Volkswagen VW Up: la Lupo Hybride diesel et électrique?
x 11433
par Christophe » 09/02/11, 12:45
Décidément, VW voit vert en ce moment! Après l'annonce de la XL1, Volkswagen prévoit cette fois ci un VRAI véhicule commercial à moins de 3L/100, elle partage d'ailleurs des bases de la XL1: https://www.econologie.com/forums/xl1-et-l1- ... 10410.html
VW to launch 95mpg Up
Volkswagen is putting the final touches to a super-economical version of the Up city car, which will be good for at least 95mpg.
Expected to be called the Up blue-e-motion, the model will be powered by a production version of the powertrain from the XL1 concept, company sources say.
Based on today’s four-cylinder, 1.6-litre VW Group diesel engine, the Up’s twin-cylinder, 800cc turbodiesel is expected to develop just 47bhp, but will be ‘assisted’ by a 26bhp electric motor. The engine’s block is made from aluminium and the bores are plasma coated. It also gets a sophisticated balancer shaft set-up to smooth out the inherently unbalanced two-cylinder layout. The engine and electric motor will be coupled to a seven-speed dual-clutch gearbox.
Unlike the XL1, however, the Up blue-e-motion will not be able to travel solely on battery power. That’s because the car’s battery pack will only be large enough to power the electric motor during standing starts or for brief periods of hard acceleration. Energy will be reclaimed during braking to help recharge the battery.
The Up is also likely to be equipped with the XL1’s new ‘pulse starting’ feature, which will make the car’s stop-start mode much more seamless. In pulse starting, the electric motor spins the idle engine up to the required speed for its restart, making it virtually undetectable by the driver.
When the XL1 is being powered purely by this hybrid diesel engine, it returns 141mpg on the EU test cycle. However, the Up will be at least 300kg heavier than the carbonfibre-bodied XL1 and will have more aerodynamic drag, due to its bigger cabin and much greater frontal area, which means fuel economy will be reduced by about a third when compared with the concept.
Source: http://www.autocar.co.uk/News/NewsArtic ... rs/255262/
D'après Wiki une version 100% électrique serait prévue: http://en.wikipedia.org/wiki/Volkswagen_up
Il n'empeche on peut s'interroger sur le gain de l'hybridation sur si petit véhicile équipée d'un diesel déjà largement downsizée ! 0.5L/100km ? Rentabilité?
La Fiat 500 Twin Air, essence et non hybride, fait quasiment aussi bien...du moins sur le papier: https://www.econologie.com/forums/fiat-500-t ... t9976.html
La VW Up diesel hybride n'est à priori, et c'est bien dommage, pas brancheable et n'aura pas de mode 100% électrique (on retrouve le fonctionnement assistance électrique de la Honda Insight 1 d'il y a plus de 10 ans!), le surcoût de l'hybridation pour une voiture de ce gabarit peut représenter un risque commercial important...d'ailleurs c'est aussi l'avis de plusieurs autres constructeurs automobiles.
Il n'empeche on va pas trop râler car depuis le temps qu'on attendait un hybride diesel...reste l'inconnue du prix... :?:
Commentaires de P. Langlois (par mail):
La voiture hybride sera équipée d’un moteur diesel deux cylindres TDI de 800 cc, doté d’une puissance de 35 kW. Un moteur électrique de 20 kW permettra d’éteindre le moteur thermique lorsque la voiture est à l’arrêt, et de le relancer au démarrage. Le moteur électrique pourra également joindre sa puissance à celle du moteur thermique lors d’accélérations plus soutenues. Il est logé entre le moteur thermique et la transmission à 7 vitesse. Les analystes de Autocar s’attendent à ce que le groupe de traction hybride soit intégré à une Up!, très légère (1090 kg, voir http://en.wikipedia.org/wiki/Volkswagen_up! ).
En fait, le groupe de traction sera identique à celui de la voiture hybride branchable concept Formula XL1 présenté au Salon de l’auto du Qatar en janvier 2011, à l’exception de la batterie (plus grosse) et de son chargeur. Cette voiture deux places ultra efficiente a des lignes très aérodynamiques (Cx=0,186, pour les experts) et une masse de 795 kg seulement. Elle est équipée d’une batterie Li-ion capable de la faire rouler pendant 35 km en mode électrique pur. En tenant compte de la traction électrique, la voiture consomme 0,9 litres/100 km. Sa vitesse maximale est de 160 km/h, et l’accélération de 0 à 100 km/h se fait en 11,9 sec.
citro
x 11
par citro » 09/02/11, 13:16
Pourquoi autant. :?: :x
Ils ne pouvaient pas la limiter à 130 kmh comme une SMART. :?:
x 2020
par Macro » 09/02/11, 13:54
Ta déja roulé a 130 sur une autoroute allemande citro???Les berlinoises arrivent aton cul avec les pleins phares allumés et te poussent vers la file de droite(celle des camions a 70km/h environ) ensuite tu es quasiment obligé d'y rester car les berlinnoisent arrivent trop vite sur la file de gauche...Donc vers 150km/h tu as a peut prés la paix...
yannko
par yannko » 09/02/11, 14:45
Meme symptome en Republique Tcheque, c'est 110 km/h a droite ou 150 - 160 km/h a gauche, donc le mec qui respecte et reste a 130km/h se tire litteralement une balle a jongler en permanence...
Si on souhaite rester tres cool, a 100-110 km/h, on tombe inevitablement sur un vehicule qui reste a 70-80 km/h, on reste bloque 5 mn a attendre le defilement des tares a gauche qui se suivent en bonne file, et on en a tellement marre apres 10 fois qu'on se cale aussi a 150 :frown: .
x 11433
par Christophe » 10/02/11, 11:52
Macro a écrit :Les berlinoises arrivent a ton cul avec les pleins phares allumés et te poussent vers la file de droite
Ca c'est ce qui arrive quand Macro va au bordel à Berlin et se tire sans payer !! :mrgreen: :mrgreen: Désolé c'est la fôte à ton pseudo !! :D
La UP était évoquée dans le T21 de fin 2009: https://www.econologie.com/t21-up-lite-d ... -4196.html
...mais elle ressemblait bien plus à la XL1 qu'à la UP version 2011...
Voici les 3 liens du début de l'article:
http://www.youtube.com/watch?v=qx0yCrwsBj4
http://www.youtube.com/watch?v=XUulohIsig4
http://www.moteurnature.com/actu/2009/v ... oncept.php
kumkat
par kumkat » 10/02/11, 13:34
dommage que la Loremo ai vécu... projet abandonné...
http://www.loremo.com/englisch/02der04_technik.htm
x 11433
par Christophe » 10/02/11, 13:41
Mince ca faisait un moment qu'on l'attendait. C'est sur que c'est abandonné? T'as une dépeche?
On avait 2 vieux sujets sur la Loremo :
https://www.econologie.com/forums/loremo-la- ... t1624.html
https://www.econologie.com/forums/la-loremo- ... t2872.html
Il faudrait l'annoncer la bas... :|
kumkat
par kumkat » 10/02/11, 13:50
x 11433
par Christophe » 10/02/11, 14:15
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 174 invités
