http://fukushima.over-blog.fr/ext/http: ... 04_16.html
Steam, high radiation detected at No.1 reactor
The operator of the damaged Fukushima Daiichi nuclear plant says steam was observed coming out of the floor of the No.1 reactor building, and extremely high radiation was detected in the vicinity.
Tokyo Electric Power Company inspected the inside of the No.1 reactor building on Friday with a remote-controlled robot.
TEPCO said it found that steam was rising from a crevice in the floor, and that extremely high radiation of 3,000 to 4,000 millisieverts per hour was measured around the area. The radiation is believed to be the highest detected in the air at the plant.
TEPCO says the steam is likely coming from water at a temperature of 50 degrees Celsius that has accumulated in the basement of the reactor building.
The company sees no major impact from the radiation so far on ongoing work, as it has been detected only within a limited section of the building.
The No.1 reactor is believed to have suffered a meltdown after the March 11th earthquake and tsunami.
It is believed to have created holes in the pressure vessel and damaged the containment vessel, causing highly contaminated water to leak out and accumulate in the basement.
Under the utility's plan to bring the plant under control, a circulatory cooling system is to be installed to decontaminate radioactive water and use it as coolant.
Saturday, June 04, 2011 13:23 +0900 (JST)
J'ai mis les infos et contradictions scientifiques en gras !!
Ils se mentent à eux même avec la vapeur à 50°C, de fait eau tombant sur le coeur en fusion très chaud à bien plus de 1000°C et se vaporisant par caléfaction hyperchargée de la radioactivité de ce coeur se surchauffant !!
S'ils étaient efficaces, ils mettraient, avec des robots des détecteurs de radioactivité en continu et prélèvements qui analysés en composants de radioactivité informent en détail sur l'activité de ce corium et surtout sur son évolution, permettant de savoir si la température augmente et si le risque de future explosion dramatique augmente avec un corium se chauffant sans fin de plus en plus confiné dans le sous sol !!!.
Ils se mentent en affirmant qu'ils peuvent mettre un système circulatoire de refroidissement normal pour refroidir ce corium spontanément surchauffé qui descend en profondeur progressivement, en fondant ce qui se trouve à sa base et qui devient de plus en plus inaccessible et confiné !!
Il s'agit de ce qui était craint à Tchernobyl et qui avait fait creuser d'urgence sous le réacteur d'extrême urgence, dans des conditions extrêmes.
Tchernobyl avait été mieux géré par les Russes après la catastrophe.
Fukushima plus lent, mais avec 4 réacteurs en perditions, va être pire sur une très longue durée sans fin.
4 Sievert /heure c'est 66milliSievert /minute dose excessive que les liquidateurs Russes avaient subie en courant une minute sur le réacteur pour nettoyer !!
Le nucléaire en perdition est totalement inaccessible aux humains et c'est criminel qu'il n'y ait pas une flotte énorme de robots résistants à ces radiations prêts à intervenir à l'échelle mondiale sur tout nucléaire en perdition pour remplacer les hommes et sauver la situation dés les débuts de la catastrophe.
La France avec sa densité maximum de nucléaire par habitant n'a pas une telle flotte fonctionnelle de robots pompiers nucléaires efficaces puisqu'elle n'en envoie aucun au Japon.
Je considère cela criminel, car toute intervention rapide diminue les conséquences !!!
Nous sommes fous de croire à l'infaillibilité du nucléaire au point de n'avoir pas une armada de robots pompiers télécommandés résistants aux radiations permettant d'intervenir vite comme si les radiations extrêmes n'existaient pas !!
