Pile thermo-chimique-solaire dense comme pile électrique Li
dedeleco
x 11
par dedeleco » 28/07/11, 15:26
Progrès en marche pour future révolution :
batterie solaire de chaleur rechargeable de longue durée stockant la chaleur solaire directement.
la lumière solaire stockée directement en énergie thermo-chimique réversible sur de très longues durées et même densité en énergie comme pour une pile électrique au Lithium
New way to store sun's heat
http://www.physorg.com/news/2011-07-sun.html
Le renouvelable est capable de révolutions, de plus matériau de carbone nano tubes et azobenzène sans atomes rares chers ou poisons dangereux .
The new material found by Grossman and Kolpak is made using carbon nanotubes, tiny tubular structures of pure carbon, in combination with a compound called azobenzene. The resulting molecules, produced using nanoscale templates to shape and constrain their physical structure, gain “new properties that aren’t available” in the separate materials, says Grossman, the Carl Richard Soderberg Associate Professor of Power Engineering.
Not only is this new chemical system less expensive than the earlier ruthenium-containing compound, but it also is vastly more efficient at storing energy in a given amount of space — about 10,000 times higher in volumetric energy density, Kolpak says — making its energy density comparable to lithium-ion batteries. By using nanofabrication methods, “you can control [the molecules’] interactions, increasing the amount of energy they can store and the length of time for which they can store it — and most importantly, you can control both independently,” she says.
Thermo-chemical storage of solar energy uses a molecule whose structure changes when exposed to sunlight, and can remain stable in that form indefinitely. Then, when nudged by a stimulus — a catalyst, a small temperature change, a flash of light — it can quickly snap back to its other form, releasing its stored energy in a burst of heat. Grossman describes it as creating a rechargeable heat battery with a long shelf life, like a conventional battery.
x 6062
par Obamot » 03/08/11, 15:39
Salut les amis,
Non, ce n'est pas que ça n'intéresse pas les éconologues dédé, Mais des fois on se demande qui s'intéresse ici réellement aux nouvelles technologies sur les EnR débusquées sur la toile? Parfois l'attention est pas plutôt monopolisée par certains, qui privilégient le faire valoir et cherchent à faire de «l'audimat» à court terme autour de leur petite personne en soutenant la contradiction à tout prix, lorsqu'il ne sagit pas purement de manipulation sans fin. Le fait est qu'à long terme démotive, ça démotive "les troupes", qui n'en n'ont rien à faire de ces provocateurs et zappent vite fait, pour ne plus jamais revenir. (Ce qui me conduit aussi à n'être plus ici autant que je le voudrais.)
A force d'épuiser son énergie à se battre contre des moulins à vent, on fini par en oublier l'essentiel => le but même de ce forum.
En attendant, on s'apperçoi que la révolution qui est en marche, l'est de plus en plus SANS LUI, comme avec le stockage de l'énergie dans:
— le sodium en fusion;
— le sol (par géothermie augmentée et déphasage thermique);
— de l'air comprimé (études très sérieuses de l'EPFL).
— de l'acide formique;
— des tubes de nano-carbonne.
Et la perspective de la sortie du nucléaire, qui va faire sortir encore bien des choses qui étaient planquées dans les tirroirs, par peur de ne pas déranger le paradigme ambiant...
Le pire est qu'il y a relativement peu de recherche de fond ici, sur:
— les nouveaux défis engendrés par le transport de l'énergie issue du renouvelable.
— les capacités et rendement réels du solaire thermique!
Bref, ce forum plafonne...
Certes on parle de ces sujets, mais beaucoup trop peu... alors qu'ils devraient constituer l'essentiel du débat, avec l'efficience énergétique.
J'ai proposé par deux fois de réaliser une synthèse de tout «ce qui marche» dans les EnR, espèrons qu'il y aura plus de succès...
DONC BRAVO ET MERCI D'AVOIR TROUVÉ CETTE PÉPITE !
[Edit: 4.08.2011, 21h25]
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 76 invités
