Skip directly to site content Skip directly to page options Skip directly to A-Z link Skip directly to A-Z link Skip directly to A-Z link
Volume 25, Number 1—January 2019
Perspective
Complexity of the Basic Reproduction Number (R0)
Paul L. DelamaterComments to Author , Erica J. Street, Timothy F. Leslie, Y. Tony Yang, and Kathryn H. Jacobsen
Author affiliations: University of North Carolina at Chapel Hill, Chapel Hill, North Carolina, USA (P.L. Delamater); George Mason University, Fairfax, Virginia, USA (E.J. Street, T.F. Leslie, K.H. Jacobsen); George Washington University, Washington, DC, USA (Y.T. Yang)
Cite This Article
Abstract
The basic reproduction number (R0), also called the basic reproduction ratio or rate or the basic reproductive rate, is an epidemiologic metric used to describe the contagiousness or transmissibility of infectious agents. R0 is affected by numerous biological, sociobehavioral, and environmental factors that govern pathogen transmission and, therefore, is usually estimated with various types of complex mathematical models, which make R0 easily misrepresented, misinterpreted, and misapplied. R0 is not a biological constant for a pathogen, a rate over time, or a measure of disease severity, and R0 cannot be modified through vaccination campaigns. R0 is rarely measured directly, and modeled R0 values are dependent on model structures and assumptions. Some R0 values reported in the scientific literature are likely obsolete. R0 must be estimated, reported, and applied with great caution because this basic metric is far from simple.
The basic reproduction number (R0), pronounced “R naught,” is intended to be an indicator of the contagiousness or transmissibility of infectious and parasitic agents. R0 is often encountered in the epidemiology and public health literature and can also be found in the popular press (1External Link6External Link). R0 has been described as being one of the fundamental and most often used metrics for the study of infectious disease dynamics (7External Link12External Link). An R0 for an infectious disease event is generally reported as a single numeric value or low–high range, and the interpretation is typically presented as straightforward; an outbreak is expected to continue if R0 has a value >1 and to end if R0 is <1 (13External Link). The potential size of an outbreak or epidemic often is based on the magnitude of the R0 value for that event (10External Link), and R0 can be used to estimate the proportion of the population that must be vaccinated to eliminate an infection from that population (14External Link,15External Link). R0 values have been published for measles, polio, influenza, Ebola virus disease, HIV disease, a diversity of vectorborne infectious diseases, and many other communicable diseases (14External Link,16External Link18External Link).
The concept of R0 was first introduced in the field of demography (9External Link), where this metric was used to count offspring. When R0 was adopted for use by epidemiologists, the objects being counted were infective cases (19External Link). Numerous definitions for R0 have been proposed. Although the basic conceptual framework is similar for each, the operational definitions are not always identical. Dietz states that R0 is “the number of secondary cases one case would produce in a completely susceptible population” (19External Link). Fine supplements this definition with the description “average number of secondary cases” (17External Link). Diekmann and colleagues use the description “expected number of secondary cases” and provide additional specificity to the terminology regarding a single case (13External Link).
In the hands of experts, R0 can be a valuable concept. However, the process of defining, calculating, interpreting, and applying R0 is far from straightforward. The simplicity of an R0 value and its corresponding interpretation in relation to infectious disease dynamics masks the complicated nature of this metric. Although R0 is a biological reality, this value is usually estimated with complex mathematical models developed using various sets of assumptions. The interpretation of R0 estimates derived from different models requires an understanding of the models’ structures, inputs, and interactions. Because many researchers using R0 have not been trained in sophisticated mathematical techniques, R0 is easily subject to misrepresentation, misinterpretation, and misapplication. Notable examples include incorrectly defining R0 (1External Link) and misinterpreting the effects of vaccination on R0 (3External Link). Further, many past lessons regarding this metric appear to have been lost or overlooked over time. Therefore, a review of the concept of R0 is needed, given the increased attention this metric receives in the academic literature (20External Link). In this article, we address misconceptions about R0 that have proliferated as this metric has become more frequently used outside of the realm of mathematical biology and theoretic epidemiology, and we recommend that R0 be applied and discussed with caution.
Variations in R0
For any given infectious agent, the scientific literature might present numerous different R0 values. Estimations of the R0 value are often calculated as a function of 3 primary parameters—the duration of contagiousness after a person becomes infected, the likelihood of infection per contact between a susceptible person and an infectious person or vector, and the contact rate—along with additional parameters that can be added to describe more complex cycles of transmission (19External Link). Further, the epidemiologic triad (agent, host, and environmental factors) sometimes provides inspiration for adding parameters related to the availability of public health resources, the policy environment, various aspects of the built environment, and other factors that influence transmission dynamics and, thus, are relevant for the estimation of R0 values (21External Link). Yet, even if the infectiousness of a pathogen (that is, the likelihood of infection occurring after an effective contact event has occurred) and the duration of contagiousness are biological constants, R0 will fluctuate if the rate of human–human or human–vector interactions varies over time or space. Limited evidence supports the applicability of R0 outside the region where the value was calculated (20External Link). Any factor having the potential to influence the contact rate, including population density (e.g., rural vs. urban), social organization (e.g., integrated vs. segregated), and seasonality (e.g., wet vs. rainy season for vectorborne infections), will ultimately affect R0. Because R0 is a function of the effective contact rate, the value of R0 is a function of human social behavior and organization, as well as the innate biological characteristics of particular pathogens. More than 20 different R0 values (range 5.4–18) were reported for measles in a variety of study areas and periods (22External Link), and a review in 2017 identified feasible measles R0 values of 3.7–203.3 (23External Link). This wide range highlights the potential variability in the value of R0 for an infectious disease event on the basis of local sociobehavioral and environmental circumstances.
Top
Various Names for R0
Inconsistency in the name and definition of R0 has potentially been a cause for misunderstanding the meaning of R0. R0 was originally called the basic case reproduction rate when George MacDonald introduced the concept into the epidemiology literature in the 1950s (17External Link,19External Link,24External Link,25External Link). Although MacDonald used Z0 to represent the metric, the current symbolic representation (R0) appears to have remained largely consistent since that time. However, multiple variations of the name for the concept expressed by R0 have been used in the scientific literature, including the use of basic and case as the first word in the term, reproduction and reproductive for the second word, and number, ratio, and rate for the final part of the term (13External Link). Although the frequent use of the term basic reproduction rate is in line with MacDonald’s original terminology (9External Link), some users interpret the use of the word rate as suggesting a quantity having a unit with a per-time dimension (7External Link). If R0 were a rate involving time, the metric would provide information about how quickly an epidemic will spread through a population. But R0 does not indicate whether new cases will occur within 24 hours after the initial case or months later, just as R0 does not indicate whether the disease produced by the infection is severe. Instead, R0 is most accurately described in terms of cases per case (7External Link,13External Link). Calling R0 a rate rather than a number or ratio might create some undue confusion about what the value represents.
Top
R0 and Vaccination Campaigns
Vaccination campaigns reduce the proportion of a population at risk for infection and have proven to be highly effective in mitigating future outbreaks (26External Link). This conclusion is sometimes used to suggest that an aim of vaccination campaigns is to remove susceptible members of the population to reduce the R0 for the event to <1. Although the removal of susceptible members from the population will affect infection transmission by reducing the number of effective contacts between infectious and susceptible persons, this activity will technically not reduce the R0 value because the definition of R0 includes the assumption of a completely susceptible population. When examining the effect of vaccination, the more appropriate metric to use is the effective reproduction number (R), which is similar to R0 but does not assume complete susceptibility of the population and, therefore, can be estimated with populations having immune members (16External Link,20External Link,27External Link). Efforts aimed at reducing the number of susceptible persons within a population through vaccination would result in a reduction of the R value, rather than R0 value. In this scenario, vaccination could potentially end an epidemic, if R can be reduced to a value <1 (16External Link,27External Link,28External Link). The effective reproduction number can also be specified at a particular time t, presented as R(t) or Rt, which can be used to trace changes in R as the number of susceptible members in a population is reduced (29External Link,30External Link). When the goal is to measure the effectiveness of vaccination campaigns or other public health interventions, R0 is not necessarily the best metric (10External Link,20External Link).
Top
Measuring and Estimating R0
Counting the number of cases of infection during an epidemic can be extremely difficult, even when public health officials use active surveillance and contact tracing to attempt to locate all infected persons. Although measuring the true R0 value is possible during an outbreak of a newly emerging infectious pathogen that is spreading through a wholly susceptible population, rarely are there sufficient data collection systems in place to capture the early stages of an outbreak when R0 might be measured most accurately. As a result, R0 is nearly always estimated retrospectively from seroepidemiologic data or by using theoretical mathematical models (31External Link). Data-driven approaches include the use of the number of susceptible persons at endemic equilibrium, average age at infection, final size equation, and intrinsic growth rate (10External Link). When mathematical models are used, R0 values are often estimated by using ordinary differential equations (8External Link10External Link,19External Link,31External Link), but high-quality data are rarely available for all components of the model. The estimated values of R0 generated by mathematical models are dependent on numerous decisions made by the modeler (8External Link,32External Link,33External Link). The population structure of the model, such as the susceptible-infectious-recovered model or susceptible-exposed-infectious-recovered model, which includes compartments for persons who are exposed but not yet infectious, as well as assumptions about demographic dynamics (e.g., births, deaths, and migration over time), are critical model parameters. Population mixing and contact patterns must also be considered; for example, for homogeneous mixing, all population members are equally likely to come into contact with one another, and for heterogeneous mixing, variation in contact patterns are present among age subgroups or geographic regions. Other decisions include whether to use a deterministic (yielding the same outcomes each time the model is run) or stochastic (generating a distribution of likely outcomes on the basis of variations in the inputs) approach and which distributions (e.g., Gaussian or uniform distributions) to use to describe the probable values of parameters, such as effective contact rates and duration of contagiousness. Furthermore, many of the parameters included in the models used to estimate R0 are merely educated guesses; the true values are often unknown or difficult or impossible to measure directly (31External Link,34External Link,35External Link). This limitation is compounded as models become more complex and, thus, require more input parameters (20External Link,35External Link), such as when using models to estimate the value of R0 for infectious pathogens with more complex transmission pathways, which can include vectorborne infectious agents or those with environmental or wildlife reservoirs. In summary, although only 1 true R0 value exists for an infectious disease event occurring in a particular place at a particular time, models that have minor differences in structure and assumptions might produce different estimates of that value, even when using the same epidemiologic data as inputs (20External Link,31External Link,32External Link,36External Link,37External Link).
Top
Obsolete R0 Values
New estimates of R0 have been produced for infectious disease events that occurred in recent history, such as the West Africa Ebola outbreak (34External Link,38External Link,39External Link). However, for many vaccine-preventable diseases, the scientific literature reports R0 values calculated much further back in history. For example, the oft-reported measles R0 values of 12–18 are based on data acquired during 1912–1928 in the United States (R0 of 12.5) and 1944–1979 in England and Wales (R0 of 13.7–18.0) (14External Link), even though more recent estimates of the R0 for measles highlight a much greater numeric range and variation across settings (23External Link). For pertussis (R0 of 12–17), the original data sources are 1908–1917 in the United States (R0 of 12.2) and 1944–1979 in England and Wales (R0 of 14.3–17.1) (14External Link). The major changes that have occurred in how humans organize themselves both socially and geographically make these historic values extremely unlikely to match present day epidemiologic realities. Behavioral changes undoubtedly have altered contact rates, which are a key component of R0 calculations. Yet, these R0 values have been repeated so often in the literature that newer R0 values generated by using modern data might be dismissed if they fall outside the range of previous estimates. Given that R0 is often considered when designing and implementing vaccination strategies and other public health interventions, the use of R0 values derived from older data is likely inappropriate (23External Link). Decisions about public health practice should be made with contemporaneous R0 values or R values instead.
Top
Conclusions
Although R0 might appear to be a simple measure that can be used to determine infectious disease transmission dynamics and the threats that new outbreaks pose to the public health, the definition, calculation, and interpretation of R0 are anything but simple. R0 remains a valuable epidemiologic concept, but the expanded use of R0 in both the scientific literature and the popular press appears to have enabled some misunderstandings to propagate. R0 is an estimate of contagiousness that is a function of human behavior and biological characteristics of pathogens. R0 is not a measure of the severity of an infectious disease or the rapidity of a pathogen’s spread through a population. R0 values are nearly always estimated from mathematical models, and the estimated values are dependent on numerous decisions made in the modeling process. The contagiousness of different historic, emerging, and reemerging infectious agents cannot be fairly compared without recalculating R0 with the same modeling assumptions. Some of the R0 values commonly reported in the literature for past epidemics might not be valid for outbreaks of the same infectious disease today.
R0 can be misrepresented, misinterpreted, and misapplied in a variety of ways that distort the metric’s true meaning and value. Because of these various sources of confusion, R0 must be applied and discussed with caution in research and practice. This epidemiologic construct will only remain valuable and relevant when used and interpreted correctly.
Top
Dr. Delamater is an assistant professor in the Department of Geography and a faculty fellow at the Carolina Population Center at the University of North Carolina at Chapel Hill, Chapel Hill, North Carolina, USA. His research focuses on the geographic aspects of health, disease, and healthcare.
TopExternal Link
Acknowledgment
This research was supported through a grant from the George Mason University Provost Multidisciplinary Research Initiative.
Top
References
  1. Johnson  R. The 10 epidemics that almost wiped out mankind. Business Insider. 2011 Sep 19 [cited 2017 Nov 17]. http://www.businessinsider.com/epidemics-pandemics-that-almost-wiped-out-mankind-2011-9External Link
  2. Coy  P. A primer on the deadly math of Ebola. Bloomberg Businessweek. 2014 Sep 26 [cited 2017 Nov 17]. http://www.bloomberg.com/news/articles/2014-09-26/ebolas-deadly-mathExternal Link
  3. Doucleff  M. No, seriously, how contagious is Ebola? NPR. 2014 Oct 2 [cited 2017 Nov 17]. http://www.npr.org/sections/health-shots/2014/10/02/352983774/no-seriously-how-contagious-is-ebolaExternal Link
  4. Freeman  C. Magic formula that will determine whether Ebola is beaten. Telegraph. 2014 Nov 6 [cited 2017 Nov 17]. http://www.telegraph.co.uk/news/worldnews/ebola/11213280/Magic-formula-that-will-determine-whether-Ebola-is-beaten.htmlExternal Link
  5. McKenna  M. The mathematics of Ebola trigger stark warnings: act now or regret it. WIRED. 2014 Sep 14 [cited 2017 Nov 17]. https://www.wired.com/2014/09/r0-ebola/External Link
  6. Fox  M. Ebola epidemic was driven by just a few infected people, study finds. NBC News. 2017 Feb 13 [cited 2017 Nov 17]. https://www.nbcnews.com/storyline/ebola-virus-outbreak/superspreaders-drove-ebola-epidemic-study-finds-n720321External Link
  7. Heesterbeek  JAP, Dietz  K. The concept of R0 in epidemic theory. Stat Neerl. 1996;50:89110. DOIExternal LinkGoogle ScholarExternal Link
  8. Keeling  MJ, Grenfell  BT. Individual-based perspectives on R(0). J Theor Biol. 2000;203:5161. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  9. Heesterbeek  JAP. A brief history of R0 and a recipe for its calculation. Acta Biotheor. 2002;50:189204. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  10. Heffernan  JM, Smith  RJ, Wahl  LM. Perspectives on the basic reproductive ratio. J R Soc Interface. 2005;2:28193. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  11. Roberts  MG. The pluses and minuses of R0. J R Soc Interface. 2007;4:94961. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  12. Pellis  L, Ball  F, Trapman  P. Reproduction numbers for epidemic models with households and other social structures. I. Definition and calculation of R0. Math Biosci. 2012;235:8597. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  13. Diekmann  O, Heesterbeek  JAP, Metz  JAJ. On the definition and the computation of the basic reproduction ratio R0 in models for infectious diseases in heterogeneous populations. J Math Biol. 1990;28:36582. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  14. Anderson  RM, May  RM. Directly transmitted infections diseases: control by vaccination. Science. 1982;215:105360. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  15. Anderson  RM, May  RM. Vaccination and herd immunity to infectious diseases. Nature. 1985;318:3239. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  16. Anderson  RM, May  RM. Infectious diseases of humans: dynamics and control. Oxford: Oxford University Press; 1991.
  17. Fine  PEM. Herd immunity: history, theory, practice. Epidemiol Rev. 1993;15:265302. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  18. Chowell  G, Nishiura  H. Transmission dynamics and control of Ebola virus disease (EVD): a review. BMC Med. 2014;12:196. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  19. Dietz  K. The estimation of the basic reproduction number for infectious diseases. Stat Methods Med Res. 1993;2:2341. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  20. Ridenhour  B, Kowalik  JM, Shay  DK. Unraveling R0: considerations for public health applications. Am J Public Health. 2014;104:e3241. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  21. Lloyd-Smith  JO, Schreiber  SJ, Kopp  PE, Getz  WM. Superspreading and the effect of individual variation on disease emergence. Nature. 2005;438:3559. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  22. Anderson  RM. Directly transmitted viral and bacterial infections of man. In: Anderson RM, editor. The population dynamics of infectious diseases: theory and applications. London: Chapman and Hall; 1982. p. 1–37.
  23. Guerra  FM, Bolotin  S, Lim  G, Heffernan  J, Deeks  SL, Li  Y, et al. The basic reproduction number (R0) of measles: a systematic review. Lancet Infect Dis. 2017;17:e4208. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  24. MacDonald  G. The analysis of equilibrium in malaria. Trop Dis Bull. 1952;49:81329.PubMedExternal LinkGoogle ScholarExternal Link
  25. MacDonald  G. The epidemiology and control of malaria. London: Oxford University Press; 1957.
  26. Bärnighausen  T, Bloom  DE, Cafiero-Fonseca  ET, O’Brien  JC. Valuing vaccination. Proc Natl Acad Sci U S A. 2014;111:123139. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  27. Anderson  RM. The concept of herd immunity and the design of community-based immunization programmes. Vaccine. 1992;10:92835. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  28. Plans Rubió  P. Is the basic reproductive number (R(0)) for measles viruses observed in recent outbreaks lower than in the pre-vaccination era? Euro Surveill. 2012;17:22, author reply 23. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  29. Nishiura  H, Chowell  G. The effective reproduction number as a prelude to statistical estimation of time-dependent epidemic trends. In: Chowell G, Hyman JM, Bettencourt LMA, Castillo-Chavez C, editors. Mathematical and statistical estimation approaches in epidemiology. Dordrecht (the Netherlands): Springer Netherlands; 2009. p. 103–21.
  30. Mercer  GN, Glass  K, Becker  NG. Effective reproduction numbers are commonly overestimated early in a disease outbreak. Stat Med. 2011;30:98494.PubMedExternal LinkGoogle ScholarExternal Link
  31. Li  J, Blakeley  D, Smith  RJ. The failure of R0. Comput Math Methods Med. 2011;2011:527610. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  32. Breban  R, Vardavas  R, Blower  S. Theory versus data: how to calculate R0? PLoS One. 2007;2:e282. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  33. Artalejo  JR, Lopez-Herrero  MJ. On the exact measure of disease spread in stochastic epidemic models. Bull Math Biol. 2013;75:103150. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  34. Khan  A, Naveed  M, Dur-E-Ahmad  M, Imran  M. Estimating the basic reproductive ratio for the Ebola outbreak in Liberia and Sierra Leone. Infect Dis Poverty. 2015;4:13. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  35. Roberts  M, Heesterbeek  H. Bluff your way in epidemic models. Trends Microbiol. 1993;1:3438. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  36. Bani-Yaghoub  M, Gautam  R, Shuai  Z, van den Driessche  P, Ivanek  R. Reproduction numbers for infections with free-living pathogens growing in the environment. J Biol Dyn. 2012;6:92340. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  37. Nishiura  H. Correcting the actual reproduction number: a simple method to estimate R(0) from early epidemic growth data. Int J Environ Res Public Health. 2010;7:291302. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  38. Legrand  J, Grais  RF, Boelle  PY, Valleron  AJ, Flahault  A. Understanding the dynamics of Ebola epidemics. Epidemiol Infect. 2007;135:61021. DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
  39. Fisman  D, Khoo  E, Tuite  A. Early epidemic dynamics of the west african 2014 ebola outbreak: estimates derived with a simple two-parameter model. PLoS Curr. 2014;6 DOIExternal LinkPubMedExternal LinkGoogle ScholarExternal Link
Top
Cite This Article
DOI: 10.3201/eid2501.171901
Original Publication Date: November 27, 2018
Table of Contents – Volume 25, Number 1—January 2019
EID Search Options
presentation_01 Advanced Article Search – Search articles by author and/or keyword.
presentation_01 Articles by Country Search – Search articles by the topic country.
presentation_01 Article Type Search – Search articles by article type and issue.
Top
Comments
Please use the form below to submit correspondence to the authors or contact them at the following address:
Paul L. Delamater, University of North Carolina at Chapel Hill, Campus Box 3220, Chapel Hill, NC 27599-3220, USA
Send To
10000 character(s) remaining.
Top
Page created: December 17, 2018
Page updated: December 17, 2018
Page reviewed: December 17, 2018
The conclusions, findings, and opinions expressed by authors contributing to this journal do not necessarily reflect the official position of the U.S. Department of Health and Human Services, the Public Health Service, the Centers for Disease Control and Prevention, or the authors' affiliated institutions. Use of trade names is for identification only and does not imply endorsement by any of the groups named above.
file_external
Can't support this form
To protect your security while using Google Translate, please do not submit information in this type of form.
Got itGo to original URL
