Description
High-strength replacement Drum support spider (04264766) compatible with Miele WMV 960 WPS-GB, W 1926, W 2839 i WPM, W 2652 WPS, W3033, Novotronic W5540, W 3253 type HW09-2, Miele Touchtronic W 1213, W 1215, W1613, W 2123, W2662, W 2104 5kg, Softtronic W 3241, 3841, Miele Meteor 3065 WPS, W4144 washing machine. Made in the custom factory from solid stainless steel for the durable work purpose
Parameters:
Outer bearing diameter | 29 mm |
Inner bearing diameter | 30 mm |
Oil seal seating ring diameter | 35 mm |
Pulley mounting type | bolt М8 |
Shaft length | 126 mm |
Distance between the center of the shaft and the attachment to the drum | 205 mm |
Shaft diameter | 30 mm (6206) |
Outer bearing fit diameter | 25 mm (6205) |
Material | stainless steel |
Pulley seat | slot 23 mm 34 teeth |
Distance from sleeve to outer bearing | 74 mm |
Distance from the seat of the outer bearing to the end of the shaft | 34 mm |
Sleeve height | 18 mm |
