ITER quand ?
moinsdewatt
x 554
Re: ITER quand ?
par moinsdewatt » 13/02/21, 11:28
Le premier des 7 solenoides supraconducteurs pour Iter a fini d'étre construit. C'est une participation tazu au programme ITER.
First ITER solenoid module completed
05 February 2021
General Atomics (GA) has completed the construction and testing of the first of seven superconducting magnet modules that will make up the Central Solenoid of the ITER international fusion machine. The module is part of the USA's largest contribution to the fusion project, and will be shipped to the ITER construction site in France later this year.
The module was built at GA's Magnet Technologies Center in Poway, California, under the direction of the US ITER project, managed by Oak Ridge National Laboratory (ORNL). Fabrication of the module began in 2015. The module was tested during and after its production in extreme conditions similar to those it will experience during ITER operation, including near-complete vacuum and cryogenic temperatures required for the magnet to become superconducting (4.5 Kelvin, -270 degrees Celsius). Components were evaluated at the SULTAN testing facility in Switzerland.
Each module is 14 feet (4.3 metres) in diameter, weighs 113 tonnes and is composed of more than three miles about (5 kilometres) of niobium-tin superconducting cable. Lessons learned on the first module have been applied to the fabrication of the subsequent six coils, one of which will serve as a spare, GA said. The second module is being tested and is expected to be shipped to ITER soon after the first.
When completed, the 1000-tonne, 59-foot-tall Central Solenoid will stand at the core of the ITER tokamak, driving 15 million amperes of current through ITER's plasma to heat and stabilise the fusion reaction. The central solenoid is one of 12 hardware systems that US ITER, funded by the Department of Energy Office of Science Fusion Energy Sciences, is providing to the project.
"The Central Solenoid ranks among the largest, most complex and demanding magnet programmes ever undertaken," GA Director of Engineering and Projects John Smith said. "We have all felt the responsibility of working on a job that has the potential to literally change the world."
ITER is being built in Cadarache, France, is designed to demonstrate that fusion energy can be generated on Earth at an industrial scale. It is now more than 70% complete and is expected to begin first plasma operations in 2025.
https://www.world-nuclear-news.org/Arti ... -completed
moinsdewatt
x 554
Re: ITER quand ?
par moinsdewatt » 13/05/21, 10:46
Fusion nucléaire : dernières nouvelles d'Iter
Laurent Sacco futura science 12/05/2021
vidéo de 7 mn datée de 2020 https://www.futura-sciences.com/science ... ter-82181/
x 1698
Re: ITER quand ?
par izentrop » 08/06/21, 07:57
La semaine dernière, des scientifiques chinois sont parvenus à faire fonctionner pendant plus de 100 secondes, à une température record, un dispositif qui simule le processus énergétique qui se déroule dans le soleil, autrement dit la fusion nucléaire.
Le ‘soleil artificiel’, appelé Experimental Advanced Superconducting Tokamak (EAST), a réussi à générer des températures de plasma de 120 millions de degrés Celsius pendant 101 secondes, avant que les scientifiques n’atteignent des températures de 160 millions de degrés Celsius pendant 20 secondes supplémentaires.
Image https://fr.businessam.be/fusion-nucleai ... artificiel
moinsdewatt
x 554
Re: ITER quand ?
par moinsdewatt » 08/06/21, 08:50
On arrive pas à savoir si cette performance Chinoise rapproche de la possibilité de récupérer de l'énergie pour en faire un jour une machine pouvant générer des MégaWatt électriques, ni à quel horizon.
x 1698
Re: ITER quand ?
par izentrop » 08/06/21, 10:19
Seul le tokamak d'ITER pourra prétendre l'auto entretien du plasma semble t'il. :?: :?:
x 5203
Re: ITER quand ?
par GuyGadeboisLeRetour » 08/06/21, 12:40
Belle info, Izy. Image
x 5817
Re: ITER quand ?
par Remundo » 09/06/21, 00:12
ces machin(e)s ne produiront jamais plus d'énergie que celle qu'on y a injectée
l'énergie nette produite pas ces bidules est même fortement négative.
Sans dire qu'intrinsèquement, des plasmas neutrogènes à 100 000 000 °C ne permettent pas d'envisager la durabilité des matériaux qui les entourent.
Et également que les instabilités du plasma créent des phénomènes d'induction et des forces de Laplace qui tordent les éléments des parois.
Le combustible Deutérium-Tritium n'existe pratiquement pas dans la nature. Le Deutérium se trouve un peu dans les océans, mais très rare.
Le Tritium quant à lui est supposé être produit par l'impact des neutrons rapides sur des plaques de lithium-6 tritigènes placées sur les parois du réacteur.
Le lithium 6 en lui-même n'est pas très abondant. Mais on en trouve suffisamment, environ 7-8 % du lithium naturel, à condition de réaliser une séparation isotopique.
Je dis bon courage !!
le temps du retrait est venu
x 1698
Re: ITER quand ?
par izentrop » 17/06/21, 00:59
Remundo sources ?
L’ITER sera bientôt doté de l’aimant le plus puissant au monde https://trustmyscience.com/iter-sera-bi ... t-au-monde
Cet aimant serait capable de soulever un porte-avions à deux mètres du sol ! Intégré au cœur de l’International thermonuclear experimental reactor (ITER), il devrait permettre de produire une quantité d’énergie quasi illimitée, sans aucune émission de carbone. Partis cette semaine de l’usine du constructeur General Atomics, en Californie, les composants du premier module de cet aimant sont actuellement en transit vers la France.
Ce sera sans doute l’un des convois les plus surveillés : les composants doivent parvenir sans encombre au centre d’études nucléaires de Cadarache, où ils formeront le solénoïde central du tokamak, l’électro-aimant le plus puissant au monde. Pour rappel, le projet ITER est un projet de réacteur à fusion nucléaire, porté par une coalition de 35 pays, visant à démontrer qu’il est possible de produire une quantité massive d’énergie sans émissions polluantes.
x 1698
Re: ITER quand ?
par izentrop » 17/06/21, 01:48
Remundo a écrit :ces machin(e)s ne produiront jamais plus d'énergie que celle qu'on y a injectée
La quantité d'énergie produite par la réaction de fusion est environ 4 millions de fois supérieure à celle que génèrent des réactions chimiques telles que la combustion du charbon, du pétrole ou du gaz naturel. Alors qu'une centrale au charbon de 1 000 MW brûle 2,7 millions de tonnes de charbon par an, une centrale de fusion comme celles qui pourraient être opérationnelles dans la deuxième partie du XXIe siècle ne consommera que 250 kilos de combustible chaque année, répartis à parts égales entre le deutérium et le tritium.
De très faibles quantités de deutérium et de tritium suffisent à alimenter la réaction de fusion (à l'intérieur de la chambre à vide la quantité de combustible dans le plasma ne dépasse jamais quelques grammes). La fusion, c'est donc une réaction qui est très économe en combustible et également une réaction très sûre parce que la quantité de combustible présente dans la chambre ne permet d'alimenter la combustion que pendant quelques secondes (il n'existe aucun danger d'emballement).
Pour obtenir du deutérium, il suffit de distiller de l'eau, qu'il s'agisse d'eau douce ou d'eau de mer. Cette ressource est largement disponible et quasiment inépuisable. Chaque mètre-cube d'eau de mer contient 33 grammes de deutérium que l'on extrait de manière routinière à des fins scientifiques et industrielles.
La réaction de fusion permet ainsi de produire du tritium de manière continue. Une fois la réaction de fusion amorcée dans un tokamak, il suffira pour l'entretenir de l'alimenter en deutérium et en lithium, deux éléments disponibles en abondance. https://www.iter.org/fr/sci/fusionfuels
x 5817
Re: ITER quand ?
par Remundo » 17/06/21, 08:31
la source c'est qu'aucun tokamak n'a jamais réussi à entretenir sa réaction de fusion plus que quelques secondes. Et qu'on est obligé de construire cette cathédrale sans être sûr de faire mieux.
le bilan énergétique d'un tokamak est absolument catastrophique.
Il faut énormément d'énergie pour porter la matière à l'état de plasma, et encore plus pour entretenir ce plasma.
Même quand on franchit le critère de Lawson, à savoir qu'on amorce la fusion, la partie est toujours loin d'être gagnée.
parce que le plasma, porté à 100 000 000 °C perd énormément d'énergie par différents mécanismes physiques
1) pertes thermiques et radiatives
2) neutrons hypervéloces qui sortent du plasma
3) particules arrachées aux parois qui rentrent dans le plasma
4) pertes électromagnétiques de "bremstrahlung" des particules dans le plasma (notamment hélium et impureté en provenance des parois).
la question n'est pas qu'il suffit de 100 kg de combustible de fusion, la question, c'est le bilan énergétique de la casserole qui est le siège des réactions thermonucléaires.
ITER, à l'instar des autres tokamaks, est plutôt une casserole qu'on devra chauffer tout le temps, qu'une vraie source de chaleur.
Utilisateurs parcourant ce forum : Majestic-12 [Bot] et 240 invités
