j'ai trouvé ça sur ebay UK. c'est un isolant thermique pour échappement.....si y'a quelqu'un que ça interesse, ils peuvent envoyer en france.
l'adresse :http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=110043338211&fromMakeTrack=true
la description du produit :
A MUST HAVE PRODUCT FOR TURBO & NON-TURBO BIKES, BOATS, CARS, KIT-CARS, LIMOUSINES, TRACTORS & TRUCKS. CAN BE FITTED TO DOWNPIPES, TUBULAR/STAINLESS STEEL MANIFOLDS & CENTRE SECTIONS TOO.
1. Originally developed for the thermal insulation of gas turbine jet pipes.
2. This exhaust wrap material has played a vital role in the European aerospace industries since the 1960's.
3. It is widely employed in nuclear reactor applications.
4. It is made out of inorganic fibres and woven into a very flexible cloth.
5. Is capable of operating continuously at 1000°C and up to 1600°C for limited periods.
6. It will not melt or vaporize until the temperatures exceed 1700°C.
7. It has a very high resistance to thermal shock.
8. It provides flexible electrical insulation at temperatures as high as 1000°C.
9. Is a good electrical insulator, with high electric strength and low electrical conductivity.
10. What more can I say? Looks great in your engine bay!
INSTRUCTIONS
· The exhaust heat wrap contains many fibres which can irritate skin! Gloves should be worn whilst handling!
· The fitting of this product can be made much easier by removing the exhaust from the vehicle.
· Once a stainless steel tie has been closed, they can be quite difficult to open. It can be done with a very fine pin, by pushing the small ball backwards.
· The exhaust heat wrap can be cut with sharp scissors.
· The cut end can be tidied up with a lighter or gas torch.
· Overlap each turn by about half an inch.
· Once you have wrapped your chosen section of exhaust, place a stainless steel tie around the end where you have finished wrapping. Pull it tight and trim the remainder of the tie off with sharp scissors or side cutters. Tie both ends if needed.
· It is perfectly normal for the exhaust heat wrap to emit a smell for approximately 10 miles!
· Jubilee clips can be used as an alternative to stainless steel ties.
Stainless Steel Tie Specifications:
360mm x 4.6mm
Stainless steel ties suit most general purpose applications and withstand most environmental conditions.
Stainless steel is highly resistant to corrosion, and is widely used in marine environments where chemicals, salts, acids, and temperature extremes may affect the bundling application
Low profile, self-locking, ball bearing head mechanism with fully adjustable strap provides quick and easy installation.
Fully enclosed head does not allow dirt or grit to interfere with locking mechanism.
High tensile strength adds strength and safety on heavy duty applications.
Smooth rounded edges ensure safe, efficient handling.
Temperature Range -112°F (-80°C) to 1000°F (538°C)
Usefull in extreme temperature environments.
Flame retardant and non-toxic.
si ça peut aider....
