New 4 stroke engine (en anglais)
Topics about this forum and the econology in english speaking language for people who are not not understanding french language.
inventor
x 82
par inventor » 10/07/10, 11:11
dedeleco a écrit :the sea is difficult with too strong killing waves :
http://pierre.hautefeuille.free.fr/TPE/limpet.htm
Zone de fortes vagues....
Why not use the energy of tree in forest with top oscillating under the wind with your dynamo or pump, using simple ropes ?
This system can be very simple.
I do not undestand why the wave energy is never used on sail boats? Only sun or wind?? With a moving mass on a sail boat, your dynamo could used?
Since when the keg came into existence, for it is her shipping by ships constituted a spot of bother. That is how, they forgot to attach, while swinging the ship rolled from one side to other side, hitting in not around with great energy. There was this great danger for the crew. That is how, they forgot to attach, while swinging the ship rolled from one side to other side, hitting in not around with great energy. I decided to use this energy for the production of the electric current with the help of the oscillatory dynamo. It is a pendulum driving the oscillatory dynamo around so with keg. It will be sufficient to install shipboard or for other swimming raft, and during waving we have the electricity, rather than danger
The sailboat had put a such oscillatory dynamo at the end of the mast, the current will be produced even when parked in port.I can be used to recharge
block of osillating dynamo (or motor):
The principle of oscillatory dynamo above in this forum
Regards Andrew Feliks
:cheesy:
Andrew Feliks
inventor
x 82
par inventor » 15/07/10, 12:27
Drive for pump or oscillating dynamo:
Will it be possible the new World Energy Policy in line
with this map ??
[url="http://www.new4stroke.com/Heightwave.PDF"]http://www.new4stroke.com/Heightwave.PDF[/url]
Regards Andrew :cheesy:
Andrew Feliks
inventor
x 82
par inventor » 04/08/10, 00:32
Well, who would have thought that Newcomen was so close to an adequate solution :blink:
Regards Andrew :D
Andrew Feliks
inventor
x 82
par inventor » 05/08/10, 18:55
Beautiful simple new 4 stroke kinematics animation made at the
King Soud University.
And a little faster
Regards Andrew :D
Andrew Feliks
inventor
x 82
par inventor » 12/08/10, 00:41
inventor a écrit :Well, who would have thought that Newcomen was so close to an adequate solution :blink:
I also very close to the Technology
Andrew Feliks
inventor
x 82
par inventor » 13/08/10, 00:51
I think that this technology is very effective. Can you imagine that by doing the same movement up and down through the traditional piston-connecting rod-crankshaft to get the same ease the movement of this vehicle?
I think that it would then be much harder work. And these four , the looks on it, they not liked to work more than need....
Can you feel it ??
http://www.youtube.com/watch?v=DiUdtxe2YnU
Andrew Feliks
inventor
x 82
par inventor » 15/08/10, 19:35
However and that will had such a good humor, just take a timber and a little grease lubricated.
Do not need any oil !! :D :D
Seal or Teflon or lubricated with diesel fuel.
OIl = diesel fuel in this picture
Andrew Feliks
inventor
x 82
par inventor » 19/08/10, 13:19
Some new4stroke history:
Print table of Fortran 1982 program.
I could choose from 100 of these tables, each for different angular positions of crakshafts.
Here is one of them:
Working drawing of the head:
Regards Andrew :D
Andrew Feliks
inventor
x 82
par inventor » 08/09/10, 03:22
The first windmills pumped water in America. To sustain this good tradition, I developed a little more modern sytem for the production of electric current in a similar way of pumping water.Whether American landscape views, are water sphere.I decided to add this view to the next shot
where the water will be collected water so that it could give electrical energy when draining it back into the lower reservoir.
This water will be pumped sphery as in the first versions of windmills, wind.
The wind turbine will move a small diameter, but it is a multi-blade, placed together with the hydraulic pump in the middle of a specially constructed balloon. Balloon will be tethered, as previously barrage balloons.
Only that will go along the line, hydraulic pipes, the hydraulic motor, which will be driven water pump located in the lower reservoir.The water pump will continuously pump water to sphery. Now the water falling from the lower reservoir back to the shery, will do an electric current through hydrogenerator.
Every so water sphere about the capacity of 2000 m 3, and the height 100 m can give power 10 MW for 3 minutes. If filling pumps water with the one I believe loss is managing to fill waters up, we will have it 10 MW driven with wind turbine in balloons.
Of course, the balloons could be filled up by hydrogen, because today we have very good material on the shell.
This system could be installed in any place where electricity is needed, and thus would have limited losses on the transfer.
Also low noise, and the invisibility of the rotating blades, not to interfere in coexistence with the environment.Balloons can be affixed to a height of 150 to 200 meters, where the wind is always blowing on the ground even when there is absolute silence.
some links:
http://media.primezone.com/cache/189/int/8385.jpg
http://www.youtube.com/watch?v=mu2glpmRXIs&feature=player_embedded#!
http://www.engadget.com/2010/06/21/northrop-grumman-wins-contract-to-build-us-armys-long-endurance/
http://www.youtube.com/watch?v=W3n5cUaG5fg&feature=player_embedded
Regards Andrew
On Saturday is the anniversary of 9 / 11, and make this possible, I decided to share with my good deed ,publication of this study.
http://www.911dayofservice.org/
Andrew Feliks
inventor
x 82
par inventor » 12/09/10, 11:38
Of course, two rotate in one direction and two in the opposite direction.
You must use a very light hydraulic oil. If it were not frozen in winter.
Hydraulic pump in the balloon has the best power to weight ratio. All the airlines are working on the hydraulic actuators.
Of course, all of the balloon must be tested in the wind tunnel aerodynamic, in order to fully match the efficiency of the 21st century.
Some pictures of how to create a balloon from the inside :D
and NASCAR wind tunnel
Regards Andrew :D
Andrew Feliks
Revenir vers « Econology forum in english »
