Sign in to confirm you’re not a bot
This helps protect our community. Learn more
Stirling engine - Sunpulse 500
808Likes
94,379Views
2015Apr 15
The SUNPULSE 500 engine converts low temperature heat effectively into mechanical energy. Therefore it can be operated day and night out of a hot water storage - a new dimension in solar technology and a Major step forward autonomy. Since the operation of the SUNPULSE is heat driven the dimension of the solar hot water storage can be reduced by adding complementary heat sources such as biogas, biomass and others to the system. Integrated into a house, the SUNPULSE works as a co-generation system delivering electricity + heat. The Sunpulse has 0,5 kW(el) power, ideal for water pumping.
Sun Orbit
660 subscribers
