Bonjour à tous,
Je viens d'acquérir ces quelques "manuels" et n'étant pas à mon
aise avec la langue de Shakespeare, certains d'entre vous seraient peut être intéressé par leurs traductions. J'ai aussi quelques vidéos techniques non sous-titrées. Par avance, merci.
Descriptif :
#1 DIY Guide
Solar Panel Systems
This is where you will learn how solar energy is produced and about the solar panel system that you will create. This guide includes both the basic solar system layout as well as detailed plans for creating your own solar energy.
* Step-by-Step Process of Creating Solar Energy
* How to Find “Free” Solar Panels
* How to Maintain Your Solar Panel System
Learn how to take the power your solar panels create and run your household energy needs (controller, batteries, inverter, disconnects, etc).
#2 DIY Guide
The "$98 Solar Panel" Guide
98 dollar solar panel Here is where it gets fun. This is a completely step-by-step explanation of how to build a solar panel from scratch. Everything from building the solar panel box to connecting solar cells is explained here with color pictures and detailed plans.
* Detailed Solar Plans
* Step-by-Step Photos Showing You Exactly What To Do
* In Our Example the Total Costs Were $98, You Could Do It For Less
#3 DIY Guide "Solar Energy Bundle"
Solar Panel Wiring Electrical Wiring Plans for Solar Panels
Learn how to hook up multiple solar panels and how to store your energy using multiple batteries at one time.
Installing and Mounting Solar Panels Guide
Learn the basics of PV solar panel installation with this helpful guide that shows the process of obtaining city permits to installation of the solar panels to then hooking up to the electrical panel. Solar PV Panel Install
Solar Energy Consumer Guide
This helpful guide discusses solar basics and how to calculate how much money solar energy can save your household.
#4 The $140 Wind Turbine
If you have ever wanted to see the exact step by step process involved in building a homemade wind turbine? Here it is!
- Step-by-Step plans show you how to build a wind turbine
- Packed full of pictures and diagrams
- In Our Example the Total Costs Were $140, You Could Do It For Less
No fluff here! You will see exactly how to create your own wind turbine that will produce energy for years.
#5 DIY Guide
Build Your Own Wind Turbine
Here is how you can create massive amounts of energy for your home. Use the wind’s energy to power your home! This beginner’s guide gives you a complete understanding of how wind energy is produced and how you can capture it for your own use.
* Explanation of How Wind Energy Is Produced
* Learn the Different Parts That Make a Wind Generator
* How to Buy or Build Your Own Wind Turbine
Aide traduction manuels panneau solaire, éoliene...
Stunzu
Voici la traduction que je t' ai fait pour les textes que tu as demandé.
#1 DIY(Do It Yourself) Guide( Guide fait le toi même)
Systèmes panneau solaire
Ceci est ou tu pourras apprendre comment l' énergie solaire est produite et concernant le système de panneau solaire que tu pourras fabriquer. Ce guide inclus le montage du système solaire de base aussi bien que les plans détaillés pour créer votre propre énergie solaire.
*Processus étape par étape de création de l' énergie solaire
*Comment trouver des Panneaux Solaire "Gratuit"
*Comment entretenir vos Système de Panneaux Solaire
Apprendre comment prendre l' énergie de vos panneaux solaire et l' utiliser pour vos besoins d' énergie de la maison (contrôleur, batteries, onduleur, débranchements, etc).
#2 DIY(Do It Yourself) Guide( Guide fait le toi même)
Le guide "panneau solaire a 98$"
Panneaux solaire a 98$, c'est ici ou vous aurez du plaisir. C' est une explication complete étape par étape pour comment construire un panneau solaire a partir de récupération. Tout, de construire le boîtier de panneau solaire à relier les cellules solaires est expliqué ici avec des images de couleur et des plans détaillés.
* Plans solaires détaillés
* Photos étape-par-étape te montrant exactement quoi faire
* Dans notre exemple le coût total étaient $98, vous pourriez le faire pour moins
#3 DIY(Do It Yourself) Guide( Guide fait le toi même)" groupe: énergie solaire"
Cablage électrique et shémas électrique pour panneaux solaire
Apprendre comment brancher plusieurs panneaux solaire et comment stocker votre énergie en utilisant plusieurs batteries en même temps.
Guide pour l' installation et l' assemblage des panneaux solaire.
Apprendre les bases de l' installation de panneau solaire PV(photo voltaïque)avec ce guide utile qui montre le processus pour obtenir les permis municipal pour l' installation des panneaux solaires au brancement au panneau électrique. Installation: panneau solaire PV
Guide de l' utilisateur pour l' énergie solaire
Ce guide pratique discute de la base du solaire and comment calculer comment d' argent, l' énergie solaire peut vous faire économiser a la maison
#4 L' éolienne a 140$
Si vous avez jamais demandé a savoir le processus étape par étape concernant la construction de votre propre éolienne? C' est ici!
-Plans étape par étape montrant comment construire une éolienne
-Lot de plein d' images et de shémas
-Dans notre exemple le coût total était de 140$, vous pouvez le faire pour moins
#5 DIY(Do It Yourself) Guide( Guide fait le toi même)
Construire votre propre éolienne
Comment créer une importante quantité d' énergies pour votre maison. Utiliser l' énergie du vent pour alimenter votre maison! Ce guide pour débutant vous donne une compréhension complète de comment l' énergie est produite and comment la capturer pour votre propre utilisation.
*Explication de comment l' énergie du Vent est produite
*Apprendre les différente composantes pour fabriquer une éolienne
*Comment acheter ou construire votre propre éolienne
Apprendre comment prendre l' énergie que votre éolienne produit et l' amener pour vos besoin en énergie de la maison (contrôleur, batteries, onduleur, etc.
Voila!
#1 DIY Guide
Solar Panel Systems
#2 DIY Guide
#5 DIY Guide
Voila!
Merci Alain
Merci Alain, c'est super gentil de votre part et quelle rapidité !
En fait, je me suis mal exprimé . Je souhaiterai traduire la totalité des manuels contre une rétribution ou un troc. Toute idée est la bienvenue. Merci encore
- Lietseu
- x 4
Bel effort pour traduire un document qui pue l'arnaque !!!
Fabriqué un panneau solaire soi-même ? Hum...
Miaou
sans compter, que vous trouverez bien plus d'informations ici gratuite et venants de gens sérieux qui n'ont pas la fibre "commerçante sans scrupules" si chère a nos amis, les financiers de bas étages, autrement appelé RAT. Société Anonyme (Renouvellement Attendu de Transfert Sans Attentes)
Miaou
- Lietseu
- x 4
Hors de la lumière pas de sens
Comme tout ce qui vis... en viens...
Et y retourne, pourquoi s'en soucier ?
- 6388 Vues
26/06/11, 18:04Un sujet posté dans le forum : Vos montages techniques, bricolages, innovations et auto-construction: fabriquer un objet ou une installation
- 5 Réponses
- 13707 Vues
Dernier message par denis
22/06/11, 20:00Un sujet posté dans le forum : Vos montages techniques, bricolages, innovations et auto-construction: fabriquer un objet ou une installation
- 5 Réponses
- 8672 Vues
Dernier message par dedeleco
31/05/11, 13:50Un sujet posté dans le forum : Vos montages techniques, bricolages, innovations et auto-construction: fabriquer un objet ou une installation
- 8729 Vues
Dernier message par r2d2
01/08/10, 01:24Un sujet posté dans le forum : Vos montages techniques, bricolages, innovations et auto-construction: fabriquer un objet ou une installation
- 3852 Vues
Dernier message par elephant
11/07/09, 17:52Un sujet posté dans le forum : Vos montages techniques, bricolages, innovations et auto-construction: fabriquer un objet ou une installation
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 147 invités
