806lm from www.amazon.com
In stock Rating (9,564)
The LED light bulb turns on automatically once movement is detected within 12 - 18ft. It shuts off 30 seconds later after no activity in the detecting scope. No ...
People also ask
Functional lighting should have a lumen between 806 - 1520. General lighting should have between 400 - 470 lumens.
Convert Watts to Lumens Easily!
Light intensity (lumen)
LED lamp (Watt)
Classic lightbulb (Watt)
470 lm
5
40
806 lm
8
60
1055 lm
12
75
1521 lm
15
100
Moderate light: Around 400-800 lumens, good for regular tasks and dining areas. Bright light: 1000-1600 lumens, ideal for workspaces and kitchens. Very bright light: 1600 lumens and above, often used in large spaces or where very bright light is needed.
For instance, a 60 watt bulb is equivalent to 800 lumens of light, a 40 watt bulb is equivalent to 450 lumens and so forth. Additionally, you can use the color temperature chart to help you in choosing the best lighting for your application.
806lm from www.lighting.philips.com
Free delivery
Light Technical · Color Code. 827 [CCT of 2700K] · Beam Angle (Nom). 180 degree(s) · Luminous Flux. 806 lm · Color Designation. Warm White (WW) · Correlated ...
806lm from www.lampemesteren.com
In stock Free delivery over €99
Buy Bulb LED 8W (806lm) E27 - Arcchio here. The widest selection of designer lamps. Fast delivery. 50-day return policy!
806lm from pholc.com
In stock
Airam LED E27 G95 806lm DIM. Regular price 124 SEK. Regular price Sale price 124 SEK. Add to cart. Get quotation. Colour samples.
806lm from www.finnishdesignshop.com
Free delivery Free 30-day returns
The warm white color (2700 K) of this LED lamp is ideal for creating soft, pleasant lighting. Product details (12). Colour: Opal white; Width ...
806lm from www.ebay.com
In stock Rating 315
Brightness Equivalent to :60W Traditional Bulbs. - Color Temperature 6500K (Cool White). 3000K (Warm White). It may take up to 8 weeks due to strict custom ...
806lm from www.lvwit.com
Out of stock Rating (152)
E26 LED Light Bulbs, 806Lm A19 · Replaces standard incandescent 60-watt light bulb - Pack of 6 · Non-Dimmable: it's not suitable for use with a dimmer switch.
806lm from www.walmart.com
Out of stock Rating (2)
Bright LED filament bulb (60W eq.). Only uses 6W of energy. · DIMMABLE & UL LISTED. Color: Warm White 2700K, Brightness: 806 lumens · $105 lifetime energy savings ...
806lm from www.any-lamp.com
Rating (60) · 14-day returns
The Philips MASTER Value LED Bulb E27 Pear Frosted 5.9W 806lm - 927 Extra Warm White | Best Colour Rendering - Dimmable - Replaces 60W is the perfect ...
