Climat: animation du cycle de l'eau (Nasa)
x 11852
par Christophe » 25/02/11, 13:12
Animation du cycle de l'eau d'après des relevés de la Nasa: cycle de l'évaporation, la vapeur atmosphérique et les précipitations!
http://www.flickr.com/photos/gsfc/5393570697/#
Les mouvements "globaux" des précipiations sont relativement constants à cette "échelle" !
Components of the Water Cycle on a Flat Map
Water regulates climate, predominately storing heat during the day and releasing it at night. Water in the ocean and atmosphere carry heat from the tropics to the poles. The process by which water moves around the earth, from the ocean, to the atmosphere, to the land and back to the ocean is called the water cycle.
The three animations of atmospheric phenomena were created using data from the GEOS-5 atmospheric model on the cubed-sphere, run at 14-km global resolution for 25-days. Variables animated here include hourly evaporation, water vapor and precipitation. For more information on GEOS-5 see gmao.gsfc.nasa.gov/systems/geos5 . For more information on the cubed-sphere work see science.gsfc.nasa.gov/610.3/cubedsphere.html.
The animation of global sea surface temperature was created using data from a model run of ECCO's Ocean General Circulation Model. See www.ecco-group.org/model.htm for more information on ECCO.
This group of animations are an orthographic view of the data used in Components of the Water Cycle.
Credit: NASA/Goddard Space Flight Center Scientific Visualization Studio This is a contribution of the Consortium for Estimating the Circulation and Climate of the Ocean (ECCO) funded by the National Oceanographic Partnership Program
NASA Goddard Space Flight Center enables NASA’s mission through four scientific endeavors: Earth Science, Heliophysics, Solar System Exploration, and Astrophysics. Goddard plays a leading role in NASA’s accomplishments by contributing compelling scientific knowledge to advance the Agency’s mission.
Credit: NASA/Goddard Space Flight Center Scientific Visualization Studio http://svs.gsfc.nasa.gov/index.html
Version Haute résolution à télécharger ici: http://svs.gsfc.nasa.gov/vis/a000000/a003800/a003811/
Trouvé via: http://www.chez-soann.com/decouvertes/c ... satellite/
par dedeleco » 25/02/11, 14:27
Déjà le cycle de l'eau dans un vieux mur épais avec petites cavités est bien difficile à comprendre et à assimiler comme le montre aerialcastor et pourtant identique à petite échelle à celui des pluies sur terre !!
https://www.econologie.com/forums/post194655.html#194655
https://www.econologie.com/forums/post194617.html#194617
On devrait faire une animation de ce cycle dans les murs et vides sanitaires avec le mécanisme moteur les petites différences de T !!!!
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 65 invités
