voici le lien de téléchargement......
http://www.tandfonline.com/eprint/q6eGZ ... p7aFH/full
Séchage solaire des plantes aromatiques et médécinales
Re: séchage solaire des plantes aromatiques et médécinales
nounou0 a écrit :voici le lien de téléchargement......
La torture pour le nuls
Hic a écrit :nounou0 a écrit :voici le lien de téléchargement......
- x 11432
Voici le .pdf directement: https://www.econologie.info/share/partag ... TuDxVi.pdf
Dites vouar, c'est balèze en équations pour du simple séchage solaire !
Abstract
An indirect forced convection solar dryer consisting of an air flat plate collector and a drying cabined was designed and fabricated to investigate its performance under the climate of Algiers. Drying experiments have been performed for spearmint leaves at different air flow rate in order to determine the drying velocity, the characteristic drying curve, the effective diffusion coefficient and the activation energy. A mathematical model based on thermal and mass balances over the component of the solar collector and the cabinet dryer was developed. Simulations are carried out for meteorological data of Algiers (Algeria). We analyze the effect of air mass flow rate, air temperature, products mass, collector area, air recycling rate on the drying time, the solar fraction and the efficiency of the dryer.
Utilisateurs parcourant ce forum : Google [Bot] et 67 invités
