inventor a écrit :So outside the box, only the water to be cooled is transmitted to the cooler and back and the resulting electric current. The heat can be supplied outside the box at normal atmospheric pressure. The efficiency of the device increases 10 times (or 100).
The steam does not go anywhere, because it is in a closed circuit, and the water is similar, it does not need to be topped up, but only cooled ..
Such "boxes" can be installed downstairs in mines to produce electricity .. with high efficiency .. But basically any source of heat can be used ..
The second law of thermodynamics, she forgot to say that the efficiency of a heat engine depends not only on the temperature difference, but also largely on the pressure at which the system works.
The Feliks-Newcomen formula.
Andrew
![Very Happy :D](https://www.econologie.com/forums/images/smilies/icon_biggrin.gif)
Well, don't worry All, I'll post the next steps ...
so that there was no shock therapy, with my inventions, I also started publishing, so that everyone could easily understand what it is because they know Boyle a little and know what pressure P is. then the engine will have 5 times more torque .. increasing the temperature of steam conversion only by 30 degrees Celsius .. And this is understandable, although the proportions are already fundamentally different than in the second law of thermodynamics .. But now, as already is quite understandable, we will not associate this efficiency with pressure,
a weight that can easily replace this pressure .. and perhaps is less technically troublesome ..
Well, now the calculation of one of my Half Rotate cylinders, 400 x 1000 = 400,000 square cm, will give us 2,000,000 KG at 5 atm (2000 tons), i.e. the average torque x 2 meters = 4,000,000 kgm and at a speed of 30 rpm min = 123 MW of electric power from one space ..
And that's it, with a childish temperature of only 130 degrees Celsius, 5 atmospheres of pressure .. and a completely closed medium circulation.
Well, everyone can see that in such an engine, it really does not depend on heat, which has increased by 30 degrees .. the motor torque has increased five TIMES !
for nuclear power plants, such a system of energy production from a reactor can also be used.
Write whether you have easily understood the emergence of energy from ... weight ...
![Image](https://new4stroke.com/newcomen_weight%20.gif)
Andrew
This is my way to "help" the atmosphere...
![Laughing :lol:](https://www.econologie.com/forums/images/smilies/icon_lol.gif)
