Ethanol cellulosique
moinsdewatt
x 554
par moinsdewatt » 07/11/15, 20:20
DuPont à inauguré son usine d' éthanol cellulosique, qui est la plus grande des USA.
Capacité de production de 30 millions de gallons annuellement à partir de tiges de Maïs.
Il faudra traiter 375,000 tonnes de ces raffles de Maïs.
L'usine a coûté 225 millions de $.
Digging into the science of cellulosic ethanol
Nov 5, 2015 Willie Vogt
The day before Halloween was a big day for Nevada, Iowa. That’s the day that DuPont officially opened its new cellulosic ethanol plant. Key dignitaries were on hand from the state and the company to mark the historic day.
DuPont’s plant, the largest in the nation, when up to full capacity will produce 30 million gallons of ethanol a year from corn stover. Jan Koninckx, global business director, Advanced Biofuels, DuPont, explains that fuel from this plant will be made generating “90% less greenhouse gas then the production of gasoline.”
Koninckx notes that the ceremony was being held ahead of the official plant opening, during the media event and tour he referred to the Nevada plant as “serial No. 1,” which means DuPont is doing something entirely new, and will gradually start up the process over time. “Plants two, three and four will start more quickly in the future,” he says, noting DuPont’s commitment to biofuels.
He adds that in the company’s 213 year history, it has brought many plants online. “We know how to bring a plant online, there’s always a degree of uncertainty in a first plant. We expect the first shipments of biofuel to begin in 2016.”
http://farmindustrynews.com/biofuel/dig ... ic-ethanol
....They flocked to see the facility that is expected to process 375,000 tons of corn stover each year (about one half-ton bale each minute) to produce about 30 million gallons of ethanol a year.
http://www.iowafarmertoday.com/news/cro ... 23a91.html
....The $225 million plant produces cellulosic ethanol from corn husks – the non-kernel parts of corn plants.
http://www.forbes.com/sites/williampent ... nt-online/
citro
par citro » 08/11/15, 11:51
Je n'ose imaginer la pollution générée par une usine qui traite des sous-produits de mais OGM qui risque diffuser dans l'atmosphère des résidus de glyphosate ou autres cochonneries...
Et bien sûr pour fabriquer du carburant de moteurs thermiques...
A la limite, si cet éthanol servait pour des piles à combustible...
Hic
x 5
par Hic » 08/11/15, 15:48
citro a écrit :Je n'ose imaginer la pollution générée par une usine qui traite des sous-produits de mais OGM qui risque diffuser dans l'atmosphère des résidus de glyphosate ou autres cochonneries...
Salut citro
ça tombe bien,je paris que cette centrale fonctionne àl' Ethanol!
pile ou face?
:mrgreen:
La torture pour le nuls
x 8690
par Did67 » 08/11/15, 16:06
Logiquement, le "principe" repose sur :
- d'abord une hydrolyse de la cellulose [la cellulose est un polymère assez simple du glucose :" La cellulose est un glucide constitué d'une chaîne linéaire de molécules de D-Glucose"]
[avant - "éthanol de 1ère génération" - on faisait la même chose avec un autre polymère du glucose, qui était l'amidon - dont on pouvait aussi se nourrir mais qui était très facile à hydrolyser : en gros un peu de salive, et l'amidon se transforme "naturellement" en glucose]
- une fois qu'on a du glucose, on le fermente avec les levures appropriées et on a de l'éthanol [là encore, quelque chose que tout producteur de cidre ou de vin connait bien].
Voilà pour le principe. C'est essentiellement de la biochimie. Très simple.
En réalité, je pense que le chimiste utilise juste les enzymes appropriées, dans des fermenteurs.
Mais bon, pas la peine non plus de s'affoler avec OGM, émissions, etc...
Il y a, ce qui est réel, un problème général autour de la production de maïs OGM. Et du bilan énergétique de ces productions "intensives" : engrais, machines, etc... Certains sont pour, d'autres contre...
Mais une fois que ceci a été fait, le maïs cultivé, le grain ramassé, le fait d’hydrolyser / fermenter un résidus, la canne, ne va plus changer grand chose.
Non, si vous cherchez le "gros défaut" de ce système, c'est que pour un agronome comme moi, la canne a vocation à revenir au sol, pour y nourrir des tas d'organismes (bactéries, champignons...), pour y être transformé en humus, qui est "stabilisant" du sol... En exploitant cette ressource de la sorte, on "trait" [du verbe "traire"] un peu plus les sols... Avec des conséquences prévisibles du coté du "taux d'humus" des sols, donc de la fragilisation du sol, et, dès les moindres pentes, des risques d'érosion accrus. Accessoirement, moins stable, moins "naturellement riche", la chute du taux d'humus va exiger une augmentation des doses d'engrais chimiques... Autrement dit d'un coté on gagne de l'éthanol, de l'autre coté, le bilan énergétique de agriculture se dégradera sans doute un peu plus...
citro
par citro » 08/11/15, 16:34
Je suis bien de ton avis...
Mais les industriels ont la réponse:
Des engrais, des pesticides, et autres intrants ayant nécessité beaucoup de pétrole pour leur production.
Sans oublier bien sûr les incontournables semences OGM... Pour ajouter une pollution génétique à la pollution chimique.
moinsdewatt
x 554
Re: Ethanol cellulosique
par moinsdewatt » 18/11/17, 20:31
Enerkem lance sa production commerciale d’éthanol cellulosique à Edmonton( Canada)
Frédéric DOUARD 19 septembre 201
Le producteur de biocarburants de seconde génération Enerkem, basé à Montréal au Québec, a annoncé le 15 septembre 2017 qu’il venait de lancer sa production commerciale d’éthanol cellulosique. L’usine novatrice d’Enerkem à Edmonton en Alberta est la première usine au monde à l’échelle commerciale à produire de l’éthanol cellulosique à partir de matières résiduelles urbaines mixtes non recyclables et non compostables.
Usine Enerkem d’Edmonton, photo Merle Prosofsky
La société a produit et vendu du biométhanol depuis 2016, avant d’étendre sa production afin d’offrir de l’éthanol cellulosique grâce à l’installation d’une unité de conversion du méthanol en éthanol plus tôt cette année.
« Nous allons maintenant augmenter progressivement la production à Edmonton, tout en préparant la construction de nos prochaines installations, tant à l’échelle locale qu’internationale », a déclaré Vincent Chornet, président et chef de la direction d’Enerkem.
https://www.bioenergie-promotion.fr/529 ... -edmonton/
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 146 invités
