Energie Hydraulique (mondial)
moinsdewatt
x 554
par moinsdewatt » 24/11/13, 13:43
30 GW de capacité hydraulique ajoutée au niveau mondial en 2012.
Dont 51% de ce chiffre pour la seule Chine.
Voir ci dessous le détail de leur 4 plus gros projets hydrau en cours.
China continues its dominance of the global hydropower market
18/11/2013 Evwind,
ITH 30GW of new capacity installed during 2012, global cumulative hydropower capacity jumped to 1127GW by the year-end, providing an estimated 3524TWh of electricity generation annually.
Thus, this technology is still by far the one with the highest cumulated installed capacity among renewable energy sources.
Just over half (51%) of the hydro capacity installed in 2012 was in China, converting this market into the most active for the year. With the largest installed capacity in the world also, accounting 240.7GW of total capacity, the country is continuing its expansion and currently has 61GW under construction.
The most notable Chinese projects underway are:
- Baihetan (13.1GW), which will be the third largest dam in China when completed and the fourth largest in the world. It is slated for completion in 2019;
- Wudongde and Xiangjiaba (8.7 and 6.4GW, respectively) are located in Jinsha River. Both are scheduled to be finished in 2015; and
- Xiluodu (14GW) located in Yangtze River. This project was temporarily stopped by the Chinese government in 2005 due to lack of environmental impact studies, but construction is again underway.
Meantime after the controversies regarding the location of the Belo Monte hydroelectric power plant in the Amazonas Area, Brazil is surging ahead once again also. Based on projects underway, it will account for 11GW of new capacity in 2015.
http://www.evwind.es/2013/11/18/china-c ... rket/38079
moinsdewatt
x 554
Re: Energie Hydraulique (mondial)
par moinsdewatt » 08/08/14, 12:35
Dans la vallée de la Romanche, le plus grand barrage hydroélectrique de France sort de terre
France 3 AlpesPublié le 04/10/2013
Dans la vallée de la Romanche c'est le plus important barrage hydroélectrique construit actuellement en France. Le "projet Romanche-Gavet" réalisé par EDF remplacera l'aménagement actuel, construit entre la fin du XIXème et le début du XXème siècle.
Des tonnes et des tonnes de ferrailles : l'armature du barrage sort peu à peu de terre. Il s'élèvera à 14 mètres de haut avec quatre piles. Terrassements, remblais, il a fallu remuer 200.000 mètres cubes de caillou, et dériver provisoirement le lit de la rivière, La Romanche, a été provisoirement dérivée
Un tunnel de 9 kilomètres a été percé dans la montagne, entre le barrage en amont, et la centrale hydroélectrique, en aval. Le courant produit pourra alimenter 250.000 foyers. C'est 30 % de plus que les 6 usines existantes, installées, il y a un siècle. Elles seront détruites, sauf l'une d'entre elles, classée "monument historique".
Lancés en 2010, les travaux vont s'échelonner jusqu' en 2017. Ils se doublent d'importantes interventions pour sécuriser les sites, notamment sur les falaises de la vallée. Des études d'impact ont également menées, notamment sur lflore, la faune, et la population piscicole. EDF doit en effet respecter des règles très précises de protection de l'environnement.
http://alpes.france3.fr/2013/10/04/dans ... 31493.html
moinsdewatt
x 554
par moinsdewatt » 04/11/16, 22:40
Kembs : EDF lance une centrale hydroélectrique de dernière génération
27 octobre 2016 / Écrit par: La Rédaction energeek
Le 20 octobre dernier, EDF a officiellement mis en service un nouvel aménagement hydroélectrique à Kembs, dans le sud du Haut-Rhin, en aval du port de Bâle. Une inauguration qui fait suite à quatre ans de travaux qui auront nécessité un investissement de plus de 50 millions d’euros de la part de l’électricien tricolore. Cette installation hydroélectrique dernière génération illustre parfaitement les impératifs qui découlent de la transition énergétique : les nouvelles infrastructures de production électrique devront désormais être de nature à satisfaire les besoins énergétique de notre pays, tout en préservant la qualité de l’environnement.
Favoriser la préservation des écosystèmes du Rhin…
L’aménagement hydroélectrique de Kembs, dont la construction s’est déroulée entre 1928 et 1932, est l’un des premiers à avoir été mis en service sur le Rhin. Il est constitué d’un barrage en charge d’alimenter en eau le Grand Canal d’Alsace, sur les rives duquel se trouvent quatre centrales hydroélectriques, dont la centrale actuelle de Kembs, d’une puissance de 160 MW. En 2010, au moment du renouvellement de la concession de Kembs, les ingénieurs d’EDF proposent de rénover l’ensemble du site grâce à un processus inédit qui allie impératifs industriels (renforcer la production électrique) et environnementaux (préserver la faune et la flore du Rhin).
Le projet visait notamment à renforcer les performances de l’aménagement hydroélectrique actuel de Kembs, tout en assurant la restauration des milieux naturels alsaciens. Dans le cadre de la contribution d’EDF à la Stratégie Nationale pour la Biodiversité, le chantier est conçu de manière globale : la conception du projet industriel est étroitement liée à la définition des mesures environnementales de compensation et d’accompagnement.
La première phase du projet a été d’augmenter, grâce à une partie de l’eau du Grand Canal, le débit du Vieux Rhin à 52 mètres cubes d’eau par seconde en hiver et jusqu’à 150 mètres cubes par seconde en été (débit dit de réserve) afin de l’adapter aux conditions de vie et de reproduction de la faune qui y réside. Proposée par EDF, cette mesure a été complétée par des travaux visant à compenser le déficit en gravier du Vieux Rhin : une digue a notamment été détruite afin de permettre une érosion maitrisée des berges.
… tout en renforçant la production hydroélectrique alsacienne
Ces aménagements ont cependant entrainé une baisse conséquente du débit du Grand Canal d’Alsace et, par conséquent, réduit les volumes d’électricité issus des centrales situées en aval (un déficit estimé à 110 GWh d’électricité par an). La construction de la nouvelle centrale K vise à compenser une partie de ce manque : constituée de deux turbines à axes horizontaux d’une puissance unitaire de 4,2 MW, elle permettra en effet de produire chaque année 25 GWh d’électricité de manière totalement respectueuse de l’environnement.
Soucieux d’assurer la continuité piscicole du Rhin, les ingénieurs d’EDF ont, dès la conception de la centrale K, prévue des ouvrages de montaison et dévalaison, tels que des passes à poissons et à castors. De plus, pour alimenter cette nouvelle unité de production renouvelable, l’électricien tricolore a procédé à la renaturation de plus de 100 hectares de terres agricoles sur l’île du Rhin et, notamment, la remise en eau d’un ancien bras du Rhin baptisé Petit Rhin. Un chantier de restauration qui reste aujourd’hui unique en Europe.
Cette centrale hydroélectrique nouvelle génération vient donc s’ajouter aux autres unités de production installées le long du Rhin. L’ensemble de ces centrales totalise une puissance installée de 1.450 MW, pour une production électrique annuelle moyenne de 8,5 TWh.
L’excellente santé de la filière hydraulique
La filière hydraulique est la première source d’énergie renouvelable en Europe, propre et issue d’un processus de production qui ne génère pas de dioxyde de carbone. En mai dernier, en raison des fortes précipitations qui se sont abattues sur le pays, la production hydraulique française a atteint un record annuel de 7.188 GWh, témoignant de l’excellente santé de la filière. Afin de favoriser l’atteinte de l’objectif de doubler la puissance installée dans le domaine des énergies renouvelables, passant ainsi de 28 GW à plus de 50 GW dans le mix électrique français d’ici 2030, le gouvernement a lancé en avril dernier un appel d’offres pour le développement de petites installations hydroélectriques, l’objectif étant de renforcer et développer de nouvelles capacités de production.
En raison de ses caractéristiques intrinsèques, l’énergie hydraulique a donc un rôle important à jouer dans la stratégie énergétique de notre pays et dans la réussite de la transition énergétique. Face à l’engagement pris par notre gouvernement dans le cadre de la lutte contre le réchauffement climatique, il semble aujourd’hui essentiel que les acteurs du secteur fassent preuve d’innovation, pour maximiser toujours plus l’exploitation du potentiel hydraulique de l’Hexagone.
http://lenergeek.com/2016/10/27/kembs-e ... eneration/
l'ombre
par l'ombre » 04/11/16, 23:26
Horreur encore un dégât annoncer par les pro-EDF une vraie catastrophe sous un tonnerre d’applaudissement :twisted:
Puiser Sans Épuiser
moinsdewatt
x 554
par moinsdewatt » 05/11/16, 12:31
l'ombre a écrit :Horreur encore un dégât annoncer par les pro-EDF une vraie catastrophe sous un tonnerre d’applaudissement :twisted:
l'ombre
par l'ombre » 05/11/16, 17:09
C'est assez clair faire et défaire c'est toujours travailler :twisted: le coût est sûrement dérisoire :oops:
Puiser Sans Épuiser
l'ombre
par l'ombre » 05/11/16, 21:05
l'ombre a écrit :Soucieux d’assurer la continuité piscicole du Rhin, les ingénieurs d’EDF ont, dès la conception de la centrale K, prévue des ouvrages de montaison et dévalaison, tels que des passes à poissons et à castors. De plus, pour alimenter cette nouvelle unité de production renouvelable, l’électricien tricolore a procédé à la renaturation de plus de 100 hectares de terres agricoles sur l’île du Rhin et, notamment, la remise en eau d’un ancien bras du Rhin baptisé Petit Rhin. Un chantier de restauration qui reste aujourd’hui unique en Europe.
PS : Un Petit lien sur les barrages et un petit résumer
Gaz a Effet de Serre
Puiser Sans Épuiser
x 1579
par izentrop » 07/11/16, 09:24
l'ombre a écrit :PS : Un Petit lien sur les barrages et un petit résumer
J'avais souligné aussi ce lien
il apparaît que les émissions sont 25 % plus élevées que ce que l'on pensait.
Ça ne veut pas dire que c'est beaucoup ...
D'un point de vue énergétique et climatique, les barrages sont donc positifs.
En revanche, il n'en va pas de même pour l'écologie et les flux de sédiments. En effet, chaque barrage, qu'il soit hydroélectrique ou non, constitue un obstacle pour la circulation des espèces et des sédiments (sable, vase...).
Pour les espèces animales, et plus particulièrement les espèces migratrices (saumons, anguilles, etc.), ces barrages bloquent les accès aux zones de reproduction et provoquent la mort de nombreux individus, même lorsqu'il y a des passes à poissons. http://www.futura-sciences.com/planete/ ... rages-910/
D'un autre côté, à moins d'un régime totalitaire, il est fort peu probable qu'un nouvel ouvrage voit le jour en Europe.
l'ombre
par l'ombre » 07/11/16, 11:39
J'ai fait l'impasse sur ton message ( Excuse- moi pour cette action )
Puiser Sans Épuiser
l'ombre
par l'ombre » 07/11/16, 13:55
Bien des barrages sont des sources a problèmes , car a y regarder avec de la hauteur > AUCUNS n'est viable sur la durée 8)
Déplacement des populations en masse , destructions des terres , un coût prohibitif dans tout les cas ,morts d'hommes et d'animaux a chaque fois
Sur le long terme la production qui n'est pas en phase avec les travaux entrepris , la liste des répercutions sont souvent oublier voir caché aux grands publique > Chine ,USA, France,Brésil,Russie,Inde,Pakistan,Espagne,Italie,Allemagne,Suisse, etc....
Avec un petit peu de recherche ,il est possible de voir ce que ces réalisations sont pour le cour terme ( la demande d'énergie est en mode exponentiel )
Faut sûrement regarder autrement pour les générations qui arrivent car ces milliers de barrages c'est des terres qui ont disparus
https://fr.wikipedia.org/wiki/Liste_des ... _puissants
http://theses.univ-lyon2.fr/documents/g ... art=154362
Quelques chiffres en 2012
Tout au long du XXe siècle, l’idée du développement économique a été associée aux barrages. Résultat : on en compte aujourd’hui 800 000 dans le monde dont 52 000 sont considérés comme des grands barrages,c’est-à-dire d’une hauteur de plus de 15 mètres et avec un réservoir supérieur à 3 millions de m3. Les quatre principaux pays constructeurs de barrages en comptent les trois quarts : 45 % en Chine, 14 % aux Etats Unis, 9 % en Inde et 6 % au Japon. La France possède, elle, 569 grands barrages, soit 1 % du total mondial.
Bonne Journée
Puiser Sans Épuiser
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 167 invités
