good thing, so he investigated it further. He modified his
system and built a cell as described above, with dozens of plates. This needed a higher
voltage to operate, so Bob used a standard 'inverter' which is a battery powered device
which generates an imitation of mains voltage and wavefoem. Bob modified the
inverter, raising the rate at which it operated from 60 cycles per second to an
adjustable range in the 600 to 800 cycles per second region. He also used some diodes
to convert the output of the inverted from Alternating Current to Direct Current pulses
of about 150 Volts. This was such a success that Bob was able to run his car on the
electrolysis gas produced by the electrical power from the car's own alternator. He
jacked the wheels clear of the floor and ran the engine in gear with the speedometer
showing 60 mph for extended periods. That was a practical example of what most
engineers, even today, believe is impossible.
Bob is not alone in this, Henry Puharich did it as well and the waveform he used is
shown in his patent which is one of the other documents in this set. Henry's waveform
looks like this:
Stanley Meyer also ran his Volkswagen car for four years on the gas produced by
splitting water. Stan broke down ordinary tap water using very little current and a
waveform like this:
Stephen Meyer (Stan's twin brother) has a current patent (xogen.com) for a water-
splitter system which uses a waveform which is shaped like this:
It is quite clear from this, that Faraday's excellent work does not cover every method
of separating water into a mixture of gases, and that a very much higher volume of
gas can be released if Faraday's DC current is replaced by a complex pulsed DC
waveform.
Bob also points out that his 316-grade stainless steel electrodes contain both
molybdenum and nickel which act as catalysts which promote the breakdown of water
into gases.
Bob has further advanced his electrolysis system and has very kindly freely shared his
development in the form of an open-source public disclosure, which he has no
intention of patenting and which he wishes to prevent others from patenting by his
prior public disclosure of the information. So, please note that Bob publicly disclosed
this information early in 2006 and any subsequent patent of it will be wholly
ineffective as it cannot be enforced due to prior public disclosure.
Bob's current system uses three adjustable oscillations. Each oscillator has its own
adjustable 'gate' which rhythmically passes the signal along, or briefly blocks it. The
three signals are then added together to produce a rich waveform which is then
boosted and passed to his electrolysis cell:
Because both the oscillator frequency and the gating frequency are variable for each
of the three oscillators, the resulting output waveform can have many different shapes,
most of which will have a rolling cyclic repeating pattern.
The summation and driver section could have many different implementations. Bob
has chosen to opt for the same method as Stan Meyer used, where the signal power
level is boosted by an FET transistor stage and then a torroidal transformer is used to
integrate the signals. It should be remarked here, that if a transformer is used, then
with frequencies as high as these, the transformer core cannot be made from iron
laminations in the same way that mains transformers are constructed. That style of
construction is good for the low mains frequency of 50Hz or 60Hz, but the core (the
transformer 'yoke') cannot handle high frequencies. Stan Meyer used a torroidal ferrite
ring for his transformer. Bob aims at having the complex signal from his generator
added to the DC current through his cell with the signal set at about 25% of the DC
voltage.
Bob does not specify exactly how the electrical drive is connected to the cell, but as
far as I can see, if the signal is to be added to a standing DC component, there are
three ways that it could be done: see original pdf file for diagrams ...
Of these, option 1 is not attractive in that it requires a blocking capacitor to avoid the
secondary of the transformer from placing an unnecessary heavy load on the battery.
Options 2 and 3 are very similar with not much to choose between them.
In either of these cases, the secondary windings needs to be heavy-duty wire to carry
the cell current, which in Bob's case will be anything from ten to thirty amps. Also, to
avoid building up too much resistance in the secondary, the number of turns will not
be fery great. The number of turns in the windings of the three primaries will then be
adjusted to give the suggested 25% ripple on the DC standing component. If that
should produce winding with ineffectively few turns, then the number of turns should
be increased to a reasonable level and the magnitude of the signal powering those
windings reduced electronically to the required level.
A possible alternative would be to have just one primary winding, and sum the three
input signals electronically before driving the primary. This can be done quite easily
by applying the three signal inputs via three resistors, to the gate of the driving FET
transistor, and placing the primary winding as the load of that FET. For the moment,
we will stick with the solution used by Stan and Bob, and assume that three primary
windings will be used.
Bob Boyce states that the transformer is a very importnat part of the total
system. Think of it as one of the most important parts of the power supply which
feeds the cells. It is an inductor, a transformer, and a source of energy from
conversion, all rolled into one. The transformer has been successfully duplicated and
used by others, driven with my triple-oscillator board, to achieve a resonant drive to
the cells which results in a performance which is well beyond the maximum stated by
Faraday. The reason there is no step-by-step instructions for constructing the
transformer is because it must be wound to match the load/impedance of the cells it
will be driving. There is no 'one-transformer-fits-all' solution for this. I use a ferrite
core of 6.5" diameter for units up to 100 cells. The MicroMetals core, part number
'T650-52' is a suitable core and is available from
http://www.micrometals.com/pcparts/torcore7.html and can be purchased in small
quantities via their 'sample requests', wich can be submitted at
http"//www.micrometals.com/samples_index.html
The primary of the transformer is 3-phase, while the secondary is single-phase. Basic
transformer knowledge will go a long way in calculating the turns ratio and wire size
needed for a particular cell stack. Regular electronics and transformer guys may
scratch their heads wondering how it can be possible work ... Ignore the 'it can't
possibly work like that' reaction and just do it, the results are well worth it.
The transformer design depends on the cell curent and cell voltage. The cell durrent is
determined by the concentration of the electrolyte and to a lesser extent, the plate
area, while the cell voltage is determined by the number of plates in the cell. Bob
cleans and conditions each electrolyser for several days using heavy DC current and
then measures the cell current and voltage for optimum performance. He then uses
these figures to calculate the wire diameters and number of turns for the transformer.
He uses military-grade teflon covered silver-coated copper wire for the windings. The
covering of any wire has a major effect on its capacity to carry current as nearly all of
the current flows between the insulation and the outer surface of the wire. The
primaries are usually wound from 20 AWG (21SWG) wire and the secondary from 16
AWG (18 SWG).
Bob Boyce has very kindly, freely shared his board design for anybody to build and
use. His design is described here with his kind permission. This unit is built on a
double-sided printed circuit board, where the connectins to some components are
made on the top of the board while other components are soldered to the tracks on the
underside of the board.
See all necessary diagrams and component lists in the pdf file.
The timing circuit is powered via an 8 volt voltage stabiliser chip which smoothes out
any variations in the battery's supply voltage. Each generated signal is boosted in
power by an FET transistor whose load goes directly to the battery/alternator power
line. The output from each ascillator can be switched in or out of the final waveform:
see diagram.
Bob's system is so very like that used by Stanley Meyer that it might be expected that
the unit should run on pure water. However, that is not so. If pure water were used
then the system would need high voltage to achieve this rapid breakdown effect. With
an electrolyte solution, the water-splitting takes place at much lower voltage. It should
be remembered that Stan Meyer used 5 volts at 2 amps for his demonstration to
Admiral Sir Griffin at the British Admiralty, anf the result was described as 'large
volume of gas'. Please remember that Potassium Hydroxide attacks 'Lexan' plastic
(Polycarbonate) but is ok with PVC and acrylic. Sodium Hydroxide (NaOH 'lye') can
be used with Lexan.
The reason why there are no step-by-step instructions for constructing the transformer
is because it must be wound to match the load/impedance of the cells it will be
driving. There is no 'one-transformer-fits-all' solution for this. Bob uses a powdered
iron core of 6.5" diameter for units up to 100 cells. The larger the diameter, the greater
the power. Ferrite is fine for lower frequencies, but for this application, a powdered
iron toroid core is essential. The MicroMetals core, part number 'T650-52' is a
suitable core.
The primary of the transformer is 3-phase, while the secondary is single-phase. As
most current flows along the outside of wires rather then through the middle of the
wire, the choice and size of the wire chosen to wind the transformer is most
important. Bob uses solid teflon-covered silver-plated copper wire. It is very
important that this wire is solid core and not stranded as stranded wire does not work
here (due to the generation of inter-strand, phase-differential induced eddy currents).
Before any winding is done, the toroid is given a layer of tape. And the materials to be
used are collected together, namely the tape, the wire, the beeswax and the heat gun:
Of paramount importance with the toroid is that unilike traditional transformer design,
the secondary is wound first, and the windings must be evenly spaced where they fan
out from the center of the core. This means even though they are tightly packed right
up against one another at the center hole, they must not be wound so that they bunch
up and gap open around the periphery. Mistakes here will cause field errors that will
lower the overall efficiency.
As you can see here, Bob uses short lengths of plastic strimmer cable as spacers for
the outside of the toroid, though the picture above has been taken to show that a
partially prepared secondary winding looks like when its windings are being moved
into very accurate positions.
You will notice that Bob has wrapped the toroid in tape before starting the secondary
winding: ... see picture in original Patrick's file
Bob also uses a jar to assist in applying beeswax to the accurately positioned turns of
the toroidal transformer:
When the windings are completed, correctly spaced and encased in beeswax, each
layer is finished off with a layer of tape.
So, to recap, the toroid is wrapped in tape, the secondary wound extending the entire
way around the toroid, the windings carefully spaced out so that the gaps around the
outer edge of the toroid are exactly equal, the winding encased in beeswax, and then
the beeswax covered with a layer of tape:
For the majority of systems, the secondary winding is a tightly wound, single layer,
full-fill wrap of 16 gauge, single-core, silver-plated, teflon-insulated copper wire.
There will be about 130 turns in this winding, needing a wire length of about 100 feet
(33 meters). Count the exact number of turns in your actual winding and make a note
of it. This secondary winding is held in place with melted beeswax, and when that has
hardened, the winding is then wrapped tightly with a good quality glass tape. This
makes a good base for the primary windings which will be wound on top of the tape
layer.
Please note that every winding starts by passing over the toroid, proceeds in a
counter-clockewise direction, and finishes by passing under the toroid. Every
winding is created in this way and the quality of workmanship is very important
indeed when making these windings. Each winding needs to be tight and positioned
exactly with turns touching each other in the center of the toroid and positioned on the
outer edge with exactly equal spaces between each tuen. Your construction work has
to be better than that of a commercial supplier and needs to reach the quality
demanded by the military, which would cost thousands of dollars for each toroid if it
were to be made up for you by professionals.
The three primaries need to be wound on to[ of the tape wrapping which covers the
secondary winding. These three windings are spaced out equally around the toroid,
that is, at 120 degree centres. The primary windings are held in place with beeswax,
and then tightly taped. The primaries may need more than a single layer, and they are
wound with the same direction of winds as the secondary, and the same care for even
winding spacing as the secondary needed. Tape the entire core well with tightly-
stretched PVC electrical tape after winding, to ensure that the primary windings do
not move and then add an outer layer of winding tape. ...
This is were the gentic information ends. The exact details of the primary windings
must be determined from the operational characteristics of the cells. This means that
you must build, cleanse and condition your cells prior to making the operational
measurements. From those measurements, calculations can be made to determine
what gauge and how many turns of solid-core, silver-plated, teflon insulated, copper
wire are to be used for each of the three primary windings.
The objective here is to have the complex waveform generated by the electronics
produce voltages of about 25% of the main power supply voltage at the electrolyzer.
In other words, if an inverter is being used and its output rectified to produce about
160 V of pulsing DC, then the toroid tranformer secondary should generate about 40
Volts.
The output from the electronics board is about 13.8 Volts when driven by a vehicle's
electrical sysstem, so to step that up to about 40V requires a step up of 2.9, which
means that the secondary winding needs to have 2.9 times as many turns in it as the
primary winding does. So divide the number of turns in youor secondary winding by
2.9 to calculate the number of turns in each of the three primary windings. If you had
130 turns in the secondary, then there would be 45 turns in each of the three primeray
windings.
Normally, the diameter of the wire used in the primaries will be greater than that of
the secondary because it will be driven by a much lower voltage and so will need a
much higher current, but that is not the case here. Now that you have cleansed and
conditioned the plates in your electrolyser, power up your inverter with your vehicle
engine running at 2000RPM or so and measure the Dc current taken by the inverter.
This is the level of current which the primary windings have to carry, so the wire size
can be selected from this measurement. Each primary winding is pulsed, so it is not
carrying current all of the time, also, the final primary current is the sum of the three
pulsing signals, so a reduction can be allowed for that. While the wire diameter for the
primary windings of each toroidal transformer need to be calculated separately, a
common diameter turns out to be AWG #20 (21 SWG). The wire length for the
primaries will be greater per turn as the turns are now being made over the secondary
winding. Forty-eight turns of #20 wire are likely to require at least thirty-five feet (12
meters) and that for each of the three windings, assuming that all turns can be laid flat
side-by-side. If it is necessary to make each a two-layer winding, then the wire length
will increase further.
# Connecting the Electrics: Bob has specified that the primary windings are
connected between the board outputs and the positive supply for the board like htis:
Please note that the diagram above does not show the low-pass filters needed in the
power supply lines to control electromagnetic interferences. The vehicle electrics of
battery and alternator, produce about 13.8Volts when the vehicle engine is running. If
all is well and the contact-breaker (or fuse) is not tripped, the electrical power passes
through to the gas-pressure switch mounted on the electrolyser. If the gas production
rate is greater than the engine requirement and as a result, the gas pressure inside the
electrolyser gets above 5psi, then the gas pressure switch disconnects the electrical
supply which in turn, cuts off the generation of more gas until the pressure inside the
electrolyser drops again as the engine uses the gas. ... The inverter output is 110Volts
AC so it is passed through a diode bridge which converts it to pulsing DC with a peak
value of about 155Volts. This voltage and the output of the electronics board toroidal
transformer are passed to the electrolyser to electrolyse the water and generate
hydroxy gas.
(from 'D3.pdf', updated October 31,2007) The output waveform from Bob Boyce's
triple-pscillator board is sharpened up by the use of carefully chosen opto-isolators,
and that output would almost certainly drive Dave Lawton's Meyer replication Water
Fuel Cell. It would also be interesting to see if it has the same effect on battery
recharging as the John Bedini pulse-charging circuits, as it is distinctly possible that it
has. You will notice that Bob defeats the Faraday maximum output by careful
construction of the electrolyser, plus one apparently simple electronics board and one
apparently simple transformer. Again, these components call for very careful, high-
quality construction as is common for most successful free-energy devices.
Serious warning needs to be given here. The combination of sharp pulsing and
accurately wound toroid core composed of an iron powder matrix, draws in so much
extra power from the environment that it is essential that it is only used with the
electrolyser cell which is capable of soaking up excess energy surges. The extra
energy drawn in is not always constant and surges can occur which can generate
currents of 10,000 Amps. It should be understood that this electrical current which we
can measure is only the 'losses' part of the real power surge which is in a form which
we can't measure as we have no instruments which can measure it directly.
Consequently, the actual environmental power surge is far, far in excess of this 10,000
Amps. It is very important then, that the electronics board and toroidal transformer
are NOT connected to other equipment 'to see what will happen'. Even more
important is not to arrange a pulsed, rotating magnetic field in the toroid by sequential
pulsing of coils spaced around the toroid. These arrangements can generate power
surges so great that the excess power not soaked up by the circuit (especially after it's
instantaneous burn-out) is liable to form the ground-leader of a lightning strike.
Bob experimented with this and was hit by a direct lightning strike. He was very
lucky to survive being hit and he now works in a worshop which has metal walls
ans roof, and lightning grounding at each corner of the building, plus a separate
ground for the equipment inside the building. A device like this is not a toy, and it
demonstrates the incredible level of free-energy which can be tapped by quite
simple devices if you know what you are doing.
