Cloner un disque dur systeme vers SSD MX500 Crucial (avis, test...) ?
- x 11234
Re: Cloner un disque dur systeme vers SSD MX500 Crucial (avis, test...) ?
J'ai un soucis récurent de Pending Sector Count avec le SSD...qui semble se résoudre tout seul ?
14/06/2021 19:43:14,#197 Current Pending Sector Count 1 -> 0
14/06/2021 19:38:13,#197 Current Pending Sector Count 0 -> 1
14/06/2021 13:05:01,#197 Current Pending Sector Count 1 -> 0
14/06/2021 12:50:01,#197 Current Pending Sector Count 0 -> 1
14/06/2021 10:34:39,#197 Current Pending Sector Count 1 -> 0
14/06/2021 10:29:38,#197 Current Pending Sector Count 0 -> 1
14/06/2021 10:24:37,#197 Current Pending Sector Count 1 -> 0
14/06/2021 10:19:36,#197 Current Pending Sector Count 0 -> 1
14/06/2021 09:49:29,#197 Current Pending Sector Count 1 -> 0
14/06/2021 09:44:28,#197 Current Pending Sector Count 0 -> 1
14/06/2021 09:14:21,#197 Current Pending Sector Count 1 -> 0
14/06/2021 09:09:20,#197 Current Pending Sector Count 0 -> 1
10/06/2021 17:42:19,#197 Current Pending Sector Count 1 -> 0
10/06/2021 14:13:23,#197 Current Pending Sector Count 0 -> 1
10/06/2021 13:58:21,#197 Current Pending Sector Count 1 -> 0
10/06/2021 13:53:21,#197 Current Pending Sector Count 0 -> 1
10/06/2021 12:53:12,#197 Current Pending Sector Count 1 -> 0
10/06/2021 12:48:12,#197 Current Pending Sector Count 0 -> 1
10/06/2021 12:18:07,#197 Current Pending Sector Count 1 -> 0
10/06/2021 12:13:07,#197 Current Pending Sector Count 0 -> 1
09/06/2021 00:30:00,#197 Current Pending Sector Count 1 -> 0
09/06/2021 00:25:00,#197 Current Pending Sector Count 0 -> 1
08/06/2021 22:01:36,#197 Current Pending Sector Count 1 -> 0
08/06/2021 21:56:35,#197 Current Pending Sector Count 0 -> 1
07/06/2021 20:04:10,#197 Current Pending Sector Count 1 -> 0
07/06/2021 19:54:09,#197 Current Pending Sector Count 0 -> 1
Est ce lié au clonage d'un disque présentant des secteurs défectueux (HDS indiquait 1 secteur HS mais quand j'ai cloné j'ai eu X erreurs de secteur illisible...j'ai fait ignorer tout donc je ne sais pas combien il y en a eu) ? C'est grave docteur ? Que faire ? Est ce que c'est le SSD qui est entrain d'auto réparer les secteur HS issus du clonage ?
Et le graphique des données smart "197 Current Pending Sector Count" reste à 0...so ???
Guy (et les autres) ? T'en penses quoi ?
- x 4690
J'en pense que le clonage c'est bien, mais qu'une clean install c'est mieux.
- x 11234
Sans blague ? C'est pour ça que t'en as déjà cloné 6 pour tes amis !! Dans le genre faux amis...je demande Guy ! Hihihi P0Wn3D !!
Bah tant qu'il se répare automatiquement pas de soucis...je sais juste pas si c'est le même secteur qui pose problème ou des différents...je penche pour des différents...2 nouvelles interventions depuis ce matin...
15/06/2021 11:42:24,#197 Current Pending Sector Count 1 -> 0
15/06/2021 11:37:23,#197 Current Pending Sector Count 0 -> 1
15/06/2021 11:32:22,#197 Current Pending Sector Count 1 -> 0
15/06/2021 11:27:22,#197 Current Pending Sector Count 0 -> 1
Marrant y a exactement 5 min entre la détection et réparation...Un indice ?
Et c'était toujours le cas sauf le tout 1er qui a mis 10 min...
ps: l'ancien disque échouait au test de lecture simple par HDS...donc je pense qu'il était plus abimé que les 99% donné par SMART...et que ses "bad sector" ont été cloné...
A voir comment ça évolue dans le temps...C'est intéressant ça montre les limites du clonage (mais je le savais avant de lancer l'opération)
- x 4690
Christophe a écrit :Sans blague ? C'est pour ça que t'en as déjà cloné 6 pour tes amis !! Dans le genre faux amis...je demande Guy !
J'ai dit "le clonage c'est bien, une clean install c'est mieux"... Pas "le clonage c'est pourri"... Une clean install c'est TOUJOURS mieux...
- x 11234
Ça va jte taquine, on est d'accord !
- x 4690
Christophe a écrit :Ça va jte taquine, on est d'accord !
C'est sûr que si on clone un disque avec des erreurs et des secteurs corrompus, on va se retrouver avec ces mêmes erreurs et ces mêmes secteurs corrompus dans le nouveau disque, pisque c'est du clonage.
- x 11234
Bien sur sauf qu'il y a 2 types de secteurs corrompus (je pense, je crois) : les hard irrécupérables et les softs récupérables...
Sur mon ancien c'était certainement des hard puisque l'auto test simple de lecture d'HDS ne passait même pas...et que le clonage n'a même pas pu s'effectuer sur certains secteur...
Ces "hard bad sectors" se sont probablement transformés en "soft bad sectors"...Et c'est peut être ce que le SSD est entrain de corriger ?
C'est simplement une hypothèse ?
- x 4690
Christophe a écrit :Bien sur sauf qu'il y a 2 types de secteurs corrompus (je pense, je crois) : les hard irrécupérables et les softs récupérables...
Si c'est irrécupérable, c'est que le secteur n'est pas corrompu, il est foutu.
- x 11234
Oui il est foutu car illisible mécaniquement (sur l'ancien dur)...En cas de clonage je pense qu'il devient récupérable (sur le nouveau dur) mais évidement avec pertes des datas...et probablement automatiquement (formatage par secteur ?)...
Les secteurs défectueux matériels, il s'agit d'un problème physique sur le disque dur.
Les secteurs défectueux logiciels. C'est un problème au niveau du système de fichiers qui peut par exemple être dû à une interruption électrique durant une opération d'écriture sur le disque. L'erreur peut être réparée par un utilitaire dédié.
https://www.malekal.com/reparer-isoler- ... isque-dur/
Le soucis c'est que chez moi les données SMART :
Rellocated Sector Count
Rellocated Event Count
Count Pending Sector
Restent à 0...y compris dans l'historique ? C'est peut-être dû à la réparation en 5 minutes ? Je connais pas la fréquence de refresh des données SMART c'est peut être 1 fois toutes les heures...Du coup les erreur réparées en 5 min passent inaperçues !
- x 1579
2.14 Go/h de moyenne de conso avec mon SSD Lexar
Je suis curieux de savoir ce que donne https://www.hwinfo.com/download/ avec le tiens.
- Pièces jointes
- HWinfo.gif (126.17 Kio) Consulté 2111 fois
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 49 invités
